[Mapbender-commits] r9487 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri May 27 00:11:29 PDT 2016
Author: armin11
Date: 2016-05-27 00:11:28 -0700 (Fri, 27 May 2016)
New Revision: 9487
Removed:
   trunk/mapbender/http/php/apc.php
   trunk/mapbender/http/php/mod_editGuiWmsMeta.php_deprecated
   trunk/mapbender/http/php/mod_export_image.php_deprecated
   trunk/mapbender/http/php/mod_getStyles.php_deprecated
   trunk/mapbender/http/php/mod_layerISOMetadataWriteToFolder.php
   trunk/mapbender/http/php/mod_treefolderAdmin.php_deprecated
   trunk/mapbender/http/php/nestedSets.php_deprecated
Fix wrong commit
Deleted: trunk/mapbender/http/php/apc.php
--- trunk/mapbender/http/php/apc.php	2016-05-27 07:07:37 UTC (rev 9486)
+++ trunk/mapbender/http/php/apc.php	2016-05-27 07:11:28 UTC (rev 9487)
@@ -1,1362 +0,0 @@
-<?php
-  | APC        |
-  | Copyright (c) 2006-2008 The PHP Group                                |
-  | This source file is subject to version 3.01 of the PHP license,      |
-  | that is bundled with this package in the file LICENSE, and is        |
-  | available through the world-wide-web at the following url:           |
-  | http://www.php.net/license/3_01.txt                                  |
-  | If you did not receive a copy of the PHP license and are unable to   |
-  | obtain it through the world-wide-web, please send a note to          |
-  | license at php.net so we can mail you a copy immediately.               |
-  | Authors: Ralf Becker <beckerr at php.net>                               |
-  |          Rasmus Lerdorf <rasmus at php.net>                             |
-  |          Ilia Alshanetsky <ilia at prohost.org>                         |
-   All other licensing and usage conditions are those of the PHP Group.
-$VERSION='$Id: apc.php 271315 2008-12-16 07:15:07Z shire $';
-////////// READ OPTIONAL CONFIGURATION FILE ////////////
-if (file_exists("apc.conf.php")) include("apc.conf.php");
-////////// BEGIN OF DEFAULT CONFIG AREA ///////////////////////////////////////////////////////////
-defaults('USE_AUTHENTICATION',1);			// Use (internal) authentication - best choice if
-											// no other authentication is available
-											// If set to 0:
-											//  There will be no further authentication. You
-											//  will have to handle this by yourself!
-											// If set to 1:
-											//  You need to change ADMIN_PASSWORD to make
-											//  this work!
-defaults('ADMIN_USERNAME','apc'); 			// Admin Username
-defaults('ADMIN_PASSWORD','apc');  	// Admin Password - CHANGE THIS TO ENABLE!!!
-// (beckerr) I'm using a clear text password here, because I've no good idea how to let
-//           users generate a md5 or crypt password in a easy way to fill it in above
-//defaults('DATE_FORMAT', "d.m.Y H:i:s");	// German
-defaults('DATE_FORMAT', 'Y/m/d H:i:s'); 	// US
-defaults('GRAPH_SIZE',200);					// Image size
-//defaults('PROXY', 'tcp://127.0.0.1:8080');
-////////// END OF DEFAULT CONFIG AREA /////////////////////////////////////////////////////////////
-// "define if not defined"
-function defaults($d,$v) {
-	if (!defined($d)) define($d,$v); // or just @define(...)
-// rewrite $PHP_SELF to block XSS attacks
-$PHP_SELF= isset($_SERVER['PHP_SELF']) ? htmlentities(strip_tags($_SERVER['PHP_SELF'],''), ENT_QUOTES, 'UTF-8') : '';
-$time = time();
-$host = php_uname('n');
-if($host) { $host = '('.$host.')'; }
-if ($_SERVER['SERVER_ADDR']) {
-  $host .= ' ('.$_SERVER['SERVER_ADDR'].')';
-// operation constants
-define('OB_HOST_STATS',1);
-define('OB_SYS_CACHE',2);
-define('OB_USER_CACHE',3);
-define('OB_SYS_CACHE_DIR',4);
-define('OB_VERSION_CHECK',9);
-// check validity of input variables
-$vardom=array(
-	'OB'	=> '/^\d+$/',			// operational mode switch
-	'CC'	=> '/^[01]$/',			// clear cache requested
-	'DU'	=> '/^.*$/',			// Delete User Key
-	'SH'	=> '/^[a-z0-9]+$/',		// shared object description
-	'IMG'	=> '/^[123]$/',			// image to generate
-	'LO'	=> '/^1$/',				// login requested
-	'COUNT'	=> '/^\d+$/',			// number of line displayed in list
-	'SCOPE'	=> '/^[AD]$/',			// list view scope
-	'SORT1'	=> '/^[AHSMCDTZ]$/',	// first sort key
-	'SORT2'	=> '/^[DA]$/',			// second sort key
-	'AGGR'	=> '/^\d+$/',			// aggregation by dir level
-	'SEARCH'	=> '~^[a-zA-Z0-1/_.-]*$~'			// aggregation by dir level
-// default cache mode
-$cache_mode='opcode';
-// cache scope
-$scope_list=array(
-	'A' => 'cache_list',
-	'D' => 'deleted_list'
-// handle POST and GET requests
-if (empty($_REQUEST)) {
-	if (!empty($_GET) && !empty($_POST)) {
-		$_REQUEST = array_merge($_GET, $_POST);
-	} else if (!empty($_GET)) {
-		$_REQUEST = $_GET;
-	} else if (!empty($_POST)) {
-		$_REQUEST = $_POST;
-	} else {
-		$_REQUEST = array();
-// check parameter syntax
-foreach($vardom as $var => $dom) {
-	if (!isset($_REQUEST[$var])) {
-		$MYREQUEST[$var]=NULL;
-	} else if (!is_array($_REQUEST[$var]) && preg_match($dom.'D',$_REQUEST[$var])) {
-		$MYREQUEST[$var]=$_REQUEST[$var];
-	} else {
-		$MYREQUEST[$var]=$_REQUEST[$var]=NULL;
-// check parameter sematics
-if (empty($MYREQUEST['SCOPE'])) $MYREQUEST['SCOPE']="A";
-if (empty($MYREQUEST['SORT1'])) $MYREQUEST['SORT1']="H";
-if (empty($MYREQUEST['SORT2'])) $MYREQUEST['SORT2']="D";
-if (empty($MYREQUEST['OB']))	$MYREQUEST['OB']=OB_HOST_STATS;
-if (!isset($MYREQUEST['COUNT'])) $MYREQUEST['COUNT']=20;
-if (!isset($scope_list[$MYREQUEST['SCOPE']])) $MYREQUEST['SCOPE']='A';
-$MY_SELF=
-	"$PHP_SELF".
-	"?SCOPE=".$MYREQUEST['SCOPE'].
-	"&SORT1=".$MYREQUEST['SORT1'].
-	"&SORT2=".$MYREQUEST['SORT2'].
-	"&COUNT=".$MYREQUEST['COUNT'];
-$MY_SELF_WO_SORT=
-	"$PHP_SELF".
-// authentication needed?
-if (!USE_AUTHENTICATION) {
-	$AUTHENTICATED=1;
-} else {
-	$AUTHENTICATED=0;
-	if (ADMIN_PASSWORD!='password' && ($MYREQUEST['LO'] == 1 || isset($_SERVER['PHP_AUTH_USER']))) {
-		if (!isset($_SERVER['PHP_AUTH_USER']) ||
-			!isset($_SERVER['PHP_AUTH_PW']) ||
-			$_SERVER['PHP_AUTH_USER'] != ADMIN_USERNAME ||
-			$_SERVER['PHP_AUTH_PW'] != ADMIN_PASSWORD) {
-			Header("WWW-Authenticate: Basic realm=\"APC Login\"");
-			Header("HTTP/1.0 401 Unauthorized");
-			echo <<<EOB
-				<html><body>
-				<h1>Rejected!</h1>
-				<big>Wrong Username or Password!</big><br/> <br/>
-				<big><a href='$PHP_SELF?OB={$MYREQUEST['OB']}'>Continue...</a></big>
-				</body></html>
-EOB;
-			exit;
-		} else {
-			$AUTHENTICATED=1;
-// select cache mode
-if ($AUTHENTICATED && $MYREQUEST['OB'] == OB_USER_CACHE) {
-	$cache_mode='user';
-// clear cache
-if ($AUTHENTICATED && isset($MYREQUEST['CC']) && $MYREQUEST['CC']) {
-	apc_clear_cache($cache_mode);
-if ($AUTHENTICATED && !empty($MYREQUEST['DU'])) {
-	apc_delete($MYREQUEST['DU']);
-if(!function_exists('apc_cache_info') || !($cache=@apc_cache_info($cache_mode))) {
-	echo "No cache info available.  APC does not appear to be running.";
-  exit;
-$cache_user = apc_cache_info('user', 1);
-$mem=apc_sma_info();
-if(!$cache['num_hits']) { $cache['num_hits']=1; $time++; }  // Avoid division by 0 errors on a cache clear
-// don't cache this page
-header("Cache-Control: no-store, no-cache, must-revalidate");  // HTTP/1.1
-header("Cache-Control: post-check=0, pre-check=0", false);
-header("Pragma: no-cache");                                    // HTTP/1.0
-function duration($ts) {
-    global $time;
-    $years = (int)((($time - $ts)/(7*86400))/52.177457);
-    $rem = (int)(($time-$ts)-($years * 52.177457 * 7 * 86400));
-    $weeks = (int)(($rem)/(7*86400));
-    $days = (int)(($rem)/86400) - $weeks*7;
-    $hours = (int)(($rem)/3600) - $days*24 - $weeks*7*24;
-    $mins = (int)(($rem)/60) - $hours*60 - $days*24*60 - $weeks*7*24*60;
-    $str = '';
-    if($years==1) $str .= "$years year, ";
-    if($years>1) $str .= "$years years, ";
-    if($weeks==1) $str .= "$weeks week, ";
-    if($weeks>1) $str .= "$weeks weeks, ";
-    if($days==1) $str .= "$days day,";
-    if($days>1) $str .= "$days days,";
-    if($hours == 1) $str .= " $hours hour and";
-    if($hours>1) $str .= " $hours hours and";
-    if($mins == 1) $str .= " 1 minute";
-    else $str .= " $mins minutes";
-    return $str;
-// create graphics
-function graphics_avail() {
-	return extension_loaded('gd');
-if (isset($MYREQUEST['IMG']))
-	if (!graphics_avail()) {
-		exit(0);
-	function fill_arc($im, $centerX, $centerY, $diameter, $start, $end, $color1,$color2,$text='',$placeindex=0) {
-		$r=$diameter/2;
-		$w=deg2rad((360+$start+($end-$start)/2)%360);
-		if (function_exists("imagefilledarc")) {
-			// exists only if GD 2.0.1 is avaliable
-			imagefilledarc($im, $centerX+1, $centerY+1, $diameter, $diameter, $start, $end, $color1, IMG_ARC_PIE);
-			imagefilledarc($im, $centerX, $centerY, $diameter, $diameter, $start, $end, $color2, IMG_ARC_PIE);
-			imagefilledarc($im, $centerX, $centerY, $diameter, $diameter, $start, $end, $color1, IMG_ARC_NOFILL|IMG_ARC_EDGED);
-		} else {
-			imagearc($im, $centerX, $centerY, $diameter, $diameter, $start, $end, $color2);
-			imageline($im, $centerX, $centerY, $centerX + cos(deg2rad($start)) * $r, $centerY + sin(deg2rad($start)) * $r, $color2);
-			imageline($im, $centerX, $centerY, $centerX + cos(deg2rad($start+1)) * $r, $centerY + sin(deg2rad($start)) * $r, $color2);
-			imageline($im, $centerX, $centerY, $centerX + cos(deg2rad($end-1))   * $r, $centerY + sin(deg2rad($end))   * $r, $color2);
-			imageline($im, $centerX, $centerY, $centerX + cos(deg2rad($end))   * $r, $centerY + sin(deg2rad($end))   * $r, $color2);
-			imagefill($im,$centerX + $r*cos($w)/2, $centerY + $r*sin($w)/2, $color2);
-		if ($text) {
-			if ($placeindex>0) {
-				imageline($im,$centerX + $r*cos($w)/2, $centerY + $r*sin($w)/2,$diameter, $placeindex*12,$color1);
-				imagestring($im,4,$diameter, $placeindex*12,$text,$color1);
-			} else {
-				imagestring($im,4,$centerX + $r*cos($w)/2, $centerY + $r*sin($w)/2,$text,$color1);
-	function text_arc($im, $centerX, $centerY, $diameter, $start, $end, $color1,$text,$placeindex=0) {
-		$r=$diameter/2;
-		} else {
-	function fill_box($im, $x, $y, $w, $h, $color1, $color2,$text='',$placeindex='') {
-		global $col_black;
-		$x1=$x+$w-1;
-		$y1=$y+$h-1;
-		imagerectangle($im, $x, $y1, $x1+1, $y+1, $col_black);
-		if($y1>$y) imagefilledrectangle($im, $x, $y, $x1, $y1, $color2);
-		else imagefilledrectangle($im, $x, $y1, $x1, $y, $color2);
-		imagerectangle($im, $x, $y1, $x1, $y, $color1);
-		if ($text) {
-				if ($placeindex<16)
-					$px=5;
-					$py=$placeindex*12+6;
-					imagefilledrectangle($im, $px+90, $py+3, $px+90-4, $py-3, $color2);
-					imageline($im,$x,$y+$h/2,$px+90,$py,$color2);
-					imagestring($im,2,$px,$py-6,$text,$color1);
-				} else {
-					if ($placeindex<31) {
-						$px=$x+40*2;
-						$py=($placeindex-15)*12+6;
-					} else {
-						$px=$x+40*2+100*intval(($placeindex-15)/15);
-						$py=($placeindex%15)*12+6;
-					imagefilledrectangle($im, $px, $py+3, $px-4, $py-3, $color2);
-					imageline($im,$x+$w,$y+$h/2,$px,$py,$color2);
-					imagestring($im,2,$px+2,$py-6,$text,$color1);
-			} else {
-				imagestring($im,4,$x+5,$y1-16,$text,$color1);
-	$size = GRAPH_SIZE; // image size
-	if ($MYREQUEST['IMG']==3)
-		$image = imagecreate(2*$size+150, $size+10);
-	else
-		$image = imagecreate($size+50, $size+10);
-	$col_white = imagecolorallocate($image, 0xFF, 0xFF, 0xFF);
-	$col_red   = imagecolorallocate($image, 0xD0, 0x60,  0x30);
-	$col_green = imagecolorallocate($image, 0x60, 0xF0, 0x60);
-	$col_black = imagecolorallocate($image,   0,   0,   0);
-	imagecolortransparent($image,$col_white);
-	switch ($MYREQUEST['IMG']) {
-	case 1:
-		$s=$mem['num_seg']*$mem['seg_size'];
-		$a=$mem['avail_mem'];
-		$x=$y=$size/2;
-		$fuzz = 0.000001;
-		// This block of code creates the pie chart.  It is a lot more complex than you
-		// would expect because we try to visualize any memory fragmentation as well.
