[Mapbender-commits] r9287 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Thu Sep 10 07:39:33 PDT 2015
Author: armin11
Date: 2015-09-10 07:39:33 -0700 (Thu, 10 Sep 2015)
New Revision: 9287
trunk/mapbender/http/classes/class_wfs_1_0_factory.php
trunk/mapbender/http/classes/class_wfs_2_0_factory.php
Enhancement as done for wfs 1.1.0 - should be extracted to special class later!
Modified: trunk/mapbender/http/classes/class_wfs_1_0_factory.php
--- trunk/mapbender/http/classes/class_wfs_1_0_factory.php 2015-09-10 14:31:16 UTC (rev 9286)
+++ trunk/mapbender/http/classes/class_wfs_1_0_factory.php 2015-09-10 14:39:33 UTC (rev 9287)
@@ -76,43 +76,59 @@
foreach ($elementList as $elementNode){
$elementName = $elementNode->getAttribute("name");
$elementType = $elementNode->getAttribute("type");
+ //if Type is empty, we assume an anonymousType, else we go looking for the anmed Type
+ if($elementType == ""){
+ //Just querying for complexTypes containing a Sequence - good enough for Simple Features
+ $query = "xs:complexType//xs:element";
+ $subElementList = $xpath->query($query,$elementNode);
+ } else {
+ // The elementType is now bound to a prefix e.g. topp:housType
+ // if the prefix is in the targetNamespace, changces are good it's defined in this very document
+ // if the prefix is not in the targetNamespace, it's likely not defined here, and we bail
- // if Type is empty, we assume an anonymousType, else we go looking for the anmed Type
- if($elementType == ""){
- // Just querying for complexTypes containing a Sequence - good enough for Simple Features
- $query = "xs:complexType//xs:element";
- $subElementList = $xpath->query($query,$elementNode);
+ list($elementTypeLocalname,$elementTypePrefix) = array_reverse(explode(":",$elementType));
+ $elementTypeNamespace = $doc->lookupNamespaceURI($elementTypePrefix);
+ if($elementTypeNamespace !== $targetNamespaceNode->nodeValue){
+ $e = new mb_warning("Tried to parse FeatureTypeName $featureTypeName : $elementType is not in the targetNamespace");
+ break;
- }else{
- // The elementType is now bound to a prefix e.g. topp:housType
- // if the prefix is in the targetNamespace, changces are good it's defined in this very document
- // if the prefiox is not in the targetNamespace, it's likely not defined here, and we bail
- list($elementTypeLocalname,$elementTypePrefix) = array_reverse(explode(":",$elementType));
- $elementTypeNamespace = $doc->lookupNamespaceURI($elementTypePrefix);
- if($elementTypeNamespace !== $targetNamespaceNode->nodeValue){
- $e = new mb_warning("Tried to parse FeatureTypeName $featureTypeName : $elementType is not in the targetNamespace");
- break;
- $query = sprintf("//xs:complexType[@name='%s']//xs:element",$elementTypeLocalname);
- $subElementList = $xpath->query($query);
- foreach($subElementList as $subElement){
- // Since this is a rewrite of the old way, it reproduces it quirks
- // in this case the namespace of the type was cut off for some reason
+ // Just querying for complexTypes containing a Sequence - good enough for Simple Features
+ $query = sprintf("//xs:complexType[@name='%s']//xs:element",$elementTypeLocalname);
+ $subElementList = $xpath->query($query);
+ foreach ($subElementList as $subElement) {
+ // Since this is a rewrite of the old way, it reproduces it quirks
+ // in this case the namespace of the type was cut off for some reason
$name = $subElement->getAttribute('name');
- $typeParts = explode(":",$subElement->getAttribute('type'));
- if(count($typeParts) == 1){
- $type = $typeParts[0];
- }else{
- $type = $typeParts[1];
- $newFeatureType->addElement($name,$type);
+ $typeParts = explode(":",$subElement->getAttribute('type'));
+ //$e = new mb_exception("element: ".$name." - type: ".$typeParts[0]);
+ if (empty($typeParts[0])) {
+ $e = new mb_warning("No type attribute found in xs:element - test for integrated simpleType!");
+ //it maybe a simple type
+ /*<xs:element name="kennung" nillable="true" minOccurs="0" maxOccurs="1">
+ <xs:simpleType>
+ <xs:restriction base="string">
+ <xs:maxLength value="40"/>
+ </xs:restriction>
+ </xs:simpleType>
+ </xs:element>*/
+ $query = "xs:simpleType/xs:restriction";
+ $restriction = $xpath->query($query,$subElement);
+ $type = $restriction->item(0)->getAttribute('base');
+ //TODO parse further information from xsd like maxLength: <xs:maxLength value="40"/> - add further column in wfs_element!
+ } else {
+ switch (count($typeParts)) {
+ case 1 :
+ $type = $typeParts[0];
+ break;
+ case 2 :
+ $type = $typeParts[1];
+ break;
+ $newFeatureType->addElement($name,$type);
return $newFeatureType;
Modified: trunk/mapbender/http/classes/class_wfs_2_0_factory.php
--- trunk/mapbender/http/classes/class_wfs_2_0_factory.php 2015-09-10 14:31:16 UTC (rev 9286)
+++ trunk/mapbender/http/classes/class_wfs_2_0_factory.php 2015-09-10 14:39:33 UTC (rev 9287)
@@ -172,43 +172,59 @@
+ } else {
+ break;
- }else{
- break;
- }else{
+ <xs:simpleType>
+ </xs:restriction>
+ </xs:simpleType>
+ </xs:element>*/
+ } else {
+ case 1 :
+ break;
+ case 2 :
+ break;
More information about the Mapbender_commits
