[Mapbender-commits] r9363 - in trunk/mapbender/http: javascripts plugins
svn_mapbender at osgeo.org
Thu Jan 14 02:35:34 PST 2016
Author: armin11
Date: 2016-01-14 02:35:34 -0800 (Thu, 14 Jan 2016)
New Revision: 9363
trunk/mapbender/http/javascripts/mb_downloadFeedClient.php
trunk/mapbender/http/plugins/mb_downloadFeedClient.php
Enhancement of INSPIRE Atom Feed Client: integrate bootstrap-select, zoom to single dataset, clickable examples
Modified: trunk/mapbender/http/javascripts/mb_downloadFeedClient.php
--- trunk/mapbender/http/javascripts/mb_downloadFeedClient.php 2016-01-13 12:18:19 UTC (rev 9362)
+++ trunk/mapbender/http/javascripts/mb_downloadFeedClient.php 2016-01-14 10:35:34 UTC (rev 9363)
@@ -54,7 +54,6 @@
function init(){
- //var form = document.getElementById("service_feed_form");
//generate 2 Mapframes
//add active class to dataset info before showing map, afterwords remove it!
$('#dataset_info').toggleClass('active');
@@ -105,6 +104,14 @@
//call server by ajax function
callServer(data,method);
+ $('.example_service_feed').click(function() {
+ //alert('click');
+ resetForm();
+ method = "getServiceFeedObjectFromUrl";
+ data = $( this ).text();
+ //call server by ajax function
+ callServer(data,method);
$('#stop_parsing').click(function () {
alert("test");
@@ -174,11 +181,11 @@
$("#download_link_list").remove();
$("#download_link").remove();
//$('#dataset_select').remove();
- $('.selectpicker').remove();
- $('.selectpicker').selectpicker('refresh');
$("#tab_header_number_datasets").text("");
$("#tab_header_number_representations").text("");
$("#number_of_tiles").text("");
+ $('.selectpicker').selectpicker('destroy');
function showDatasetList(featureCollection,id) {
@@ -223,6 +230,7 @@
identifierAnchor.attr({'id':'dataset_identifier_link'});
identifierAnchor.attr({'uuid':featureCollection.features[i].properties.code});
identifierAnchor.attr({'href':'../php/mod_iso19139ToHtml.php?url='+encodeURIComponent(featureCollection.features[i].properties.metadataLink)});
+ identifierAnchor.attr({'target':'_blank'});
identifierAnchor.text(featureCollection.features[i].properties.namespace+"#"+featureCollection.features[i].properties.code);
selectOptions = selectOptions+"<option value='"+featureCollection.features[i].properties.datasetFeedLink+"' url='"+featureCollection.features[i].properties.datasetFeedLink+"' optionid='"+i+"'>"+featureCollection.features[i].properties.title+"</option>";
@@ -231,10 +239,11 @@
//add number of datasets to tab header
$("#tab_header_number_datasets").text(" "+"("+featureCollection.features.length+")");
datasetSelect.append(selectOptions);
- //datasetSelect.addClass('selectpicker');
- //datasetSelect.attr({'data-style':'btn-primary'});
- //datasetSelect.attr({'data-width':'auto'});
- //$('.selectpicker').selectpicker('render');
+ //following has to be enabled for boootstrap selectboxes
+ datasetSelect.addClass('selectpicker');
+ datasetSelect.attr({'data-style':'btn-primary'});
+ datasetSelect.attr({'data-width':'100%'});
+ datasetSelect.attr({'data-live-search':'true'});
$("#dataset_information").css("display","block");
$("#label_dataset_select").css("display","block");
//preselect option
@@ -244,14 +253,18 @@
optionSelected = $(this).find('option:selected').attr('optionid');
//alert(optionSelected);
showDatasetList(featureCollection,optionSelected);
+ //zoom viewer to extent and highlight vector of current extent
+ drawMetadataPolygon(featureCollection.features[optionSelected]);
method = "getDatasetFeedObjectFromUrl";
data = $this.val();
//resetForm();
//call second feed with first entry for default
data = featureCollection.features[0].properties.datasetFeedLink;
+ $('.selectpicker').selectpicker('refresh');
datasetFeedObject = callServer(data,method);
@@ -261,8 +274,8 @@
alert("No parseable content found");
return false;
- //remove select element for the different possible representations (formats, crs, ...)
- $('#dataset_representation_select').remove();
+ //remove old select element for the different possible representations (formats, crs, ...)
