[Mapbender-commits] r9348 - in trunk/mapbender/http: javascripts plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jan 12 10:43:19 PST 2016
Author: armin11
Date: 2016-01-12 10:43:19 -0800 (Tue, 12 Jan 2016)
New Revision: 9348
   trunk/mapbender/http/javascripts/mb_downloadFeedClient.php
   trunk/mapbender/http/plugins/mb_downloadFeedClient.php
Bugfixes ATOM Feed Client
Modified: trunk/mapbender/http/javascripts/mb_downloadFeedClient.php
--- trunk/mapbender/http/javascripts/mb_downloadFeedClient.php	2016-01-12 15:50:37 UTC (rev 9347)
+++ trunk/mapbender/http/javascripts/mb_downloadFeedClient.php	2016-01-12 18:43:19 UTC (rev 9348)
@@ -55,15 +55,11 @@
 function init(){
 	//var form = document.getElementById("service_feed_form");
 	//generate 2 Mapframes
 	//add active class to dataset info before showing map, afterwords remove it!
 	$('#dataset_info').toggleClass('active');
 	mapframe_dataset_list = new OpenLayers.Map('mapframe_dataset_list');
 	$('#representations').toggleClass('active');
 	mapframe_file_list = new OpenLayers.Map('mapframe_file_list');
@@ -81,7 +77,6 @@
 	bboxFiles = new OpenLayers.Layer.Vector("File bounding boxes");
 	mapframe_dataset_list.addLayers([<?php echo $addBackgroundLayerUpper; ?>]);
 	mapframe_dataset_list.addLayers([bboxDataset]);
 	mapframe_dataset_list.addControl(new OpenLayers.Control.MousePosition());
 	mapframe_dataset_list.addControl(new OpenLayers.Control.PanPanel());
 	mapframe_file_list.addLayers([<?php echo $addBackgroundLayerLower; ?>]);
@@ -155,7 +150,7 @@
 				//$("#parse_service_feed_modal").toggle();
 				$("#loading_image_dataset").css("display","none");
 				//select tab
-				$('#mytabs a[href="#representations"]').tab('show');
+				//$('#mytabs a[href="#representations"]').tab('show');
 				showDatasetEntryList(result, id);
@@ -172,6 +167,8 @@
 	$("#representation_info").css("display","none");
 	$("#dataset_information").css("display","none");
 	$("#capabilities_hybrid").css("display","none");
+	$("#label_capabilities_hybrid").css("display","none");
+	$("#label_dataset_select").css("display","none");
 	//change size of outer fieldset
 	$("#client").css("height","450px");
 	$("#download_link_list").remove();
@@ -203,8 +200,11 @@
 	for(var i=0; i<featureCollection.features.length; ++i) {
 		//fill in first title, rights and abstract in fields
 		if (i == id) {
+			$('#dataset_title').empty();
 			$('#dataset_title').append(featureCollection.features[i].properties.title);
+			$('#dataset_rights').empty();
 			$('#dataset_rights').append(featureCollection.features[i].properties.rights);
+			$('#dataset_abstract').empty();
 			$('#dataset_abstract').append(featureCollection.features[i].properties.summary);
 			//add capabilities anchor
 			identifierAnchor =  $(document.createElement('a')).appendTo('#capabilities_hybrid');
@@ -214,6 +214,7 @@
 			//show hybrid link only if it is there
 			if (typeof featureCollection.features[i].properties.capabilitiesLink !== 'undefined' && featureCollection.features[i].properties.capabilitiesLink !== '' && featureCollection.features[i].properties.capabilitiesLink !== null) {
 				$("#capabilities_hybrid").css("display","block");
+				$("#label_capabilities_hybrid").css("display","block");
 			//add identifier anchor
 			identifierAnchor =  $(document.createElement('a')).appendTo('#dataset_identifier');
@@ -231,6 +232,7 @@
 	//datasetSelect.attr({'data-width':'auto'});
 	//$('.selectpicker').selectpicker('render');
 	$("#dataset_information").css("display","block");
+	$("#label_dataset_select").css("display","block");
 	//preselect option
 	$("#dataset_select option[optionid='" + id + "']").attr("selected","selected");
 	$('#dataset_select').bind('change', function() {
@@ -240,7 +242,7 @@
 		showDatasetList(featureCollection,optionSelected);
 		method =  "getDatasetFeedObjectFromUrl";
         	data = $this.val();
-		resetForm();
+		//resetForm();
 		callServer(data,method);
Modified: trunk/mapbender/http/plugins/mb_downloadFeedClient.php
--- trunk/mapbender/http/plugins/mb_downloadFeedClient.php	2016-01-12 15:50:37 UTC (rev 9347)
+++ trunk/mapbender/http/plugins/mb_downloadFeedClient.php	2016-01-12 18:43:19 UTC (rev 9348)
@@ -100,7 +100,7 @@
 <script src="../extensions/bootstrap-3.3.6-dist/js/bootstrap.min.js"></script>
 <script src="../extensions/bootstrap-select-1.9.3/dist/js/bootstrap-select.min.js"></script>
 <script src="../extensions/bootstrap-select-1.9.3/dist/js/i18n/defaults-de_DE.js"></script>
