[Mapbender-commits] r9372 - trunk/mapbender/owsproxy/http
svn_mapbender at osgeo.org
Mon Jan 18 08:01:54 PST 2016
Author: armin11
Date: 2016-01-18 08:01:54 -0800 (Mon, 18 Jan 2016)
New Revision: 9372
trunk/mapbender/owsproxy/http/index.php
First draft for allowing owsproxy functions for wfs
Modified: trunk/mapbender/owsproxy/http/index.php
--- trunk/mapbender/owsproxy/http/index.php 2016-01-18 16:01:16 UTC (rev 9371)
+++ trunk/mapbender/owsproxy/http/index.php 2016-01-18 16:01:54 UTC (rev 9372)
@@ -45,6 +45,9 @@
$reqParams = $query->getRequestParams();
$e = new mb_notice("incoming request: " . OWSPROXY . "/" . $_REQUEST['sid'] . "/" . $_REQUEST['wms'] . $query->getRequest());
$e = new mb_notice("owsproxy requested from: " . $_SERVER["REMOTE_ADDR"]);
+$e = new mb_exception("owsproxy requested: " . $query->getRequest());
+$sid = $_REQUEST['sid'];
+$serviceId = $_REQUEST['wms'];
if (defined("OWSPROXY_SESSION_GRABBING_WHITELIST")) {
$whiteListArray = explode(",", OWSPROXY_SESSION_GRABBING_WHITELIST);
@@ -168,18 +171,7 @@
$e = new mb_notice("user id for authorization test: " . getUserFromSession());
-$wmsId = $n->getWmsIdFromOwsproxyString($query->getOwsproxyServiceId());
-//get authentication infos if they are available in wms table! if not $auth = false
-if ($reqParams['request'] !== 'external') {
- $auth = $n->getAuthInfoOfWMS($wmsId);
-if ($auth['auth_type'] == '') {
- unset($auth);
-/* * *********** workflow *********** */
-$n = new administration();
if (count($_REQUEST) > 0) {
foreach ($_REQUEST as $key => $value) {
if (strtoupper($key) === "SERVICE")
@@ -188,16 +180,60 @@
if (!$found)
$query->setParam("service", "WMS");
+//check for kind of service
+switch (strtolower($reqParams['service'])) {
+ case 'wms':
+ $wmsId = $n->getWmsIdFromOwsproxyString($query->getOwsproxyServiceId());
+ //get authentication infos if they are available in wms table! if not $auth = false
+ if ($reqParams['request'] !== 'external') {
+ $auth = $n->getAuthInfoOfWMS($wmsId);
+ if ($auth['auth_type'] == '') {
+ unset($auth);
+ break;
+ case 'wfs':
+ $wfsId = $n->getWfsIdFromOwsproxyString($query->getOwsproxyServiceId());
+ //get authentication infos if they are available in wfs table! if not $auth = false
+ $auth = $n->getAuthInfoOfWFS($wfsId);
+ unset($auth);
+ break;
+/* * *********** workflow *********** */
switch (strtolower($reqParams['request'])) {
case 'getcapabilities':
- $arrayOnlineresources = checkWmsPermission($query->getOwsproxyServiceId());
- $query->setOnlineResource($arrayOnlineresources['wms_getcapabilities']);
- $request = $query->getRequest();
- if (isset($auth)) {
- getCapabilities($request, $auth);
- } else {
- getCapabilities($request);
+ switch (strtolower($reqParams['service'])) {
+ case 'wfs':
+ $arrayOnlineresources = checkWfsPermission($query->getOwsproxyServiceId(), false);
+ $query->setOnlineResource($arrayOnlineresources['wfs_getcapabilities']);
+ $request = $query->getRequest();
+ if (isset($auth)) {
+ getWfsCapabilities($request, $auth);
+ } else {
+ getWfsCapabilities($request);
+ break;
+ case 'wms':
+ $arrayOnlineresources = checkWmsPermission($query->getOwsproxyServiceId());
+ $query->setOnlineResource($arrayOnlineresources['wms_getcapabilities']);
+ getCapabilities($request, $auth);
+ } else {
+ getCapabilities($request);
+ break;
break;
case 'getfeatureinfo':
@@ -291,8 +327,24 @@
$query->setOnlineResource($arrayOnlineresources['wfs_getfeature']);
$request = stripslashes($request);
- getFeature($request);
+ getFeature($request, $auth);
+ } else {
+ getFeature($request);
break;
+ case 'describefeaturetype':
+ $arrayFeatures = array($reqParams['typename']);
+ $arrayOnlineresources = checkWfsPermission($query->getOwsproxyServiceId(), $arrayFeatures);
+ $query->setOnlineResource($arrayOnlineresources['wfs_describefeaturetype']);
+ $request = stripslashes($request);
+ describeFeaturetype($request, $auth);
+ } else {
+ describeFeaturetype($request);
+ break;
// case wfs transaction (because of raw POST the request param is empty)
case '':
$arrayFeatures = getWfsFeaturesFromTransaction($HTTP_RAW_POST_DATA);
@@ -302,6 +354,8 @@
doTransaction($request, $HTTP_RAW_POST_DATA);
break;
default:
+ throwText(array("Request parameter not known to mapbender security proxy!"));
+ break;
//why delete session here - only if it was temporary?
