[Mapbender-commits] r9521 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Mon Jun 13 00:39:27 PDT 2016
Author: armin11
Date: 2016-06-13 00:39:27 -0700 (Mon, 13 Jun 2016)
New Revision: 9521
trunk/mapbender/http/javascripts/map_obj.js
Fix for getfeatureinfo handling with queryable wms layergroups as used by deegree wms
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js 2016-06-10 10:30:18 UTC (rev 9520)
+++ trunk/mapbender/http/javascripts/map_obj.js 2016-06-13 07:39:27 UTC (rev 9521)
@@ -981,13 +981,14 @@
if (!ignoreThisWms) {
- //switch for service based featureInfo od layer based one
+ //switch for service based featureInfo or layer based one
if (featureInfoCollectLayers) {
//instantiate return object
var featureInfoObj = {};
featureInfoObj.title = "";
featureInfoObj.names = "";
featureInfoObj.legendurl = "";
+ featureInfoObj.styles = "";
var featureInfoRequest = this.wms[i].getFeatureInfoRequest(this, clickPoint);
//check if featureinfo for this service is available - push only those into return object
if (typeof(featureInfoRequest) !== 'undefined' && featureInfoRequest !== "" && featureInfoRequest !== false) {
@@ -1010,6 +1011,11 @@
} else {
featureInfoObj.legendurl += "empty"+",";
+ if (typeof(this.wms[i].objLayer[j].layer_style[0]) !=='undefined') {
+ featureInfoObj.styles += this.wms[i].objLayer[j].layer_style[0].name+",";
+ } else {
+ featureInfoObj.styles += "default"+",";
@@ -1017,8 +1023,10 @@
//do following things only, if some name exists!
if (featureInfoObj.names !=='') {
//exchange trailing ","
- featureInfoObj.names = featureInfoObj.names.replace(/,+$/, "");
- featureInfoObj.title = featureInfoObj.title.replace(/, +$/, "");
+ featureInfoObj.names = featureInfoObj.names.replace(/,\s*$/, "");
+ featureInfoObj.title = featureInfoObj.title.replace(/,\s*$/, "");
+ featureInfoObj.styles = featureInfoObj.styles.replace(/,\s*$/, "");
//check for length of title - if length is > 1 use wms title, cause window is too small!
/*if(featureInfoObj.title.split(",").length > 1) {
featureInfoObj.title = this.wms[i].wms_title;
@@ -1027,6 +1035,7 @@
//remove wrong layers from getFeatureInfo request
featureInfoRequest = changeURLParameterValue(featureInfoRequest,"LAYERS", featureInfoObj.names);
featureInfoRequest = changeURLParameterValue(featureInfoRequest,"QUERY_LAYERS", featureInfoObj.names);
+ featureInfoRequest = changeURLParameterValue(featureInfoRequest,"STYLES", featureInfoObj.styles);
featureInfoObj.request = featureInfoRequest;
//give back objects
allRequests.push(featureInfoObj);
More information about the Mapbender_commits