-<script src="../javascripts/mb_downloadFeedClient1.php"></script>
+<script src="../javascripts/mb_downloadFeedClient.php"></script>
 </head>
 <body onload="init()">
 <!-- Navbar -->
@@ -143,14 +143,14 @@
     </div>
   </div>
 </div>-->
-<div id="loading_image_service" style="display: none;"><p><img class="inspire_loading" src="../img/inspire_tr_36.png" style="margin-left: auto; margin-right: auto;"/>Loading Service Feed ...</p></div>
+<div id="loading_image_service" style="display: none;"><p><img class="inspire_loading" src="../img/inspire_tr_36.png" style="margin-left: auto; margin-right: auto;"/><?php echo _mb("Loading Service Feed ...");?></p></div>
 <!-- <button class="btn btn-primary" type="button" id="stop_parsing"><?php echo _mb("reset");?></button> -->
-<div id="loading_image_dataset" style="display: none;"><p><img class="inspire_loading" src="../img/inspire_tr_36.png" style="margin-left: auto; margin-right: auto;"/>Loading Dataset Feed ...</p></div>
+<div id="loading_image_dataset" style="display: none;"><p><img class="inspire_loading" src="../img/inspire_tr_36.png" style="margin-left: auto; margin-right: auto;"/><?php echo _mb("Loading Dataset Feed ...");?></p></div>
 <!-- Tabs-Navs -->
 <ul class="nav nav-tabs" role="tablist" id="mytabs">
   <li role="presentation" class="active"><a href="#input_feed_url" role="tab" data-toggle="tab"><?php echo _mb("Url to feed");?></a></li>
-  <li role="presentation"><a href="#dataset_info" role="tab" data-toggle="tab"><?php echo _mb("Available datasets");?></a></li>
+  <li role="presentation"><a href="#dataset_info" role="tab" data-toggle="tab"><?php echo _mb("Datasets");?></a></li>
   <li role="presentation"><a href="#representations" role="tab" data-toggle="tab"><?php echo _mb("Access to representations");?></a></li>
 </ul>
 <!-- Tab-Inhalte -->
@@ -163,13 +163,26 @@
 <button class="btn btn-primary" type="button" id="download_feed_button">
   <?php echo _mb("Get feed content");?>
 </button>
+	<p>
+		<label for="example_feeds"><?php echo _mb("Example feeds");?>:</label>
+		<ul id="example_feeds">
+			<li>http://www.geoportal.rlp.de/mapbender/php/mod_inspireDownloadFeed.php?id=2b009ae4-aa3e-ff21-870b-49846d9561b2&type=SERVICE&generateFrom=wmslayer&layerid=30694</li>
+			<li>http://www.geoportal.rlp.de/mapbender/php/mod_inspireDownloadFeed.php?id=c2019e4f-3a3b-1caf-5c61-98a4343bf249&type=SERVICE&generateFrom=wfs&wfsid=216</li>
+			<li>http://geo.noe.gv.at/inspire-download/download_service_feed.xml</li>
+			<li>http://ole.e-steiermark.com/inspire/DownloadServiceFeed.xml</li>
+			<li>https://www.geoportal.ie/geoportal/download/ProtectedSites_SPA/npws-inspire-protected-sites-special-protection-areas.atom.en.xml</li>
+		</ul>
+	</p>
 	<!--<input type="button" title="Get Feed" id="download_feed_button" value="<?php echo _mb("Get feed content");?>"/>-->
       </form>
     </p>
   </div>
   <div role="tabpanel" class="tab-pane" id="dataset_info">
-    <div id="dataset_list">
-      <div id="dataset_select"></div>
+    <div id="dataset_list">
+      <p>
+        <label for="dataset_select" id="label_dataset_select"><?php echo _mb("Available datasets");?>:</label>
+        <div id="dataset_select"></div>
+      </p>
     </div>
     <br>
     <div id="mapframe_dataset_list"></div>
@@ -184,8 +197,8 @@
         <p readonly="readonly" name="dataset_abstract" id="dataset_abstract"></p>
       </p>
       <p>
-        <!--<label for="resource_identifier"><?php echo _mb("Resource identifier");?>:</label>-->
-        <div id="dataset_identifier"><?php echo _mb("Resource identifier (linkage to metadata)");?>:<br></div>
+        <label for="resource_identifier"><?php echo _mb("Resource identifier (linkage to metadata)");?>:</label>
+        <p readonly="readonly" id="dataset_identifier"></p>
       </p>
       <p>
         <label for="dataset_rights"><?php echo _mb("Rights");?>:</label>
@@ -197,7 +210,10 @@
     </div>
   </div>
   <div role="tabpanel" class="tab-pane" id="representations">
-    <div id="capabilities_hybrid"><?php echo _mb("Capabilities (WFS-hybrid)");?>:<br></div>
+    <p>
+    <label for="capabilities_hybrid" id="label_capabilities_hybrid"><?php echo _mb("Capabilities (WFS-hybrid)");?>:</label>
+    <div id="capabilities_hybrid"></div>
+    </p>
     <div id="representation_select">
       <p>
         <label for="representations"><?php echo _mb("Available representations");?>:</label>
More information about the Mapbender_commits mailing list