+ $('#dataset_representation_list').empty();
//generate new select element
var datasetEntrySelect = $(document.createElement('select')).appendTo('#dataset_representation_list');
datasetEntrySelect.attr({'id':'dataset_representation_select'});
@@ -274,10 +287,11 @@
$("#tab_header_number_representations").text(" "+"("+featureCollection.features.length+")");
datasetEntrySelect.append(selectROptions);
- //datasetEntrySelect.addClass('selectpicker');
- //datasetEntrySelect.attr({'data-style':'btn-primary'});
- //datasetEntrySelect.attr({'data-width':'auto'});
+ datasetEntrySelect.addClass('selectpicker');
+ datasetEntrySelect.attr({'data-style':'btn-primary'});
+ datasetEntrySelect.attr({'data-width':'100%'});
+ datasetEntrySelect.selectpicker('refresh');
fillSectionList(featureCollection, id);
$('#dataset_representation_select').bind('change', function() {
var $this = $(this);
@@ -338,7 +352,7 @@
//set number of links:
- $("#number_of_tiles").text(" "+"("+numberOfLinks+"<?php echo " single tiles"?>"+")");
+ $("#number_of_tiles").text(" "+"("+numberOfLinks+"<?php echo " tile(s)"?>"+")");
//count features of bboxFiles
//bboxFiles if not available show error message
@@ -418,6 +432,28 @@
+function drawMetadataPolygon(feature) {
+ var type = "geojson";
+ var features = formats['in'][type].read(feature);
+ var bounds;
+ if(features) {
+ if(features.constructor != Array) {
+ features = [features];
+ for(var i=0; i<features.length; ++i) {
+ if (!bounds) {
+ bounds = features[i].geometry.getBounds();
+ } else {
+ bounds.extend(features[i].geometry.getBounds());
+ //delete old features:
+ bboxDataset.removeAllFeatures();
+ bboxDataset.addFeatures(features);
+ mapframe_dataset_list.zoomToExtent(bounds);
function highlightFeatureIndexById(id, open) {
features = bboxFiles.features;
Modified: trunk/mapbender/http/plugins/mb_downloadFeedClient.php
--- trunk/mapbender/http/plugins/mb_downloadFeedClient.php 2016-01-13 12:18:19 UTC (rev 9362)
+++ trunk/mapbender/http/plugins/mb_downloadFeedClient.php 2016-01-14 10:35:34 UTC (rev 9363)
@@ -60,6 +60,10 @@
line-height: 16px;
font-family: "Verdana","Arial",sans-serif;
color: black;
+ margin-top: 10px;
+ margin-bottom: 10px;
+ margin-right: 10px;
+ margin-left: 10px;
.olControlPanPanel{margin-top:55px;}
select, textarea {
@@ -74,6 +78,7 @@
@-moz-keyframes spin { 100% { -moz-transform: rotate(360deg); } }
@-webkit-keyframes spin { 100% { -webkit-transform: rotate(360deg); } }
@keyframes spin { 100% { -webkit-transform: rotate(360deg); transform:rotate(360deg); } }
+select {max-width: 100%;}
#mapframe_dataset_list {
position: absolut;
top: 0;
@@ -82,27 +87,17 @@
height: 250px;
border: 1px solid #ccc;
+#mapframe {
#mapframe_file_list {
width: 325px;
height: 225px;
-#section_list {
- position: relative;
- top: 0;
- left: 0;
- width: 325px;
- height: 225px;
+.bootstrap-select {
+ z-index: 1500;
-#input {
- width: 512px;
-#text {
- font-size: 0.85em;
- margin: 1em 0 1em 0;
- width: 100%;
- height: 10em;
</style>
<!--<script src="../extensions/OpenLayers-2.13.1/OpenLayers.mobile.js"></script>//TODO: bugs with control panels-->
<script src="../extensions/OpenLayers-2.13.1/OpenLayers.js"></script>
@@ -173,22 +168,22 @@
</button>
<p>
<label for="example_feeds"><?php echo _mb("Example feeds");?>:</label>
- <ul id="example_feeds">
- <li>http://www.geoportal.rlp.de/mapbender/php/mod_inspireDownloadFeed.php?id=2b009ae4-aa3e-ff21-870b-49846d9561b2&type=SERVICE&generateFrom=wmslayer&layerid=30694</li>
- <li>http://www.geoportal.rlp.de/mapbender/php/mod_inspireDownloadFeed.php?id=c2019e4f-3a3b-1caf-5c61-98a4343bf249&type=SERVICE&generateFrom=wfs&wfsid=216</li>
- <li>http://geo.noe.gv.at/inspire-download/download_service_feed.xml</li>
- <li>http://ole.e-steiermark.com/inspire/DownloadServiceFeed.xml</li>
- <li>https://www.geoportal.ie/geoportal/download/ProtectedSites_SPA/npws-inspire-protected-sites-special-protection-areas.atom.en.xml</li>
- <li>http://catalogue.sigloire.fr/PRRA/atomfeed/topatom.php</li>
