[Mapbender-commits] r9435 - trunk/mapbender/http/geoportal
svn_mapbender at osgeo.org
Thu Apr 7 08:01:15 PDT 2016
Author: armin11
Date: 2016-04-07 08:01:15 -0700 (Thu, 07 Apr 2016)
New Revision: 9435
trunk/mapbender/http/geoportal/mod_showCatalogueStatistics.php
trunk/mapbender/http/geoportal/mod_showCatalogueStatistics_server.php
Some little enhancement - thanx to karl owesny ;-)
Modified: trunk/mapbender/http/geoportal/mod_showCatalogueStatistics.php
--- trunk/mapbender/http/geoportal/mod_showCatalogueStatistics.php 2016-04-07 13:54:00 UTC (rev 9434)
+++ trunk/mapbender/http/geoportal/mod_showCatalogueStatistics.php 2016-04-07 15:01:15 UTC (rev 9435)
@@ -19,6 +19,21 @@
'</head>';
$style = <<< HTML
<style>
+#pie2 svg {
+ display:block;
+ margin: 0 auto;
+#buttons {
+ text-align: center;
+#pie svg {
+ display:block;
+ margin: 0 auto;
.outer {
position: relative;
justify-content: center;
@@ -33,11 +48,13 @@
//css
$html .= '<link type="text/css" href="../extensions/jquery-ui-1.8.1.custom/css/custom-theme/jquery-ui-1.8.5.custom.css" rel="Stylesheet" />';
$html .= $metadataStr;
+$html .= '<div id="buttons">';
$html .= '<button class="pulldata" id="NUTS_1" value="NUTS_1">Land</button>';
$html .= '<button class="pulldata" id="NUTS_2" value="NUTS_2">Regierungsbezirk</button>';
$html .= '<button class="pulldata" id="NUTS_3" value="NUTS_3">Kreis</button>';
$html .= '<button class="pulldata" id="LAU_1" value="LAU_1">Kommunalverband</button>';
$html .= '<button class="pulldata" id="LAU_2" value="LAU_2">Kommune</button>';
+$html .= '</div>';
$html .= '<div id="pie" class="inner"></div>';
$html .= '<div id="dialog" class="inner"><div id="pie2" class="inner"></div></div>';
//internal lib javascript part
@@ -113,8 +130,8 @@
var pie2 = new d3pie("pie2", {
pieOuterRadius: "50%",
- canvasHeight: 300,
- canvasWidth: 300
+ canvasHeight: 380,
+ canvasWidth: 380
data: {
sortOrder: "value-asc",
@@ -135,8 +152,8 @@
} else {
- alert("Keine weitere Kategorisierung vorhanden!");
- $("#dialog").dialog("close");
+ //alert("Keine weitere Kategorisierung vorhanden!");
+ $("#dialog").append( "<p id=\"error\">Keine Kategorisierung von Datensätzen vorhanden!</p>" );
if (pie2 !== undefined) {
pie2.destroy();
@@ -144,6 +161,9 @@
+ $('#dialog').live("dialogclose", function(){
+ $('#error').remove();
</script>
JAVASCRIPT;
$html .= $javascript;
Modified: trunk/mapbender/http/geoportal/mod_showCatalogueStatistics_server.php
--- trunk/mapbender/http/geoportal/mod_showCatalogueStatistics_server.php 2016-04-07 13:54:00 UTC (rev 9434)
+++ trunk/mapbender/http/geoportal/mod_showCatalogueStatistics_server.php 2016-04-07 15:01:15 UTC (rev 9435)
@@ -92,7 +92,7 @@
} else {
//call searchInterface for categories
- $connector = new connector("http://localhost/mb_trunk/php/mod_callMetadata.php?searchText=e&outputFormat=json&resultTarget=categories&searchResources=wms&searchId=test®istratingDepartments=".$registratingDepartments);
+ $connector = new connector("http://localhost/mapbender/php/mod_callMetadata.php?searchText=e&outputFormat=json&resultTarget=categories&searchResources=wms&searchId=test®istratingDepartments=".$registratingDepartments);
$jsonString = $connector->file;
$jsonObject = json_decode($jsonString);
$i = 0;
More information about the Mapbender_commits