-		$angle_from = 0;
-		$string_placement=array();
-		for($i=0; $i<$mem['num_seg']; $i++) {
-			$ptr = 0;
-			$free = $mem['block_lists'][$i];
-			uasort($free, 'block_sort');
-			foreach($free as $block) {
-				if($block['offset']!=$ptr) {       // Used block
-					$angle_to = $angle_from+($block['offset']-$ptr)/$s;
-					if(($angle_to+$fuzz)>1) $angle_to = 1;
-					if( ($angle_to*360) - ($angle_from*360) >= 1) {
-						fill_arc($image,$x,$y,$size,$angle_from*360,$angle_to*360,$col_black,$col_red);
-						if (($angle_to-$angle_from)>0.05) {
-							array_push($string_placement, array($angle_from,$angle_to));
-					$angle_from = $angle_to;
-				$angle_to = $angle_from+($block['size'])/$s;
-					fill_arc($image,$x,$y,$size,$angle_from*360,$angle_to*360,$col_black,$col_green);
-				$ptr = $block['offset']+$block['size'];
-			if ($ptr < $mem['seg_size']) { // memory at the end
-				$angle_to = $angle_from + ($mem['seg_size'] - $ptr)/$s;
-		foreach ($string_placement as $angle) {
-			text_arc($image,$x,$y,$size,$angle[0]*360,$angle[1]*360,$col_black,bsize($s*($angle[1]-$angle[0])));
-		break;
-	case 2:
-		$s=$cache['num_hits']+$cache['num_misses'];
-		$a=$cache['num_hits'];
-		fill_box($image, 30,$size,50,-$a*($size-21)/$s,$col_black,$col_green,sprintf("%.1f%%",$cache['num_hits']*100/$s));
-		fill_box($image,130,$size,50,-max(4,($s-$a)*($size-21)/$s),$col_black,$col_red,sprintf("%.1f%%",$cache['num_misses']*100/$s));
-		break;
-	case 3:
-		$x=130;
-		$y=1;
-		$j=1;
-		// This block of code creates the bar chart.  It is a lot more complex than you
-			$ptr = 0;
-					$h=(GRAPH_SIZE-5)*($block['offset']-$ptr)/$s;
-					if ($h>0) {
-                                                $j++;
-						if($j<75) fill_box($image,$x,$y,50,$h,$col_black,$col_red,bsize($block['offset']-$ptr),$j);
-                                                else fill_box($image,$x,$y,50,$h,$col_black,$col_red);
-					$y+=$h;
-				$h=(GRAPH_SIZE-5)*($block['size'])/$s;
-				if ($h>0) {
-                                        $j++;
-					if($j<75) fill_box($image,$x,$y,50,$h,$col_black,$col_green,bsize($block['size']),$j);
-					else fill_box($image,$x,$y,50,$h,$col_black,$col_green);
-				$y+=$h;
-				$h = (GRAPH_SIZE-5) * ($mem['seg_size'] - $ptr) / $s;
-				if ($h > 0) {
-					fill_box($image,$x,$y,50,$h,$col_black,$col_red,bsize($mem['seg_size']-$ptr),$j++);
-		break;
-	case 4:
-		break;
-	header("Content-type: image/png");
-	imagepng($image);
-	exit;
-// pretty printer for byte values
-function bsize($s) {
-	foreach (array('','K','M','G') as $i => $k) {
-		if ($s < 1024) break;
-		$s/=1024;
-	return sprintf("%5.1f %sBytes",$s,$k);
-// sortable table header in "scripts for this host" view
-function sortheader($key,$name,$extra='') {
-	global $MYREQUEST, $MY_SELF_WO_SORT;
-	if ($MYREQUEST['SORT1']==$key) {
-		$MYREQUEST['SORT2'] = $MYREQUEST['SORT2']=='A' ? 'D' : 'A';
-	return "<a class=sortable href=\"$MY_SELF_WO_SORT$extra&SORT1=$key&SORT2=".$MYREQUEST['SORT2']."\">$name</a>";
-// create menu entry
-function menu_entry($ob,$title) {
-	global $MYREQUEST,$MY_SELF;
-	if ($MYREQUEST['OB']!=$ob) {
-		return "<li><a href=\"$MY_SELF&OB=$ob\">$title</a></li>";
-	} else if (empty($MYREQUEST['SH'])) {
-		return "<li><span class=active>$title</span></li>";
-	} else {
-		return "<li><a class=\"child_active\" href=\"$MY_SELF&OB=$ob\">$title</a></li>";
-function put_login_link($s="Login")
-	global $MY_SELF,$MYREQUEST,$AUTHENTICATED;
-	// needs ADMIN_PASSWORD to be changed!
-	if (!USE_AUTHENTICATION) {
-		return;
-	} else if (ADMIN_PASSWORD=='password')
-		print <<<EOB
-			<a href="#" onClick="javascript:alert('You need to set a password at the top of apc.php before this will work!');return false";>$s</a>
-EOB;
-	} else if ($AUTHENTICATED) {
-		print <<<EOB
-			'{$_SERVER['PHP_AUTH_USER']}' logged in!
-EOB;
-	} else{
-		print <<<EOB
-			<a href="$MY_SELF&LO=1&OB={$MYREQUEST['OB']}">$s</a>
-EOB;
-function block_sort($array1, $array2)
-	if ($array1['offset'] > $array2['offset']) {
-		return 1;
-	} else {
-		return -1;
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head><title>APC INFO <?php echo $host ?></title>
-<style><!--
-body { background:white; font-size:100.01%; margin:0; padding:0; }
-body,p,td,th,input,submit { font-size:0.8em;font-family:arial,helvetica,sans-serif; }
-* html body   {font-size:0.8em}
-* html p      {font-size:0.8em}
-* html td     {font-size:0.8em}
-* html th     {font-size:0.8em}
-* html input  {font-size:0.8em}
-* html submit {font-size:0.8em}
-td { vertical-align:top }
-a { color:black; font-weight:none; text-decoration:none; }
-a:hover { text-decoration:underline; }
-div.content { padding:1em 1em 1em 1em; position:absolute; width:97%; z-index:100; }
-div.head div.login {
-	position:absolute;
-	right: 1em;
-	top: 1.2em;
-	color:white;
-	width:6em;
-div.head div.login a {
-	right: 0em;
-	background:rgb(119,123,180);
-	border:solid rgb(102,102,153) 2px;
-	color:white;
-	font-weight:bold;
-	padding:0.1em 0.5em 0.1em 0.5em;
-	text-decoration:none;
-div.head div.login a:hover {
-	background:rgb(193,193,244);
-h1.apc { background:rgb(153,153,204); margin:0; padding:0.5em 1em 0.5em 1em; }
-* html h1.apc { margin-bottom:-7px; }
-h1.apc a:hover { text-decoration:none; color:rgb(90,90,90); }
-h1.apc div.logo span.logo {
-	color:black;
-	border-right: solid black 1px;
-	border-bottom: solid black 1px;
-	font-style:italic;
-	font-size:1em;
-	padding-left:1.2em;
-	padding-right:1.2em;
-	text-align:right;
-h1.apc div.logo span.name { color:white; font-size:0.7em; padding:0 0.8em 0 2em; }
-h1.apc div.nameinfo { color:white; display:inline; font-size:0.4em; margin-left: 3em; }
-h1.apc div.copy { color:black; font-size:0.4em; position:absolute; right:1em; }
-hr.apc {
-	background:white;
-	border-bottom:solid rgb(102,102,153) 1px;
-	border-style:none;
-	border-top:solid rgb(102,102,153) 10px;
-	height:12px;
-	margin:0;
-	margin-top:1px;
-	padding:0;
-ol,menu { margin:1em 0 0 0; padding:0.2em; margin-left:1em;}
-ol.menu li { display:inline; margin-right:0.7em; list-style:none; font-size:85%}
-ol.menu a {
-	background:rgb(153,153,204);
-	color:white;
-	font-weight:bold;
-	margin-right:0em;
-	margin-left: 5px;
-ol.menu a.child_active {
-	color:white;
-	font-weight:bold;
-	margin-right:0em;
-	border-left: solid black 5px;
-	margin-left: 0px;
-ol.menu span.active {
-	color:black;
-	font-weight:bold;
-	margin-right:0em;
-ol.menu span.inactive {
-	border:solid rgb(182,182,233) 2px;
-	color:white;
-	font-weight:bold;
-	margin-right:0em;
-	margin-left: 5px;
-ol.menu a:hover {
-div.info {
-	background:rgb(204,204,204);
-	border:solid rgb(204,204,204) 1px;
-	margin-bottom:1em;
-div.info h2 {
-	color:black;
-	font-size:1em;
-	margin:0;
-	padding:0.1em 1em 0.1em 1em;
-div.info table {
-	border-spacing:0;
-	width:100%;
-div.info table th {
-	color:white;
-	margin:0;
-div.info table th a.sortable { color:black; }
-div.info table tr.tr-0 { background:rgb(238,238,238); }
-div.info table tr.tr-1 { background:rgb(221,221,221); }
-div.info table td { padding:0.3em 1em 0.3em 1em; }
-div.info table td.td-0 { border-right:solid rgb(102,102,153) 1px; white-space:nowrap; }
-div.info table td.td-n { border-right:solid rgb(102,102,153) 1px; }
-div.info table td h3 {
-	color:black;
-	font-size:1.1em;
-	margin-left:-0.3em;
-div.graph { margin-bottom:1em }
-div.graph h2 { background:rgb(204,204,204);; color:black; font-size:1em; margin:0; padding:0.1em 1em 0.1em 1em; }
-div.graph table { border:solid rgb(204,204,204) 1px; color:black; font-weight:normal; width:100%; }
-div.graph table td.td-0 { background:rgb(238,238,238); }
-div.graph table td.td-1 { background:rgb(221,221,221); }
-div.graph table td { padding:0.2em 1em 0.4em 1em; }
-div.div1,div.div2 { margin-bottom:1em; width:35em; }
-div.div3 { position:absolute; left:40em; top:1em; width:580px; }
-//div.div3 { position:absolute; left:37em; top:1em; right:1em; }
-div.sorting { margin:1.5em 0em 1.5em 2em }
-.center { text-align:center }
-.aright { position:absolute;right:1em }
-.right { text-align:right }
-.ok { color:rgb(0,200,0); font-weight:bold}
-.failed { color:rgb(200,0,0); font-weight:bold}
-span.box {
-	border: black solid 1px;
-	border-right:solid black 2px;
-	border-bottom:solid black 2px;
-	padding:0 0.5em 0 0.5em;
-	margin-right:1em;
-span.green { background:#60F060; padding:0 0.5em 0 0.5em}
-span.red { background:#D06030; padding:0 0.5em 0 0.5em }
-div.authneeded {
-	background:rgb(238,238,238);
-	color:rgb(200,0,0);
-	font-size:1.2em;
-	font-weight:bold;
-	padding:2em;
-	text-align:center;
-input {
-	color:white;
-	font-weight:bold;
-	margin-right:1em;
-</style>
-</head>
-<body>
-<div class="head">
-	<h1 class="apc">
-		<div class="logo"><span class="logo"><a href="http://pecl.php.net/package/APC">APC</a></span></div>
-		<div class="nameinfo">Opcode Cache</div>
-	</h1>
-	<div class="login">
-	<?php put_login_link(); ?>
-	</div>
-	<hr class="apc">
-</div>
-<?php
-// Display main Menu
-echo <<<EOB
-	<ol class=menu>
-	<li><a href="$MY_SELF&OB={$MYREQUEST['OB']}&SH={$MYREQUEST['SH']}">Refresh Data</a></li>
-EOB;
-echo
-	menu_entry(1,'View Host Stats'),
-	menu_entry(2,'System Cache Entries');
-if ($AUTHENTICATED) {
-	echo menu_entry(4,'Per-Directory Entries');
-echo
-	menu_entry(3,'User Cache Entries'),
-	menu_entry(9,'Version Check');
-	echo <<<EOB
-		<li><a class="aright" href="$MY_SELF&CC=1&OB={$MYREQUEST['OB']}" onClick="javascipt:return confirm('Are you sure?');">Clear $cache_mode Cache</a></li>
-EOB;
-echo <<<EOB
-	</ol>
-EOB;
-// CONTENT
-echo <<<EOB
-	<div class=content>
-EOB;
-// MAIN SWITCH STATEMENT
-switch ($MYREQUEST['OB']) {
-// Host Stats
-case OB_HOST_STATS:
-	$mem_size = $mem['num_seg']*$mem['seg_size'];
-	$mem_avail= $mem['avail_mem'];
-	$mem_used = $mem_size-$mem_avail;
-	$seg_size = bsize($mem['seg_size']);
-	$req_rate = sprintf("%.2f",($cache['num_hits']+$cache['num_misses'])/($time-$cache['start_time']));
-	$hit_rate = sprintf("%.2f",($cache['num_hits'])/($time-$cache['start_time']));
-	$miss_rate = sprintf("%.2f",($cache['num_misses'])/($time-$cache['start_time']));
-	$insert_rate = sprintf("%.2f",($cache['num_inserts'])/($time-$cache['start_time']));
-	$req_rate_user = sprintf("%.2f",($cache_user['num_hits']+$cache_user['num_misses'])/($time-$cache_user['start_time']));
-	$hit_rate_user = sprintf("%.2f",($cache_user['num_hits'])/($time-$cache_user['start_time']));
