[Mapbender-commits] r9319 - in trunk/mapbender/resources/db: . pgsql/UTF-8/update
svn_mapbender at osgeo.org
Wed Nov 25 07:50:55 PST 2015
Author: armin11
Date: 2015-11-25 07:50:55 -0800 (Wed, 25 Nov 2015)
New Revision: 9319
trunk/mapbender/resources/db/install.sh
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
New possibility to allow printing of digitized objects in pdf
Modified: trunk/mapbender/resources/db/install.sh
--- trunk/mapbender/resources/db/install.sh 2015-11-25 15:49:57 UTC (rev 9318)
+++ trunk/mapbender/resources/db/install.sh 2015-11-25 15:50:55 UTC (rev 9319)
@@ -141,6 +141,8 @@
pgsql/$DBENCODING/update/update_2.7rc1_to_2.7rc2_pgsql_$DBENCODING.sql \
pgsql/$DBENCODING/update/update_2.7.1_to_2.7.2_pgsql_$DBENCODING.sql \
pgsql/$DBENCODING/update/update_2.7.2_to_2.7.3_pgsql_$DBENCODING.sql \
+ pgsql/$DBENCODING/update/update_2.7.3_to_2.7.4_pgsql_$DBENCODING.sql \
+ pgsql/$DBENCODING/update/update_2.7.4_to_2.8_pgsql_$DBENCODING.sql \
pgsql/pgsql_serial_set_sequences_2.7.sql \
> _install.sql
echo "inserting data (this might take a while longer)"
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql 2015-11-25 15:49:57 UTC (rev 9318)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql 2015-11-25 15:50:55 UTC (rev 9319)
@@ -694,3 +694,5 @@
-- ALTER TABLE mb_metadata DROP COLUMN md_license_source_note;
ALTER TABLE mb_metadata ADD COLUMN md_license_source_note text DEFAULT null;
+UPDATE gui_element SET e_content='<div id="printPDF_working_bg"></div><div id="printPDF_working"><img src="../img/indicator_wheel.gif" style="padding:10px 0 0 10px">Generating PDF</div><div id="printPDF_input"><form id="printPDF_form" action="../print/printFactory.php"><div id="printPDF_selector"></div><div class="print_option"><input type="hidden" id="map_url" name="map_url" value=""/><input type="hidden" id="legend_url" name="legend_url" value=""/><input type="hidden" id="opacity" name="opacity" value=""/> <input type="hidden" id="overview_url" name="overview_url" value=""/><input type="hidden" id="map_scale" name="map_scale" value=""/><input type="hidden" name="measured_x_values" /><input type="hidden" name="measured_y_values" /><input type="hidden" name="map_svg_kml" /><input type="hidden" name="svg_extent" /><input type="hidden" name="map_svg_measures" /><br /></div><div class="print_option" id="printPDF_formsubmit"><input id="submit" type="submit" value="Print"><br /></div></f
orm><div id="printPDF_result"></div></div>' WHERE e_id='printPDF';
More information about the Mapbender_commits
