[Mapbender-commits] r9430 - trunk/mapbender/http/classes
    svn_mapbender at osgeo.org
    Wed Apr  6 07:21:56 PDT 2016
Author: armin11
Date: 2016-04-06 07:21:56 -0700 (Wed, 06 Apr 2016)
New Revision: 9430
Added:
   trunk/mapbender/http/classes/class_owsContext.php
First draft of a class to generate OWS Context documents from mapbenders extented  wmc documents ;-) - the OWS Context spec 1.0  seems to be not really ready to be used  :-(
Added: trunk/mapbender/http/classes/class_owsContext.php
--- trunk/mapbender/http/classes/class_owsContext.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_owsContext.php	2016-04-06 14:21:56 UTC (rev 9430)
@@ -0,0 +1,479 @@
+<?php
+# $Id: class_owsContext.php armin11 $
+# http://www.mapbender2.org/index.php/class_owsContext.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/class_Uuid.php");
+require_once(dirname(__FILE__)."/class_wmc.php");
+ * An OWS Context (OWS Context) class, based on the OGC OWS Context Conceptual Model
+ * Version 1.0 - https://portal.opengeospatial.org/files/?artifact_id=55182
+class OwsContext {
+	var $specReference; //mandatory
+	var $language; //mandatory
+	var $id; //mandatory
+	var $title; //mandatory
+	var $abstract; //[0..1]
+	var $updateDate; //[0..1]
+	var $author; //[0..*]
+	var $publisher; //[0..1]
+	var $creator; //[0..1] OwsContextResourceCreator
+	var $rights; //[0..1]
+	var $areaOfInterest; //[0..1]
+	var $timeIntervalOfInterest; //[0..1]
+	var $keyword; //[0..*]
+	var $extension; //[0..*]
+	//relations
+	var $resource; //[0..*] OwsContextResource (ordered)
+	var $resourceMetadata; //[0..*] MD_Metadata
+	//internal
+	var $version; //1.0
+	public function __construct() {
+		//mandatory
+		$this->specReference = "";
+		$this->language = "de";
+		$this->id = new uuid();
+		$this->title = "dummy title";
+		//arrays
+		$this->author = array();
+		$this->keyword = array();
+		$this->extensions = array();
+		//relations
+		$this->resource = array();
+		$this->resourceMetadata = array();
+		//internal
+		$this->version = "1.0";
+	public function setCreator($aCreator) {
+		$this->creator = $aCreator;
+	public function delCreator() {
+		unset($this->creator);
+	public function addResource($aResource) {
+		array_push($this->resource, $aResource);
+	public function updateResource($aResource, $resourceId) {
+		$resourcePos = $this->getResourcePosById($resourceId);
+		if ($resourcePos !== false) {
+			$this->resource[$resourcePos] = $aResource;
+			return true;
+		} else {
+			return false;
+	public function getResourceById($resourceId) {
+		foreach ($this->resource as $resource) {
+			if ($resource->id == $resourceId) {
+				return $resource;
+		return false;
+	public function getResourcePosById($resourceId) {
+		$resourceIndex = 0;
+				return $resourceIndex;
+			$resourceIndex++;
+		return false;
+	public function export($outputFormat) {
+		switch ($outputFormat) {
+			case "atom":
+				return $this->export2Atom(1);
+			break;
+			case "json":
+			break;
+	public function export2Atom($resourceId) {
+		//Initialize XML document
+		$owsContextDoc = new DOMDocument('1.0');
+		$owsContextDoc->encoding = 'UTF-8';
+		$owsContextDoc->preserveWhiteSpace = false;
+		$owsContextDoc->formatOutput = true;
+		$atomFeed = $owsContextDoc->createElementNS('http://www.w3.org/2005/Atom', 'feed');
+		$atomFeed = $owsContextDoc->appendChild($atomFeed);
+		$atomFeed->setAttribute("xmlns:owc", "http://www.opengis.net/owc/1.0");
+		$atomFeed->setAttribute("xmlns:dc", "http://purl.org/dc/elements/1.1/");
+		$atomFeed->setAttribute("xmlns:georss", "http://www.georss.org/georss");
+		$atomFeed->setAttribute("xmlns:gml", "http://www.opengis.net/gml");
+		//$atomFeed->setAttribute("xmlns:gco", "http://www.isotc211.org/2005/gco");
+		//$atomFeed->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+		$atomFeed->setAttribute("xml:lang", $this->language);
+		//part for feed
+		$feedTitle = $owsContextDoc->createElement("title");