-	$miss_rate_user = sprintf("%.2f",($cache_user['num_misses'])/($time-$cache_user['start_time']));
-	$insert_rate_user = sprintf("%.2f",($cache_user['num_inserts'])/($time-$cache_user['start_time']));
-	$apcversion = phpversion('apc');
-	$phpversion = phpversion();
-	$number_files = $cache['num_entries'];
-    $size_files = bsize($cache['mem_size']);
-	$number_vars = $cache_user['num_entries'];
-    $size_vars = bsize($cache_user['mem_size']);
-	$i=0;
-	echo <<< EOB
-		<div class="info div1"><h2>General Cache Information</h2>
-		<table cellspacing=0><tbody>
-		<tr class=tr-0><td class=td-0>APC Version</td><td>$apcversion</td></tr>
-		<tr class=tr-1><td class=td-0>PHP Version</td><td>$phpversion</td></tr>
-EOB;
-	if(!empty($_SERVER['SERVER_NAME']))
-		echo "<tr class=tr-0><td class=td-0>APC Host</td><td>{$_SERVER['SERVER_NAME']} $host</td></tr>\n";
-	if(!empty($_SERVER['SERVER_SOFTWARE']))
-		echo "<tr class=tr-1><td class=td-0>Server Software</td><td>{$_SERVER['SERVER_SOFTWARE']}</td></tr>\n";
-	echo <<<EOB
-		<tr class=tr-0><td class=td-0>Shared Memory</td><td>{$mem['num_seg']} Segment(s) with $seg_size
-    <br/> ({$cache['memory_type']} memory, {$cache['locking_type']} locking)
-    </td></tr>
-EOB;
-	echo   '<tr class=tr-1><td class=td-0>Start Time</td><td>',date(DATE_FORMAT,$cache['start_time']),'</td></tr>';
-	echo   '<tr class=tr-0><td class=td-0>Uptime</td><td>',duration($cache['start_time']),'</td></tr>';
-	echo   '<tr class=tr-1><td class=td-0>File Upload Support</td><td>',$cache['file_upload_progress'],'</td></tr>';
-	echo <<<EOB
-		</tbody></table>
-		</div>
-		<div class="info div1"><h2>File Cache Information</h2>
-		<tr class=tr-0><td class=td-0>Cached Files</td><td>$number_files ($size_files)</td></tr>
-		<tr class=tr-1><td class=td-0>Hits</td><td>{$cache['num_hits']}</td></tr>
-		<tr class=tr-0><td class=td-0>Misses</td><td>{$cache['num_misses']}</td></tr>
-		<tr class=tr-1><td class=td-0>Request Rate (hits, misses)</td><td>$req_rate cache requests/second</td></tr>
-		<tr class=tr-0><td class=td-0>Hit Rate</td><td>$hit_rate cache requests/second</td></tr>
-		<tr class=tr-1><td class=td-0>Miss Rate</td><td>$miss_rate cache requests/second</td></tr>
-		<tr class=tr-0><td class=td-0>Insert Rate</td><td>$insert_rate cache requests/second</td></tr>
-		<tr class=tr-1><td class=td-0>Cache full count</td><td>{$cache['expunges']}</td></tr>
-		</tbody></table>
-		</div>
-		<div class="info div1"><h2>User Cache Information</h2>
-    <tr class=tr-0><td class=td-0>Cached Variables</td><td>$number_vars ($size_vars)</td></tr>
-		<tr class=tr-1><td class=td-0>Hits</td><td>{$cache_user['num_hits']}</td></tr>
-		<tr class=tr-0><td class=td-0>Misses</td><td>{$cache_user['num_misses']}</td></tr>
-		<tr class=tr-1><td class=td-0>Request Rate (hits, misses)</td><td>$req_rate_user cache requests/second</td></tr>
-		<tr class=tr-0><td class=td-0>Hit Rate</td><td>$hit_rate_user cache requests/second</td></tr>
-		<tr class=tr-1><td class=td-0>Miss Rate</td><td>$miss_rate_user cache requests/second</td></tr>
-		<tr class=tr-0><td class=td-0>Insert Rate</td><td>$insert_rate_user cache requests/second</td></tr>
-		<tr class=tr-1><td class=td-0>Cache full count</td><td>{$cache_user['expunges']}</td></tr>
-		</tbody></table>
-		</div>
-		<div class="info div2"><h2>Runtime Settings</h2><table cellspacing=0><tbody>
-EOB;
-	$j = 0;
-	foreach (ini_get_all('apc') as $k => $v) {
-		echo "<tr class=tr-$j><td class=td-0>",$k,"</td><td>",str_replace(',',',<br />',$v['local_value']),"</td></tr>\n";
-		$j = 1 - $j;
-	if($mem['num_seg']>1 || $mem['num_seg']==1 && count($mem['block_lists'][0])>1)
-		$mem_note = "Memory Usage<br /><font size=-2>(multiple slices indicate fragments)</font>";
-	else
-		$mem_note = "Memory Usage";
-	echo <<< EOB
-		</tbody></table>
-		</div>
-		<div class="graph div3"><h2>Host Status Diagrams</h2>
-EOB;
-	$size='width='.(GRAPH_SIZE+50).' height='.(GRAPH_SIZE+10);
-	echo <<<EOB
-		<tr>
-		<td class=td-0>$mem_note</td>
-		<td class=td-1>Hits & Misses</td>
-		</tr>
-EOB;
-	echo
-		graphics_avail() ?
-			  '<tr>'.
-			  "<td class=td-0><img alt=\"\" $size src=\"$PHP_SELF?IMG=1&$time\"></td>".
-			  "<td class=td-1><img alt=\"\" $size src=\"$PHP_SELF?IMG=2&$time\"></td></tr>\n"
-		'<tr>',
-		'<td class=td-0><span class="green box"> </span>Free: ',bsize($mem_avail).sprintf(" (%.1f%%)",$mem_avail*100/$mem_size),"</td>\n",
-		'<td class=td-1><span class="green box"> </span>Hits: ',$cache['num_hits'].sprintf(" (%.1f%%)",$cache['num_hits']*100/($cache['num_hits']+$cache['num_misses'])),"</td>\n",
-		'</tr>',
-		'<tr>',
-		'<td class=td-0><span class="red box"> </span>Used: ',bsize($mem_used ).sprintf(" (%.1f%%)",$mem_used *100/$mem_size),"</td>\n",
-		'<td class=td-1><span class="red box"> </span>Misses: ',$cache['num_misses'].sprintf(" (%.1f%%)",$cache['num_misses']*100/($cache['num_hits']+$cache['num_misses'])),"</td>\n";
-	echo <<< EOB
-		</tr>
-		</tbody></table>
-		<br/>
-		<h2>Detailed Memory Usage and Fragmentation</h2>
-		<tr>
-		<td class=td-0 colspan=2><br/>
-EOB;
-	// Fragementation: (freeseg - 1) / total_seg
-	$nseg = $freeseg = $fragsize = $freetotal = 0;
-		$ptr = 0;
-		foreach($mem['block_lists'][$i] as $block) {
-			if ($block['offset'] != $ptr) {
-				++$nseg;
-			$ptr = $block['offset'] + $block['size'];
-                        /* Only consider blocks <5M for the fragmentation % */
-                        if($block['size']<(5*1024*1024)) $fragsize+=$block['size'];
-                        $freetotal+=$block['size'];
-		$freeseg += count($mem['block_lists'][$i]);
-	if ($freeseg > 1) {
-		$frag = sprintf("%.2f%% (%s out of %s in %d fragments)", ($fragsize/$freetotal)*100,bsize($fragsize),bsize($freetotal),$freeseg);
-	} else {
-		$frag = "0%";
-	if (graphics_avail()) {
-		$size='width='.(2*GRAPH_SIZE+150).' height='.(GRAPH_SIZE+10);
-		echo <<<EOB
-			<img alt="" $size src="$PHP_SELF?IMG=3&$time">
-EOB;
-	echo <<<EOB
-		</br>Fragmentation: $frag
-		</td>
-		</tr>
-EOB;
-        if(isset($mem['adist'])) {
-          foreach($mem['adist'] as $i=>$v) {
-            $cur = pow(2,$i); $nxt = pow(2,$i+1)-1;
-            if($i==0) $range = "1";
-            else $range = "$cur - $nxt";
-            echo "<tr><th align=right>$range</th><td align=right>$v</td></tr>\n";
-        echo <<<EOB
-		</tbody></table>
-		</div>
-EOB;
-	break;
-// User Cache Entries
-case OB_USER_CACHE:
-	if (!$AUTHENTICATED) {
-    echo '<div class="error">You need to login to see the user values here!<br/> <br/>';
-		put_login_link("Login now!");
-		echo '</div>';
-		break;
-	$fieldname='info';
-	$fieldheading='User Entry Label';
-	$fieldkey='info';
-// System Cache Entries
-case OB_SYS_CACHE:
-	if (!isset($fieldname))
-		$fieldname='filename';
-		$fieldheading='Script Filename';
-		if(ini_get("apc.stat")) $fieldkey='inode';
-		else $fieldkey='filename';
-	if (!empty($MYREQUEST['SH']))
-		echo <<< EOB
-			<div class="info"><table cellspacing=0><tbody>
-			<tr><th>Attribute</th><th>Value</th></tr>
-EOB;
-		$m=0;
-		foreach($scope_list as $j => $list) {
-			foreach($cache[$list] as $i => $entry) {
-				if (md5($entry[$fieldkey])!=$MYREQUEST['SH']) continue;
-				foreach($entry as $k => $value) {
-						// hide all path entries if not logged in
-						$value=preg_replace('/^.*(\\/|\\\\)/','<i><hidden></i>/',$value);
-					if ($k == "num_hits") {
-						$value=sprintf("%s (%.2f%%)",$value,$value*100/$cache['num_hits']);
-					if ($k == 'deletion_time') {
-						if(!$entry['deletion_time']) $value = "None";
-					echo
-						"<tr class=tr-$m>",
-						"<td class=td-0>",ucwords(preg_replace("/_/"," ",$k)),"</td>",
-						"<td class=td-last>",(preg_match("/time/",$k) && $value!='None') ? date(DATE_FORMAT,$value) : $value,"</td>",
-						"</tr>";
-					$m=1-$m;
-				if($fieldkey=='info') {
-					echo "<tr class=tr-$m><td class=td-0>Stored Value</td><td class=td-last><pre>";
-					$output = var_export(apc_fetch($entry[$fieldkey]),true);
-					echo htmlspecialchars($output);
-					echo "</pre></td></tr>\n";
-				break;
-		echo <<<EOB
-			</tbody></table>
-			</div>
-EOB;
-		break;
-	$cols=6;
-	echo <<<EOB
-		<div class=sorting><form>Scope:
-		<input type=hidden name=OB value={$MYREQUEST['OB']}>
-		<select name=SCOPE>
-EOB;
-	echo
-		"<option value=A",$MYREQUEST['SCOPE']=='A' ? " selected":"",">Active</option>",
-		"<option value=D",$MYREQUEST['SCOPE']=='D' ? " selected":"",">Deleted</option>",
-		"</select>",
-		", Sorting:<select name=SORT1>",
-		"<option value=H",$MYREQUEST['SORT1']=='H' ? " selected":"",">Hits</option>",
-		"<option value=Z",$MYREQUEST['SORT1']=='Z' ? " selected":"",">Size</option>",
-		"<option value=S",$MYREQUEST['SORT1']=='S' ? " selected":"",">$fieldheading</option>",
-		"<option value=A",$MYREQUEST['SORT1']=='A' ? " selected":"",">Last accessed</option>",
-		"<option value=M",$MYREQUEST['SORT1']=='M' ? " selected":"",">Last modified</option>",
-		"<option value=C",$MYREQUEST['SORT1']=='C' ? " selected":"",">Created at</option>",
-		"<option value=D",$MYREQUEST['SORT1']=='D' ? " selected":"",">Deleted at</option>";
-	if($fieldname=='info') echo
-		"<option value=D",$MYREQUEST['SORT1']=='T' ? " selected":"",">Timeout</option>";
-	echo
-		'</select>',
-		'<select name=SORT2>',
-		'<option value=D',$MYREQUEST['SORT2']=='D' ? ' selected':'','>DESC</option>',
-		'<option value=A',$MYREQUEST['SORT2']=='A' ? ' selected':'','>ASC</option>',
-		'</select>',
-		'<select name=COUNT onChange="form.submit()">',
-		'<option value=10 ',$MYREQUEST['COUNT']=='10' ? ' selected':'','>Top 10</option>',
-		'<option value=20 ',$MYREQUEST['COUNT']=='20' ? ' selected':'','>Top 20</option>',
-		'<option value=50 ',$MYREQUEST['COUNT']=='50' ? ' selected':'','>Top 50</option>',
-		'<option value=100',$MYREQUEST['COUNT']=='100'? ' selected':'','>Top 100</option>',
-		'<option value=150',$MYREQUEST['COUNT']=='150'? ' selected':'','>Top 150</option>',
-		'<option value=200',$MYREQUEST['COUNT']=='200'? ' selected':'','>Top 200</option>',
-		'<option value=500',$MYREQUEST['COUNT']=='500'? ' selected':'','>Top 500</option>',
-		'<option value=0  ',$MYREQUEST['COUNT']=='0'  ? ' selected':'','>All</option>',
-		'</select>',
-    '  Search: <input name=SEARCH value="',$MYREQUEST['SEARCH'],'" type=text size=25/>',
-		' <input type=submit value="GO!">',
-		'</form></div>';
-  if (isset($MYREQUEST['SEARCH'])) {
-   // Don't use preg_quote because we want the user to be able to specify a
-   // regular expression subpattern.
