[Mapbender-commits] r9296 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Oct 20 23:20:24 PDT 2015
Author: armin11
Date: 2015-10-20 23:20:24 -0700 (Tue, 20 Oct 2015)
New Revision: 9296
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
Add possibility to prohibit export of layer metadata to external catalogues
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql	2015-10-09 11:54:55 UTC (rev 9295)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql	2015-10-21 06:20:24 UTC (rev 9296)
@@ -612,6 +612,6 @@
 UPDATE mb_user SET mb_user_newsletter = false WHERE mb_user_newsletter IS NULL;
 UPDATE mb_user SET mb_user_allow_survey = true WHERE mb_user_allow_survey IS NULL;
+--Add possibility to prohibit export of layer metadata to external catalogues
+ALTER TABLE layer ADD COLUMN export2csw boolean DEFAULT true;
More information about the Mapbender_commits mailing list
