[Mapbender-commits] r9518 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Thu Jun 9 07:47:46 PDT 2016
Author: armin11
Date: 2016-06-09 07:47:46 -0700 (Thu, 09 Jun 2016)
New Revision: 9518
trunk/mapbender/http/classes/class_metadata_new.php
Add database search with wildcard * - disable like filter
Modified: trunk/mapbender/http/classes/class_metadata_new.php
--- trunk/mapbender/http/classes/class_metadata_new.php 2016-06-09 09:22:26 UTC (rev 9517)
+++ trunk/mapbender/http/classes/class_metadata_new.php 2016-06-09 14:47:46 UTC (rev 9518)
@@ -1185,15 +1185,13 @@
$e = new mb_notice("Wrote the MD_Dataset-File");
private function replaceChars_all($text){
$search = array( "ä", "ö", "ü", "Ä", "Ö", "Ü", "ß");
$repWith = array("ae", "oe", "ue", "AE", "OE", "UE", "ss");
$replaced = str_replace($search, $repWith, $text);
return $replaced;
private function generateSearchSQL() {
//elements needed to exist in mb wfs,wms,wmc view or table:
//1. textfield - all texts - searchText
@@ -1205,15 +1203,13 @@
$searchStringArray = $this->generateSearchStringArray();
$v = array();
$t = array();
- $sql = "SELECT * from ".$this->searchView." where ";
- #$sqlN = "SELECT count(".$this->searchResources."_id) from ".$this->searchView." where ";
+ $sql = "SELECT * from ".$this->searchView." ";
$whereStr = "";
$whereCondArray = array();
$isTextSearch = "false";
$e = new mb_notice("Number of used searchstrings: ".count($searchStringArray));
//textsearch
- if ($this->searchText != NULL) {
+ if ($this->searchText != NULL && trim($this->searchText) != '*') {
for($i=0; $i < count($searchStringArray); $i++){
$isTextSearch = "true";
if($i>0) {
@@ -1230,7 +1226,6 @@
// This is only for the later postgis versions. The within and disjoint is to slow, cause there is no usage of the geometrical index in the old versions!
//check for postgis version
//sql for get version string
@@ -1425,6 +1420,9 @@
$whereStr .= $txt_whereCond;
//Add WHERE condition to search
+ if ($whereStr !== '') {
+ $whereStr = "WHERE ".$whereStr;
$sql .= $whereStr;
//TODO ORDER BY in SQL - not necessary for counting things:
$sql .= $this->orderBy;
@@ -1442,23 +1440,16 @@
return array($sql, $v, $t, $n);
/** Function to write a json file which includes the categories of the search result for each searchResource - wms/wfs/wmc/georss, new: it should also count the keyword distribution of the searchResource ans save it as a special json file!
private function writeCategories($whereStr, $v, $t) {
//generate count sql
//generate count of all entries
- $sqlN = "SELECT count(".$this->searchResources."_id) from ".$this->searchView." where ";
- $sqlN .= $whereStr;
+ $sqlN = "SELECT count(".$this->searchResources."_id) from ".$this->searchView." ";
+ if ($whereStr != '') {
+ $sqlN .= $whereStr;
//Get total number of results
$count = db_prep_query($sqlN, $v, $t);
$n = db_fetch_all($count);
More information about the Mapbender_commits