-   $MYREQUEST['SEARCH'] = '/'.str_replace('/', '\\/', $MYREQUEST['SEARCH']).'/i';
-   if (preg_match($MYREQUEST['SEARCH'], 'test') === false) {
-     echo '<div class="error">Error: enter a valid regular expression as a search query.</div>';
-     break;
-  echo
-		'<div class="info"><table cellspacing=0><tbody>',
-		'<tr>',
-		'<th>',sortheader('S',$fieldheading,  "&OB=".$MYREQUEST['OB']),'</th>',
-		'<th>',sortheader('H','Hits',         "&OB=".$MYREQUEST['OB']),'</th>',
-		'<th>',sortheader('Z','Size',         "&OB=".$MYREQUEST['OB']),'</th>',
-		'<th>',sortheader('A','Last accessed',"&OB=".$MYREQUEST['OB']),'</th>',
-		'<th>',sortheader('M','Last modified',"&OB=".$MYREQUEST['OB']),'</th>',
-		'<th>',sortheader('C','Created at',   "&OB=".$MYREQUEST['OB']),'</th>';
-	if($fieldname=='info') {
-		$cols+=2;
-		 echo '<th>',sortheader('T','Timeout',"&OB=".$MYREQUEST['OB']),'</th>';
-	echo '<th>',sortheader('D','Deleted at',"&OB=".$MYREQUEST['OB']),'</th></tr>';
-	// builds list with alpha numeric sortable keys
-	$list = array();
-	foreach($cache[$scope_list[$MYREQUEST['SCOPE']]] as $i => $entry) {
-		switch($MYREQUEST['SORT1']) {
-			case 'A': $k=sprintf('%015d-',$entry['access_time']); 	break;
-			case 'H': $k=sprintf('%015d-',$entry['num_hits']); 		break;
-			case 'Z': $k=sprintf('%015d-',$entry['mem_size']); 		break;
-			case 'M': $k=sprintf('%015d-',$entry['mtime']);			break;
-			case 'C': $k=sprintf('%015d-',$entry['creation_time']);	break;
-			case 'T': $k=sprintf('%015d-',$entry['ttl']);			break;
-			case 'D': $k=sprintf('%015d-',$entry['deletion_time']);	break;
-			case 'S': $k='';										break;
-			$list[$k.$entry[$fieldname]]=preg_replace('/^.*(\\/|\\\\)/','*hidden*/',$entry);
-		} else {
-			$list[$k.$entry[$fieldname]]=$entry;
-	if ($list) {
-		// sort list
-		switch ($MYREQUEST['SORT2']) {
-			case "A":	krsort($list);	break;
-			case "D":	ksort($list);	break;
-		// output list
-		$i=0;
-		foreach($list as $k => $entry) {
-      if(!$MYREQUEST['SEARCH'] || preg_match($MYREQUEST['SEARCH'], $entry[$fieldname]) != 0) {
-        $field_value = htmlentities(strip_tags($entry[$fieldname],''), ENT_QUOTES, 'UTF-8');
-        echo
-          '<tr class=tr-',$i%2,'>',
-          "<td class=td-0><a href=\"$MY_SELF&OB=",$MYREQUEST['OB'],"&SH=",md5($entry[$fieldkey]),"\">",$field_value,'</a></td>',
-          '<td class="td-n center">',$entry['num_hits'],'</td>',
-          '<td class="td-n right">',$entry['mem_size'],'</td>',
-          '<td class="td-n center">',date(DATE_FORMAT,$entry['access_time']),'</td>',
-          '<td class="td-n center">',date(DATE_FORMAT,$entry['mtime']),'</td>',
-          '<td class="td-n center">',date(DATE_FORMAT,$entry['creation_time']),'</td>';
-          if($entry['ttl'])
-            echo '<td class="td-n center">'.$entry['ttl'].' seconds</td>';
-          else
-            echo '<td class="td-n center">None</td>';
-        if ($entry['deletion_time']) {
-          echo '<td class="td-last center">', date(DATE_FORMAT,$entry['deletion_time']), '</td>';
-        } else if ($MYREQUEST['OB'] == OB_USER_CACHE) {
-          echo '<td class="td-last center">';
-          echo '[<a href="', $MY_SELF, '&OB=', $MYREQUEST['OB'], '&DU=', urlencode($entry[$fieldkey]), '">Delete Now</a>]';
-          echo '</td>';
-        } else {
-          echo '<td class="td-last center">   </td>';
-        echo '</tr>';
-        $i++;
-        if ($i == $MYREQUEST['COUNT'])
-          break;
-	} else {
-		echo '<tr class=tr-0><td class="center" colspan=',$cols,'><i>No data</i></td></tr>';
-	echo <<< EOB
-		</tbody></table>
-EOB;
-	if ($list && $i < count($list)) {
-		echo "<a href=\"$MY_SELF&OB=",$MYREQUEST['OB'],"&COUNT=0\"><i>",count($list)-$i,' more available...</i></a>';
-	echo <<< EOB
-		</div>
-EOB;
-	break;
-// Per-Directory System Cache Entries
-case OB_SYS_CACHE_DIR:
-		break;
-	echo <<<EOB
-EOB;
-	echo
-		"</select>",
-		"<option value=H",$MYREQUEST['SORT1']=='H' ? " selected":"",">Total Hits</option>",
-		"<option value=Z",$MYREQUEST['SORT1']=='Z' ? " selected":"",">Total Size</option>",
-		"<option value=T",$MYREQUEST['SORT1']=='T' ? " selected":"",">Number of Files</option>",
-		"<option value=S",$MYREQUEST['SORT1']=='S' ? " selected":"",">Directory Name</option>",
-		"<option value=A",$MYREQUEST['SORT1']=='A' ? " selected":"",">Avg. Size</option>",
-		"<option value=C",$MYREQUEST['SORT1']=='C' ? " selected":"",">Avg. Hits</option>",
-		'</select>',
-		'</select>',
-		'</select>',
-		", Group By Dir Level:<select name=AGGR>",
-		"<option value='' selected>None</option>";
-		for ($i = 1; $i < 10; $i++)
-			echo "<option value=$i",$MYREQUEST['AGGR']==$i ? " selected":"",">$i</option>";
-		echo '</select>',
-		'</form></div>',
-		'<tr>',
-		'<th>',sortheader('S','Directory Name',	"&OB=".$MYREQUEST['OB']),'</th>',
-		'<th>',sortheader('T','Number of Files',"&OB=".$MYREQUEST['OB']),'</th>',
-		'<th>',sortheader('H','Total Hits',	"&OB=".$MYREQUEST['OB']),'</th>',
-		'<th>',sortheader('Z','Total Size',	"&OB=".$MYREQUEST['OB']),'</th>',
-		'<th>',sortheader('C','Avg. Hits',	"&OB=".$MYREQUEST['OB']),'</th>',
-		'<th>',sortheader('A','Avg. Size',	"&OB=".$MYREQUEST['OB']),'</th>',
-		'</tr>';
-	$tmp = $list = array();
-	foreach($cache[$scope_list[$MYREQUEST['SCOPE']]] as $entry) {
-		$n = dirname($entry['filename']);
-		if ($MYREQUEST['AGGR'] > 0) {
-			$n = preg_replace("!^(/?(?:[^/\\\\]+[/\\\\]){".($MYREQUEST['AGGR']-1)."}[^/\\\\]*).*!", "$1", $n);
-		if (!isset($tmp[$n])) {
-			$tmp[$n] = array('hits'=>0,'size'=>0,'ents'=>0);
-		$tmp[$n]['hits'] += $entry['num_hits'];
-		$tmp[$n]['size'] += $entry['mem_size'];
-		++$tmp[$n]['ents'];
-	foreach ($tmp as $k => $v) {
-			case 'A': $kn=sprintf('%015d-',$v['size'] / $v['ents']);break;
-			case 'T': $kn=sprintf('%015d-',$v['ents']);		break;
-			case 'H': $kn=sprintf('%015d-',$v['hits']);		break;
-			case 'Z': $kn=sprintf('%015d-',$v['size']);		break;
-			case 'C': $kn=sprintf('%015d-',$v['hits'] / $v['ents']);break;
-			case 'S': $kn = $k;					break;
-		$list[$kn.$k] = array($k, $v['ents'], $v['hits'], $v['size']);
-	if ($list) {
-		// sort list
-		// output list
-		$i = 0;
-		foreach($list as $entry) {
-			echo
-				"<td class=td-0>",$entry[0],'</a></td>',
-				'<td class="td-n center">',$entry[1],'</td>',
-				'<td class="td-n center">',$entry[2],'</td>',
-				'<td class="td-n center">',$entry[3],'</td>',
-				'<td class="td-n center">',round($entry[2] / $entry[1]),'</td>',
-				'<td class="td-n center">',round($entry[3] / $entry[1]),'</td>',
-				'</tr>';
-			if (++$i == $MYREQUEST['COUNT']) break;
-	} else {
-		echo '<tr class=tr-0><td class="center" colspan=6><i>No data</i></td></tr>';
-	echo <<< EOB
-		</tbody></table>
-EOB;
-	echo <<< EOB
-		</div>
-EOB;
-	break;
-// Version check
-case OB_VERSION_CHECK:
-	echo <<<EOB
-		<div class="info"><h2>APC Version Information</h2>
-		<tr>
-		<th></th>
-		</tr>
-EOB;
-  if (defined('PROXY')) {
-    $ctxt = stream_context_create( array( 'http' => array( 'proxy' => PROXY, 'request_fulluri' => True ) ) );
-    $rss = @file_get_contents("http://pecl.php.net/feeds/pkg_apc.rss", False, $ctxt);
-  } else {
-    $rss = @file_get_contents("http://pecl.php.net/feeds/pkg_apc.rss");
-	if (!$rss) {
-		echo '<tr class="td-last center"><td>Unable to fetch version information.</td></tr>';
-	} else {
-		preg_match('!<title>APC ([0-9.]+)</title>!', $rss, $match);
-		echo '<tr class="tr-0 center"><td>';
-		if (version_compare($apcversion, $match[1], '>=')) {
-			echo '<div class="ok">You are running the latest version of APC ('.$apcversion.')</div>';
-			$i = 3;
-		} else {
-			echo '<div class="failed">You are running an older version of APC ('.$apcversion.'),
-				newer version '.$match[1].' is available at <a href="http://pecl.php.net/package/APC/'.$match[1].'">
-				http://pecl.php.net/package/APC/'.$match[1].'</a>
-				</div>';
-			$i = -1;
-		echo '</td></tr>';
-		echo '<tr class="tr-0"><td><h3>Change Log:</h3><br/>';
-		preg_match_all('!<(title|description)>([^<]+)</\\1>!', $rss, $match);
-		next($match[2]); next($match[2]);
-		while (list(,$v) = each($match[2])) {
-			list(,$ver) = explode(' ', $v, 2);
-			if ($i < 0 && version_compare($apcversion, $ver, '>=')) {
-				break;
-			} else if (!$i--) {
-				break;
-			echo "<b><a href=\"http://pecl.php.net/package/APC/$ver\">".htmlspecialchars($v)."</a></b><br><blockquote>";
-			echo nl2br(htmlspecialchars(current($match[2])))."</blockquote>";
-			next($match[2]);
-	echo <<< EOB
-		</tbody></table>
-		</div>
-EOB;
-	break;
-echo <<< EOB
-	</div>
-EOB;
-<!-- <?php echo "\nBased on APCGUI By R.Becker\n$VERSION\n"?> -->
-</body>
-</html>
Deleted: trunk/mapbender/http/php/mod_editGuiWmsMeta.php_deprecated
--- trunk/mapbender/http/php/mod_editGuiWmsMeta.php_deprecated	2016-05-27 07:07:37 UTC (rev 9486)
+++ trunk/mapbender/http/php/mod_editGuiWmsMeta.php_deprecated	2016-05-27 07:11:28 UTC (rev 9487)
@@ -1,190 +0,0 @@
-<?php
-# $Id: mod_editGuiWmsMeta.php 7097 2010-11-08 07:48:25Z apour $
-# http://www.mapbender.org/index.php/mod_editGuiWmsMeta.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
- * @security_patch irv open
-// security_patch_log(__FILE__,__LINE__);
-import_request_variables("PG");
-include(dirname(__FILE__)."/../php/mb_validateSession.php");
-<html>
-<head>
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Edit WMS Meta Data</title>
-<?php
-include '../include/dyn_css.php';
-<style type="text/css">
-   body{
-      background-color: #ffffff;
-      font-family: Arial, Helvetica, sans-serif;
-      font-size : 12px;
-      color: #808080
-   .guiList1{
-   	top:30px;
-   	left:10px;
-   	width:200px
-   .buttonbar{
-   	top:40px;
-   	left:10px;
-   .guiList1_text{
-   	top:10px;
-   	left:10px;
-      font-size:16px;
-      color: #0066cc;
-   .guiList2{
-   	top:40px;
-   	left:400px;
-   	width:200px
-   .all{
-   	top:38px;
-   	left:610px;
-   .guiList2_header{
-   	top:10px;
-   	left:400px;
-      font-size:16px;
