[Mapbender-commits] r9528 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Mon Jun 27 07:21:48 PDT 2016
Author: armin11
Date: 2016-06-27 07:21:48 -0700 (Mon, 27 Jun 2016)
New Revision: 9528
trunk/mapbender/http/php/wms.php
Fix for srs inheritance of older layers
Modified: trunk/mapbender/http/php/wms.php
--- trunk/mapbender/http/php/wms.php 2016-06-24 10:26:40 UTC (rev 9527)
+++ trunk/mapbender/http/php/wms.php 2016-06-27 14:21:48 UTC (rev 9528)
@@ -514,11 +514,11 @@
#GetCapabilities
-#Creatig the "GetCapabilities" node
+#Creating the "GetCapabilities" node
$getCapabilities = $doc->createElement("GetCapabilities");
$getCapabilities = $request->appendChild($getCapabilities);
-#Creatig the "Format" node
+#Creating the "Format" node
$wms_format_sql ="SELECT data_format FROM wms_format WHERE fkey_wms_id = $1 AND data_type = 'capability'";
$v = array($wms_row['wms_id']);
$t = array("i");
@@ -857,6 +857,12 @@
#SQL statement to get additional layer information from layer epsg
$epsg_sql = "SELECT layer_epsg.epsg, layer_epsg.minx, layer_epsg.miny, " .
"layer_epsg.maxy, layer_epsg.maxx " .
@@ -869,6 +875,9 @@
$latLonBoundingBoxCreated = false;
$BoundingBoxCreated = false;
+//pull all other parent layer and their epsg!!
while ($epsg_row = db_fetch_array($res_espg_sql)) {
#Creating SRS node
$srs = $doc->createElement("SRS");
@@ -990,7 +999,7 @@
if($layerRow['layer_abstract'] <> "" AND $layerRow['layer_abstract'] <> NULL) {
$layerAbstract = $layerRow['layer_abstract'];
} else {
- $layerAbstract = _mb('No abtract for the specific layer was given, please add a description to your layer ressource.');
+ $layerAbstract = _mb('No abstract for the specific layer was given, please add a description to your layer ressource.');
$abstract = $doc->createElement("Abstract");
$abstract = $layer->appendChild($abstract);
@@ -1026,13 +1035,76 @@
"WHERE fkey_layer_id = ".$layerRow['layer_id'];
//" OR fkey_layer_id = " . $layer_row['layer_id'];
$res_layer_srs_sql = db_query($layer_srs_sql);
+ //store srs into array
+ $origLayerEpsg = array();
while ($layer_srs_row = db_fetch_array($res_layer_srs_sql)) {
- #Creating SRS node
+ //Creating SRS node
$srs = $layer->appendChild($srs);
$srsText = $doc->createTextNode(str_replace('epsg','EPSG',$layer_srs_row['epsg']));
+ $origLayerEpsg[] = str_replace('epsg','EPSG',$layer_srs_row['epsg']);
$srsText = $srs->appendChild($srsText);
+ //extent this list with srs from all parent layers
+ //build tree
+ $parent_layer_srs_sql = "SELECT layer_id, layer_pos, layer_parent FROM layer WHERE fkey_wms_id = $1";
+ $vPL = array($wmsRow['wms_id']);
+ $tPL = array('i');
+ $resPL = db_prep_query($parent_layer_srs_sql, $vPL, $tPL);
+ while ($layerTree = db_fetch_array($resPL)) {
+ $layerTreeArray['layer_id'][] = $layerTree['layer_id'];
+ $layerTreeArray['layer_pos'][] = $layerTree['layer_pos'];
+ $layerTreeArray['layer_parent'][] = $layerTree['layer_parent'];
+ $rootLayerFound = false;
+ $layerStructure = array();
+ $searchLayerId = $layerRow['layer_id'];
+ //$layerStructure[] = $searchLayerId;
+ while ($rootLayerFound == false) {
+ $layerStructure[] = $searchLayerId; //pull only parent layerIds
+ $key = array_search($searchLayerId, $layerTreeArray['layer_id']);
+ if (!$key) {
+ $rootLayerFound = true;
+ } else {
+ $parent = $layerTreeArray['layer_parent'][$key];
+ if ($parent == null || $parent == '') {
+ } else {
+ $parentId = $layerTreeArray['layer_id'][array_search($parent, $layerTreeArray['layer_pos'])];
+ $searchLayerId = $parentId;
+ //remove first entry
+ unset($layerStructure[0]);
+ $layerStructure = array_values($layerStructure);
+ //debug*************************************
+ /*foreach ($layerStructure as $singleLayer) {
+ echo $singleLayer."<br>";
+ die();*/
+ if (count($layerStructure) > 0) {
+ $parent_layer_srs_sql = "SELECT DISTINCT epsg FROM layer_epsg WHERE fkey_layer_id IN (".implode(',',$layerStructure).")";
+ $res_parent_layer_srs_sql = db_query($parent_layer_srs_sql);
+ while ($layer_parent_srs_row = db_fetch_array($res_parent_layer_srs_sql)) {
+ //check if already exists
+ if (!in_array(str_replace('epsg','EPSG',$layer_parent_srs_row['epsg']), $origLayerEpsg)) {
+ //$e = new mb_exception("add epsg support from parent layer: ".str_replace('epsg','EPSG',$layer_parent_srs_row['epsg']));
+ $srs = $doc->createElement("SRS");
+ $srs = $layer->appendChild($srs);
+ $srsText = $doc->createTextNode(str_replace('epsg','EPSG',$layer_parent_srs_row['epsg']));
+ $srsText = $srs->appendChild($srsText);
+ } else {
+ //$e = new mb_exception("EPSG from parent layers already defined in sublayer: ".str_replace('epsg','EPSG',$layer_parent_srs_row['epsg']));
"layer_epsg.maxy, layer_epsg.maxx FROM layer_epsg " .
More information about the Mapbender_commits
