[Mapbender-commits] r9543 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jul 14 08:01:01 PDT 2016
Author: armin11
Date: 2016-07-14 08:01:01 -0700 (Thu, 14 Jul 2016)
New Revision: 9543
   trunk/mapbender/http/classes/class_wms.php
New possibility to sync mapbender registry with external csw via csw-t - done for wms layer resources
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php	2016-07-13 15:13:47 UTC (rev 9542)
+++ trunk/mapbender/http/classes/class_wms.php	2016-07-14 15:01:01 UTC (rev 9543)
@@ -14,6 +14,7 @@
 require_once dirname(__FILE__) . "/class_georss_factory.php";
 require_once dirname(__FILE__) . "/class_mb_exception.php";
 require_once dirname(__FILE__) . "/class_iso19139.php";
+require_once(dirname(__FILE__) . "/class_cswClient.php");
 require_once dirname(__FILE__) . "/../classes/class_universal_wms_factory.php";
 class wms {
 	var $lastURL;
@@ -1905,7 +1906,38 @@
 				$e = new mb_exception("class_wms.php: Twitter API give back error code: ".$result);
+		//Propagate information for each new layer to csw if configured
+		if (defined("SYNC_CHANGES_TO_CSW") && SYNC_CHANGES_TO_CSW == true && defined("SYNC_CATALOGUE_ID") && is_int(SYNC_CATALOGUE_ID)) {
+			if (defined("MAPBENDER_PATH") && MAPBENDER_PATH !== "") {
+				//layer service metadata generator
+				$servMdPath = MAPBENDER_PATH."/php/mod_layerISOMetadata.php?SERVICE=WMS&outputFormat=iso19139&Id=";
+			} else {
+				$servMdPath = "http://".$_SERVER['HTTP_HOST']."/mapbender"."/php/mod_layerISOMetadata.php?SERVICE=WMS&outputFormat=iso19139&Id=";
+			$cswClient = new cswClient();
+			$cswClient->cswId = SYNC_CATALOGUE_ID;
+			$isoMetadata = new Iso19139();
+			//select all layer which are searchable
+			$sql = "SELECT layer_id, uuid FROM layer WHERE fkey_wms_id = $1 and layer_searchable = 1";
+			$v = array($myWMS);
+			$t = array('i');
+			$res = db_prep_query($sql,$v,$t);
+			$insertedLayerArray = array();
+			while($row = db_fetch_array($res)){
+				$insertedLayerArray[] = array(
+						"id" => $row['layer_id'],
+						"uuid" => $row['uuid']
+			//update existing layer
+			foreach ($insertedLayerArray as $insertedLayer) {
+					//$e = new mb_exception("classes/class_wms.php: try to push metadata for layer ".$insertedLayer['id']." into csw");
+					$metadata = $isoMetadata->createFromUrl($servMdPath.$insertedLayer['id']);
+					$result = $cswClient->pushRecord($metadata);
+					//$e = new mb_exception("classes/class_wms.php: result of pushing: ".$result);
 	    //Changes JW
 	    $this->wms_id = $myWMS;
@@ -2002,6 +2034,7 @@
 	function updateLayer($i,$myWMS,$updateMetadataOnly=false){
@@ -2870,7 +2903,7 @@
 		$v = array($myWMS);
 		$t = array('i');
 		$c = 2;
-		$sql = "SELECT layer_id, layer_name, layer_title, layer_abstract, inspire_download FROM layer WHERE fkey_wms_id = $1 AND layer_pos > 0 AND NOT layer_name IN(";
+		$sql = "SELECT layer_id, layer_name, layer_title, layer_abstract, inspire_download, uuid FROM layer WHERE fkey_wms_id = $1 AND layer_pos > 0 AND NOT layer_name IN(";
 		for($i=1; $i<count($this->objLayer); $i++){
 			if($i>1){$sql .= ',';}
 			$sql .= "$".$c;
@@ -2885,7 +2918,9 @@
 					"id" => $row["layer_id"],
 					"name" => $row["layer_name"],
 					"title" => $row["layer_title"],
-					"abstract" => $row["layer_abstract"]
+					"abstract" => $row["layer_abstract"],
+					"uuid" => $row["uuid"],
+					"layer_searchable" => $row["layer_searchable"]
 					//"inspire_download" => $row["inspire_download"]
@@ -2935,7 +2970,7 @@
 		################ end section for all child layers
 		# update or insert?
-		$sql = "SELECT layer_name FROM layer WHERE fkey_wms_id = $1";
+		$sql = "SELECT layer_id, layer_name, uuid, layer_searchable FROM layer WHERE fkey_wms_id = $1";
 		$v = array($myWMS);
 		$t = array('i');
@@ -2943,7 +2978,6 @@
 			array_push($exLayer,$row["layer_name"]);
 		$sql = "SELECT fkey_gui_id FROM gui_wms WHERE fkey_wms_id = $1";
 		$v = array($myWMS);
 		$t = array('i');
@@ -2972,6 +3006,20 @@
+		//select new layer after update and insert
+		$t = array('i');
+		$updatedInsertedLayerArray = array();
+			$updatedInsertedLayerArray[] = array(
+					"uuid" => $row['uuid'],
+					"layer_searchable" => $row['layer_searchable']
+			//$e = new mb_exception("insert update layer: ".$row['uuid']." - searchable: ". $row['layer_searchable']);
 		db_commit();
@@ -3040,8 +3088,45 @@
+		//sync to metadatacatalogue (service metadata for each layer by uuid) if configured - use uuid
+		//TODO need absolute url to srv metadata generator! - possible if invoked via shell (scheduler)?
+			} else {
+			//delete old orphaned layer
+			foreach ($oldLayerNameArray as $oldLayer) {
+				if ($oldLayer['layer_searchable'] == "1") {
+					//$e = new mb_exception("classes/class_wms.php: try to delete: ".$oldLayer['uuid']);
+					$result = $cswClient->deleteRecord($oldLayer['uuid']);
+					//$e = new mb_exception("classes/class_wms.php: delete metadata in csw: ".$result);
+			foreach ($updatedInsertedLayerArray as $updatedInsertedLayer) {
+				//$e = new mb_exception("classes/class_wms.php: layer_searchable: ".gettype($updatedInsertedLayer['layer_searchable'])." - value: ".$updatedInsertedLayer['layer_searchable']);
+				if ($updatedInsertedLayer['layer_searchable'] !== "1") {
+					//$e = new mb_exception("classes/class_wms.php: try to delete: ".$updatedInsertedLayer['uuid']);
+					$result = $cswClient->deleteRecord($updatedInsertedLayer['uuid']);
+				} else {
+					//$e = new mb_exception("classes/class_wms.php: try to insert or update: ".$updatedInsertedLayer['uuid']);
+					$metadata = $isoMetadata->createFromUrl($servMdPath.$updatedInsertedLayer['id']);
+					//$e = new mb_exception("classes/class_wms.php: metadata url: ".$servMdPath.$updatedInsertedLayer['id']);
+					//$e = new mb_exception("classes/class_wms.php: insert or update metadata in csw: ".$result);
 		if ($authType != '') { //some authentication is needed!
  			$admin = new administration();
  			echo "WMS ID: ".$myWMS;
More information about the Mapbender_commits mailing list
