[Mapbender-commits] r9402 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Fri Feb 19 04:07:23 PST 2016
Author: armin11
Date: 2016-02-19 04:07:23 -0800 (Fri, 19 Feb 2016)
New Revision: 9402
trunk/mapbender/http/classes/class_iso19139.php
smal bugfix for metadata management
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php 2016-02-18 13:28:40 UTC (rev 9401)
+++ trunk/mapbender/http/classes/class_iso19139.php 2016-02-19 12:07:23 UTC (rev 9402)
@@ -2032,6 +2032,7 @@
return $result;
+ $this->harvestResult = 1;
} else {
$e = new mb_exception("class_Iso19139:"."MetadataURL format or type of following url is not supported: Format: ".$this->format." | type: ".$this->type);
@@ -2042,17 +2043,18 @@
if ($metadata == false) {
//try to insert only MetadataURL elements
if (!$this->insertMetadataUrlToDB($resourceType, $resourceId)) {
- $e = new mb_exception("class_Iso19139:"."Problem while storing MetadataURL entry from wms capabilities to mb_metadata table!");
+ $e = new mb_exception("class_Iso19139:"."Problem while storing metadata source to mb_metadata table!");
$result['value'] = false;
- $result['message'] = "Problem while storing MetadataURL entry from wms capabilities to mb_metadata table!";
+ $result['message'] = "Problem while storing metadata source to mb_metadata table!";
return $result;
} else {
- $e = new mb_exception("class_Iso19139:"."Storing only MetadataURL ".$metadata->href." from capabilities to mb database cause the target could not be accessed or parsed!");
+ $e = new mb_exception("class_Iso19139:"."Storing only MetadataURL ".$metadata->href." from external source to mb database cause the target could not be accessed or parsed!");
$result['value'] = true;
- $result['message'] = "Storing only MetadataURL ".$metadata->href." from capabilities to mb database cause the target could not be accessed or parsed!";
+ $result['message'] = "Storing only MetadataURL ".$metadata->href." from external source to mb database cause the target could not be accessed or parsed!";
return $result;
break;
case "metador":
//nothing to do at all?
@@ -2070,10 +2072,11 @@
return $result;
//else save it into database
break;
case "internal":
//only set relation to existing record - return true;
- //is actually handled thru plugins/mn_metadata_server*
+ //is actually handled thru plugins/mb_metadata_server*
break;
default:
$e = new mb_exception("class_Iso19139:"."Metadata origin is not known - please set it before storing values to DB!");
@@ -2088,7 +2091,9 @@
if ($metadataId != false) {
//update the metadata - new random id set therefor there is no problem when setting the relation afterwards
$e = new mb_notice("existing metadata fileIdentifier found at metadata with id: ".$metadataId[0]." - update will be performed");
- //check if the timestamp of an existing metadata element is not newer than the timestamp of the current metadata object!!!!
+ //TODO: Check if the timestamp of an existing metadata element is not newer than the timestamp of the current metadata object!!!!
+ //for uploaded metadata the harvesting was ok otherwise the function returned before
$res = $this->updateMetadataById($metadataId[0]);
$this->insertKeywordsAndCategoriesIntoDB($metadataId[0],$resourceType,$resourceId);
} else {
More information about the Mapbender_commits
