[Mapbender-commits] r9470 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Mon May 23 06:52:41 PDT 2016
Author: armin11
Date: 2016-05-23 06:52:41 -0700 (Mon, 23 May 2016)
New Revision: 9470
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
bugfix
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql 2016-05-23 08:59:54 UTC (rev 9469)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql 2016-05-23 13:52:41 UTC (rev 9470)
@@ -953,12 +953,6 @@
ALTER TABLE search_dataset_view
OWNER TO postgres;
-DROP VIEW search_wfs_view;
-CREATE OR REPLACE VIEW search_wfs_view AS
-SELECT wfs_without_geom.wfs_id, wfs_without_geom.wfs_title, wfs_without_geom.wfs_abstract, wfs_without_geom.administrativearea, wfs_without_geom.country, wfs_without_geom.accessconstraints, wfs_without_geom.termsofuse, wfs_without_geom.isopen, wfs_without_geom.wfs_owner, wfs_without_geom.featuretype_id, wfs_without_geom.featuretype_srs, wfs_without_geom.featuretype_title, wfs_without_geom.featuretype_abstract, wfs_without_geom.searchtext, wfs_without_geom.element_type, wfs_without_geom.wfs_conf_id, wfs_without_geom.wfs_conf_abstract, wfs_without_geom.wfs_conf_description, wfs_without_geom.modultype, wfs_without_geom.wfs_timestamp, wfs_without_geom.department, wfs_without_geom.mb_group_name, wfs_without_geom.mb_group_logo_path, wfs_without_geom.wfs_network_access, wfs_without_geom.wfs_pricevolume, wfs_without_geom.wfs_proxylog, wfs_without_geom.featuretype_latlon_bbox, wfs_without_geom.featuretype_latlon_array, geometryfromtext(((((((((((((((((((('POLYGON(('::text || wfs_without_geom
.featuretype_latlon_array[1]) || ' '::text) || wfs_without_geom.featuretype_latlon_array[2]) || ','::text) || wfs_without_geom.featuretype_latlon_array[1]) || ' '::text) || wfs_without_geom.featuretype_latlon_array[4]) || ','::text) || wfs_without_geom.featuretype_latlon_array[3]) || ' '::text) || wfs_without_geom.featuretype_latlon_array[4]) || ','::text) || wfs_without_geom.featuretype_latlon_array[3]) || ' '::text) || wfs_without_geom.featuretype_latlon_array[2]) || ','::text) || wfs_without_geom.featuretype_latlon_array[1]) || ' '::text) || wfs_without_geom.featuretype_latlon_array[2]) || '))'::text, 4326) AS the_geom, (((((wfs_without_geom.featuretype_latlon_array[1] || ','::text) || wfs_without_geom.featuretype_latlon_array[2]) || ','::text) || wfs_without_geom.featuretype_latlon_array[3]) || ','::text) || wfs_without_geom.featuretype_latlon_array[4] AS bbox
- FROM (
--new search wfs view with all featuretypes
More information about the Mapbender_commits
