[Mapbender-commits] r9489 - trunk/mapbender/http/plugins
    svn_mapbender at osgeo.org
    Fri May 27 00:19:06 PDT 2016
Author: armin11
Date: 2016-05-27 00:19:06 -0700 (Fri, 27 May 2016)
New Revision: 9489
Removed:
   trunk/mapbender/http/plugins/adminpopup.js_deprecated
   trunk/mapbender/http/plugins/kmlTree.js
   trunk/mapbender/http/plugins/mb_div2jqdialog.js_deprecated
   trunk/mapbender/http/plugins/mb_downloadFeedClient.php~
   trunk/mapbender/http/plugins/mb_iframeButtonPopup.js_deprecated
   trunk/mapbender/http/plugins/mb_measure.js_deprecated
   trunk/mapbender/http/plugins/mb_measure_widget.js_deprecated
   trunk/mapbender/http/plugins/mb_print.js_deprecated
   trunk/mapbender/http/plugins/mb_twitter.php_deprecated
   trunk/mapbender/http/plugins/mb_twitter_signin.js_deprecated
   trunk/mapbender/http/plugins/mb_twitter_update.js_deprecated
   trunk/mapbender/http/plugins/mod_jsonAutocompleteGazetteer.php.old
Fix wrong commit
Deleted: trunk/mapbender/http/plugins/adminpopup.js_deprecated
--- trunk/mapbender/http/plugins/adminpopup.js_deprecated	2016-05-27 07:16:01 UTC (rev 9488)
+++ trunk/mapbender/http/plugins/adminpopup.js_deprecated	2016-05-27 07:19:06 UTC (rev 9489)
@@ -1,65 +0,0 @@
- * Package: button
- * Description:
- * Imagine you have a DIV element in your application. In order to save screen
- * real estate, you might want to only show the DIV if the user clicked a
- * button. That's what this module does. The button will open a dialog
- * containing the element specified in the target column. In the example, a
- * button will open the print form in a new dialog.
- * Files:
- *  - ../plugins/mb_button.js
- * SQL:
- * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
- * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height,
- * > e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod,
- * > e_target, e_requires, e_url) VALUES('<appId>','printButton',1,1,'',
- * > 'Print','img','../img/button_blue_red/print_off.png','',NULL ,NULL ,24,24,
- * > NULL ,'','','','../plugins/mb_button.js','','printPDF','','');
- * Maintainer:
- * http://www.mapbender.org/User:Christoph_Baudson
- * Parameters:
- * License:
- * Copyright (c) 2009, Open Source Geospatial Foundation
- * This program is dual licensed under the GNU General Public License
- * and Simplified BSD license.
- * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
-var $button = $(this);
-var ButtonApi = function (o) {
-	var that = this;
-	var target = (o.$target && o.$target.jquery && o.$target.size() === 1) ?
-		o.$target : $([]);
-	var dialog = target.css({
-		position: "static",
-		width: "auto",
-		height: "auto",
-		top: "auto",
-		left: "auto"
-	}).hide().dialog({
-		autoOpen: false
-	var openDialog = function () {
-		dialog.dialog("open");
-		button.stop();
-	var button = new Mapbender.Button({
-		domElement: $button.get(0),
-		over: o.src.replace(/_off/, "_over"),
-		on: o.src.replace(/_off/, "_on"),
-		off: o.src,
-		name: o.id,
-		go: openDialog
-$button.mapbender(new ButtonApi(options));
Deleted: trunk/mapbender/http/plugins/kmlTree.js
--- trunk/mapbender/http/plugins/kmlTree.js	2016-05-27 07:16:01 UTC (rev 9488)
+++ trunk/mapbender/http/plugins/kmlTree.js	2016-05-27 07:19:06 UTC (rev 9489)
@@ -1,884 +0,0 @@
- * Package: kmlTree
- * Description:
- * Module to load KML temporary in a tree
- * Files:
- *  - mapbender/http/plugins/kmlTree.js
- *  - mapebnder/lib/mb.ui.displayKmlFeatures.js
- *  - mapbender/http/css/kmltree.css
- * SQL:
- * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,
- * > e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,
- * > e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('<app_id>',
- * > 'kmlTree',2,1,'Displays KML on the map','KML','ul','','',1,1,200,200,NULL ,
- * > 'visibility:visible','','ul','../plugins/kmlTree.js','../../lib/mb.ui.displayKmlFeatures.js',
- * > 'mapframe1','jq_ui_widget','http://www.mapbender.org/Loadkml');
- * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'kmlTree',
- * > 'buffer', '100', '' ,'var');
- * > VALUES('gui', 'kmlTree', 'styles', '../css/kmltree.css', '' ,'file/css');
- * Help:
- * http://www.mapbender.org/Loadkml
- * Maintainer:
- * http://www.mapbender.org/User:Armin_Retterath
- * License:
-if (typeof window.DOMParser === "undefined") {
-	window.DOMParser = function() {};
-	window.DOMParser.prototype.parseFromString = function(str, contentType) {
-		if (typeof ActiveXObject !== 'undefined') {
-			var xmldata = new ActiveXObject('MSXML.DomDocument');
-			xmldata.async = false;
-			xmldata.loadXML(str);
-			return xmldata;
-		} else if (typeof XMLHttpRequest !== 'undefined') {
-			var xmldata = new XMLHttpRequest;
-			if (!contentType) {
-				contentType = 'application/xml';
-			xmldata.open('GET', 'data:' + contentType + ';charset=utf-8,' + encodeURIComponent(str), false);
-			if (xmldata.overrideMimeType) {
-				xmldata.overrideMimeType(contentType);
-			xmldata.send(null);
-			return xmldata.responseXML;
-var $kmlTree = $(this);
-var KmlTree = function(o) {
-	$kmlTree.children().remove();
-	$kmlTree.addClass('kmlTree');
-	var $KMLfolder = $('<li class="open kml"><ul></ul></li>');
-	$kmlTree.append($KMLfolder);
-	$addButton = $('<button class="add" name="addkml" value="addkml"></button>');
-	var selectButton = $('<img id="toggle-select-features" src="../img/osgeo_graphics/geosilk/cursor.png"></img>');
-	$addButton.click(function() {
-		if ($('#mySpatialData').dialog('isOpen') === true) {
-			return;
-		} else {
-			var dlg = $('<div id="mySpatialData"></div>').dialog({
-				"title": "My spatial data",
-				width: 720,
-				height: 420,
-				close: function() {
-					$('#kml-load-tabs').tabs('destroy');
-					$(this).html('').dialog('destroy');
-					// $('#mySpatialData').dialog('destroy');
-					$('#mySpatialData').remove();
-			var dlgcontent = '<div id="kml-load-tabs">' + '<ul><li><a class="icon icon-wmc" href="#kml-from-wmc">Stored data</a></li>' + '<li><a class="icon icon-local" href="#kml-from-upload">Upload</a></li>' + '<li><a class="icon icon-remote" href="#kml-from-url">External source</a></li>' + '<li><a class="icon icon-new" href="#kml-new">New</a></li></ul>' + '<div id="kml-from-wmc">wmc</div>' + '<div id="kml-from-upload">' + '<iframe name="kml-upload-target" style="width: 0; height: 0; border: 0px;"></iframe>' + '<form action="../php/uploadKml.php" method="post" enctype="multipart/form-data" target="kml-upload-target">' + '<input type="file" name="kml"></input>' + '<input type="submit" class="upload" value="Upload"></input><br>' + 'You can upload local KML, GPX and geoJSON files here. The filename should' + ' have the typical file extension (.kml, .gpx or .geojson) and the size' + ' is limited to 250kb of data.' + '</div>' + '</form>' + '<div id="kml-from-url">URL: <input class="kmlurl" /><b
 utton class="add" name="add" value="add"></button><br>' + 'You can give an url to a datafile which is located somewhere in the www. ' + 'Only KML, geoJSON and GPX files are supported. The files will be validated before they' + ' are loaded into the mapviewer.' + '</div>' + '<div id="kml-new">' + '<label>Title: <input type="text" name="kml-new-title"></input></label>' + '<button class="add-kml"></button>' + '</div>' + '</div>';
-			$('#kml-load-tabs').remove();
-			$(dlg).append(dlgcontent);
-			$.ajax({
-				type: 'get',
-				url: '../php/mb_list_wmc_local_data.php',
-				success: function(data) {
-					var origData = $.extend(true, {}, data);
-					$.each(data, function(_, v) {
-						v[2] = new Date(v[2] * 1000);
-						if (v[3]) {
-							v[3] = '<img src="' + v[3] + '"></img>';
-						if (v[4]) {
-							v[4] = '<img class="publishIcon" src="../img/osgeo_graphics/check.png"></img><img class="exportImage" src="../img/osgeo_graphics/geosilk/link22.png"></img>';
-						} else {
-							v[4] = '<img class="publishIcon" src="../img/button_digitize/geomRemove.png"></img>';
-						v[5] = Math.round(v[5] / 1024) + 'kb';
-					// add dialog for ópen links
-					$('#kml-from-wmc').html('<table class="display"></table>').find('table').dataTable({
-							aaData: data,
-							aoColumns: [{
-								sTitle: 'ID'
-								sTitle: 'Title'
-								sTitle: 'last change'
-								sTitle: 'License'
-								sTitle: 'public'
-								sTitle: 'size'
-								sTitle: 'owner'
-						.find('tr').bind('dblclick', function() {
-							var id = $($(this).find('td')[0]).text();
-							$.ajax({
-								type: 'post',
-								url: '../php/mb_load_local_data.php',
-								data: {
-									id: id
-									var kml = $('#mapframe1').data('kml');
-									$.each(data, function(url, json) {
-										kml.addLayer(url, json.data);
-									$(dlg).dialog('destroy');
-						}).end()
-						.find('.exportImage').bind('click', function(event) { // add click event to the link image
-							// stop event propagation beacause the following bind has to catch the click events on the 'tr'
-							event.stopPropagation();
-							if ($('#dataExportDialog').dialog('isOpen') === true) {
-								$('#dataExportDialog').dialog('close');
-								$('#dataExportDialog').remove();
-								$(this).trigger('click');
-							} else {
-								var title = $(this).parent().siblings().eq(1).html();
-								var wmc_serial_id = $(this).parent().siblings().eq(0).html();
-								var outputFormat;
-								var dataExportDlg = $('<div id="dataExportDialog"></div>').dialog({
-									title: "Export my data " + title,
-									width: 250,
-									height: 212,
-									position: {
-										my: "center",
-										at: "top",
-										of: window
-										$('#dataExportDialog').dialog('destroy');
-								// var exportHtmlsdfdsf = '<div id="exportHtml">' + '<form>' + '<label class="export-format-kml">KML<input type="radio" name="export-format" value="kml" checked="checked"></input></label>' + '<label class="export-format-kml">KML<input type="radio" name="export-format" value="kml" checked="checked"></input></label>' + '<label class="export-format-kml">KML<input type="radio" name="export-format" value="kml" checked="checked"></input></label><br><br>' +
-								//     '<img src="../img/osgeo_graphics/geosilk/link22.png"/>' + '<label class="export-format-gpx">GPX</label>' + '<label class="export-format-geojson">geoJSON</label><br></br>' +
-								//     '<a download="myfeatures.kml" href="#" class="digitize-image digitize-export" style="float: left;"></a>' + '</form>' + '</div>';
-								var exportHtml = '<div id="exportHtml"><table><tbody>' +
-									'<tr><td>KML:</td><td><label class="export-format-kml exportDatasetIcon" style="padding-top:11px;"></label></td><td class="exportDataLink kml" wmcId="' + wmc_serial_id + '"outputFormat="kml"><img src="../img/osgeo_graphics/geosilk/link22.png"/></td></tr>' +
-									'<tr><td>GPX:</td><td><label class="export-format-gpx exportDatasetIcon" style="padding-top:11px;"></label></td><td class="exportDataLink gpx" wmcId="' + wmc_serial_id + '"outputFormat="gpx"><img src="../img/osgeo_graphics/geosilk/link22.png"/></td></tr>' +
-									'<tr><td>GeoJson:</td><td><label class="export-format-geojson exportDatasetIcon" style="padding-top:11px;"></label></td><td class="exportDataLink geojson" wmcId="' + wmc_serial_id + '"outputFormat="geojson"><img src="../img/osgeo_graphics/geosilk/link22.png"/></td></tr>' +
-									'</tbody></table></div><iframe id="export-DataCollection" style="border:0;height:0; width:0;"></iframe>';
-								// append the context
-								$(dataExportDlg).append(exportHtml);
-								//export the data
-								$('.exportDatasetIcon').bind('click', function(event) {
-									var exportClass = $(this).attr('class').toString().split(' ')[0];
-									//getting the outputformat
-									switch (exportClass) {
-										case 'export-format-kml':
-											outputFormat = 'kml';
-											break;
-										case 'export-format-gpx':
-											outputFormat = 'gpx';
-											break;