-      color: #0066cc;
-   .myElements{
-   	top:70px;
-   	left:400px;
-   .myTable{
-   	border: 1px solid;
-      font-size: 11px;
-   .myForm{
-   	top:70px;
-   	left:10px;
-   .textfield{
-      width:277px
-   .textfield_small{
-      width:150px
-   .on{
-      color: #0066cc;
-</style>
-<script type="text/javascript">
-   function windowSize() {
-      window.resizeTo(800,500)
-      window.moveTo(130,200)
-   function windowQuit() {
-      window.close()
-</script>
-   </head>
-   <body onload='windowSize()'>
-<?php
-   echo "      <form name='editMetaData' action='".$self."' method='get'>\n";
-   $layer_id   = $_REQUEST["layer_id"];
-   if ( isset($_REQUEST["function"] ) ) {
-      $function = $_REQUEST["function"];
-      if ( $function = "update" ) {
-         $sql = "UPDATE layer SET layer_meta_datum = $1, ";
-         $sql.= "layer_meta_lieferant = $2, ";
-         $sql.= "layer_meta_quelle = $3, ";
-         $sql.= "layer_meta_ansprechpartner = $4, ";
-         $sql.= "layer_meta_lieferant_basis = $5, ";
-         $sql.= "layer_meta_copyright = $6 ";
-         $sql.= " WHERE layer_id = $7;";
-         $v = array($_REQUEST["layer_meta_datum"], $_REQUEST["layer_meta_lieferant"], $_REQUEST["layer_meta_quelle"], $_REQUEST["layer_meta_ansprechpartner"], $_REQUEST["layer_meta_lieferant_basis"], $_REQUEST["layer_meta_copyright"], $layer_id);
-         $t = array("s", "s", "s", "s", "s", "s", "i");
-         $res = db_prep_query($sql, $v, $t);
-   $sql = "SELECT * FROM layer WHERE layer_id = $1;";
-   $v = array($layer_id);
-   $t = array("i");
-   if ( db_fetch_row($res, 0) ) {
-   	  echo "         <h3>Editieren von Metadaten</h3>\n";
-      echo "         <table class='myTable' border='1' cellpadding='2'>\n";
-      echo "            <tr>\n";
-      echo "               <td >Aktualisierungsdatum</td>\n";
-      echo "               <td><input name='layer_meta_datum' type='text' size='100' value='".db_result($res, 0, "layer_meta_datum")."'></td>\n";
-      echo "            </tr>\n";
-      echo "            <tr>\n";
-      echo "               <td>Datenlieferant</td>\n";
-      echo "               <td><input name='layer_meta_lieferant' type='text' size='100' value='".db_result($res, 0, "layer_meta_lieferant")."'></td>\n";
-      echo "            </tr>\n";
-      echo "            <tr>\n";
-      echo "               <td>Datenquelle</td>\n";
-      echo "               <td><input name='layer_meta_quelle' type='text' size='100' value='".db_result($res, 0, "layer_meta_quelle")."'></td>\n";
-      echo "            </tr>\n";
-      echo "            <tr>\n";
-      echo "               <td>Ansprechpartner</td>\n";
-      echo "               <td><input name='layer_meta_ansprechpartner' type='text' size='100' value='".db_result($res, 0, "layer_meta_ansprechpartner")."'></td>\n";
-      echo "            </tr>\n";
-      echo "            <tr>\n";
-      echo "               <td>Datenlieferant (Basisdaten)</td>\n";
-      echo "               <td><input name='layer_meta_lieferant_basis' type='text' size='100' value='".db_result($res, 0, "layer_meta_lieferant_basis")."'></td>\n";
-      echo "            </tr>\n";
-      echo "            <tr>\n";
-      echo "               <td>Copyright</td>\n";
-      echo "               <td><input name='layer_meta_copyright' type='text' size='100' value='".db_result($res, 0, "layer_meta_copyright")."'></td>\n";
-      echo "            </tr>\n";
-      echo "         </table>\n";
-   echo "         <p></p>\n";
-   echo "         <input type='submit' name='function' value='update'>\n";
-   echo "         <input type='button' onclick='windowQuit()' value='   exit   '>\n";
-   echo "         <input type='hidden' name='layer_id' value='".$layer_id."'>\n";
-      </form>
-   </body>
-</html>
\ No newline at end of file
Deleted: trunk/mapbender/http/php/mod_export_image.php_deprecated
--- trunk/mapbender/http/php/mod_export_image.php_deprecated	2016-05-27 07:07:37 UTC (rev 9486)
+++ trunk/mapbender/http/php/mod_export_image.php_deprecated	2016-05-27 07:11:28 UTC (rev 9487)
@@ -1,45 +0,0 @@
-<?php
-# $Id: mod_export_image.php 7097 2010-11-08 07:48:25Z apour $
-# http://www.mapbender.org/index.php/mod_export_image.php
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-Mapbender::session()->set("mb_print_url",$map_url);
-Mapbender::session()->set("mb_print_resolution",$quality);
-header("Content-type: application/png"); // mark the following content as PNG file
-$date = date("d.m.y");
-header("Content-Disposition: attachment; filename=export".$date.".png");
-header("Expires: 0");
-include(dirname(__FILE__)."/../../conf/print.conf");
-$header_height = intval($_REQUEST["header_height"]) * $deformation;
-$map_width = intval($_REQUEST["map_width"]) * $deformation;
-$map_height = intval($_REQUEST["map_height"]) * $deformation;
-#map
-//include "../classes/class_weldMaps2PNG.php";
-include "../extensions/exp_weldMaps.php";
-//$i = new weldMaps($map_urls, Mapbender::session()->get("mb_print_resolution"));
-//print $i;
Deleted: trunk/mapbender/http/php/mod_getStyles.php_deprecated
--- trunk/mapbender/http/php/mod_getStyles.php_deprecated	2016-05-27 07:07:37 UTC (rev 9486)
+++ trunk/mapbender/http/php/mod_getStyles.php_deprecated	2016-05-27 07:11:28 UTC (rev 9487)
@@ -1,186 +0,0 @@
-<?php
-# $Id: mod_getStyles.php 7097 2010-11-08 07:48:25Z apour $
-# http://www.mapbender.org/index.php/Administration
-$pattern = "admin_name";
-<html>
-<head>
-<meta name="author-mail" content="info at ccgis.de">
-<meta name="author" content="U. Rothstein">
-<?php
-<title>SLD Get Styles</title>
-<?php
-body{
-.button_del{
-   color: red;
-.textfield{
-.wmsList{
-   	width:200px
-</style>
-function validate(){
-	var ind = document.form1.wmsList.selectedIndex;
-	document.form1.getstyle.value = 1;
-	document.form1.submit();
-</script>
-</head>
-<body>
-<?php
-###delete
-if($wmsList && $getstyle == '1'){
-function proxy_url($proxy_url)
-   global $proxy_name,$proxy_port,$proxy_cont,$proxy_user,$proxy_pass;
-//echo $proxy_user;
-   $proxy_fp = fsockopen($proxy_name, $proxy_port) or die ("Fehler beim �ffnen der Verbindung zum Proxy");
-   if (!$proxy_fp)    {return false;}
-      $headers = "GET $proxy_url HTTP/1.0\r\nHost: $proxy_name\r\n";
-   $headers .= 'Proxy-Authorization: ' . 'Basic ' . base64_encode($proxy_user . ':' . $proxy_pass)."\r\nConnection: Keep-Alive\r\n\r\n";
-   fputs($proxy_fp, $headers);
-   while(!feof($proxy_fp))
-   {$proxy_cont .= fread($proxy_fp,4096);
-   fclose($proxy_fp);
-   $proxy_cont = substr($proxy_cont, strpos($proxy_cont,"\r\n\r\n")+4);
-   return $proxy_cont;
-/* Sends an http request to www.example.com
-   with additional headers shown above */
-//$fp = fopen('http://www.example.com', 'r', false, $context);
-	$style_xml = proxy_url($url) or die("Error: ". $ur . " .. no valid resource");
-	#echo "<pre>";
-	#echo $style_xml;
-	#echo "</pre>";
-	#$style_content = fread($style_xml);
-	#<ogc:PropertyName>admin_name</ogc:PropertyName><ogc:Literal>Brandenburg</ogc:Literal>
-	$style_filename = "../getstyles/wms_".$wmsList.".php";
-	$style_file = fopen($style_filename,"w") or die ($style_filename." not writable!");
-	if(!is_writable($style_filename)){
-		echo $style_filename."not writable!!!<br>";
-	$cnt_line = 0;
-	fwrite($style_file, "<".chr(63)."php echo '<?xml version=\"1.0\" encoding=\"ISO-8859-1\" standalone=\"yes\" ?>'; ".chr(63).">\r\n");
-	//while(!feof($style_xml)){
-		//$line = preg_replace("md5userid", "<".chr(63)."php echo ".chr(36)."_REQUEST['id']; ".chr(63).">",fgets($style_xml));
-		fwrite($style_file, $style_xml);
-		#echo fgets($style_xml);
-		//$cnt_line++;
-	#fputs($style_file, $style_content) or die ($style_filename." not writable");
-	@fclose($style_xml);
-	fclose($style_file);
-	#include(dirname(__FILE__)."/../../conf/www.conf");
-	$pattern = "/" . basename($login) . "/";
-	$sql = "UPDATE wms SET wms_filter = $1 WHERE wms_id = $2";
-	$v = array(preg_replace($pattern,$style_filename,$login), $wmsList);
-	$t = array("s", "i");
-	echo $sql;
-	db_prep_query($sql, $v, $t) or die("unable to change filter!");
-$sql = "SELECT * FROM wms ORDER BY wms_title";
-$res = db_query($sql);
-$cnt = 0;
-echo "<form name='form1' action='" . $self ."' method='post'>";
-echo "<select class='wmsList' size='20' name='wmsList' class='wmsList' onchange='submit()'>";
-while($row = db_fetch_array($res)){
-	# getStyle - Request:
-	if($wmsList && $row["wms_id"] == $wmsList){
-		$getStyle = $row["wms_getmap"]."&VERSION=1.1.1&REQUEST=getStyles&SERVICE=WMS&LAYERS=";
-		$sql_style = "SELECT layer_name FROM layer WHERE fkey_wms_id = $1";
-		$v = array($wmsList);
-		$t = array("i");
-		$res_style = db_prep_query($sql_style, $v, $t);
-		$cnt_style = 0;
-		while($row2 = db_fetch_array($res_style)){
-			if($cnt_style > 0){
-				if($cnt_style > 1){
-					$getStyle .= ",";
-				$getStyle .= $row2["layer_name"];
-			$cnt_style++;
-	echo "<option value='".$row["wms_id"]."' ";
-	if($row["wms_id"] == $wmsList){
-		echo "selected";
-	echo ">".$row["wms_title"]."</option>";
-	$cnt++;
-echo "</select><br>";
-echo "<textarea class='textfield' name='url' cols='70' rows='3' wrap='virtual'>".htmlentities($getStyle,ENT_QUOTES)."</textarea><br>";
-echo "<input class='button_del' type='button' value='getStyle' onclick='validate()'><br>";
-if($style_filename){
-	$style_file = fopen($style_filename,"r");
-	while(!feof($style_file)){
-		$content = preg_replace("/</","<",fgets($style_file));
-		echo preg_replace("/>/",">",$content)."<br>";
-<input type='hidden' name='getstyle'>
-</form>
-</body>
-</html>
Deleted: trunk/mapbender/http/php/mod_layerISOMetadataWriteToFolder.php
--- trunk/mapbender/http/php/mod_layerISOMetadataWriteToFolder.php	2016-05-27 07:07:37 UTC (rev 9486)
+++ trunk/mapbender/http/php/mod_layerISOMetadataWriteToFolder.php	2016-05-27 07:11:28 UTC (rev 9487)
@@ -1,110 +0,0 @@
-<?php
-#http://www.geoportal.rlp.de/mapbender/php/mod_exportISOMetadata.php?