- <li>https://www.regionalstatistik.de/genesisws/inspire/pd/03/feeds/sf_200-71-4-B.xml</li>
- <li>http://sg.geodatenzentrum.de/web_download/downloadservice.atom.xml</li>
- <li>http://www.lfu.bayern.de/gdi/dls/biotopkartierung.xml</li>
- <li>http://www.geoportal.hessen.de/mapbender//php/mod_inspireDownloadFeed.php?id=5cf8456c-abf4-b593-0acc-0942341f0957&type=SERVICE&generateFrom=wfs&wfsid=264</li>
- <li>http://rips-gdi.lubw.baden-wuerttemberg.de/Atom_feed/de-bw-lubw_inspire_downloadservice_rips_naturschutz/de-bw-lubw_inspire_downloadservice_rips_naturschutz.xml</li>
- <li>http://maps.waterschapservices.nl/www/download/nl.xml</li>
- <li>http://services.rce.geovoorziening.nl/www/download/nl.xml</li>
- <li>http://mapy.geoportal.gov.pl/wss/service/ATOM/httpauth/atom/SR</li>
- <li>http://sedsh127.sedsh.gov.uk/Atom_data/ScotGov/ProtectedSites/SG_ProtectedSites.atom.en.xml</li>
+ <ul class="list-group" id="example_feeds">
+ <li class="example_service_feed list-group-item-success">http://www.geoportal.rlp.de/mapbender/php/mod_inspireDownloadFeed.php?id=2b009ae4-aa3e-ff21-870b-49846d9561b2&type=SERVICE&generateFrom=wmslayer&layerid=30694</li>
+ <li class="example_service_feed list-group-item-info">http://www.geoportal.rlp.de/mapbender/php/mod_inspireDownloadFeed.php?id=c2019e4f-3a3b-1caf-5c61-98a4343bf249&type=SERVICE&generateFrom=wfs&wfsid=216</li>
+ <li class="example_service_feed list-group-item-warning">http://geo.noe.gv.at/inspire-download/download_service_feed.xml</li>
+ <li class="example_service_feed list-group-item-danger">http://ole.e-steiermark.com/inspire/DownloadServiceFeed.xml</li>
+ <li class="example_service_feed list-group-item-success">https://www.geoportal.ie/geoportal/download/ProtectedSites_SPA/npws-inspire-protected-sites-special-protection-areas.atom.en.xml</li>
+ <li class="example_service_feed list-group-item-info">http://catalogue.sigloire.fr/PRRA/atomfeed/topatom.php</li>
+ <li class="example_service_feed list-group-item-warning">https://www.regionalstatistik.de/genesisws/inspire/pd/03/feeds/sf_200-71-4-B.xml</li>
+ <li class="example_service_feed list-group-item-danger">http://sg.geodatenzentrum.de/web_download/downloadservice.atom.xml</li>
+ <li class="example_service_feed list-group-item-success">http://www.lfu.bayern.de/gdi/dls/biotopkartierung.xml</li>
+ <li class="example_service_feed list-group-item-info">http://www.geoportal.hessen.de/mapbender//php/mod_inspireDownloadFeed.php?id=5cf8456c-abf4-b593-0acc-0942341f0957&type=SERVICE&generateFrom=wfs&wfsid=264</li>
+ <li class="example_service_feed list-group-item-warning">http://rips-gdi.lubw.baden-wuerttemberg.de/Atom_feed/de-bw-lubw_inspire_downloadservice_rips_naturschutz/de-bw-lubw_inspire_downloadservice_rips_naturschutz.xml</li>
+ <li class="example_service_feed list-group-item-danger">http://maps.waterschapservices.nl/www/download/nl.xml</li>
+ <li class="example_service_feed list-group-item-success">http://services.rce.geovoorziening.nl/www/download/nl.xml</li>
+ <li class="example_service_feed list-group-item-info">http://mapy.geoportal.gov.pl/wss/service/ATOM/httpauth/atom/SR</li>
+ <li class="example_service_feed list-group-item-warning">http://sedsh127.sedsh.gov.uk/Atom_data/ScotGov/ProtectedSites/SG_ProtectedSites.atom.en.xml</li>
</ul>
</p>
<!--<input type="button" title="Get Feed" id="download_feed_button" value="<?php echo _mb("Get feed content");?>"/>-->
@@ -196,7 +191,7 @@
</p>
</div>
<div role="tabpanel" class="tab-pane" id="dataset_info">
- <div id="dataset_list">
+ <div style="z-index: 1200;" id="dataset_list">
<p>
<label for="dataset_select" id="label_dataset_select"><?php echo _mb("Available datasets");?>:</label>
<div id="dataset_select"></div>
@@ -235,7 +230,7 @@
<div id="representation_select">
<p>
<label for="representations"><?php echo _mb("Available representations");?>:</label>
- <div id="dataset_representation_list"></div>
+ <div style="z-index: 1000;" id="dataset_representation_list"></div>
</p>
</div>
<br>
More information about the Mapbender_commits