-										case 'export-format-geojson':
-											outputFormat = 'geojson';
-											break;
-									$('#export-DataCollection').attr("src", "../php/mod_GetPublishedData.php?wmc_id=" + wmc_serial_id + "&outputFormat=" + outputFormat);
-								$('.exportDataLink').bind('click', function(event) {
-									var format = $(this).attr('outputFormat');
-									var exportDataLinkDlg = $('<div id="exportDataLinkDlg"></div>').dialog({
-										"title": "Link to your Dataset",
-										width: 350,
-										height: 80,
-											$('#exportDataLinkDlg').dialog('destroy');
-											$('#exportDataLinkDlg').remove();
-									var exportDataLinkContent = '<div><label for="exportLinkInput">Link: </label><input id="exportLinkInput" size="35" type="text" value="http://' + window.location.hostname + '/mapbender/php/mod_GetPublishedData.php?wmc_id=' + wmc_serial_id + '&outputFormat=' + format + '"></div>';
-									$(exportDataLinkDlg).append(exportDataLinkContent);
-						.end()
-						.find('.publishIcon').bind('click', function() {
-							// var id = $($(this).find('td')[0]).text();
-							var id = $(this).parent().parent().children(':first').html();
-							var d;
-							$.each(origData, function(_, val) {
-								if (val[0] == id) {
-									d = val;
-							var dlg = '<div title="Options ' + d[1] + '">' +
-								'<ul class="kmltree-metadata-list">' + '<li class="kmltree-metadata-delete"><img style="vertical-align: middle;" src="../img/button_digitize/geomRemove.png"></img>Delete datacollection</li>';
-							if (d[4]) {
-								dlg += '<li class="kmltree-metadata-unpublish"><img style="vertical-align: middle;" src="../img/gnome/emblem-unreadable.png"></img>Withdraw publication</li>';
-							} else {
-								dlg += '<li class="kmltree-metadata-publish"><img style="vertical-align: middle;" src="../img/gnome/share.png"></img>Publish datacollection</li>';
-							dlg += '</ul></div>';
-							dlg = $(dlg).appendTo('body');
-							$(dlg).dialog({
-								create: function() {
-									$(dlg).find('li.kmltree-metadata-delete').bind('click', function() {
-										if (confirm('Really delete spatial data set?')) {
-											$.ajax({
-												type: 'post',
-												url: '../php/mb_delete_local_data.php',
-												data: {
-													id: id
-													if (arguments[1] == 'success') {
-														alert('Deleting local data was succesfull');
-														$('#mySpatialData').dialog('destroy');
-														$($addButton).trigger('click');
-													} else {
-														alert('Problem when deleting local data');
-									$(dlg).find('li.kmltree-metadata-unpublish').bind('click', function() {
-										if (confirm('Really unpublish spatial data set?')) {
-											$.ajax({
-												url: '../php/mb_unpublish_wmc.php',
-												type: 'POST',
-												data: {
-													wmc_serial_id: id
-									$(dlg).find('li.kmltree-metadata-publish').bind('click', function() {
-										// check if the user is public(guest-user) or not
-										var isPublic;
-										$.ajax({
-											url: '../php/mb_checkGuest.php',
-											type: 'POST',
-												isPublic = data;
-												if (isPublic == 1){
-													alert('To publicate a WMC is not allowed for the Guest-User!'+
-														  'If you want to use this function, please create an account.');
-													return false;
-												var publishDialog;
-												if ($('#wmcPublishConfirm').dialog('isOpen') === true) {
-													return;
-												} else {
-													publishDialog = $('<div id="wmcPublishConfirm"></div>').dialog({
-														title: "Publish datacollection " + d[1],
-														width: 373,
-														height: 'auto',
-														position: {
-															my: "center",
-															at: "top",
-															of: window
-															// $('#kml-load-tabs').tabs('destroy');
-															// $(this).html('').dialog('destroy');
-															$('#wmcPublishConfirm').dialog('destroy');
-															$('#wmcPublishConfirm').remove();
-													var publishDlgContent = "<div style='font-size:16px;text-align:justify'>If you want to publish a datacolletcion, you first have to choose a license" +
-														" under which you want to distribute your data. Actually only OpenData compatible" +
-														" licences are supported in this application. Please read the licenses carefully before" +
-														" you activate this option. All of your data will be available for each person in the web" +
-														" in different formats and may be redistributed freely without any copyright. </div>" +
-														"<table style='margin-top:7px' ><tr><th id = 'publishDenied'><img src='../img/button_digitize/geomRemove.png'></img>  No, I dont't want to publish</th>" +
-														"<th style='width:16%;visibility:hidden'>empty</th>" +
-														"<th id = 'publishConfirmed'><img src='../img/osgeo_graphics/check.png'></img>  Yes, I know what I am doing </th></tr></table>";
-													$(publishDialog).append(publishDlgContent);
-												$(publishDialog).find('#publishConfirmed').bind('click', function() {
-													$(publishDialog).dialog('close');
-													var chooseLicenseDialog = $('<div id="chooseLicenseDialog"></div>').dialog({
-														title: "Choose OpenData license for datacollection " + d[1],
-														width: 720,
-														height: 150,
-														position: {
-															my: "center",
-															at: "top",
-															of: window
-															$('#chooseLicenseDialog').dialog('destroy');
-															$('#chooseLicenseDialog').remove();
-													var chooseLicenseDlgCont = "<div><table id='licenseTbl'style='border-collapse: collapse'>" +
-														"<tr><th>Lizenz</th>" +
-														"<th>Logo</th><th>Beschreibung</th><th>Opendata</th></tr>" +
-														"<tr><td><select id='licenseChooser name='license'>" +
-														"</select></td>" +
-														"<td id='licenseImg'></td>" +
-														"<td id='licenseDescription'></td>" +
-														"<td id='licenseOpen' nowrap></td></tr>" +
-														"<tr id='submitLicense' ><td style='border:none;cursor:pointer; nowrap'><img src='../img/osgeo_graphics/check.png' style='margin-top:10px'/> <span>Publish data</span></td></tr>" +
-														"</table></div>";
-													//  add options for the select box
-													$(chooseLicenseDialog).append(chooseLicenseDlgCont);
-													$.ajax({
-														url: '../php/mb_publish_wmc.php',
-														type: 'POST',
-														data: {
-															wmc_serial_id: id,
-															mode: 'getAllLicencesMode',
-															license: 'empty',
-															openData_only: options.openData_only,
-															for (var i = 0; i < data.length; i++) {
-																$('#licenseTbl select').append("<option>" + data[i].name + "</option>");
-													$.ajax({
-														type: 'POST',
-														data: {
-															mode: 'getLicenseMode',
-															license: 'cc-by'
-															$('#licenseImg').html('<img src="' + data.symbollink + '" />');
-															$('#licenseDescription').html('<a href="' + data.description + '" />' + data.description + '</a>');
-															if (data.isopen == 1) {
-																$('#licenseOpen').html('<img src="../img/od_80x15_blue.png" />');
-															} else {
-																$('#licenseOpen').html('<span>No OpenData</span>');
-													$('#licenseTbl select').bind('change', function(event) {
-														$('#licenseImg').html('');
-														$('#licenseDescription').html('');
-														$.ajax({
-															type: 'POST',
-															data: {
-																license: $('#licenseTbl select').val()
-																} else {
-													$('#submitLicense').bind('click', function(event) {
-														//save the license from the choosed wmc
-														$.ajax({
-															type: 'POST',
-															data: {
-																mode: 'saveLicenseMode',
-												$(publishDialog).find('#publishDenied').bind('click', function() {
-					// .bind('dblclick', function() {
-					//     $.ajax({
-					//         type: 'post',
-					//         url: '../php/mb_load_local_data.php',
-					//         data: {
-					//             id: id
-					//         success: function(data) {
-					//             var kml = $('#mapframe1').data('kml');
-					//             $.each(data, function(url, json) {
-					//                 kml.addLayer(url, json.data);
-					//             $(dlg).dialog('destroy');
-			$('#kml-load-tabs').tabs();
-			$('#kml-load-tabs').find('button.add').bind('click', function() {
-				$('#mapframe1').kml({ //TODO: what is happening?
-					url: $('#kml-load-tabs').find('.kmlurl').val()
-			$('#kml-load-tabs').find('button.add-kml').bind('click', function() {
-				var title = $('#kml-load-tabs input[name="kml-new-title"]').val();
-				var version = 'v1'
-				if (title == '') {
-					return;
-				kml.addLayer(title, {
-					uuid: UUID.genV4().toString(),
-					created: new Date().toISOString(),
-					title: title,
-					updated: new Date().toISOString(),
-					version: version,
-					type: 'FeatureCollection',
-					features: []
-			var ifr = $('iframe[name="kml-upload-target"]')[0];
-			var onloadfun = function() {
-				ifr.onload = null;
-				var txt = $(this).contents().find('pre').text(); // result von uploadKML.php
-				var data;
-				try {
-					data = JSON.parse(txt);
-				} catch (e) {
-					var xml = new DOMParser().parseFromString(txt, 'application/xml');
-					data = toGeoJSON.gpx(xml);
-				var name;
-				// check the features for properties
-				data = setFeatureAttr(data);
-				if (data.hasOwnProperty('title')) {
-					name = data['title'];
-					kml.addLayer(name, data);
-				} else {
-					name = $('#kml-from-upload input[type="file"]').val();
-					// test.replace(/\\/g,"/").split("/")
-					if (name.replace(/\\/g, "/").split("/")) {
-						// name = name.match(/[\\]([^\\]+)/g);
-						name = name.replace(/\\/g, "/").split("/");
-					name = name[name.length - 1];
-			$('#kml-from-upload form').bind('submit', function() {
-				if ( $( "#kml-from-upload > form > input[type='file'] " ).val() === "") {
-					return;
-				ifr.onload = onloadfun;
-	$KMLfolder.find('ul').before(selectButton);
-	$KMLfolder.find("ul").before($addButton);
-	var btn = new Mapbender.Button({
-		domElement: selectButton[0],
-		over: '../img/osgeo_graphics/geosilk/cursor_selected.png',
-		on: '../img/osgeo_graphics/geosilk/cursor_selected.png',
-		off: '../img/osgeo_graphics/geosilk/cursor.png',
-		name: 'toggle-select-features',
-		go: function() {
-			kml.setQueriedLayer(true);
-		stop: function() {
-			kml.setQueriedLayer(false);
-	o.$target.bind('kml:loaded', function(e, obj) {
-		var checked = obj.display ? 'checked="checked"' : '';
-		title = obj.url;
-		if (obj.refreshing) {
-			$KMLfolder.find('ul li[title="' + title + '"]').remove();
-		abbrevTitle = title.length < 20 ? title : title.substr(0, 17) + "...";
-		$kmlEntry = $('<li title="' + title + '" class="open"><button class="digitize-menu-arrow"></button><button class="toggle" name="toggle" value="toggle" ></button> <input type="checkbox"' + checked + '/><a href="#">' + abbrevTitle + '</a></li>');
-		$KMLfolder.children("ul").append($kmlEntry);
-		$kmlEntry.find("a").bind("click", (function(url) {
-			return function() {
-				$('#mapframe1').data('kml').zoomToLayer(url);
-		})(obj.url));
-		//@TODO: add default icon for points,polygons and linestrings on import
-		$featureList = $("<ul />");
-		$kmlEntry.append($featureList);
-		var pointCount = 1;
-		var polygonCount = 1;
-		var linestringCount = 1;
-		for (var i = obj.data.features.length - 1; i >= 0; --i) { //FIXME: for feature without the "type: FeatureCollection ",change functionallity: if (obj.data.type == "Feature") ...