-# $Id: mod_exportISOMetadata.php 235
-# http://www.mapbender.org/index.php/Inspire_Metadata_Editor
-require_once(dirname(__FILE__) . "/../../core/globalSettings.php");
-require_once(dirname(__FILE__) . "/../classes/class_connector.php");
-$con = db_connect(DBSERVER,OWNER,PW);
-db_select_db(DB,$con);
-//define the view or table where to read out the layer ids for which metadatafiles should be generated
-$wmsView = "search_wms_view";
-//$wmsView = '';
-//parse request parameter
-//make all parameters available as upper case
-foreach($_REQUEST as $key => $val) {
-	$_REQUEST[strtoupper($key)] = $val;
-//validate request params
-if (!isset($_REQUEST['TYPE'])) {
-	echo 'GET Parameter Type lacks';
-	die();
-if (isset($_REQUEST['TYPE']) and $_REQUEST['TYPE'] != "ALL") {
-	echo 'validate: <b>'.$_REQUEST['TYPE'].'</b> is not valid.<br/>';
-	die();
-$sql = "SELECT layer_id, uuid ";
-//$sql .= "FROM ".$wmsView;
-$sql .= "FROM layer WHERE layer_id IN (20203,20202)";
-$v = array();
-$t = array();
-$res = db_prep_query($sql,$v,$t);
-$generatorScript = '/mapbender/php/mod_layerISOMetadata.php?';
-$generatorBaseUrl = 'http://'.$_SERVER['HTTP_HOST'].$generatorScript;
-$generatorScriptMetadata = '/mapbender/php/mod_dataISOMetadata.php?';
-$generatorBaseUrlMetadata = 'http://'.$_SERVER['HTTP_HOST'].$generatorScriptMetadata;
-echo $generatorBaseUrl."<br>";
-	$generatorUrl = $generatorBaseUrl."SERVICE=WMS&outputFormat=iso19139&id=".$row['layer_id'];
-	echo "URL requested : ".$generatorUrl."<br>";
-	$generatorInterfaceObject = new connector($generatorUrl);
-	$ISOFile = $generatorInterfaceObject->file;
-	$layerId = $row['layer_id'];
-	echo "File for layer ".$row['layer_id']." will be generated<br>";
-	//generate temporary files under tmp
-	if($h = fopen(TMPDIR."/metadata/mapbenderServiceMetadata_".$layerId."_iso19139.xml","w")){
-		if(!fwrite($h,$ISOFile)){
-			$e = new mb_exception("mod_exportISOMetadata.php: cannot write to file: ".TMPDIR."/mapbenderLayerMetadata_".$row['layer_id']."_iso19139.xml");
-	echo "Service metadata file for layer ".$row['layer_id']." written to TMP<br>";
-	fclose($h);
-	//get all connected metadata for this layer and save it too
-	$sql = <<<SQL
-SELECT metadata_id, uuid, link, linktype, md_format, origin FROM mb_metadata
-INNER JOIN (SELECT * from ows_relation_metadata
-WHERE fkey_layer_id = $layerId ) as relation ON
-mb_metadata.metadata_id = relation.fkey_metadata_id WHERE mb_metadata.export2csw = TRUE
-SQL;
-	$i = 0;
-	$res_metadata = db_query($sql);
-	while ($row_metadata = db_fetch_array($res_metadata)) {
-		$generatorUrlMetadata = $generatorBaseUrlMetadata."outputFormat=iso19139&id=".$row_metadata['uuid'];
-		echo "URL requested : ".$generatorUrlMetadata."<br>";
-		$generatorInterfaceObject = new connector($generatorUrlMetadata);
-		echo "Metadata uuid: ".$row_metadata['uuid']."<br>";
-		if($h = fopen(TMPDIR."/metadata/mapbenderMetadata_".$layerId."_".$row_metadata['uuid']."_iso19139.xml","w")){
-			$e = new mb_exception("mod_exportISOMetadata.php: cannot write to file: ".TMPDIR."/metadata/mapbenderMetadata_".$layerId."_".$row_metadata['uuid']."_iso19139.xml");
-		echo "Data metadate file for layer ".$row['layer_id']." and metadata ".$row_metadata['uuid']." written to TMP<br>";
-		fclose($h);
-		$i++;
Deleted: trunk/mapbender/http/php/mod_treefolderAdmin.php_deprecated
--- trunk/mapbender/http/php/mod_treefolderAdmin.php_deprecated	2016-05-27 07:07:37 UTC (rev 9486)
+++ trunk/mapbender/http/php/mod_treefolderAdmin.php_deprecated	2016-05-27 07:11:28 UTC (rev 9487)
@@ -1,563 +0,0 @@
-<?php
-# $Id: mod_treefolderAdmin.php 7097 2010-11-08 07:48:25Z apour $
-# Copyright (C) see license below
-# Dual License
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
-<HTML>
-<HEAD>
-<META NAME="Generator" CONTENT="Cosmo Create 1.0.3">
-<?php
-<TITLE>Treefolder Administration</TITLE>
-<STYLE TYPE="text/css">
-    .sitemap {
-	    font-family:Arial,Helvetica;
-	    font-size:10pt;
-	    line-height:6pt;
-    body { margin-top:7px;
-           margin-left:4px;
-    a:link { text-decoration: none }
-    a:visited { text-decoration: none }
-    a:active { text-decoration: none }
-</STYLE>
-<SCRIPT language="JavaScript1.2">
-   * sitemap.js 1.31 05/02/2000
-   *  - Opera 5
-   * sitemap.js 1.3 27/11/2000
-   *  - Netscape 6
-   * sitemap.js 1.2 20/05/2000
-   *  - split array tree into arrays for each element old tree
-   *  - no mory type flag, an folder is an entry which has sons
-   *  - a folder can have an link
-   *  - while initing an default layers is shown
-   * sitemap.js 1.1 20/10/1999
-   *  - showTree only updates and init layers new which have been really changed
-   *  - add deep to knot entry
-   *  - substitute knotDeep[ id ] w/ tree[ id2treeIndex[ id ] ].deep
-   *  - add alignment to img and a   at the beginning of eyery line
-   *  - add a fake img for bookmarks on top panel
-   * sitemap.js 1.02 14/10/1999
-   *  - fix bug in initStyles
-   * sitemap.js 1.01 06/10/1999
-   *  - fix bug in knotDeep for Netscape 4.00-4.0.5
-   * sitemap.js 1.0 20/09/1999
-   * Javascript function for displaying hierarchic directory structures with
-   * the ability to collapse and expand directories.
-   * Copyright (c) 1999 Polzin GmbH, Duesseldorf. All Rights Reserved.
-   * Author: Lutz Eymers <ixtab at polzin.com>
-   * Download: http://www.polzin.com/inet/fset_inet.phtml?w=goodies
-   * Permission to use, copy, modify, and distribute this software
-   * and its documentation for any purposes and without fee
-   * is hereby granted provided that this copyright notice
-   * appears in all copies.
-   * Of course, this software is provided "as is" without express or implied
-   * warranty of any kind.
-window.onError=null;
-var idx=0
-var treeId = new Array();
-var treeP_id = new Array();
-var treeIsOn = new Array();
-var treeTyp = new Array();
-var treeName = new Array();
-var treeUrl = new Array();
-var treeWasOn = new Array();
-var treeDeep = new Array();
-var treeLastY = new Array();
-var treeIsShown = new Array();
-var treeURL = new Array();
-var treeWMS = new Array();
-function Note( id,p_id,name,url,left,wms_id) {
-	treeId[ idx ] = id;
-	treeP_id[ idx ] = p_id;
-	treeIsOn[ idx ] = true;
-	treeTyp[ idx ] = 'f';
-	treeName[ idx ] = name + "  <input type='radio' value='"+left+"' name='radio1' style='width:10px;height:10px' onclick='parent.document.forms[0].left.value="+left+"'>" + left + " ("+url+" - "+wms_id+")";
-	treeUrl[ idx ] = url ;
-	treeWasOn[ idx ] = true;
-	treeDeep[ idx ] = 0;
-	treeLastY[ idx ] = 0;
-	treeIsShown[ idx ] = true;
-	treeURL [ idx ] = url;
-	treeWMS [ idx ] = wms_id;
-	idx++;
-//     if(url != ''){
-//      parent.loadImage(name);
-  function initDiv ( )
-    if ( isDOM || isDomIE )
-      divPrefix='<DIV CLASS="sitemap" style="position:absolute; left:0; top:0; visibility:hidden;" ID="sitemap'
-      divInfo='<DIV CLASS="sitemap" style="position:absolute; visibility:visible" ID="sitemap'
-    else
-      divPrefix='<DIV CLASS="sitemap" ID="sitemap'
-      divInfo='<DIV CLASS="sitemap" ID="sitemap'
-    document.writeln( divInfo +  'info">Bitte haben Sie etwas Geduld.<BR> <BR>Es werden die Einträge aus<BR> <BR>der Datenbank initialisiert.</DIV> ' );
-	 document.writeln("<form name='treeForm'>");
-    for ( var i=1; i<idx; i++ )
-      // linked Name ?
-      if ( treeUrl[i] != '' )
-//		 onClick='if(this.checked){parent.addSelectedLayer("1",""+treeURL[i]+"","visibles")} else{parent.removeSelectedLayer("1",""+treeURL[i]+"","visibles")}'
-        linkedName = "<input type='checkbox' onClick=''><IMG SRC='../img/tree/1w.gif' BORDER='0' WIDTH='3'><span>" + treeName[i] + "</span>"
-      else
-        linkedName =  '<IMG SRC="../img/tree/1w.gif" BORDER="0" WIDTH="3">' + treeName[i]
-      // don't link folder icon if node has no sons
-      if ( i == idx-1 || treeP_id[i+1] != treeId[i] ) {
-        if ( treeDeep[ i ] == 0 )
-          folderImg = '<IMG ALIGN="BOTTOM" SRC="../img/tree/file_empty.gif" BORDER="0" HEIGHT="16" WIDTH="1" HSPACE="0">'
-        else
-          folderImg = ''
-      } else {
-        folderImg = '<A HREF="javascript:sitemapClick(' + treeId[i] + ')"><IMG ALIGN="BOTTOM" SRC="../img/tree/folder_off.gif" BORDER="0" NAME="folder' + treeId[i] + '" HEIGHT="16" WIDTH="30" HSPACE="0"></A>'
-      // which type of file icon should be displayed?