+		$feedTitleText = $owsContextDoc->createTextNode($this->title);
+		$feedTitle->appendChild($feedTitleText);
+		$atomFeed->appendChild($feedTitle);
+		//mandatory link with reference to profile
+		$profileLink = $owsContextDoc->createElement("link");
+		$profileLink->setAttribute("rel", "profile");
+		$profileLink->setAttribute("href", "http://www.opengis.net/spec/owc-atom/1.0/req/core");
+		$profileLink->setAttribute("title", _mb("This file is compliant with version 1.0 of OGC Context"));
+		$atomFeed->appendChild($profileLink);
+		//mandatory id
+		$feedId = $owsContextDoc->createElement("id");
+		$feedIdText = $owsContextDoc->createTextNode($this->id);
+		$feedId->appendChild($feedIdText);
+		$atomFeed->appendChild($feedId);
+		//mandatory updateDate
+		$feedUpdated = $owsContextDoc->createElement("updated");
+		$feedUpdatedText = $owsContextDoc->createTextNode($this->updateDate);
+		$feedUpdated->appendChild($feedUpdatedText);
+		$atomFeed->appendChild($feedUpdated);
+		//mandatory author fields - if not given in each entry
+		$feedAuthor = $owsContextDoc->createElement("author");
+		$feedAuthorName = $owsContextDoc->createElement("name");
+		$feedAuthorNameText = $owsContextDoc->createTextNode($this->author[0]['name']);
+		$feedAuthorEmail = $owsContextDoc->createElement("email");
+		$feedAuthorEmailText = $owsContextDoc->createTextNode($this->author[0]['email']);
+		$feedAuthorName->appendChild($feedAuthorNameText);
+		$feedAuthorEmail->appendChild($feedAuthorEmailText);
+		$feedAuthor->appendChild($feedAuthorName);
+		$feedAuthor->appendChild($feedAuthorEmail);
+		$atomFeed->appendChild($feedAuthor);
+		//optional areaOfInterest
+		if (isset($this->areaOfInterest) && $this->areaOfInterest !== "") {
+			$feedAreaOfInterest = $owsContextDoc->createElement("georss:where");
+			//parse xml as simple xml object and add it to dom
+			$fragment = $owsContextDoc->createDocumentFragment();
+			$fragment->appendXml($this->areaOfInterest);
+			$feedAreaOfInterest->appendChild($fragment);
+			//$feedAreaOfInterestText = $owsContextDoc->createTextNode($this->areaOfInterest);
+			//$feedAreaOfInterest->appendChild($feedAreaOfInterestText);
+			$atomFeed->appendChild($feedAreaOfInterest);
+			$feedEntry = $owsContextDoc->createElement("entry");
+			//title
+			$feedEntryTitle = $owsContextDoc->createElement("title");
+			$feedEntryTitleText = $owsContextDoc->createTextNode($resource->title);
+			$feedEntryTitle->appendChild($feedEntryTitleText);
+			$feedEntry->appendChild($feedEntryTitle);
+			//abstract
+			$feedEntryAbstract = $owsContextDoc->createElement("abstract");
+			$feedEntryAbstractText = $owsContextDoc->createTextNode($resource->abstract);
+			$feedEntryAbstract->appendChild($feedEntryAbstractText);
+			$feedEntry->appendChild($feedEntryAbstract);
+			if (count($resource->preview) >= 1) {
+				$feedPreview = $owsContextDoc->createElement("link");
+				$feedPreview->setAttribute("rel", "icon");
+				$feedPreview->setAttribute("type", "image/png");
+				$feedPreview->setAttribute("length", "12345");
+				$feedPreview->setAttribute("title", "Preview for layer X");
+				$feedPreview->setAttribute("href", $resource->preview[0]);
+				$feedEntry->appendChild($feedPreview);
+			foreach ($resource->offering as $offering) {
+					$resourceOffering = $owsContextDoc->createElement("offering");
+					$resourceOffering->setAttribute("code", $offering->code);
+					foreach ($offering->operation as $operation) {
+						$offeringOperation = $owsContextDoc->createElement("operation");
+						$offeringOperation->setAttribute("method", $operation->method);
+						$offeringOperation->setAttribute("code", $operation->code);
+						$offeringOperation->setAttribute("href", $operation->href);
+						$resourceOffering->appendChild($offeringOperation);
+					$feedEntry->appendChild($resourceOffering);
+			if ($resource->active == true) {