-			var multi = obj.data.features[i].geometry.type.match(/^Multi/i);
-			var toggle = '';
-			if (multi) {
-				toggle = '<button class="toggle" name="toggle" value="toggle"></button>';
-			if (obj.data.features[i].properties.name) {
-				title = obj.data.features[i].properties.name;
-			} else if (obj.data.features[i].properties.title) {
-				title = obj.data.features[i].properties.title;
-			} else {
-				switch (obj.data.features[i].geometry.type){
-					case 'Point':
-						title = 'point_'+pointCount;
-						pointCount += 1;
-						break;
-					case 'Polygon':
-						title = 'polygon_'+polygonCount;
-						polygonCount += 1;
-						break;
-					case 'LineString':
-						title = 'linestring_'+linestringCount;
-						linestringCount += 1;
-						break;
-				// title = 'Title undefined';
-			// title = obj.data.features[i].properties.name;
-			var displ = obj.data.features[i].display === true || obj.data.features[i].display === undefined;
-			$feature = $('<li idx="' + i + '" title="' + title + '"><button class="digitize-menu-arrow"></button>' + toggle + '<input type="checkbox" ' + (displ ? 'checked="checked"' : '') + '/><div class="style-preview" style="width: 20px; height: 20px; display: inline;"></div><a href="#" >' + abbrevTitle + '</a></li>');
-			$featureList.append($feature);
-			var preview = $feature.find('.style-preview').get(0);
-			$('#mapframe1').data('kml').renderPreview(obj.data.features[i], preview, 20);
-			$feature.bind('mouseout', (function(jsonFeature) {
-					var map = o.$target.mapbender();
-					var g = new GeometryArray();
-					g.importGeoJSON(jsonFeature, false);
-					var feature = g.get(0);
-					if (feature.geomType != "point") {
-						var me = $kmlTree.mapbender();
-						me.resultHighlight.clean();
-						me.resultHighlight.paint();
-			})(obj.data.features[i]));
-			$feature.bind('mouseover', (function(jsonFeature) {
-						feature = feature.getBBox4();
-						me.resultHighlight = new Highlight(
-							[o.target],
-							"KmlTreeHighlight", {
-								"position": "absolute",
-								"top": "0px",
-								"left": "0px",
-								"z-index": 100
-							2);
-						me.resultHighlight.add(feature, "#00ff00");
-					} else if (feature.geomType == "point") {
-		$('button.digitize-layer', $kmlEntry).bind('click', function() {
-			var active = $(this).toggleClass('active').hasClass('active');
-			if (active) {
-				$(this).parent().siblings().find('button.digitize-layer').removeClass('active');
-		$('#kmlTree > li > ul').sortable({
-			update: function() {
-				var urls = [];
-				$(this).children('li[title]').each(function(k, v) {
-					urls.push($(this).attr('title'));
-				kml.setOrder(urls);
-		$('#kmlTree > li > ul > li > ul').sortable({
-			update: function(evt, data) {
-				var url = $(this).parent().attr('title');
-				var ids = [];
-				var i = $(this).children().length;;
-				$.each($(this).children(), function(k, v) {
-					ids.push($(v).attr('idx'));
-					$(v).attr('idx', --i);
-				kml.reorderFeatures(url, ids.reverse());
-		$('input[type="checkbox"]', $kmlEntry).bind('click', function() {
-			var idx = $(this).parent().attr('idx');
-			if (idx === undefined) {
-				if ($(this).attr('checked')) {
-					o.$target.kml('show', obj.url);
-				} else {
-					o.$target.kml('hide', obj.url);
-			} else {
-					kml.showFeature(obj.url, idx);
-				} else {
-					kml.hideFeature(obj.url, idx);
-		$("button.toggle", $kmlEntry).bind('click', function() {
-			if ($(this).parent().hasClass("open")) {
-				$(this).parent().removeClass("open");
-				$(this).parent().addClass("closed");
-			} else {
-				$(this).parent().removeClass("closed");
-				$(this).parent().addClass("open");
-			// IE8 workaround to make style previews visible...
-			$(this).parent().find('ul.ui-sortable li .rvml').removeClass('rvml').addClass('rvml');
-		$('#tabs_kmlTree').bind('click', function() {
-			window.setTimeout(function() {
-				$('#kmlTree').find('ul.ui-sortable li .rvml').removeClass('rvml').addClass('rvml');
-			}, 1000);
-	var setFeatureAttr = function(data) {
-		var simpleStyleDefaults = {
-			"title": "",
-			"description": "",
-			"marker-size": "medium",
-			"marker-symbol": "",
-			"marker-color": "7e7e7e",
-			"stroke": "#555555",
-			"stroke-opacity": 1.0,
-			"stroke-width": 2,
-			"fill": "#555555",
-			"fill-opacity": 0.5
-		if (data.type == 'Feature') {
-			if (Object.getOwnPropertyNames(data.properties).length === 0 || data.properties === null) {
-				data.properties = simplyStyleDefaults;
-			} else {
-				$.each(simpleStyleDefaults, function(index, val) {
-					if (!data.properties.hasOwnProperty(index)) {
-						data.properties[index] = value;
-		} else if (data.type == 'FeatureCollection') {
-			// get all features in the featureCollection and set the default properties if they are not set
-			$.each(data.features, function(index, val) {
-				$.each(simpleStyleDefaults, function(prop, propVal) {
-					if (!val.properties.hasOwnProperty(prop)) {
-						//TODO: get index in this scope
-						data.features[index].properties[prop] = propVal;
-		return data;
-Mapbender.events.init.register(function() {
-	$kmlTree.mapbender(new KmlTree(options));
Deleted: trunk/mapbender/http/plugins/mb_div2jqdialog.js_deprecated
--- trunk/mapbender/http/plugins/mb_div2jqdialog.js_deprecated	2016-05-27 07:16:01 UTC (rev 9488)
+++ trunk/mapbender/http/plugins/mb_div2jqdialog.js_deprecated	2016-05-27 07:19:06 UTC (rev 9489)
@@ -1,68 +0,0 @@
- * Package: mb_div2jqdialog
- * Description:
- * Files:
- *  - ../plugins/mb_div2jqdialog.js
- * SQL:
- * Maintainer:
- * Parameters:
- * License:
-//check for elementVars
-options.divPopupTitle  = options.divPopupTitle || "Popup";
-options.divPopupHeight	= options.divPopupHeight || 250;
-options.divPopupWidth 	= options.divPopupWidth || 400;
-// see http://docs.jquery.com/UI/Dialog for possible values
-options.position = options.position || 'center';
-var $divjqdialog = $(this);
-var DivJqDialogApi = function(o) {
-		$(this).click(function(e) {
-			e.preventDefault();
-			var $this = $(this);
-			var horizontalPadding = 30;
-			var verticalPadding = 30;
-		var infoPopup = $('<div class="infoPopup"></div>');
-	        infoPopup.dialog({
-	            title: ($this.attr('title')) ? $this.attr('title') : "Popup",
-	            autoOpen: true,
-	            width: 800,
-	            height: 500,
-	            modal: true,
-	            resizable: true,
-				autoResize: true,
-	            overlay: {
-	                opacity: 0.5,
-	                background: "black"
-	        }).width(800 - horizontalPadding).height(500 - verticalPadding);
-		infoPopup.dialog("open");
-Mapbender.events.init.register(function(){
-     $divjqdialog.mapbender(new DivJqDialogApi(options));
Deleted: trunk/mapbender/http/plugins/mb_downloadFeedClient.php~
--- trunk/mapbender/http/plugins/mb_downloadFeedClient.php~	2016-05-27 07:16:01 UTC (rev 9488)
+++ trunk/mapbender/http/plugins/mb_downloadFeedClient.php~	2016-05-27 07:19:06 UTC (rev 9489)
@@ -1,178 +0,0 @@
-<?php
-	//http://localhost/mapbender_trunk/plugins/mb_downloadFeedClient.php
-	require_once dirname(__FILE__) . "/../../core/globalSettings.php";
-	require_once dirname(__FILE__) . "/../classes/class_user.php";
-if (isset($_REQUEST['url']) & $_REQUEST['url'] != "") {
-	//validate to iso date format YYYY-MM-DD
-	$testMatch = $_REQUEST["url"];
-	$pattern = '/^http\:\/\/[a-zA-Z0-9\-\.]+\.[a-zA-Z]{2,3}(\/\S*)?$/';
- 	if (!preg_match($pattern,$testMatch)){
-		echo 'url: <b>'.$testMatch.'</b> is not a valid url.<br/>';
-		die();
-	$url = urldecode($testMatch);
-	$testMatch = NULL;
-<html>
-<head>
-<title><?php echo _mb("INSPIRE ATOM Feed Client");?></title>
-<meta name="description" content="INSPIRE ATOM Feed Client" xml:lang="en" />
-<meta name="keywords" content="INSPIRE SDI GDI Download" xml:lang="en" />
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<meta http-equiv="content-language" content="en" />
-<meta http-equiv="content-style-type" content="text/css" />
-<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
-	<link rel="stylesheet" href="../extensions/OpenLayers-2.9.1/theme/default/style.css" type="text/css">
-	<style type="text/css">
-        select, textarea {
-            font: 0.9em Verdana, Arial, sans-serif;
-	textarea {
-		position: absolute;
-		right: 0;
-		width: 300px;
-		height: 40px;
-	#client {
-		width: 650px;
-		height: 870px;
-	#input_feed_url {
-	#dataset_select {
-	#dataset_info {
-		position: relative;
-	#representation_select {
-	#representation_info {
-	#dataset_info {
-		width: 1000px;
-		height: 300px;
-        #mapframe_dataset_list {
-	    position: absolut;
-	    top: 0;
-	    left: 0;
-            width: 350px;
-            height: 250px;
-            border: 1px solid #ccc;
-	#dataset_information{
-	    left: 400;
-	    top: 0;
-	    width: 500px;
-            height: 270px;
-	#mapframe {
-        #mapframe_file_list {
-            width: 325px;
-            height: 225px;
-	#section_list {
-		top: 0;
-		left: 0;
-		width: 325px;
-            	height: 225px;
-        #input {
-            width: 512px;
-        #text {
-            font-size: 0.85em;
-            margin: 1em 0 1em 0;
-            width: 100%;
-            height: 10em;
-        p {
-            margin: 0;
-            padding: 0.75em 0 0.75em 0;
-    </style>
-    	<!--<script src="../extensions/OpenLayers-2.9.1/OpenLayers.js"></script>-->
-	<script src="http://openlayers.org/api/OpenLayers.js"></script>
-	<script src="../extensions/jquery-ui-1.8.16.custom/js/jquery-1.6.2.min.js"></script>
-	<script src="../extensions/jquery-ui-1.8.16.custom/js/jquery-ui-1.8.16.custom.min.js"></script>
-	<script src="../javascripts/mb_downloadFeedClient.js"></script>
-</head>
-<body onload="init()">
-<fieldset id="client">
-	<legend><?php echo _mb("INSPIRE Download Service ATOM Feed Client");?><img src="../img/inspire_tr_36.png" /><!--<img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Client to download INSPIRE data on an easy way.");?>'}" src="../img/questionmark.png" alt="" />--></legend>
