[Mapbender-commits] r9513 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jun 9 02:12:23 PDT 2016
Author: armin11
Date: 2016-06-09 02:12:23 -0700 (Thu, 09 Jun 2016)
New Revision: 9513
   trunk/mapbender/http/classes/class_iso19139.php
Handle preview image url by internal metadata class
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php	2016-06-09 09:11:44 UTC (rev 9512)
+++ trunk/mapbender/http/classes/class_iso19139.php	2016-06-09 09:12:23 UTC (rev 9513)
@@ -61,6 +61,7 @@
 	var $inspireCharset;
 	var $licenseSourceNote;
 	var $licenseJson;
+	var $previewImage;
 	//the following attribute is specific to predefined terms of use as they are managed by the mapbender database - it is the identifier (fkey) of an entry in the termsofuse table
 	var $termsOfUseRef;
 	var $accessConstraints;
@@ -129,6 +130,7 @@
 		$this->licenseJson = null;
 		$this->resourceResponsibleParty = null;
 		$this->resourceContactEmail = null;
+		$this->previewImage = null;
 	public function removeGetRecordTag ($xml) {
@@ -307,7 +309,14 @@
 				$this->transferSize = $this->transferSize[0];
 			} else {
 				$this->transferSize = null;
+			//preview image
+			$this->previewImage = $iso19139Xml->xpath('//gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:graphicOverview/gmd:MD_BrowseGraphic/gmd:fileName/gco:CharacterString');
+			if (is_array($this->previewImage) && $this->previewImage[0] !== '') {
+				$this->previewImage = $this->previewImage[0];
+			} else {
 			//$e = new mb_exception("class_iso19139.php: count of downloadlinks: ".count($this->downloadLinks));
 			//$this->downloadLinks = array_values($this->downloadLinks);
 			//$dump = var_export($this->downloadLinks, true);
@@ -1036,6 +1045,7 @@
 			$this->licenseSourceNote = $row['md_license_source_note'];
 			$this->resourceResponsibleParty = $row['responsible_party_name'];
 			$this->resourceContactEmail = $row['responsible_party_email'];
+			$this->previewImage = $row['preview_image'];
 			//get relations from other tables:
 			//get categories and keywords
 			//get isoCategories
@@ -1764,7 +1774,7 @@
 		//insert an instance for iso19139 into mapbenders database
 		$e = new mb_exception("class_iso19139.php: insert metadata with title: ".$this->title);
 		$sql = <<<SQL
-INSERT INTO mb_metadata (lastchanged, link, origin, md_format, data, linktype, uuid, title, createdate, changedate, abstract, searchtext, type, tmp_reference_1, tmp_reference_2, export2csw, datasetid, datasetid_codespace, randomid, fkey_mb_user_id, harvestresult, harvestexception, lineage, inspire_top_consistence, spatial_res_type, spatial_res_value, update_frequency, format, inspire_charset, ref_system, the_geom, datalinks, inspire_whole_area, inspire_actual_coverage, inspire_download, bounding_geom, transfer_size, fees, md_license_source_note, constraints, responsible_party_name, responsible_party_email)  VALUES(now(), $1, $18, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17, $19, $20, $21, $22, $23, $24, $25, $26, $27, $28, $29, $30, $31, $32, $33, $34, $35, $36, $37, $38, $39, $40, $41)
+INSERT INTO mb_metadata (lastchanged, link, origin, md_format, data, linktype, uuid, title, createdate, changedate, abstract, searchtext, type, tmp_reference_1, tmp_reference_2, export2csw, datasetid, datasetid_codespace, randomid, fkey_mb_user_id, harvestresult, harvestexception, lineage, inspire_top_consistence, spatial_res_type, spatial_res_value, update_frequency, format, inspire_charset, ref_system, the_geom, datalinks, inspire_whole_area, inspire_actual_coverage, inspire_download, bounding_geom, transfer_size, fees, md_license_source_note, constraints, responsible_party_name, responsible_party_email, preview_image)  VALUES(now(), $1, $18, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17, $19, $20, $21, $22, $23, $24, $25, $26, $27, $28, $29, $30, $31, $32, $33, $34, $35, $36, $37, $38, $39, $40, $41, $42)
 SQL;
 		$v = array(
 			$this->href,
@@ -1807,13 +1817,14 @@
 			$this->licenseSourceNote,
 			$this->accessConstraints,
 			$this->resourceResponsibleParty,
-			$this->resourceContactEmail
+			$this->resourceContactEmail,
 			//$e = new mb_exception($this->tmpExtentBegin);
 			//$e = new mb_exception($this->tmpExtentEnd);
 			//$e = new mb_exception($this->createDate);
 			//$e = new mb_exception($this->changeDate);
-			$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','b','s','s','s','s','i','i','s','s','b','s','s','s','s','s','s','POLYGON','s','s','s','i','POLYGON','d','s','s','s','s','s');
+			$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','b','s','s','s','s','i','i','s','s','b','s','s','s','s','s','s','POLYGON','s','s','s','i','POLYGON','d','s','s','s','s','s','s');
 			$res = db_prep_query($sql,$v,$t);
 			return $res;
@@ -1871,7 +1882,7 @@
 		$sql .= "linktype = $4, uuid = $5, title = $6, createdate = $7, changedate = $8, lastchanged = now(), ";
 		$sql .= "abstract = $9, searchtext = $10, type = $11, tmp_reference_1 = $12, tmp_reference_2 = $13, export2csw = $14, datasetid = $15, ";
 		$sql .= "datasetid_codespace = $16, randomid = $17, harvestresult = $20, harvestexception = $21, lineage = $22, inspire_top_consistence = $23, ";
-		$sql .= "spatial_res_type = $24, spatial_res_value = $25, update_frequency = $26, format = $27, inspire_charset = $28, ref_system = $29, the_geom = $30, datalinks = $31, inspire_whole_area = $32, inspire_actual_coverage = $33, inspire_download = $34, bounding_geom = $35, transfer_size = $36, fees = $37, md_license_source_note = $38, constraints = $39, responsible_party_name = $40, responsible_party_email = $41 WHERE metadata_id = $19";
+		$sql .= "spatial_res_type = $24, spatial_res_value = $25, update_frequency = $26, format = $27, inspire_charset = $28, ref_system = $29, the_geom = $30, datalinks = $31, inspire_whole_area = $32, inspire_actual_coverage = $33, inspire_download = $34, bounding_geom = $35, transfer_size = $36, fees = $37, md_license_source_note = $38, constraints = $39, responsible_party_name = $40, responsible_party_email = $41 , preview_image = $42 WHERE metadata_id = $19";
 		//$e= new mb_exception("class_iso19139.php: downloadLinks json".$this->jsonEncodeDownloadLinks($this->downloadLinks));
 		//$e= new mb_exception("class_iso19139.php: downloadLinks[0]".$this->downloadLinks[0]);
 		$v = array(
@@ -1916,10 +1927,11 @@
 		//$e = new mb_exception("class_iso19139: ".$this->createWktBboxFromArray($this->wgs84Bbox));
 		return $res;
More information about the Mapbender_commits mailing list