+				$activeCategory = $owsContextDoc->createElement("category");
+				$activeCategory->setAttribute("scheme", "http://www.opengis.net/spec/owc/active");
+				$activeCategory->setAttribute("term", "true");
+				$feedEntry->appendChild($activeCategory);
+			if (isset($resource->minScaleDenominator)) {
+				$owcMinScaleDenominator = $owsContextDoc->createElement("owc:minScaleDenominator");
+				$owcMinScaleDenominatorText = $owsContextDoc->createTextNode($resource->minScaleDenominator);
+				$owcMinScaleDenominator->appendChild($owcMinScaleDenominatorText);
+				$feedEntry->appendChild($owcMinScaleDenominator);
+			if (isset($resource->maxScaleDenominator)) {
+				$owcMaxScaleDenominator = $owsContextDoc->createElement("owc:maxScaleDenominator");
+				$owcMaxScaleDenominatorText = $owsContextDoc->createTextNode($resource->maxScaleDenominator);
+				$owcMaxScaleDenominator->appendChild($owcMaxScaleDenominatorText);
+				$feedEntry->appendChild($owcMaxScaleDenominator);
+			$atomFeed->appendChild($feedEntry);
+		return $owsContextDoc->saveXML();
+	public function export2Json($resourceId) {
+	public function readFromWmc($wmcXml) {
+	public function readFromInternalWmc($wmcId) {
+  		$myWmc = new wmc();
+  		$myWmc->createFromDb($wmcId);
+		//read title
+		$this->title = $myWmc->wmc_title;
+		$this->id = $myWmc->uuid;
+		$this->updateDate = date(DATE_ATOM,$myWmc->timestamp);
+		$this->author[0]['name'] = $myWmc->wmc_contactperson;
+		$this->author[0]['email'] = $myWmc->wmc_contactemail;
+		//build georss:where from extent given in special srs
+		//minx miny, maxx miny, maxx maxy, minx maxy, minx miny
+		$minx = $myWmc->wmc_extent->minx;
+		$miny = $myWmc->wmc_extent->miny;
+		$maxx = $myWmc->wmc_extent->maxx;
+		$maxy = $myWmc->wmc_extent->maxy;
+		$sql = "SELECT ST_ASGML(3, ST_TRANSFORM(ST_GeomFromText('POLYGON(( $minx $miny , $maxx $miny , $maxx $maxy , $minx $maxy , $minx $miny ))',".str_replace('EPSG:','',$myWmc->wmc_srs)."),4326),15,16);";
+		$res = db_query($sql);
+		$georssGmlPolygon = db_fetch_row($res);
+		$this->areaOfInterest = $georssGmlPolygon[0];
+		//get the layers as single resources
+		libxml_use_internal_errors(true);
+		try {
+			$WMCDoc = simplexml_load_string($myWmc->toXml());
+			//$WMCDoc = simplexml_load_string(str_replace("xlink:href","xlinkhref",$myWmc->toXml()));
+			if ($WMCDoc === false) {
+				foreach(libxml_get_errors() as $error) {
+        				$err = new mb_exception("class_owsContext.php:".$error->message);
+				throw new Exception("class_owsContext.php:".'Cannot parse WMC XML!');
+				return false;
+		catch (Exception $e) {
+    			$err = new mb_exception("class_owsContext.php:".$e->getMessage());
+			return false;
+		//register relevant namespaces
+		$WMCDoc->registerXPathNamespace("wmc","http://www.opengis.net/context");
+		$WMCDoc->registerXPathNamespace("mapbender","http://www.mapbender.org/context");
+		$WMCDoc->registerXPathNamespace("xlink","http://www.w3.org/1999/xlink");
+		//pull out List of layer objects
+		$layerList = $WMCDoc->xpath("/wmc:ViewContext/wmc:LayerList/wmc:Layer");
+		//pull all available server ids from mapbenders extension
+		//get relevant urls from database
+		foreach ($layerList as $layer) {
+			//pull relevant information out of xml snippet
+                	$version = $layer->Server->attributes()->version;
+			$getmap = $layer->Server->OnlineResource->attributes("xlink", true)->href;
+			//check if featureInfo active
+			$owsContextResource = new OwsContextResource();
+			$owsContextResource->title = $layer->Title;
+			$owsContextResource->abstract = $layer->Abstract;
+			//add offering
+			$owsContextResourceOffering = new OwsContextResourceOffering();
+			$owsContextResourceOffering->code = "http://www.opengis.net/spec/owc-atom/1.0/req/wms";
+			//add operation for getcapabilities
+			$owsContextResourceOfferingOperation = new OwsContextResourceOfferingOperation();