-	<div id="input_feed_url">
-	<p>
-		<form id="service_feed_form">
-		<label for="download_feed_url"><?php echo _mb("ATOM Feed url");?></label>
-		<input name="download_feed_url" id="download_feed_url" class="required" <?php if (isset($url)) {echo " value=\"".$url."\"";} else { echo " value=\"\"";}?>/><input type="button" title="Get Feed" id="download_feed_button" value="Get Feed Content"/>
-		</form>
-	</p>
-	</div>
-	<div id="dataset_list">
-		<div id="dataset_select"></div>
-	</div>
-	<br>
-	<div id="dataset_info">
-	<!--<fieldset>
-		<legend><?php echo _mb("Select dataset");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Select single dataset either in list or on map");?>'}" src="../img/questionmark.png" alt="" /></legend>-->
-		<div id="mapframe_dataset_list"></div>
-		<div id="dataset_information">
-			<!--<fieldset>
-				<legend><?php echo _mb("Dataset Feed entries");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("The fieldset shows the content of the INSPIRE Download Service service-feed document. It contains one or more links to different datasets.");?>'}" src="../img/questionmark.png" alt="" /></legend>-->
-				<p>
-					<label for="dataset_title"><?php echo _mb("Dataset title");?>:</label>
-					<textarea readonly="readonly" name="dataset_title" id="dataset_title"></textarea>
-				</p>
-				<p>
-					<label for="dataset_abstract"><?php echo _mb("Dataset abstract");?>:</label>
-					<textarea type="text" readonly="readonly" name="dataset_abstract" id="dataset_abstract" width="250px" height="20px"></textarea>
-				</p>
-				<p>
-					<!--<label for="resource_identifier"><?php echo _mb("Resource identifier");?>:</label>-->
-					<div id="dataset_identifier"><?php echo _mb("Resource identifier");?>:<br></div>
-				</p>
-				<p>
-					<label for="dataset_rights"><?php echo _mb("Rights");?>:</label>
-					<textarea readonly="readonly" name="dataset_rights" id="dataset_rights"></textarea>
-				</p>
-			<!--</fieldset>-->
-		</div>
-    </div>
-    <div id="representation_select">
-	<p>
-		<label for="representations"><?php echo _mb("Available representations");?>:</label>
-		<div id="dataset_representation_list"></div>
-	</p>
-    </div>
-    <div id="representation_info">
-	<!--<fieldset>
-	<legend><?php echo _mb("Files");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Files which can be downloaded");?>'}" src="../img/questionmark.png" alt="" /></legend>-->
-	<!--<input id="multi_select" type="checkbox" disabled ><?php echo _mb("Select multiple tiles");?></input><br>-->
-	<!--<label for="mapframe_file_list"><?php echo _mb("Position of files (if available)");?>:</label>-->
-	<!--<input type="list" id="file_list"/>-->
-	<div id="mapframe_file_list"></div>
-	<br>
-	<!--<label for="section_list"><?php echo _mb("List of files");?>:</label>-->
-	<!--<select id="section_file_list" multiple='multiple'>-->
-	<!--<input type="button" title="Download selected files" value="Download selection"/>-->
-	<!--</fieldset>	-->
-    </div>
-</fieldset>
-</body>
-</html>
Deleted: trunk/mapbender/http/plugins/mb_iframeButtonPopup.js_deprecated
--- trunk/mapbender/http/plugins/mb_iframeButtonPopup.js_deprecated	2016-05-27 07:16:01 UTC (rev 9488)
+++ trunk/mapbender/http/plugins/mb_iframeButtonPopup.js_deprecated	2016-05-27 07:19:06 UTC (rev 9489)
@@ -1,57 +0,0 @@
- * Package: mb_iframeButtonPopup
- * Description:
- * Files:
- *  - ../plugins/mb_iframeButtonPopup.js
- * SQL:
- * Maintainer:
- * Parameters:
- * License:
-var $iframebuttonpopup = $(this);
-var IframeButtonPopup = function(o) {
-		$(this).find('img').click(function(e) {
-	        $('<iframe src="' + this.href + '" target="'+this.target+'"/>').dialog({
-	            title: ($this.attr('title')) ? $this.attr('title') : 'External Site',
-	            autoOpen: true,
-	            width: 800,
-	            height: 500,
-	            modal: true,
-	            resizable: true,
-				autoResize: true,
-	            overlay: {
-	                opacity: 0.5,
-     $iframebuttonpopup.mapbender(new IframeButtonPopup(options));
Deleted: trunk/mapbender/http/plugins/mb_measure.js_deprecated
--- trunk/mapbender/http/plugins/mb_measure.js_deprecated	2016-05-27 07:16:01 UTC (rev 9488)
+++ trunk/mapbender/http/plugins/mb_measure.js_deprecated	2016-05-27 07:19:06 UTC (rev 9489)
@@ -1,330 +0,0 @@
-var $measure = $(this);
-var MeasureApi = function (o) {
-	var measureDialog,
-		measurePoints = [],
-		button,
-		canvases = {},
-		that = this,
-		opacity = 0.4,
-		srs;
-	var hideMeasureData = function () {
-		measureDialog.find(".mb-measure-clicked-point").parent().hide();
-		measureDialog.find(".mb-measure-current-point").parent().hide();
-		measureDialog.find(".mb-measure-distance").parent().hide();
-		measureDialog.find(".mb-measure-area").parent().hide();
-	var create = function () {
-		// Initialise measure dialog
-		var html = "<div>" +
-			"<p class='mb-measure-text'>Fahren Sie mit der Maus über die Karte, um die Koordinaten anzuzeigen.<br> Klicken Sie, um eine Messung zu starten</p>" +
-			"<p>Letzter Punkt: <span class='mb-measure-clicked-point' /></p>" +
-			"<p>Aktuelle Koordinaten: <span class='mb-measure-current-point' /></p>" +
-			"<p>Distanz: <span class='mb-measure-distance' /> m</p>" +
-			"<p>Fläche: <span class='mb-measure-area' /> <span class='mb-measure-area-unit' /></p>" +
-		"</div>";
-		measureDialog = $(html).appendTo(o.$target);
-		measureDialog.dialog({
-			autoOpen: false
-		}).bind("dialogclose", function () {
-			button.stop();
-		// Initialise Raphael canvas
-		Mapbender.events.init.register(function () {
-			o.$target.each(function () {
-				var map = $(this).mapbender();
-				var $canvas = $("<div />").css({
-					"z-index": 100,
-					"position": "relative"
-				}).appendTo(this);
-				canvases[map.elementName] =
-					Raphael($canvas.get(0), map.getWidth(), map.getHeight());
-		// Initialise button
-		button = new Mapbender.Button({
-			domElement: $measure.get(0),
-			off: o.src,
-			name: o.id,
-			go: that.activate,
-			stop: that.deactivate
-	var draw = function (map, pos) {
-		var canvas = canvases[map.elementName];
-		canvas.clear();
-		var str_path = "";
-		measurePoints.push(pos);
-		var len = measurePoints.length;
-		if (len > 0){
-			for (var k=0; k < len; k++) {
-				var pk = measurePoints[k];
-				var q = map.convertRealToPixel(pk);
-				if (k === 0) {
-					str_path += 'M';
-				else {
-					str_path += 'L';
-				str_path += q.x + ' ' + q.y;
-				var circle = canvas.circle(q.x, q.y, 3);
-				if (k === 0) {
-					circle.attr({
-						fill: "#f00",
-						stroke: "none",
-						opacity: opacity
-				else {
-					circle.attr({
-						fill: "#f00",
-						stroke: "none",
-						opacity: opacity
-		measurePoints.pop();
-		if (isPolygon(measurePoints, pos)) {
-			var poly = canvas.path(str_path + 'Z');
-			poly.attr({
-				fill: "#0f0",
-				opacity: opacity
-		var line = canvas.path(str_path);
-		line.attr({
-			stroke: "#00f",
-			opacity: opacity
-		line.toFront();
-	var updateCurrentPoint = function (p) {
-		measureDialog.find(".mb-measure-current-point").text(
-			p.x + " " + p.y
-		).parent().show();
-	var updateClickedPoint = function (p) {
-		measureDialog.find(".mb-measure-clicked-point").text(
-			p.x + " " + p.y
-	var updateDistance = function (dist) {
-		if (!dist) {
-			return;
-		measureDialog.find(".mb-measure-distance").text(Math.abs(dist)).parent().show();
-	var updateArea = function (area) {
-		if (area === null) {
-			return;
-		var areaUnit = "m²";
-		if (area > 10000000){
-			area /= 1000000;
-			areaUnit = "km²";
-		else if (area > 100000){
-			area /= 10000;
-			areaUnit = "ha";
-		area = Math.round(area*10)/10;
-		measureDialog.find(".mb-measure-area-unit").html(areaUnit);
-		measureDialog.find(".mb-measure-area").text(area).parent().show();
-	var calculateDistanceGeographic = function (a, b) {
-		var lon_from = (a.x * Math.PI) / 180;
-		var lat_from = (a.y * Math.PI) / 180;
-		var lon_to = (b.x * Math.PI) / 180;
-		var lat_to = (b.y * Math.PI) / 180;
-		return Math.abs(6371229 * Math.acos(
-			Math.sin(lat_from) * Math.sin(lat_to) +
-			Math.cos(lat_from) * Math.cos(lat_to) *
-			Math.cos(lon_from - lon_to)
-	var calculateDistanceMetric = function (a, b) {
-		return Math.abs(Math.sqrt(
-			Math.pow(Math.abs(b.x - a.x), 2) +
-			Math.pow(Math.abs(b.y - a.y), 2)
-	var calculateDistance = function (map, a, b) {
-		if (a !== null && b !== null) {
-			switch (map.getSrs()) {
-				case "EPSG:4326":
-					return calculateDistanceGeographic(a, b);
-				default:
-					return calculateDistanceMetric(a, b);
-		return null;
-	var calculateArea = function (pos) {
-		if (measurePoints.length < 2) {
-			return null;
-		var area = 0;
-		var p0 = measurePoints[0], pi, pj;
-		for (var i = 0; i < measurePoints.length - 1; i++)  {
-			pi = measurePoints[i];
-			pj = measurePoints[i + 1];
-			area += (pi.y + pj.y) * (pi.x - pj.x) / 2;
-		area += (p0.y + pj.y) * (p0.x - pj.x) / 2;
-		return Math.abs(area);
-	var isPolygon = function (measurePoints, pos) {
-		if (len < 2) {
-			return false;
-		var pn = measurePoints[len - 1];
-		for (var i = 0; i < measurePoints.length - 2; i++)  {
-			var p1 = measurePoints[i];
-			var p2 = measurePoints[i + 1];
-			if (lineIntersect(p1.x, p1.y, p2.x, p2.y, pn.x, pn.y, pos.x, pos.y)) {
-				return false;
-		return true;
-	var lineIntersect = function ( a1, a2, b1, b2, c1, c2, d1, d2 ) {
-		var s, t, N = (b1-a1)*(d2-c2)-(b2-a2)*(d1-c1);
-		if (N === 0) {
-			// parallel
-			return false;
-		s = ((c1-a1)*(d2-c2)-(c2-a2)*(d1-c1)) / N;
-		t = (a1-c1 + s*(b1-a1)) / (d1-c1);
-		if (s <= 1 && s>=0 && t <= 1 && t>=0) {
-			return true;
-		return false;
-	var measure = function (e) {
-		var map = $(e.currentTarget).mapbender();
-		if (srs !== map.getSrs()){
-			button.stop();
-			return;
-		var pos = map.convertPixelToReal(map.getMousePosition(e));
-		updateCurrentPoint(pos);
-		var previousPoint = measurePoints.length > 0 ?