-      if ( treeP_id[i] != 0 )
-        if ( lastEntryInFolder( treeId[i] ) )
-          fileImg = '<IMG ALIGN="BOTTOM" SRC="../img/tree/file_last.gif" BORDER="0" NAME="file'
-            + treeId[i] + '" HEIGHT="16" WIDTH="30" HSPACE="0">'
-        else
-          fileImg = '<IMG ALIGN="BOTTOM" SRC="../img/tree/file.gif" BORDER="0" NAME="file'
-      else
-        fileImg = ''
-      // traverse parents up to root and show vertical lines if parent
-      // is not the last entry on this layer
-      verticales = ''
-      for( var act_id=treeId[i] ; treeDeep[ id2treeIndex[ act_id ] ] > 1;  )
-        act_id = treeP_id[ id2treeIndex[ act_id ]]
-        if ( lastEntryInFolder( act_id ) )
-          verticales = '<IMG ALIGN="BOTTOM" SRC="../img/tree/file_empty.gif" BORDER="0" HEIGHT="16" WIDTH="30" HSPACE="0">' + verticales
-        else
-          verticales = '<IMG ALIGN="BOTTOM" SRC="../img/tree/file_vert.gif" BORDER="0" HEIGHT="16" WIDTH="30" HSPACE="0">' + verticales
-      document.writeln( divPrefix + treeId[i] + '"><NOBR> ' + verticales + fileImg + folderImg + linkedName + '</NOBR></DIV><BR>'
-	  document.writeln("</form>");
-  function initStyles ( )
-    document.writeln( '<STYLE TYPE="text/css">' + "\n" + '<!--' )
-    for ( var i=1,y=y0; i<idx; i++ )
-      document.writeln( '#sitemap' + treeId[i] + ' {POSITION: absolute; VISIBILITY: hidden;}' )
-      if ( treeIsOn[ id2treeIndex[ treeP_id[i] ] ] )
-        y += deltaY
-    document.writeln( '#sitemapinfo {POSITION: absolute; VISIBILITY: visible;}' )
-    document.writeln( '//-->' + "\n" + '</STYLE>' )
-  function sitemapClick( id )
-    var i = id2treeIndex[ id ]
-    if ( treeIsOn[ i ] )
-    // close directory
-      // mark node as invisible
-      treeIsOn[ i ]=false
-      // mark all sons as invisible
-      actDeep = treeDeep[ i ]
-      for( var j=i+1; j<idx && treeDeep[j] > actDeep; j++ )
-        treeWasOn[ j ] = treeIsOn[ j ]
-        treeIsOn[ j ]=false
-      gif_off( id )
-    else
-    // open directory
-      treeIsOn[ i ]=true
-      // remember and restore old status
-        treeIsOn[ j ] = treeWasOn[ j ]
-      gif_on( id )
-    showTree()
-  function knotDeep( id )
-    var deep=0
-    while ( true )
-      if ( treeP_id[ id2treeIndex[id] ] == 0 )
-        return deep
-      else
-        ++deep
-        id = treeP_id[ id2treeIndex[id] ]
-    return deep
-  function initTree( id )
-    treeIsOn[ id2treeIndex[id] ] = true
-    if ( treeTyp[ id2treeIndex[id] ] != 'b' )
-      gif_on( id )
-    while ( treeP_id[ id2treeIndex[id] ] != 0 )
-        gif_on( id )
-  function lastEntryInFolder( id )
-    var i = id2treeIndex[id]
-    if ( i == idx-1 )
-      return true
-    if ( treeTyp[i] == 'b' )
-      if ( treeP_id[i+1] != treeP_id[i] )
-        return true
-      else
-        return false
-    else
-      var actDeep = treeDeep[i]
-      for( var j=i+1; j<idx && treeDeep[j] > actDeep ; j++ )
-      if ( j<idx && treeDeep[j] == actDeep )
-        return false
-      else
-        return true
-  function showTree()
-    for( var i=1, y=y0, x=x0; i<idx; i++ )
-        // show current node
-        if ( !(y == treeLastY[i] && treeIsShown[i] ) )
-          showLayer( "sitemap"+ treeId[i] )
-          setyLayer( "sitemap"+ treeId[i], y )
-          treeIsShown[i] = true
-        treeLastY[i] = y
-        y += deltaY
-      else
-        // hide current node and all sons
-        if ( treeIsShown[ i ] )
-          hideLayer( "sitemap"+ treeId[i] )
-          treeIsShown[i] = false
-  function initIndex() {
-    for( var i=0; i<idx; i++ )
-      id2treeIndex[ treeId[i] ] = i
-  function gif_name (name, width, height) {
-    this.on = new Image (width, height);
-    this.on.src ="../img/tree/" +  name + "_on.gif"
-    this.off = new Image (width, height);
-    this.off.src ="../img/tree/" +  name + "_off.gif"
-  function load_gif (name, width, height) {
-    gif_name [name] = new gif_name (name,width,height);
-  function load_all () {
-    load_gif ('folder',30,16)
-    file_last = new Image( 30,16 )
-    file_last.src = "file_last.gif"
-    file_middle = new Image( 30,16 )
-    file_middle.src = "file.gif"
-    file_vert = new Image( 30,16 )
-    file_vert.src = "file_vert.gif"
-    file_empty = new Image( 30,16 )
-    file_empty = "file_empty.gif"
-  function gif_on ( id ) {
-    eval("document['folder" + id + "'].src = gif_name['folder'].on.src")
-  function gif_off ( id ) {
-    eval("document['folder" + id + "'].src = gif_name['folder'].off.src")
-  // global configuration
-  var deltaX = 30
-  var deltaY = 16
-  var x0 = 5
-  var y0 = 5
-  var defaultTarget = 'examplemain'
-  var browserName = navigator.appName;
-  var browserVersion = parseInt(navigator.appVersion);
-  var isIE = false;
-  var isNN = false;
-  var isDOM = false;
-  var isDomIE = false;
-  var isDomNN = false;
-  var layerok = false;
-  var isIE = browserName.indexOf("Microsoft Internet Explorer" )==-1?false:true;
-  var isNN = browserName.indexOf("Netscape")==-1?false:true;
-  var isOpera = browserName.indexOf("Opera")==-1?false:true;
-  var isDOM = document.getElementById?true:false;
-  var isDomNN = document.layers?true:false;
-  var isDomIE = document.all?true:false;
-  if ( isNN && browserVersion>=4 ) layerok=true;
-  if ( isIE && browserVersion>=4 ) layerok=true;
-  if ( isOpera && browserVersion>=5 ) layerok=true;
-  function hideLayer(layerName) {
-    if (isDOM)
-      document.getElementById(layerName).style.visibility="hidden"
-    else if (isDomIE)
-      document.all[layerName].style.visibility="hidden";
-    else if (isDomNN)
-      document.layers[layerName].visibility="hidden";
-  function showLayer(layerName) {
-    if (isDOM)
-      document.getElementById(layerName).style.visibility="visible"
-    else if (isDomIE)
-      document.all[layerName].style.visibility="visible";
-    else if (isDomNN)
-      document.layers[layerName].visibility="visible";
-  function setyLayer(layerName, y) {
-    if (isDOM)
-      document.getElementById(layerName).style.top=y + "px"
-    else if (isDomIE)
-      document.all[layerName].style.top=y + "px";
-    else if (isDomNN)
-      document.layers[layerName].top=y + "px";
-  var id2treeIndex = new Array()
-  // the structure is easy to understand with a simple example
-  // p_id is the id of the parent
-  // E0                                      ( id=0,p_id=-1 )
-  //          E11                            ( id=1,p_id=0)
-  //                     E111                ( id=2,p_id=1 )
-  //                     E112                ( id=3,p_id=1 )
-  //          E12                            ( id=4,p_id=0 )
-  //                     E121                ( id=5,p_id=4 )
-  //          E13                            ( id=6,p_id=0 )
-  //                     E131                ( id=7,p_id=6 )
-  //                                 E1311   ( id=8,p_id=7 )
-  //                     E132                ( id=9,p_id=6 )
-  // this is a multinary tree structure which is easy to
-  // populate with database data :)
-<?php
-$sql = "SELECT id FROM gui_treegde WHERE fkey_gui_id = $1";
-// $v and $t will be re-used below!
-$v = array($guiList);
-$t = array("s");
-$res = db_prep_query($sql, $v, $t);
-if(!db_fetch_row($res)){
-	$sql = "INSERT INTO gui_treegde(fkey_gui_id, my_layer_title,lft,rgt,layer) VALUES($1, 'new','1','4','')";
-	//using $v and $t fom above
-	db_prep_query($sql, $v, $t);
-	$sql = "INSERT INTO gui_treegde(fkey_gui_id,my_layer_title,lft,rgt,layer) VALUES($1,'new','2','3','')";
-$sql = "SELECT n.wms_id, n.id, n.my_layer_title, n.lft, n.rgt, n.layer, COUNT(*) AS level1, ((n.rgt - n.lft -1)/2) AS offspring ";
-$sql .= "FROM gui_treegde as n, gui_treegde as p WHERE n.lft BETWEEN p.lft AND p.rgt ";
-$sql .= " AND n.fkey_gui_id = $1 AND p.fkey_gui_id = $2 ";
-$sql .= " GROUP BY n.wms_id, n.lft, n.my_layer_title,  ((n.rgt - n.lft -1)/2) , n.id, n.rgt, n.layer ORDER BY n.lft;";
-#echo $sql;
-$v = array($guiList, $guiList);
-$t = array("s", "s");
-	echo "function initArray(){";
-	echo "Note(0,-1,'','');";
-	$cnt = 0;
-	while($row = db_fetch_array($res)){
-		if(db_result($res, $cnt, "level1") == 1 && $row["offspring"] >= 0 ){
-			if(count($parent) > 0){unset($parent);}
-			$level =  db_result($res, $cnt, "level1");
-			$parent[$level+1] = db_result($res, $cnt, "id");
-			echo "Note(".$row["id"].",0,'".$row["my_layer_title"]."','".$row["layer"]."',".$row["lft"];
-			if($row["wms_id"] != ''){
-				echo ", '".$row["wms_id"]."'";
-			echo ");";
-		else if($row["level1"] > $level){
-			$level =  $row["level1"];
-			$parent[$level+1] = $row["id"];
-			echo "Note(".$row["id"].",".$parent[$level].",'".$row["my_layer_title"]."','".$row["layer"]."',".$row["lft"];
-			echo ");";
-		else if($row["level1"] == $level){
-			echo ");";
-		else if($row["level1"] < $level){
-			$parent[$level + 1] = $row["id"];
-			echo ");";
-		$cnt++;
-	echo "treeTyp[0] = 'f'; treeIsOn[0] = true; treeWasOn[0] = true;";
-	echo "}";
-  function initArray_()
-    Note(0,-1,'','')
-	  Note(1,0,'Tutorials','')
-    Note(8,1,'HTML','')
-    Note(10,8,'SelfHtml','http://www.teamone.de/selfaktuell/')
-	  Note(9,1,'willi','')
-    Note(100,9,'SelfHtml','http://www.teamone.de/selfaktuell/')
-	  Note(3,1,'JavaScript','')
-    Note(4,3, 'Netscape Guide 1.3','http://developer.netscape.com/docs/manuals/js/client/jsguide/index.htm')
-    Note(7,3, 'Introduction to Javascript','http://rummelplatz.uni-mannheim.de/~skoch/js/script.htm')
-    Note(12,1, 'Perl','')
-    Note(14,12, 'Perl Tutorial','http://www.awu.id.ethz.ch/~didi/perl/perl_start.html')
-    Note(13,1,'SQL','')
-    Note(15,13, 'Introduction to SQL','http://w3.one.net/~jhoffman/sqltut.htm')
-	  Note(111,1, 'Introduction to SQL','http://w3.one.net/~jhoffman/sqltut.htm')
-    Note(2,0, 'Reference Manuals','')
-    Note(11,2, 'HTML Version 3.2 Referenz','http://www.cls-online.de/htmlref/index.htm')
-    Note(6,2,'Netscape Reference 1.3','http://developer.netscape.com/docs/manuals/js/client/jsref/index.htm')
-    Note(17,2,'PHP Manual','http://www.php.net/manual/html/')
-    treeTyp[0] = 'f'
-    treeIsOn[0] = true
-    treeWasOn[0] = true
-  var idx=0
-  initArray()
-  initIndex()
-  load_all()
-  for( i=1; i<idx; i++ )
-    treeDeep[i] = knotDeep( treeId[i] )
-    if ( treeDeep[i] == 0 )
-  if ( isDomNN )
-    initStyles();
-  </SCRIPT>
-</HEAD>
-<BODY VLINK="#000000" ALINK="#000000" LINK="#000000" BGCOLOR="#ffffff" TEXT="#000000"
- onLoad="if (layerok) showTree();"
- MARGINHEIGHT="0" MARGINWIDTH="0" LEFTMARGIN="0" TOPMARGIN="0" onkeydown="parent.keyhandler('FolderFrame')">
-  initDiv();
-  hideLayer("sitemapinfo");
-</SCRIPT>
-</BODY>
-</HTML>
Deleted: trunk/mapbender/http/php/nestedSets.php_deprecated
--- trunk/mapbender/http/php/nestedSets.php_deprecated	2016-05-27 07:07:37 UTC (rev 9486)
+++ trunk/mapbender/http/php/nestedSets.php_deprecated	2016-05-27 07:11:28 UTC (rev 9487)
@@ -1,412 +0,0 @@
-<?php
-# $Id: nestedSets.php 7097 2010-11-08 07:48:25Z apour $
-<html>
-<head>
-<?php
-<title>nestedSets</title>
-<?php
