[Mapbender-commits] r9282 - trunk/mapbender/http/geoportal
svn_mapbender at osgeo.org
Wed Sep 9 04:02:16 PDT 2015
Author: armin11
Date: 2015-09-09 04:02:16 -0700 (Wed, 09 Sep 2015)
New Revision: 9282
trunk/mapbender/http/geoportal/deleteUserProfile.php
trunk/mapbender/http/geoportal/insertUserDataIntoDb.php
Username should be unambigious
Modified: trunk/mapbender/http/geoportal/deleteUserProfile.php
--- trunk/mapbender/http/geoportal/deleteUserProfile.php 2015-09-08 13:21:30 UTC (rev 9281)
+++ trunk/mapbender/http/geoportal/deleteUserProfile.php 2015-09-09 11:02:16 UTC (rev 9282)
@@ -95,7 +95,7 @@
if ($message !=="") {
- $message = "The current profile cannot be deleted for the following reasons: ".$message;
+ $message = _mb("The current profile cannot be deleted for the following reasons: ").$message;
abort($message);
Modified: trunk/mapbender/http/geoportal/insertUserDataIntoDb.php
--- trunk/mapbender/http/geoportal/insertUserDataIntoDb.php 2015-09-08 13:21:30 UTC (rev 9281)
+++ trunk/mapbender/http/geoportal/insertUserDataIntoDb.php 2015-09-09 11:02:16 UTC (rev 9282)
@@ -39,8 +39,12 @@
if ($mb_user_name == 'guest') {
$registerAsGuest = true;
+ //Trimmen des Nutzernamens um Leerstellen - gibt sonst Probleme
+ $mb_user_name = trim($mb_user_name);
//überprüfen ob User und oder Mail bereits existieren
- $sql = "SELECT * FROM mb_user WHERE mb_user_name = $1 AND mb_user_email = $2";
+ //$sql = "SELECT * FROM mb_user WHERE mb_user_name = $1 AND mb_user_email = $2";
+ //Neu seit 2015-09-10 - Nutzernamen jetzt nur noch eindeutig möglich!
+ $sql = "SELECT * FROM mb_user WHERE mb_user_name = $1";
$v = array($mb_user_name,$mb_user_email); // wird in unserer Lösung immer md5 genutzt?
$t = array('s','s');
$res = db_prep_query($sql,$v,$t);
More information about the Mapbender_commits