-			measurePoints[measurePoints.length - 1] : null;
-		var distance = calculateDistance(map, previousPoint, pos);
-		updateDistance(distance);
-			updateArea(calculateArea(pos));
-		draw(map, pos);
-	var addPoint = function (e) {
-		updateClickedPoint(pos);
-		draw(map, pos);
-	var addLastPoint = function (e) {
-		if ($(e.currentTarget).size() > 0) {
-			$(e.currentTarget).unbind("mousedown", addPoint)
-				.unbind("dblclick", addLastPoint)
-				.unbind("mousemove", measure);
-			$(e.currentTarget).css("cursor", "auto");
-		addPoint(e);
-	this.activate = function () {
-		if (o.$target.size() > 0) {
-			o.$target.bind("mousedown", addPoint)
-				.bind("dblclick", addLastPoint)
-				.bind("mousemove", measure);
-			o.$target.css("cursor", "crosshair");
-		srs = o.$target.mapbender().getSrs();
-		measureDialog.dialog("open");
-	this.deactivate = function () {
-			o.$target.unbind("mousedown", addPoint)
-			o.$target.css("cursor", "auto");
-		srs = undefined;
-		for (var i in canvases) {
-			canvases[i].clear();
-		measurePoints = [];
-		hideMeasureData();
-		measureDialog.dialog("close");
-		button.stop();
-	create();
-$measure.mapbender(new MeasureApi(options));
Deleted: trunk/mapbender/http/plugins/mb_measure_widget.js_deprecated
--- trunk/mapbender/http/plugins/mb_measure_widget.js_deprecated	2016-05-27 07:16:01 UTC (rev 9488)
+++ trunk/mapbender/http/plugins/mb_measure_widget.js_deprecated	2016-05-27 07:19:06 UTC (rev 9489)
@@ -1,184 +0,0 @@
- * Package: measure_widget
- * Description:
- * Measure module with jQuery UI widget factory and RaphaelJS
- * Files:
- *  - http/plugins/mb_measure_widget.js
- *  - http/widgets/w_measure.js
- * SQL:
- * > e_target, e_requires, e_url) VALUES('<appId>','measure_widget',2,1,
- * > 'Measure','Measure distance','img',
- * > '../img/button_blink_red/measure_off.png','',515,60,24,24,1,'','','',
- * > '../plugins/mb_measure_widget.js',
- * > '../widgets/w_measure.js,../extensions/RaphaelJS/raphael-1.4.7.min.js',
- * > 'mapframe1','jq_ui_dialog,jq_ui_widget',
- * > 'http://www.mapbender.org/index.php/Measure');
- * Help:
- * http://www.mapbender.org/Measure_widget
- * Maintainer:
- * License:
-		button,
-		that = this,
-		title = "Messung",
-		defaultHtml = "<div title='" + title + "'>" +
-			"<div class='mb-measure-text'>Fahren Sie mit der Maus über die Karte, um die Koordinaten anzuzeigen.<br> Klicken Sie, um eine Messung zu starten</div>" +
-		"</div>",
-		totalDistance,
-		currentDistance,
-		informationHtml =
-			"<div>Letzter Punkt: <span class='mb-measure-clicked-point' /></div>" +
-			"<div>Aktuelle Koordinaten: <span class='mb-measure-current-point' /></div>" +
-			"<div>Distanz (zum letzten Punkt): <span class='mb-measure-distance-last' />  <span class='mb-measure-distance-last-unit' /></div>" +
-			"<div>Distanz (gesamt): <span class='mb-measure-distance-total' /> <span class='mb-measure-distance-total-unit' /></div>" +
-			"<div>Fläche: <span class='mb-measure-area' /> <span class='mb-measure-area-unit' /></div>" +
-			"<a class='mb-measure-clear' href='#' title='Messung löschen'/>";
-//		measureDialog.find(".mb-measure-current-point").parent().hide();
-		measureDialog.find(".mb-measure-distance-last").parent().hide();
-		measureDialog.find(".mb-measure-distance-total").parent().hide();
-	var changeDialogContent = function () {
-		measureDialog.html(informationHtml);
-		o.$target.unbind("mouseenter", changeDialogContent);
-		measureDialog = $(defaultHtml);
-			autoOpen: false,
-			position: [o.$target.offset().left, o.$target.offset().top]
-			that.deactivate();
-			off: o.src,
-			name: o.id,
-	var updateCurrentPoint = function (evt, p) {
-			p.pos.x + " " + p.pos.y
-	var updateClickedPoint = function (evt, p) {
-		totalDistance = typeof totalDistance === "number" ? totalDistance + currentDistance : currentDistance;
-	var updateDistance = function (evt, dist) {
-		if (typeof dist !== "number") {
-			return;
-		var lastDistanceUnit = "m";
-		currentDistance = dist;
-		displayDistance = dist;
-		if (displayDistance > 10000){
-			displayDistance /= 1000;
-			lastDistanceUnit = "km";
-		measureDialog.find(".mb-measure-distance-last-unit").html(lastDistanceUnit);
-		measureDialog.find(".mb-measure-distance-last").text(Math.round(displayDistance*10)/10).parent().show();
-		var totalDistanceUnit = "m";
-		var displayTotalDistance = typeof totalDistance === "number" ? totalDistance + dist : dist;
-		if (displayTotalDistance > 10000){
-			displayTotalDistance = displayTotalDistance / 1000;
-			totalDistanceUnit = "km";
-		measureDialog.find(".mb-measure-distance-total-unit").html(totalDistanceUnit);
-		measureDialog.find(".mb-measure-distance-total").text(Math.round(displayTotalDistance*10)/10).parent().show();
-	var updateArea = function (evt, area) {
-			return;
-			area /= 1000000;
-			areaUnit = "km²";
-			area /= 10000;
-			areaUnit = "ha";
-			o.$target
-				.mb_measure()
-				.bind("mb_measurepointadded", updateClickedPoint)
-				.bind("mb_measureonmeasure", updateCurrentPoint)
-				.bind("mb_measureonmeasuredistance", updateDistance)
-				.bind("mb_measureonmeasurearea", updateArea)
-				.bind("mouseenter", changeDialogContent);
-			o.$target.mb_measure("destroy");
-		if (measureDialog.dialog("isOpen")) {
-	create();
Deleted: trunk/mapbender/http/plugins/mb_print.js_deprecated
--- trunk/mapbender/http/plugins/mb_print.js_deprecated	2016-05-27 07:16:01 UTC (rev 9488)
+++ trunk/mapbender/http/plugins/mb_print.js_deprecated	2016-05-27 07:19:06 UTC (rev 9489)
@@ -1,565 +0,0 @@
- * Package: printPDF
- * Description:
- * Mapbender print PDF with PDF templates module.
- * Files:
- *  - http/plugins/mb_print.php
- *  - http/print/classes
- *  - http/print/printFactory.php
- *  - http/print/printPDF_download.php
- *  - lib/printbox.js
- * SQL:
- * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
- * > e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>','printPDF',
- * > 2,1,'pdf print','Print','div','','',1,1,2,2,5,'',
- * > '<div id="printPDF_working_bg"></div><div id="printPDF_working"><img src="../img/indicator_wheel.gif" style="padding:10px 0 0 10px">Generating PDF</div><div id="printPDF_input"><form id="printPDF_form" action="../print/printFactory.php"><div id="printPDF_selector"></div><div class="print_option"><input type="hidden" id="map_url" name="map_url" value=""/><input type="hidden" id="legend_url" name="legend_url" value=""/><input type="hidden" id="overview_url" name="overview_url" value=""/><input type="hidden" id="map_scale" name="map_scale" value=""/><input type="hidden" name="measured_x_values" /><input type="hidden" name="measured_y_values" /><br /></div><div class="print_option" id="printPDF_formsubmit"><input id="submit" type="submit" value="Print"><br /></div></form><div id="printPDF_result"></div></div>',
- * > 'div','../plugins/mb_print.php',
- * > '../../lib/printbox.js,../extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe/jquery.bgiframe.min.js,../extensions/jquery.form.min.js',
- * > 'mapframe1','','http://www.mapbender.org/index.php/Print');
- * > var_value, context, var_type) VALUES('<appId>', 'printPDF',
- * > 'mbPrintConfig', '{"Standard": "mapbender_template.json"}', '' ,'var');
- * > var_value, context, var_type) VALUES('<appId>', 'body',
- * > 'print_css', '../css/print_div.css', '' ,'file/css');
- * Help:
- * http://www.mapbender.org/PrintPDF_with_template
- * Maintainer:
- * http://www.mapbender.org/User:Michael_Schulz
- * Parameters:
- * mbPrintConfig      - *[optional]* object with name and filename of template,
- * 							like 	{
- * 										"Standard": "a_template.json",
- * 										"Different": "another_template.json"
- * License:
-var myTarget = options.target ? options.target[0] : "mapframe1";
-var myId = options ? options.id : "printPDF";
-var mbPrintConfig = options.mbPrintConfig;
-/* the array of json print config files */
-if (typeof mbPrintConfig === "object") {
-	mbPrintConfigFilenames = [];
-	mbPrintConfigTitles = [];
-	for (var i in mbPrintConfig) {
-		mbPrintConfigFilenames.push(mbPrintConfig[i]);
-		mbPrintConfigTitles.push(i);
-if (typeof mbPrintConfigFilenames === "undefined") {
-	mbPrintConfigFilenames = ["mapbender_template.json"];
-if (typeof mbPrintConfigTitles === "undefined") {
-	mbPrintConfigTitles = ["Default"];
-var mbPrintConfigPath = "../print/";
-/* ------------- printbox addition ------------- */
-var PrintPDF = function (options) {
-	var that = this;
- 	 * Property: actualConfig
-	 * object, holds the actual configuration after loading the json file
-	var actualConfig;
- 	 * constructor
-	eventInit.register(function () {
-		mod_printPDF_init();
- 	 * Property: printBox
-	 * the movable printframe
-	var printBox = null;
-	eventAfterMapRequest.register(function () {
-		if (printBox !== null) {
-			printBox.repaint();
- 	 * Method: createPrintBox
-	 * creates a printBox in the current view, calculates the scale
-	 * (tbd. if not set from the config) so that the printbox fits in the mapframe.
-	 * Width and height are taken from the configuration.
-	this.createPrintBox = function () {
-		size = "A4";
-		//document.form1.size.value = size;
-		format = "portrait";
-		var w, h;
-		//validate();
-		var map = getMapObjByName(myTarget);
-		var map_el = map.getDomElement();
-		var jqForm = $("#"+myId+"_form");
-		var $scaleInput = $("#scale");
-			printBox.destroy();
-			printBox = null;
-			jqForm[0].scale.value = "";
-			jqForm[0].coordinates.value = "";
-			jqForm[0].angle.value = "";
-		else {
-			printBox = new Mapbender.PrintBox({
-				target : myTarget,
-				printWidth : getPDFMapSize("width")/10,
-				printHeight : getPDFMapSize("height")/10,
-				scale : $scaleInput.size() > 0 && !isNaN(parseInt($scaleInput.val(), 10)) ?