if (isset($tmpSession) && Mapbender::session()->storageExists($tmpSession)) {
@@ -438,16 +492,26 @@
* @param string the url of the GetFeature request
* @return echo the content of the GetFeature document
-function getFeature($url)
+function getFeature($url, $auth = false)
global $reqParams;
+ $content = getDocumentContent(false, $url, "Content-Type: application/xml", $auth);
- header("Content-Type: " . $reqParams['info_format']);
- $content = getDocumentContent(false, $url);
- $content = matchUrls($content);
- echo $content;
+ * fetchs and returns the content of WFS DescribeFeaturetype response
+ * @param string the url of the DescribeFeaturetype request
+ * @return echo the content of the DescribeFeaturetype document
+function describeFeaturetype($url, $auth = false)
+ global $reqParams;
* simulates a post request to host
@@ -665,15 +729,37 @@
function getCapabilities($url)
global $arrayOnlineresources;
- global $sid, $wms;
+ global $sid, $serviceId;
$t = array(htmlentities($arrayOnlineresources["wms_getcapabilities"]), htmlentities($arrayOnlineresources["wms_getmap"]),
htmlentities($arrayOnlineresources["wms_getfeatureinfo"]));
- $new = OWSPROXY . "/" . $sid . "/" . $wms . "?";
+ $new = OWSPROXY . "/" . $sid . "/" . $serviceId . "?";
$r = str_replace($t, $new, $arrayOnlineresources["wms_getcapabilities_doc"]);
+ //delete trailing amp; 's
+ $r = str_replace('amp;', '', $r);
header("Content-Type: application/xml");
echo $r;
+function getWfsCapabilities($request, $auth = false)
+ global $arrayOnlineresources;
+ $t = array(htmlentities($arrayOnlineresources["wfs_getcapabilities"]), htmlentities($arrayOnlineresources["wfs_getmap"]),
+ htmlentities($arrayOnlineresources["wfs_getfeatureinfo"]));
+ //get actual capabilities from external server
+ if (!$auth) {
+ $wfsCaps = new connector($arrayOnlineresources["wfs_getcapabilities"].$request);
+ } else {
+ $wfsCaps = new connector($arrayOnlineresources["wfs_getcapabilities"].$request, $auth);
+ $r = str_replace($t, $new, $wfsCaps->file);
+ header("Content-Type: application/xml");
+ echo $r;
* gets the original url of the requested legend graphic
@@ -771,11 +857,12 @@
global $con, $n;
$myconfs = $n->getWfsConfByPermission($_SESSION["mb_user_id"]);
- //check if we know the features requested
- if (count($features) == 0) {
- throwE(array("No wfs_feature data available."));
- die();
+ if ($features !== false) {
+ //check if we know the features requested
+ if (count($features) == 0) {
+ throwE(array("No wfs_feature data available."));
+ die();
//get wfs
@@ -808,7 +895,7 @@
$t = array("i", "s");
$res = db_prep_query($sql, $v, $t);
if (!($row = db_fetch_array($res))) {
- $notice = new mb_exception("Permissioncheck failed no wfs conf for wfs " . $service["wfs_id"] . " with feturetype " . $feature);
+ $notice = new mb_exception("Permissioncheck failed no wfs conf for wfs " . $service["wfs_id"] . " with featuretype " . $feature);
throwE(array("No wfs_conf data for featuretype " . $feature));
die();
@@ -903,6 +990,39 @@
echo $content;
return true;
+ } elseif (strtoupper($reqParams["request"]) == "GETFEATURE") {
+ $e = new mb_exception("getfeature invoked");
+ //parse featureCollection and get number of objects
+ libxml_use_internal_errors(true);
+ try {
+ $featureCollectionXml = simplexml_load_string($content);
+ if ($featureCollectionXml === false) {
+ foreach(libxml_get_errors() as $error) {
+ $err = new mb_exception("owsproxy/index.php:".$error->message);
+ throw new Exception("owsproxy/index.php:".'Cannot parse featureCollection XML!');
+ //TODO give error message
+ catch (Exception $e) {
+ $err = new mb_exception("owsproxy/index.php:".$e->getMessage());
+ if ($featureCollectionXml !== false) {
+ $featureCollectionXml->registerXPathNamespace("gmd", "http://www.isotc211.org/2005/gmd");
+ $featureCollectionXml->registerXPathNamespace("gco", "http://www.isotc211.org/2005/gco");
+ $featureCollectionXml->registerXPathNamespace("gml", "http://www.opengis.net/gml");
+ $featureCollectionXml->registerXPathNamespace("xlink", "http://www.w3.org/1999/xlink");
+ $featureCollectionXml->registerXPathNamespace("xsi", "http://www.w3.org/2001/XMLSchema-instance");
+ $featureCollectionXml->registerXPathNamespace("default", "");
+ $numberOfFeatures = $featureCollectionXml->xpath('//wfs:FeatureCollection/@numberOfFeatures');
+ $numberOfFeatures = $numberOfFeatures[0];
+ $e = new mb_exception("owsproxy/index.php: ".$numberOfFeatures." delivered features from wfs ");
+ if (header !== false) {
+ header($header);
+ echo $content;
} else {
header($header);
More information about the Mapbender_commits