+			$owsContextResourceOfferingOperation->code = "GetCapabilities";
+			$owsContextResourceOfferingOperation->method = "GET";
+			//TODO: use operations from database if wms id is given in wmc
+			$owsContextResourceOfferingOperation->href = $getmap;
+			$owsContextResourceOffering->addOperation($owsContextResourceOfferingOperation);
+			$owsContextResource->addOffering($owsContextResourceOffering);
+			//active
+			if ($layer->attributes()->hidden == "0") {
+				$owsContextResource->active = true;
+			//scale
+			if (isset($layer->Extension->children('http://www.mapbender.org/context')->gui_minscale)) {
+				$owsContextResource->minScaleDenominator = $layer->Extension->children('http://www.mapbender.org/context')->gui_minscale;
+			if (isset($layer->Extension->children('http://www.mapbender.org/context')->gui_maxscale)) {
+				$owsContextResource->maxScaleDenominator = $layer->Extension->children('http://www.mapbender.org/context')->gui_maxscale;
+			if (isset($layer->Extension->children('http://www.mapbender.org/context')->layer_id)) {
+				$owsContextResource->addPreview(MAPBENDER_PATH."/geoportal/mod_showPreview.php?resource=layer&id=".$layer->Extension->children('http://www.mapbender.org/context')->layer_id);
+			$this->addResource($owsContextResource);
+			unset($owsContextResource);
+class OwsContextResource {
+	var $updateDate; //[0..1] - TM_Date
+	var $author; //[0..*] ? - really *
+	var $geospatialExtent; //[0..1] GM_Envelope
+	var $temporalExtent; //[0..1] TM_GeometricPrimitive
+	var $contentDescription; //[0..1] Any
+	var $preview; //[0..*] URI
+	var $contentByRef; //[0..*] URI
+	var $offering; //[0..*] OwsContextResourceOffering
+	var $active; //[0..1] Boolean
+	var $maxScaleDenominator; //[0..1] Double
+	var $minScaleDenominator; //[0..1] Double
+	var $folder; //[0..1]
+	var $extension; //[0..*] Any
+	//relations
+		//mandatory
+		$this->id = "dummy title";
+		//arrays
+		$this->preview = array();
+		$this->contentByRef = array();
+		$this->offering = array();
+		$this->extension = array();
+	public function addOffering($aOffering) {
+		array_push($this->offering, $aOffering);
+	public function addPreview($aPreview) {
+		array_push($this->preview, $aPreview);
+class OwsContextResourceCreator {
+	var $creatorApplication; //[0..1] OwsContextResourceCreatorApplication
+	var $creatorDisplay; //[0..1] OwsContextResourceCreatorDisplay
+class OwsContextResourceCreatorApplication {
+	var $title; //[0..1]
+	var $uri; //[0..1] URI
+	var $version; //[0..1]
+class OwsContextResourceCreatorDisplay {
+	var $pixelWidth; //[0..1] integer
+	var $pixelHeight; //[0..1] integer
+	var $mmPerPixel; //[0..1] double
+		//arrays
+class OwsContextResourceOffering {
+	var $code; //mandatory URI
+	var $operation; //[0..*] OwsContextResourceOfferingOperation
+	var $content; //[0..*] OwsContextResourceOfferingContent
+	var $styleSet; //[0..*] OwsContextResourceOfferingStyleSet
+		//mandatory
+		$this->code = "dummy code";
+		//arrays
+		$this->operation = array();
+		$this->content = array();
+		$this->styleSet = array();
+	public function addOperation($aOperation) {
+		array_push($this->operation, $aOperation);
+class OwsContextResourceOfferingOperation {
+	var $method; //mandatory
+	var $type; //mandatory
+	var $requestURL; //mandatory URI
+	var $request; //[0..1] OwsContextResourceOfferingContent
+	var $result; //[0..1] Any
+		//mandatory
+		$this->method = "dummy method";
+		$this->type = "dummy type";
+		$this->requestURL = "dummy requestURL";
+		//arrays
+class OwsContextResourceOfferingContent {
+	var $URL; //[0..1] URI
+	var $content; //[0..1] Any
+		//mandatory
+		//arrays
+class OwsContextResourceOfferingStyleSet {
+	var $name; //mandatory
+	var $default; //[0..1]
+	var $legendURL; //[0..*] URI
+	var $content; //[0..1] OwsContextResourceOfferingContent
+		//mandatory
+		$this->name = "dummy name";
+		//arrays
+		$this->legendURL = array();
More information about the Mapbender_commits