-					parseInt($scaleInput.val(), 10) :
-					Math.pow(10, Math.floor(Math.log(map.getScale())/Math.LN10)),
-				afterChangeAngle : function (obj) {
-					if (typeof(obj) == "object") {
-						if (typeof(obj.angle) == "number") {
-							jqForm[0].angle.value = obj.angle;
-						if (obj.coordinates) {
-							jqForm[0].coordinates.value = String(obj.coordinates);
-				afterChangeSize : function (obj) {
-						if (obj.scale) {
-							jqForm[0].scale.value = parseInt(obj.scale / 10, 10) * 10;
-			printBox.paintPoints();
-			printBox.paintBox();
- 	 * Method: getPDFMapSize
-	 * checks the actual config for the size w/h values.
-	 * Parameters:
-	 * key      - string, the key which value to retrieve (currently width or height)
-	var getPDFMapSize = function (key) {
-		for (var page in actualConfig.pages) {
-			for (var pageElement in actualConfig.pages[page].elements) {
-				if (actualConfig.pages[page].elements[pageElement].type == "map") {
-					return actualConfig.pages[page].elements[pageElement][key];
- 	 * Method: destroyPrintBox
-	 * removes an existing printBox.
-	var destroyPrintBox = function () {
-		if (printBox) {
- 	 * Method: mod_printPDF_init
-	 * initializes the print modules, generates template chooser and loads first configuration.
-	var mod_printPDF_init = function () {
-		/* first we'd need to build the configuration selection */
-		buildConfigSelector();
-		/* second we'd need to read the json configuration */
-		that.loadConfig(mbPrintConfigFilenames[0]);
- 	 * Method: loadConfig
-	 * GETs the config, build corresponding form, remove an existing printBox
-	this.loadConfig = function (configFilename, callback) {
-		$.get(mbPrintConfigPath + configFilename, function(json, status){
-		    actualConfig = $.parseJSON(json);
-		    buildForm();
-		    hookForm();
-			if (typeof callback === "function") {
-				printBox = null;
-				callback();
-		destroyPrintBox();
- 	 * Method: hookForm
-	 * utility method to connect the form plugin to the print form.
-	var hookForm = function () {
-		var o = {
-	   		url:			'../print/printFactory.php',
-	   		type:			'post',
-	   		dataType:		'json',
-	   		beforeSubmit: 	validate,
-	   		success:    	showResult
-		$("#"+myId+"_form").ajaxForm(o);
-	 * Change status of the working elements. These should begin with "$myId_working"
-	 * @param {String} newStatus either "hide or "show"
-	var showHideWorking = function (newStatus) {
-		if (newStatus=="hide") {
-	    	$("[id^='"+myId+"_working']").hide();
-	    else {
-	    	$("[id^='"+myId+"_working']").show();
-	 * update form values helper function
-	var updateFormField = function (formData, key, value) {
-		for(var j=0; j < formData.length; j++){
-			if (formData[j].name == key) {
-				formData[j].value = value;
-				break;
-	var getCurrentResolution = function (type) {
-		// default resolution is 72 dpi
-		var dpi = 72;
-		// set resolution according to map configuration in template
-		for (var i in actualConfig.pages) {
-			var page = actualConfig.pages[i];
-			for (var j in page.elements) {
-				var el = page.elements[j];
-				if (type === el.type && typeof el.res_dpi === "number") {
-					dpi = el.res_dpi;
-		// set resolution according to resolution select box (if present)
-		// check if hq print is requested
-		var resolutionControl = null;
-		for (var i in actualConfig.controls) {
-			var c = actualConfig.controls[i];
-			try {
-				for (var j in c.pageElementsLink) {
-					if (c.pageElementsLink[j] === "res_dpi") {
-						resolutionControl = typeof c.id === "string" &&
-							c.id.length > 0 ? $("#" + c.id) : null;
-			catch (e) {
-		if (resolutionControl !== null && resolutionControl.size() === 1) {
-			dpi = resolutionControl.val();
-		return parseInt(dpi, 10);
-	var replaceMapFileForHighQualityPrint = function (currentMapUrl, type) {
-		var dpi = getCurrentResolution(type);
-		// replace map file with hq map file (if configured)
-		var hqmapfiles = $.isArray(options.highqualitymapfiles) ?
-			options.highqualitymapfiles : [];
-		for (var i = 0; i < hqmapfiles.length; i++) {
-			var exp = new RegExp(hqmapfiles[i].pattern);
-			if (hqmapfiles[i].pattern && typeof currentMapUrl === "string" && currentMapUrl.match(exp)) {
-				// check if mapping in current resolution exists
-				var resolutions = hqmapfiles[i].replacement;
-				var resolutionExists = false;
-				for (var r in resolutions) {
-					if (parseInt(r, 10) === dpi) {
-						resolutionExists = true;
-				if (resolutionExists) {
-					// replace with hqmapfile
-					var hqmapfile = resolutions[dpi];
-					currentMapUrl = currentMapUrl.replace(exp, hqmapfile);
-		return currentMapUrl;
-	 * Validates and updates form data values.
-	 * Adds the elements before the submit button.
-	 * @see jquery.forms#beforeSubmitHandler
-	var validate = function (formData, jqForm, params) {
-		showHideWorking("show");
-		// map urls
-		var ind = getMapObjIndexByName(myTarget);
-		var f = jqForm[0];
-		f.map_url.value = '';
-		var scale = f.scale.value || mb_mapObj[ind].getScale();
-		scale = parseInt(scale, 10);
-		var legendUrlArray = [];
-		f.overview_url.value = '';
-		for(var i=0; i < mb_mapObj[ind].wms.length; i++){
-			var currentWms = mb_mapObj[ind].wms[i];
-			if(mb_mapObj[ind].wms[i].gui_wms_visible > 0){
-				if (mb_mapObj[ind].wms[i].mapURL != false && mb_mapObj[ind].wms[i].mapURL != 'false' && mb_mapObj[ind].wms[i].mapURL != ''){
-					if(f.map_url.value != ""){
-						f.map_url.value += '___';
-					var currentMapUrl = mb_mapObj[ind].getMapUrl(i, mb_mapObj[ind].getExtentInfos(), scale);
-					currentMapUrl = replaceMapFileForHighQualityPrint(currentMapUrl, "map");
-					f.map_url.value += currentMapUrl
-					var wmsLegendObj = [];
-					var layers = currentWms.getLayers(mb_mapObj[ind], scale);
-					for (var j = 0; j < layers.length; j++) {
-						var currentLayer = currentWms.getLayerByLayerName(layers[j]);
-						// TODO: add only visible layers
-						var isVisible = (currentLayer.gui_layer_visible === 1);
-						var hasNoChildren = (!currentLayer.has_childs);
-						if (isVisible && hasNoChildren){
-							var layerLegendObj = {};
-							layerLegendObj.name = currentLayer.layer_name;
-							layerLegendObj.title = currentWms.getTitleByLayerName(currentLayer.layer_name);
-							var layerStyle = currentWms.getCurrentStyleByLayerName(currentLayer.layer_name);
-							if (layerStyle === false) {
-								layerStyle = "default";
-							layerLegendObj.legendUrl = currentWms.getLegendUrlByGuiLayerStyle(currentLayer.layer_name, layerStyle);
-							if (layerLegendObj.legendUrl !== false) {
-								wmsLegendObj.push(layerLegendObj);
-					if (wmsLegendObj.length > 0) {
-						var tmpObj = {};
-						tmpObj[currentWms.wms_currentTitle] = wmsLegendObj;
-						legendUrlArray.push(tmpObj);
-		updateFormField(formData, "legend_url", $.toJSON(legendUrlArray));
-		updateFormField(formData, "map_url", f.map_url.value);
-		updateFormField(formData, "scale", scale);
-		//overview_url
-		var ind_overview = getMapObjIndexByName('overview');
-		if(mb_mapObj[ind_overview].mapURL != false ){
-		    var overviewUrl = mb_mapObj[ind_overview].mapURL;
-			overviewUrl = $.isArray(overviewUrl) ? overviewUrl[0] : overviewUrl;
-		    f.overview_url.value = replaceMapFileForHighQualityPrint(overviewUrl, "overview");
-			updateFormField(formData, "overview_url", f.overview_url.value);
-		updateFormField(formData, "map_scale", mb_getScale(myTarget));
-		// write the measured coordinates
-		if (typeof(mod_measure_RX) !== "undefined") {
-			var tmp_x = '';
-			var tmp_y = '';
-			for(i = 0; i < mod_measure_RX.length; i++) {
-				if(tmp_x != '') {
-					tmp_x += ',';
-				tmp_x += mod_measure_RX[i];
-			for(i = 0; i < mod_measure_RY.length; i++) {
-				if(tmp_y != '') {
-					tmp_y += ',';
-				tmp_y += mod_measure_RY[i];
-			updateFormField(formData, "measured_x_values", tmp_x);
-			updateFormField(formData, "measured_y_values", tmp_y);
-		if (f.map_url.value!="") {
-			//return true;
-		} else {
-		    showHideWorking("hide");
-			return false;
- 	 * Method: showResult
-	 * load the generated PDF from the returned URL as an attachment,
-	 * that triggers a download popup or is displayed in PDF plugin.
-	var showResult = function (res, text) {
-		if (text == 'success') {
-			var $downloadFrame = $("#" + myId + "_frame");
-			if ($downloadFrame.size() === 0) {
-				$downloadFrame = $(
-					"<iframe id='" + myId + "_frame' name='" +
-					myId + "_frame' width='0' height='0' style='display:none'></iframe>"
-				).appendTo("body");
-			if ($.browser.msie && $.browser.version === "6.0") {
-				var newWin = window.open(stripslashes(res.outputFileName), "Druckausgabe", "width=200,height=200,left=700,top=200,resizable=yes");
-			else {
-				window.frames[myId + "_frame"].location.href =
-					stripslashes(res.outputFileName);
-		else {
-			/* something went wrong */
-			$("#"+myId+"_result").html(text);
-	 * Generates form elements as specified in the config controls object.
