[Mapbender-commits] r9493 - trunk/mapbender/resources
svn_mapbender at osgeo.org
Fri May 27 00:30:15 PDT 2016
Author: armin11
Date: 2016-05-27 00:30:15 -0700 (Fri, 27 May 2016)
New Revision: 9493
Removed:
trunk/mapbender/resources/install_mapbender.sh
Fix wrong commit
Deleted: trunk/mapbender/resources/install_mapbender.sh
--- trunk/mapbender/resources/install_mapbender.sh 2016-05-27 07:29:34 UTC (rev 9492)
+++ trunk/mapbender/resources/install_mapbender.sh 2016-05-27 07:30:15 UTC (rev 9493)
@@ -1,98 +0,0 @@
-#!/bin/sh
-# Copyright (c) 2009 The Open Source Geospatial Foundation.
-# Licensed under the GNU LGPL.
-# This library is free software; you can redistribute it and/or modify it
-# under the terms of the GNU Lesser General Public License as published
-# by the Free Software Foundation, either version 2.1 of the License,
-# or any later version. This library is distributed in the hope that
-# it will be useful, but WITHOUT ANY WARRANTY, without even the implied
-# warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
-# See the GNU Lesser General Public License for more details, either
-# in the "LICENSE.LGPL.txt" file distributed with this software or at
-# web page "http://www.fsf.org/licenses/lgpl.html".
-# About:
-# This script will install Mapbender 2.6.1
-# Running:
-# sudo service apache2 start
-# Then open a web browser and go to http://localhost/mapbender/ Login with root/root
-# Requires: Apache2, PHP5, gettext, image magic
-ZIP="mapbender_2.6.1.zip"
-TMP="/tmp/mapbender"
-INSTALL_DIR="/usr/lib"
-MAPBENDER_INSTALL_DIR="$INSTALL_DIR/mapbender"
-DATA_FOLDER="/data/mapbender"
-APACHE_USER="www-data"
-POSTGRESQL_USER_NAME="mapbender"
-MAPBENDER_DATABASE_NAME="mapbender"
-MAPBENDER_DATABASE_USER="mapbender"
-MAPBENDER_DATABASE_NAME MAPBENDER_DATABASE_TEMPLATE MAPBENDER_DATABASE_USER
-# check required tools are installed
-if [ ! -x "`which wget`" ] ; then
- echo "ERROR: wget is required, please install it and try again"
- exit 1
-fi
-## Setup things... ##
-if [ ! -d "$DATA_FOLDER" ] ; then
- mkdir "$DATA_FOLDER"
-fi
-# Check get-text
-apt-get install gettext
-# add gettext to the PATH if needed
-if [ `grep -c '/usr/bin/msgfmt'` -eq 0 ] ; then
- echo 'PATH="$PATH:/usr/bin/"'"
-fi
-# Check PostgreSQl/PostGIS
-#set default user/password to the system user for easy login
-sudo -u postgres createuser --superuser $POSTGRESQL_USER_NAME
-####### echo "alter role \"POSTGRESQL_USER_NAME\" with password 'user'" > /tmp/mapbender/log.txt
-# Check php Konfiguration
-php-gettext
-# wo soll Mapbender liegen
-# APACHE ALIAS
-grep -c '/usr/bin/msgfmt'
-# create tmp folders
-mkdir -p "$TMP"
-cd "$TMP"
-# CASE OF A ZIP
-if [ -f "$ZIP" ] ; then
- echo "$ZIP has already been downloaded."
-else
- wget -c --progress=dot:mega "http://www.mapbender.org/download/$ZIP"
-fi
-# entpacken nach INSTALL_DIR
-# Rechte auf install.sh und Verzeichnis
-cd MAPBENDER_INSTALL_DIR/resources/db
-./install.sh localhost 5432 MAPBENDER_DATABASE_NAME MAPBENDER_DATABASE_TEMPLATE MAPBENDER_DATABASE_USER
More information about the Mapbender_commits