-	input{
-		width: 164px;
-	body{
-		font-family : Arial, Helvetica, sans-serif;
-		font-size: 12px;
-</style>
-</head>
-<!-- <link rel='stylesheet' type='text/css' href='administration.css'> -->
-function validate(value){
-	var permission = true;
-	if(value == 'insert'){
-		if(document.forms[0].title.value == ''){alert("Bitte geben Sie einen Titel an."); permission = false; return;}
-		if(document.forms[0].left.value == ''){alert("Wählen Sie eine Position."); permission = false; return;}
-      	if(document.forms[0].title.value == ''){alert("<?php echo _mb("Please insert a title.") ?>"); permission = false; return;}
-		if(document.forms[0].left.value == ''){alert("Please choose a position."); permission = false; return;}
-      if(document.forms[0].wmsList.selectedIndex > 0 && document.forms[0].layer.selectedIndex == 0){alert("Wählen Sie einen Layer."); permission = false; return;}
-		if(permission == true){document.forms[0].action.value = "insert"; document.forms[0].submit();}
-	if(value == 'delete'){
-		//permission = confirm("Soll das Objekt mit Inhalten gelöscht werden?");
-		permission = confirm("Do you want to delete the object and the content of the object?");
-		document.forms[0].action.value = "delete";
-		document.forms[0].submit();
-	if(value == 'update'){
-		if(document.forms[0].left.value == ''){alert("Bitte wählen Sie eine Position."); permission = false; return;}
-		if(document.forms[0].title.value == ''){alert("Please fill in a labeling."); permission = false; return;}
-		if(permission == true){document.forms[0].action.value = "update"; document.forms[0].submit();}
-	if(value == 'add'){
-		if(document.forms[0].guiList.selectedIndex == 0){alert("Bitte wählen Sie eine GUI."); permission = false; return;}
-		if(document.forms[0].wmsList.selectedIndex == 0){alert("Bitte wählen Sie einen WMS."); permission = false; return;}
-		if(document.forms[0].layer.selectedIndex == 0){alert("Bitte wählen Sie eine Ebene."); permission = false; return;}
-		if(document.forms[0].left.value == ''){alert("Please fill in a position."); permission = false; return;}
-		if(document.forms[0].guiList.selectedIndex == 0){alert("Please choose a GUI."); permission = false; return;}
-		if(document.forms[0].wmsList.selectedIndex == 0){alert("Please choose a WMS."); permission = false; return;}
-		if(document.forms[0].layer.selectedIndex == 0){alert("Please choose a layer."); permission = false; return;}
-		if(permission == true){document.forms[0].action.value = "add"; document.forms[0].submit();}
-function rmWMS(obj){
-	if(obj.value == ''){
-		document.forms[0].wmsList.selectedIndex = 0;
-</script>
-<body >
-<?php
-if(isset($action)){
-   if($layer == 'Ordner'){$layer = "";}
-if(isset($action) && $action == "insert"){
-	$temp = explode("###", $layer);
-	$sql = "SELECT rgt FROM gui_treegde WHERE lft = $1 AND fkey_gui_id = $2";
-	$v = array($left, $guiList);
-	$t = array("i", "s");
-	if($pos == 'in'){$left = $left + 1;}
-	else if($pos == 'hinter'){$left = db_result($res,0,"rgt") + 1;}
-	else{ $left = $left + 2;}
-	$sql = "UPDATE gui_treegde SET rgt=rgt+2 WHERE rgt >= $1 AND fkey_gui_id = $2";
-#echo $sql . " 1: ".$left." 2:".$guiList."<br>";
-	$sql = "UPDATE gui_treegde SET lft=lft+2 WHERE lft >= $1 AND fkey_gui_id = $2";
-	$sql = "INSERT INTO gui_treegde(fkey_gui_id, fkey_layer_id, lft,rgt, ";
-	$sql .= "my_layer_title, layer, wms_id) VALUES($1, $2, $3, $4, $5, $6, $7)";
-#echo $sql . "<br>";
-	$v = array($guiList, $temp[0], $left, ($left+1), $name, $temp[1], $wmsList);
-	$t = array("s", "s", "i", "i", "s", "s", "s");
-	if($layer == ""){
-		$left = $left + 1;
-		$sql = "UPDATE gui_treegde SET rgt=rgt+2 WHERE rgt >=". $left." AND fkey_gui_id = '".$guiList."'";
-		db_query($sql);
-		$sql = "UPDATE gui_treegde SET lft=lft+2 WHERE lft >=".$left." AND fkey_gui_id = '".$guiList."'";
-		db_query($sql);
-		#hier ist noch was falsch
-		$sql = "INSERT INTO gui_treegde(fkey_gui_id,my_layer_title,lft,rgt,layer) VALUES('".$guiList."','new',".$left.",".($left+1).",'new')";
-		#echo $sql . "<br />";
-		db_query($sql);
-if(isset($action) && $action == "delete"){
-	if($left){
-		$right = db_result($res,0,"rgt");
-		$sql = "DELETE FROM gui_treegde WHERE lft BETWEEN $1 and $2 AND fkey_gui_id = $3";
-		$v = array($left, $right, $guiList);
-		$t = array("i", "i", "s");
-		$sql = "UPDATE gui_treegde SET lft=lft-$1 WHERE lft > $2 AND fkey_gui_id = $3";
-		$v = array($right-$left+1, $right, $guiList);
-#echo $sql . " r:".$right." l:".$left." 2:".$guiList."<br>";
-		$sql = "UPDATE gui_treegde SET rgt=rgt-$1 WHERE rgt > $2 AND fkey_gui_id = $3";
-if(isset($action) && $action == "update"){
-	$sql = "UPDATE gui_treegde SET ";
-	$sql .= "my_layer_title = $1, ";
-	$sql .= "fkey_layer_id = $2, ";
-	$sql .= "layer = $3, ";
-	$sql .= "wms_id = $4";
-	$sql .= " WHERE lft = $5 AND fkey_gui_id = $6";
-	$v = array($name, $temp[0], $temp[1], $wmsList, $left, $guiList);
-	$t = array("s", "s", "s", "s", "i", "s");
-if(isset($action) && $action == "add"){
-	$sql_val = "SELECT * FROM gui_treegde WHERE lft = $1 AND fkey_gui_id = $2";
-	$res_val = db_prep_query($sql_val, $v, $t);
-	$sql .= "fkey_layer_id = $1, layer = $2, wms_id =  $3 ";
-	$sql .= "WHERE lft = $4 AND fkey_gui_id = $5";
-	$v = array();
-	$t = array("s", "s", "s", "i", "s");
-	if (db_result($res_val, 0, "fkey_layer_id") != '') {
-		array_push($v, db_result($res_val, 0, "fkey_layer_id") . "," . $temp[0]);
-	else {
-		array_push($v, $temp[0]);
-	if (db_result($res_val, 0, "layer") != '') {
-		array_push($v, db_result($res_val, 0, "layer") . "," . $temp[1]);
-	else {
-		array_push($v, $temp[1]);
-	if (db_result($res_val, 0, "wms_id") != '') {
-		array_push($v, db_result($res_val, 0, "wms_id") . "," . $wmsList);
-	else {
-		array_push($v, $wmsList);
-	array_push($v, $left);
-	array_push($v, $guiList);
-<br />
-<b>Create your own tree for your GUI. Include the element treeconfGDE to see this tree</b><br />
-Find detailed infos in the (<a href='http://www.mapbender.org/index.php/ConfTreeGde' target='_blank'>Mapbender Wiki</a>)<br />
-1. Select the GUI you want to create the new tree for <br />
-2. Select an element in the folder view<br />
-<br />
-<br />
-<?php
-if(isset($guiList) && $guiList != ""){
-	echo "<iframe ID='foldertree' name='foldertree' height='400' width='300' src='mod_treefolderAdmin.php?guiList=".urlencode($guiList)."' scrolling='auto' frameborder='1'></iframe>";
-else{
-	echo "<iframe ID='foldertree' name='foldertree' height='400' width='300' src='../html/mod_blank.html' scrolling='auto' frameborder='1'></iframe>";
-<div style='position:absolute;top:50px;left:350px'>
-<form action='<?php $self; ?>' method='POST'>
-<br><br>
-<table >
-<tr><td></td><td></td></tr>
-<?php
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-$admin = new administration();
-$ownguis = $admin->getGuisByOwner(Mapbender::session()->get("mb_user_id"),true);
-$sql = "SELECT * FROM gui WHERE gui_id IN (";
-$v = $ownguis;
-$t = array();
-for ($i = 1; $i <= count($ownguis); $i++){
-	if ($i > 1) {
-		$sql .= ",";
-	$sql .= "$" . $i;
-	array_push($t, "s");
-$sql .= ") ORDER BY gui_name";
-$cnt = 0;
-echo "<select class='guiList' size='10' name='guiList' class='guiList'  onchange='document.forms[0].submit()'>";
-echo "<option value=''>GUI ...</option>";
-	echo "<option value='".$row["gui_id"]."' ";
-	if(isset($guiList) && $guiList == $row["gui_id"]){
-		echo "selected";
-	echo ">".$row["gui_name"]."</option>";
-	$cnt++;
-echo "<tr>";
-   #echo "<td>Beschriftung:</td>";
-   echo "<td>Labeling:</td>";
-   echo "<td><input type='text' size='16' name='name' value='";
-   echo htmlentities($name, ENT_QUOTES);
-   echo "'></td>";
-echo "</tr>";
-<tr>
-<td>WMS: </td>
-<td>
-	<select name='wmsList' onchange='document.forms[0].submit()'>
-	<option value=''>WMS ...</option>
-	<?php
-	if(isset($guiList) && $guiList != ""){
-		$sql = "SELECT gui_wms.fkey_wms_id, wms.wms_title FROM gui_wms ";
-		$sql .= "INNER JOIN wms ON gui_wms.fkey_wms_id = wms.wms_id  ";
-		$sql .= "WHERE gui_wms.fkey_gui_id = $1 ";
-		$sql .= "ORDER BY wms.wms_title";
-		$v = array($guiList);
-		$t = array("s");
-		$cnt = 0;
-			echo "<option value='".$row["fkey_wms_id"]."' ";
-			if($wmsList == $row["fkey_wms_id"]){
-				echo "selected";
-			echo ">";
-			echo $row["wms_title"];
-			echo "</option>";
-			$cnt++;
-	else{echo "<option value=''>no gui selected</option>";}
-	echo"</select>";
-	echo"</td>   </tr><tr>";
-	#echo"<td>Ordner oder Ebene: </td>";
-	echo"<td>Folder or Layer: </td>";
-	echo"<td>";
-	echo"<select name='layer' onchange='rmWMS(this)'>";
-	#echo"<option value=''>Ordner</option>";
-	echo"<option value=''>Folder</option>";
-	if(isset($wmsList) && $wmsList != ""){
-		$sql_l = "SELECT gui_layer.fkey_layer_id, layer.layer_name, layer.layer_title FROM gui_layer ";
-		$sql_l .= "LEFT JOIN layer ON gui_layer.fkey_layer_id = layer.layer_id ";
-		$sql_l .= "WHERE gui_layer.gui_layer_wms_id = $1 AND layer.layer_parent = '0' AND gui_layer.fkey_gui_id = $2";
-		$sql_l .= " ORDER BY layer.layer_title";
-		$v = array($wmsList, $guiList);
-		$res_l = db_prep_query($sql_l, $v, $t);
-		$cnt = 0;
-		while($row = db_fetch_array($res_l)){
-			echo "<option value='".$row["fkey_layer_id"]."###".$row["layer_name"]."'>";
-			echo $row["layer_title"];
-			echo "</option>";
-			$cnt++;
-	</select>
-</td>
-</tr>
-<tr>
-   <td>Position: </td>
-   <td>
-   <select name='pos'>
-<?php
-	#echo "<option value='hinter'>hinter</option>";
-	echo "<option value='hinter'>behind</option>";
-	echo "<option value='in' ";
-	if($pos == 'in'){
-		echo "selected";
-	echo ">in</option>";
-	echo"</select>      </td>   </tr><tr>";
-	#echo"<td>Hinter bzw. in Element Nr.:</td>";
-	echo"<td>Insert behind or <br>in element with number:</td>";
-	echo "<td><input type='text' size='1' name='left' ";
-	if($left)
-		echo "value='".htmlentities($left,ENT_QUOTES)."'";
-	echo "></td>";
-</tr>
-<tr>
-	<td>
-	<!--<input class='abutton' type='button' name="insert" value='einfügen' onclick="validate('insert')"></td>
-	<input class='abutton' type='button' name="insert" value='create new element' onclick="validate('insert')"></td>
-	<td></td>
-</tr>
-<tr>
-	<td>
-	<input class='abutton' type='button' name="delete" value='löschen' onclick="validate('delete')"></td>
-	<input class='abutton' type='button' name="delete" value='delete element' onclick="validate('delete')"></td>
-   <td></td>
-</tr>
-<tr>
-	<td>
-	<input class='abutton' type='button' name="update" value='&amlndern' onclick="validate('update')"></td>
-	<input class='abutton' type='button' name="update" value='change element' onclick="validate('update')"></td>
-	<td></td>
-</tr>
-<tr>
-	<td>
-	<input class='abutton' type='button' name="update" value='Ebene verbinden' onclick="validate('add')"></td>
-	<input class='abutton' type='button' name="update" value='join layer' onclick="validate('add')"></td>
-	<td></td>
-</tr>
-<input type='hidden' name="action">
-</table>
-</form>
-</div>
-</body>
-</html>
More information about the Mapbender_commits mailing list