-	 * @param {Object} json the config object in json
-	var buildForm = function () {
-		$(".print_option_dyn").remove();
-		var str = "";
-		for (var item in actualConfig.controls) {
-			var element = actualConfig.controls[item];
-			var element_id = myId + "_" + element.id;
-			if (element.type != "hidden") {
-				str += '<div class="print_option_dyn">\n';
-				str += '<label class="print_label" for="'+element.id+'">'+element.label+'</label>\n';
-			} else {
-				str += '<div class="print_option_dyn" style="display:none;">\n';
-			switch (element.type) {
-				case "text":
-					str += '<input type="'+element.type+'" name="'+element.id+'" id="'+element.id+'" size="'+element.size+'"><br>\n';
-					break;
-				case "hidden":
-					str += '<input type="'+element.type+'" name="'+element.id+'" id="'+element.id+'">\n';
-					break;
-				case "textarea":
-					str += '<textarea id="'+element.id+'" name="'+element.id+'" size="'+element.size+'"></textarea><br>\n';
-					break;
-				case "select":
-					str += '<select id="'+element.id+'" name="'+element.id+'" size="1">\n';
-					for (var option_index in element.options) {
-						option = element.options[option_index];
-						str += '<option value="'+option.value+'">'+option.label+'</option>\n';
-					str += '</select><br>\n';
-					break;
-			str += '</div>\n';
-		if (str) {
-			$("#" + myId + "_formsubmit").before(str);
-			$("#scale").keydown(function (e) {
-				if (e.keyCode !== 13) {
-					return;
-				var scale = parseInt(this.value, 10);
-				if (isNaN(scale) || typeof printBox === "undefined") {
-					return false;
-				printBox.setScale(scale);
-				return false;
-	 * Generates the configuration select element from the gui element vars
-	 * mbPrintConfigFilenames and mbPrintConfigTitles
-	var buildConfigSelector = function () {
-		var str = "";
-		str += '<label class="print_label" for="printPDF_template">Vorlage</label>\n';
-		str += '<select id="printPDF_template" name="printPDF_template" size="1">\n';
-		for (var i = 0; i < mbPrintConfigFilenames.length; i++) {
-			str += '<option value="'+mbPrintConfigFilenames[i]+'">'+mbPrintConfigTitles[i]+'</option>\n';
-		str += '</select><img id="printPDF_handle" src="../print/img/shape_handles.png" title="Use printbox">\n';
-		if (str) {
-			$("#printPDF_selector").append(str).find("#printPDF_template").change(function () {
-				printObj.loadConfig(mbPrintConfigFilenames[this.selectedIndex], function () {
-					printObj.createPrintBox()
-			$("#printPDF_handle").click(function () {
-				printObj.createPrintBox();
-			$("#printPDF_working").bgiframe({
-				src: "BLOCKED SCRIPT'<html></html>';",
-				width: 200,
-				height: 200
-	var stripslashes = function ( str ) {
-	    return (str+'').replace(/\0/g, '0').replace(/\\([\\'"])/g, '$1');
-var printObj = new PrintPDF(options);
Deleted: trunk/mapbender/http/plugins/mb_twitter.php_deprecated
--- trunk/mapbender/http/plugins/mb_twitter.php_deprecated	2016-05-27 07:16:01 UTC (rev 9488)
+++ trunk/mapbender/http/plugins/mb_twitter.php_deprecated	2016-05-27 07:19:06 UTC (rev 9489)
@@ -1,130 +0,0 @@
-<?php
-# License:
-# Copyright (c) 2009, Open Source Geospatial Foundation
-# This program is dual licensed under the GNU General Public License
-# and Simplified BSD license.
-# http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
-require_once dirname(__FILE__) . "/../../core/globalSettings.php";
-require_once '../extensions/epicode/EpiCurl.php';
-require_once '../extensions/epicode/EpiOAuth.php';
-require_once '../extensions/epicode/EpiTwitter.php';
-$gui_id = Mapbender::session()->get("mb_user_gui");
-$e_id = "twitter_signin";
-require_once '../include/dyn_php.php';
-$ajaxResponse = new AjaxResponse($_POST);
-if (!isset($consumerKey) || !isset($consumerSecret)) {
-	$ajaxResponse->setSuccess(false);
-	$ajaxResponse->setMessage(_mb("Element vars consumerKey and consumerSecret are not set. If you don't have them, get them from Twitter."));
-	$ajaxResponse->send();
-function isSignedIn ($token = null) {
-	global $Twitter;
-	if (!is_null($token)) {
-		try {
-			$Twitter->setToken($token);
-			$accessToken = $Twitter->getAccessToken();
-			Mapbender::session()->set("twitter_token", $accessToken->oauth_token);
-			Mapbender::session()->set("twitter_token_secret", $accessToken->oauth_token_secret);
-		catch (Exception $e) {
-			Mapbender::session()->delete("twitter_token");
-			Mapbender::session()->delete("twitter_token_secret");
-			return false;
-	if (Mapbender::session()->exists("twitter_token") && Mapbender::session()->exists("twitter_token_secret")) {
-			Mapbender::session()->get("twitter_token"),
-			Mapbender::session()->get("twitter_token_secret")
-		new mb_exception("token: " . Mapbender::session()->get("twitter_token"));
-		new mb_exception("token_secret: " . Mapbender::session()->get("twitter_token_secret"));
-		return true;
-	return false;
-$Twitter = new EpiTwitter($consumerKey, $consumerSecret);
-switch ($ajaxResponse->getMethod()) {
-	case "isSignedIn" :
-		$token = $ajaxResponse->getParameter("token");
-		if (isSignedIn($token)) {
-			$ajaxResponse->setResult(array("signedIn" => true));
-			$ajaxResponse->setMessage(_mb("Signed in."));
-		$ajaxResponse->setResult(array("signedIn" => false));
-		$ajaxResponse->setMessage(_mb("Not signed in."));
-		$ajaxResponse->setSuccess(true);
-		break;
-	case "signin" :
-		try {
-			$url = $Twitter->getAuthenticateUrl();
-			$ajaxResponse->setMessage(_mb("Could not connect to Twitter."));
-		$ajaxResponse->setResult(array("url" => $url));
-		break;
-	case "signout" :
-		$ajaxResponse->setResult(array("signedOut" => true));
-		$ajaxResponse->setMessage(_mb("Signed out."));
-		break;
-	case "update":
-		if (!isSignedIn()) {
-		$Twitter = new EpiTwitter($consumerKey, $consumerSecret);
-		$status = $ajaxResponse->getParameter("status");
-		$lat = $ajaxResponse->getParameter("lat");
-		$lon = $ajaxResponse->getParameter("lon");
-		try {
-			$newStatus = $Twitter->post_statusesUpdate(array(
-				'status' => $text,
-				'lat' => $lat,
-				'long' => $long
-			"res" => serialize($newStatus)
-		break;
-	default:
-		$ajaxResponse->setMessage(_mb("An unknown error occured."));
-		break;
-$ajaxResponse->send();
Deleted: trunk/mapbender/http/plugins/mb_twitter_signin.js_deprecated
--- trunk/mapbender/http/plugins/mb_twitter_signin.js_deprecated	2016-05-27 07:16:01 UTC (rev 9488)
+++ trunk/mapbender/http/plugins/mb_twitter_signin.js_deprecated	2016-05-27 07:19:06 UTC (rev 9489)
@@ -1,171 +0,0 @@
- * Package: twitter_signin
- * Description:
- * Authenticate with Twitter
- * Files:
- *  - http/plugins/mb_twitter_signin.js
- * SQL:
- * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
- * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
- * > e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>','twitter_signin',
- * > 1,1,'Authenticate with Twitter','Authenticate with Twitter','img',
- * > '../img/twitter_signin.png','',900,10,NULL ,NULL ,NULL ,'','','',
- * > '../plugins/mb_twitter_signin.js','','','','');
- * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
- * > var_value, context, var_type) VALUES('<appId>', 'twitter_signin',
- * > 'consumerKey', '<your key>', '' ,'php_var');
- * > 'consumerSecret', '<your secret>',
- * > '' ,'php_var');
- * Help:
- * http://www.mapbender.org/Twitter_signin
- * Maintainer:
- * http://www.mapbender.org/User:Christoph_Baudson
- * Parameters:
- * consumerKey      - your consumer key from Twitter (PHP var)
- * consumerSecret   - your consumer secret from Twitter (PHP var)
- * License:
- * Copyright (c) 2009, Open Source Geospatial Foundation
- * This program is dual licensed under the GNU General Public License
- * and Simplified BSD license.
- * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
-var $this = $(this);
-var originalI18nObject = {
-	"logIn" : "Log in at Twitter",
-	"logOut" : "Log out at Twitter"
-var translatedI18nObject = Mapbender.cloneObject(originalI18nObject);
-var TwitterSignin = function (options) {
-	var that = this;
-	this.isSignedIn = function () {
-		var req = new Mapbender.Ajax.Request({
-			url: "../plugins/mb_twitter.php",
-			method: "isSignedIn",
-			parameters: {
-				token: getOauthToken()
-			callback: function (obj, result, message) {
-				if (!result) {
-					alert(message);
-					$this.text(translatedI18nObject.logIn);
-					return;
-				if (obj.signedIn) {
-					alert(message);
-					$this.text(translatedI18nObject.logOut);
-					$this.mapbender(function () {
-						this.signedIn = true;
-						this.events.signedIn.trigger();
-				else {
-						this.signedIn = false;
-						this.events.signedOut.trigger();
-		req.send();
-	this.events = {
-		signedIn: new Mapbender.Event(),
-		signedOut: new Mapbender.Event()
-	var getOauthToken = function () {
-		var getString = document.location.search.substr(1,document.location.search.length);
-		if (getString === '') {
-			return null;
-		var gArr = getString.split('&');
-		for (i = 0; i < gArr.length; ++i) {
-			var v = '';
-			vArr = gArr[i].split('=');
-	        	if (vArr.length > 1) {
-				v = vArr[1];
-			var key = unescape(vArr[0]);
-			if (key === "oauth_token") {
-				return unescape(v);
-		return null;
-	$this.click(function () {
-		var method = that.signedIn ? "signout" : "signin";
-			method: method,
-			parameters: {
-				if (!result) {
-					alert(message);
-					return;
-				if (method === "signin" && obj.url && typeof obj.url === "string") {
-				  window.location.href = obj.url;
-				else if (method === "signout") {
-					var newUrl = window.location.href.replace(/oauth_token\=[0-9a-zA-Z]+/g, "");
-					window.location.href = newUrl;
-		req.send();
-$this.mapbender(new TwitterSignin());
-Mapbender.events.init.register(function () {
-	// check if signed in
-		this.isSignedIn();
-	Mapbender.events.localize.register(function () {
-		Mapbender.modules.i18n.queue(options.id, originalI18nObj, function (translatedObj) {
-			if (typeof translatedObj !== "object") {
-				return;
-			translatedI18nObj = translatedObj;
-			try {
-			catch (exc) {
-				new Mb_warning("Error when translating: " . exc.message);
Deleted: trunk/mapbender/http/plugins/mb_twitter_update.js_deprecated
--- trunk/mapbender/http/plugins/mb_twitter_update.js_deprecated	2016-05-27 07:16:01 UTC (rev 9488)
+++ trunk/mapbender/http/plugins/mb_twitter_update.js_deprecated	2016-05-27 07:19:06 UTC (rev 9489)
@@ -1,116 +0,0 @@
-$twitterUpdate = $(this);
-var that = this;
-Mapbender.events.beforeInit.register(function () {
-	var signIn = Mapbender.modules.twitter_signin;
-	if (signIn !== undefined) {
-		signIn.events.signedIn.register(function () {
-			$twitterUpdate.fadeIn();
-		signIn.events.signedOut.register(function () {
-			$twitterUpdate.fadeOut();
-	var updateStatus = function (status, lat, lon, callback) {
-			method: "update",
-			parameters: {
-				status: status,
-				lat: lat,
-				lon: lon
-				if (!result) {
-					alert(message);
-					return;
-					callback();
-				alert("Updated");
-				new Mapbender.Notice($.toJSON(obj));
-		req.send();
-	var button = new Mapbender.Button({
-		domElement: that,
-		over: options.src.replace(/_off/, "_over"),
-		on: options.src.replace(/_off/, "_on"),
-		off: options.src,
-		name: options.id,
-		go: function () {
- 			options.$target.each(function () {
-				var $twitterStatus, m;
-				var cancel = function () {
-						$twitterStatus.fadeOut("slow", function () {
-							m.remove();
-							$(this).remove();
-				$(this).mapbender(function () {
-					this.events.afterMapRequest.register(cancel);
-	 			$(this).css("cursor", "pointer")
-	 			.mousedown(function (e) {
