[Mapbender-commits] r9410 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Tue Feb 23 07:28:07 PST 2016
Author: armin11
Date: 2016-02-23 07:28:07 -0800 (Tue, 23 Feb 2016)
New Revision: 9410
trunk/mapbender/http/php/mod_inspireDownloadFeed.php
Fix for wfs 1.0 based INSPIRE ATOM Feeds
Modified: trunk/mapbender/http/php/mod_inspireDownloadFeed.php
--- trunk/mapbender/http/php/mod_inspireDownloadFeed.php 2016-02-23 15:27:34 UTC (rev 9409)
+++ trunk/mapbender/http/php/mod_inspireDownloadFeed.php 2016-02-23 15:28:07 UTC (rev 9410)
@@ -1241,44 +1241,44 @@
//calculate further bboxes if the # of hits extents some value
//minimum number of single tiles:
$countTiles = ceil($featureHits[$i]/$maxFeatureCount);
- //calculate number of rows and columns from x / y ratio
- if ($epsgId == '4326' && $alterAxisOrder) {
- //no transformation needed only change order
- $minx = $mapbenderMetadata[$i]->miny;
- $miny = $mapbenderMetadata[$i]->minx;
- $maxx = $mapbenderMetadata[$i]->maxy;
- $maxy = $mapbenderMetadata[$i]->maxx;
+ } else {
+ $countTiles = 1;
+ //calculate number of rows and columns from x / y ratio
+ if ($epsgId == '4326' && $alterAxisOrder) {
+ //no transformation needed only change order
+ $minx = $mapbenderMetadata[$i]->miny;
+ $miny = $mapbenderMetadata[$i]->minx;
+ $maxx = $mapbenderMetadata[$i]->maxy;
+ $maxy = $mapbenderMetadata[$i]->maxx;
+ } else {
+ //no transformation needed normal order
+ if ($epsgId == '4326') {
+ $minx = $mapbenderMetadata[$i]->minx;
+ $miny = $mapbenderMetadata[$i]->miny;
+ $maxx = $mapbenderMetadata[$i]->maxx;
+ $maxy = $mapbenderMetadata[$i]->maxy;
} else {
- //no transformation needed normal order
- if ($epsgId == '4326') {
- $minx = $mapbenderMetadata[$i]->minx;
- $miny = $mapbenderMetadata[$i]->miny;
- $maxx = $mapbenderMetadata[$i]->maxx;
- $maxy = $mapbenderMetadata[$i]->maxy;
- } else {
- //transformation needed and axis order changed
- if ($alterAxisOrder) {
- $e = new mb_exception("axis_order_altered");
- $minxI = $mapbenderMetadata[$i]->miny;
- $minyI = $mapbenderMetadata[$i]->minx;
- $maxxI = $mapbenderMetadata[$i]->maxy;
- $maxyI = $mapbenderMetadata[$i]->maxx;
- $mapbenderMetadata[$i]->miny = $minyI;
- $mapbenderMetadata[$i]->minx = $minxI;
- $mapbenderMetadata[$i]->maxy = $maxyI;
- $mapbenderMetadata[$i]->maxx = $maxxI;
- $sqlExtent = "SELECT X(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->minx." ".$mapbenderMetadata[$i]->miny.")',4326),".$epsgId.")) as minx, Y(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->minx." ".$mapbenderMetadata[$i]->miny.")',4326),".$epsgId.")) as miny, X(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->maxx." ".$mapbenderMetadata[$i]->maxy.")',4326),".$epsgId.")) as maxx, Y(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->maxx." ".$mapbenderMetadata[$i]->maxy.")',4326),".$epsgId.")) as maxy";
- $resExtent = db_query($sqlExtent);
- $minx = floatval(db_result($resExtent,0,"minx"));
- $miny = floatval(db_result($resExtent,0,"miny"));
- $maxx = floatval(db_result($resExtent,0,"maxx"));
- $maxy = floatval(db_result($resExtent,0,"maxy"));
+ //transformation needed and axis order changed
+ if ($alterAxisOrder) {
+ $e = new mb_exception("axis_order_altered");
+ $minxI = $mapbenderMetadata[$i]->miny;
+ $minyI = $mapbenderMetadata[$i]->minx;
+ $maxxI = $mapbenderMetadata[$i]->maxy;
+ $maxyI = $mapbenderMetadata[$i]->maxx;
+ $mapbenderMetadata[$i]->miny = $minyI;
+ $mapbenderMetadata[$i]->minx = $minxI;
+ $mapbenderMetadata[$i]->maxy = $maxyI;
+ $mapbenderMetadata[$i]->maxx = $maxxI;
+ $sqlExtent = "SELECT X(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->minx." ".$mapbenderMetadata[$i]->miny.")',4326),".$epsgId.")) as minx, Y(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->minx." ".$mapbenderMetadata[$i]->miny.")',4326),".$epsgId.")) as miny, X(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->maxx." ".$mapbenderMetadata[$i]->maxy.")',4326),".$epsgId.")) as maxx, Y(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->maxx." ".$mapbenderMetadata[$i]->maxy.")',4326),".$epsgId.")) as maxy";
+ $resExtent = db_query($sqlExtent);
+ $minx = floatval(db_result($resExtent,0,"minx"));
+ $miny = floatval(db_result($resExtent,0,"miny"));
+ $maxx = floatval(db_result($resExtent,0,"maxx"));
+ $maxy = floatval(db_result($resExtent,0,"maxy"));
- } else {
- $countTiles = 1;
//only calculate new boxes if countTiles > 1
if ($countTiles > 1) {
$diffX = $maxx - $minx; //in m - depends on given epsg code
More information about the Mapbender_commits