-					mb_disableThisButton(options.id);
-					var height = map.getHeight();
-					var width = map.getWidth();
-					var offset = 10;
-					var pix = map.getMousePosition(e);
-					var p = map.convertPixelToReal(pix);
-					m = new Mapbender.Marker(p, map);
-					$twitterStatus = $("<div style='z-index:999;position:absolute;top:" +
-						(pix.y + parseInt(this.style.top, 10)) + "px;" +
-						"left:" + (offset + parseInt(this.style.left, 10)) + "px;width:"+(width-2*offset)+"px;display:none'>" +
-						"<div style='width:100%;height:10px;background-position:" + (pix.x-offset-10) + "px 0px;background-image:url(http://s.twimg.com/a/1266605807/images/arr2.gif);background-repeat:no-repeat;'/>" +
-						"<div style='background-color:#fff;height:110px;padding:8px;'>" +
-						"<div>What's happening?<span class='chars-left' style='float:right'>140</span></div>" +
-						"<textarea rows='2' cols='70'></textarea>" +
-						"<br><span style='float:right;margin:10px;'>" +
-						"<span id='twitter_update_send' style='cursor:pointer;margin:5px;padding:5px;' " +
-						"class='ui-state-default ui-corner-all'>update</span>" +
-						"<a id='twitter_cancel' href='#'>cancel</a></span>" +
-						"</div></div>").appendTo("body").fadeIn("slow");
-					var $charsLeft = $("span.chars-left", $twitterStatus);
-					var $textarea = $("textarea", $twitterStatus);
-					$textarea.focus().keypress(function () {
-						var chars = $textarea.val().length;
-						var avail = 140 - chars;
-						$charsLeft.text(avail);
-					var $button = $("#twitter_update_send");
-					$button.click(function () {
-							m.remove();
-						// show sandclock
-						updateStatus($textarea.val(), p.y, p.x, function () {
-							// hide sandclock
-					var $cancel = $("#twitter_cancel");
-					$cancel.click(function () {
-						return cancel();
-					return false;
-		stop: function () {
-				$(this).css("cursor", "default").unbind("mousedown");
Deleted: trunk/mapbender/http/plugins/mod_jsonAutocompleteGazetteer.php.old
--- trunk/mapbender/http/plugins/mod_jsonAutocompleteGazetteer.php.old	2016-05-27 07:16:01 UTC (rev 9488)
+++ trunk/mapbender/http/plugins/mod_jsonAutocompleteGazetteer.php.old	2016-05-27 07:19:06 UTC (rev 9489)
@@ -1,306 +0,0 @@
-<?php
-/** ENWICKLUNGSumgebung
- * Package: mod_jsonAutocompleteGazetteer
- * Description:
- * This module is a client for a json gazetteer webservice as used by http://www.geonames.org. The default
- * service is the service from geonames.org which allows searching for
- * Files:
- *  - http/plugins/mod_jsonAutocompleteGazetteer.php
- * SQL:
- * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src,
- * > e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag,
- * > e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('<app_id>','jq_ui_autocomplete',5,1,
- * > 'Module to manage jQuery UI autocomplete module','','div','','',-1,-1,15,15,NULL ,'','','div',
- * > '','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.autocomplete.js',
- * > '','jq_ui,jq_ui_widget,jq_ui_position','');
- * > e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,
- * > e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('<app_id>',
- * > 'jsonAutocompleteGazetteer',12,1,'Client for json webservices like geonames.org','Gazetteer',
- * > 'div','','',230,30,NULL ,NULL ,999,'','','div','../plugins/mod_jsonAutocompleteGazetteer.php',
- * > '','mapframe1','','http://www.mapbender.org/index.php/mod_jsonAutocompleteGazetteer');
- * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
- * > VALUES('<app_id>', 'jsonAutocompleteGazetteer', 'gazetteerUrl', 'http://www.geoportal.rlp.de/mapbender/geoportal/gaz_geom_mobile.php',
- * >  '' ,'var');
- * >  VALUES('<app_id>', 'jsonAutocompleteGazetteer', 'isGeonames', 'true', '' ,'var');
- * Help:
- * http://www.mapbender.org/mod_jsonAutocompleteGazetteer
- * Maintainer:
- * http://www.mapbender.org/User:Armin_Retterath
- * Parameters:
- * none
- * License:
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-var standingHighlight = null;
-Mapbender.events.afterMapRequest.register( function(){
-	if(standingHighlight){
-		standingHighlight.paint();
-//initialize modul
-if (options.gazetteerUrl === undefined) {
-	options.gazetteerUrl = 'http://10.176.178.10/mapbender/geoportal/gaz_geom_mobile.php';
-if (options.isGeonames === undefined) {
-	options.isGeonames = true;
-if (options.latLonZoomExtension === undefined) {
-	options.latLonZoomExtension = 0.1;
-if (options.minLength === undefined) {
-	options.minLength = 3;
-if (options.delay === undefined) {
-	options.delay = 400;
-if (options.isDraggable === undefined) {
-	options.isDraggable = true;
-if (options.maxResults === undefined) {
-	options.maxResults = 15;
-if (options.inputWidth === undefined) {
-	options.inputWidth = 250;
-if (options.searchEpsg === undefined) {
-	options.searchEpsg = "25832";
-if (options.drawCentrePoint === undefined) {
-	options.drawCentrePoint = true;
-if (options.gazetteerFrontImageOn === undefined) {
-	options.gazetteerFrontImageOn = "../img/button_blue_red/gazetteer3_on.png";
-if (options.gazetteerFrontImageOff === undefined) {
-	options.gazetteerFrontImageOff = "../img/button_blue_red/gazetteer3_off.png";
-if (options.helpText === undefined) {
-	options.helpText = "";
-var JsonAutocompleteGazetteer = function() {
-	var that = this;
-	var targetName = options.target;
-	var ind = getMapObjIndexByName(targetName);
-	var my = mb_mapObj[ind];
-	this.zoomToExtent = function(fromSrs,minx,miny,maxx,maxy) {
-		var parameters = {
-			fromSrs: fromSrs,
-			toSrs: Mapbender.modules[targetName].epsg
-		parameters.bbox = parseFloat(minx)+ "," +parseFloat(miny)+ "," +parseFloat(maxx)+ "," +parseFloat(maxy);
-		//function to transform from one crs to another
-			url: "../php/mod_coordsLookup_server.php",
-			method: "transform",
-			parameters: parameters,
-			callback: function (obj, success, message) {
-				if (!success) {
-					new Mapbender.Exception(message);
-					return;
-				if (options.drawCentrePoint) {
-					//generate layer for visualization of point
-					if(standingHighlight !== null){
-						standingHighlight.clean();
-					}else{
-						standingHighlight = new Highlight(
-							[options.target],
-							"standingHighlight",
-							{"position":"absolute", "top":"0px", "left":"0px", "z-index":999},
-							2);
-					var point0 = new Point(obj.points[0].x,obj.points[0].y);
-					var point1 = new Point(obj.points[1].x,obj.points[1].y);
-					var x = point0.x + (point1.x - point0.x)/2;
-					var y = point0.y + (point1.y - point0.y)/2;
-					var point = new Point(x,y);
-					var ga = new GeometryArray();
-					ga.importPoint({
-						coordinates:[x,y,null]
-					},Mapbender.modules[targetName].epsg)
-					var m = ga.get(-1,-1);
-					standingHighlight.add(m, "#ff0000");
-					//alert(m);
-				if (obj.points) {
-					if (obj.points.length === 2) {
-						var newExtent = new Extent(
-							obj.points[0].x,
-							obj.points[0].y,
-							obj.points[1].x,
-							obj.points[1].y
-						my.calculateExtent(newExtent);
-					my.setMapRequest();
-		req.send();
-	this.showSearchHelp = function(){
-	this.toggleInput = function(){
-		if ($("#geographicName").css("display") == 'none') {
-			$("#geographicName").show();
-			$("#helpSymbolId").show();
-			$("#symboldForInputId").attr({'src':options.gazetteerFrontImageOn});
-		} else {
-			$("#geographicName").hide();
-			$("#helpSymbolId").hide();
-			$("#symboldForInputId").attr({'src':options.gazetteerFrontImageOff});
-	this.initForm = function() {
-		epsg = Mapbender.modules[targetName].epsg.replace('EPSG:', '');
-		this.formContainer = $(document.createElement('form')).attr({'id':'json-autocomplete-gazetteer'}).appendTo('#' + options.id);
-		this.formContainer.submit(function() {
-			return false;
-		if (options.isDraggable){
-			//this.formContainer.draggable();//problem with print module
-		this.symbolForInput = $(document.createElement('img')).appendTo(this.formContainer);
-		this.symbolForInput.attr({'id':'symboldForInputId'});
-		this.symbolForInput.attr({'src':options.gazetteerFrontImageOn});
-		this.symbolForInput.attr({'title':'<?php echo _mb('Address'); ?>'});
-		$("#symboldForInputId").click(function() {
-			that.toggleInput();
-		this.inputAddress = $(document.createElement('input')).appendTo(this.formContainer);
-		//do the following things only if
-		if (options.helpText != '') {
-			this.helpSymbol = $(document.createElement('img')).appendTo(this.formContainer);
-			this.helpText = $(document.createElement('div')).appendTo(this.formContainer);
-			this.helpText.attr({'id':'helpTextId'});
-			$("#helpTextId").hide();
-			$("#helpTextId").append(options.helpText);
-			this.helpSymbol.attr({'id':'helpSymbolId'});
-			this.helpSymbol.attr({'src':'../img/questionmark.png'});
-			this.helpSymbol.attr({'width':'17'});
-			this.helpSymbol.attr({'height':'17'});
-			$("#helpSymbolId").hover(
-				function () {
-    					//create dialog
-					$("#helpTextId").dialog({ title: "<?php echo _mb('Help for address search'); ?>" });
-				function () {
-    					//create dialog
-					$("#helpTextId").dialog('close');
-		this.inputAddress.attr({'id':'geographicName'});
-		//default value
-		this.inputAddress.val('<?php echo _mb('Search for addresses'); ?>');
-		this.inputAddress.click(function() {
-			that.inputAddress.val('');
-		this.inputAddress.css('width',options.inputWidth);
-		$('.ui-menu').css('width','100px');
-		$('.ui-menu-item').css('width','100px');
-		//set the loading symbol for autoloader class
-		//$('.ui-autocomplete-loading').css('background','white url("../img/indicator_wheel.gif") right center no-repeat');
-		//http://stackoverflow.com/questions/622122/how-can-i-change-the-css-class-rules-using-jquery
-		//$("<style type='text/css'> .ui-autocomplete { position: absolute; cursor: default; background:black; color:white} </style>").appendTo("head");
-		$(function() {
-			$( "#geographicName" ).autocomplete({
-				source: function( request, response ) {
-					$.ajax({
-						url: options.gazetteerUrl,
-						dataType: "jsonp",
-						data: {
-							outputFormat: 'json',
-							resultTarget: 'web',
-							searchEPSG: options.searchEpsg,
-							maxResults: options.maxResults,
-							maxRows: options.maxResults,
-							searchText: request.term,
-							featureClass: "P",
-							style: "full",
-							name_startsWith: request.term
-						success: function( data ) {
-							if (options.isGeonames) {
-								response( $.map( data.geonames, function( item ) {
-									return {
-										label: item.name+" - "+item.fclName+" - "+item.countryName,
-										minx: item.lng-options.latLonZoomExtension,
-										miny: item.lat-options.latLonZoomExtension,
-										maxx: item.lng+options.latLonZoomExtension,
-										maxy: item.lat+options.latLonZoomExtension
-							} else {
-									return {
-										label: item.title,
-										minx: item.minx,
-										miny: item.miny,
-										maxx: item.maxx,
-										maxy: item.maxy
-				minLength: options.minLength,
-				delay: options.delay,
-				select: function( event, ui ) {
-					that.zoomToExtent("EPSG:"+options.searchEpsg,ui.item.minx,ui.item.miny,ui.item.maxx,ui.item.maxy);
-				open: function() {
-					$( this ).removeClass( "ui-corner-all" ).addClass( "ui-corner-top" );
-				close: function() {
-					$( this ).removeClass( "ui-corner-top" ).addClass( "ui-corner-all" );
-	this.initForm();
-	Mapbender.modules[options.id] = $.extend(new JsonAutocompleteGazetteer(),Mapbender.modules[options.id]);
More information about the Mapbender_commits
