[Mapbender-commits] r9620 - in trunk/mapbender: http/classes http/javascripts http/php resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Oct 21 03:37:57 PDT 2016
Author: armin11
Date: 2016-10-21 03:37:57 -0700 (Fri, 21 Oct 2016)
New Revision: 9620
   trunk/mapbender/http/classes/class_iso19139.php
   trunk/mapbender/http/classes/class_wms.php
   trunk/mapbender/http/javascripts/initWmcObj.php
   trunk/mapbender/http/php/mb_getWmsData.php
   trunk/mapbender/http/php/mod_loadCapabilities.php
   trunk/mapbender/http/php/mod_loadwms.php
   trunk/mapbender/http/php/mod_updateWMS.php
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
New possibility for dataset metadata to inherit the contact and licence information from the service from which they are delivered
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php	2016-10-20 11:41:18 UTC (rev 9619)
+++ trunk/mapbender/http/classes/class_iso19139.php	2016-10-21 10:37:57 UTC (rev 9620)
@@ -51,6 +51,7 @@
 	var $type;
 	var $origin;
 	var $owner;
+	var $fkey_mb_group_id;
 	var $harvestResult;
 	var $harvestException;
 	var $lineage;
@@ -104,6 +105,7 @@
 		$this->tmpExtentEnd = "1900-01-01";
 		$this->randomId = new Uuid();
 		$this->owner = 0; //dummy entry for metadata owner - in case of metadataURL entries the owner of the corresponding service
+		$this->fkey_mb_group_id = null;
 		$this->href = "";
 		$this->format = "";
 		$this->type = "";
@@ -1420,6 +1422,48 @@
 		return $postGisPolygon;
+	public function inheritContactAndLicenceInformation($metadataId,$resourceType,$resourceId,$inheritContactInfo,$inheritLicenceInfo){
+		//$e = new mb_exception("class_iso19139.php: inherit function invoked!");
+		if ($inheritContactInfo == true || $inheritLicenceInfo == true) {
+			//get info from coupled service
+			switch ($resourceType) {
+				case "layer":
+					$sql = "SELECT fkey_mb_group_id, wms.wms_id as service_id, fkey_termsofuse_id FROM wms LEFT JOIN wms_termsofuse ON wms.wms_id = wms_termsofuse.fkey_wms_id WHERE wms_id = (SELECT fkey_wms_id FROM layer WHERE layer_id = $resourceId)";
+					break;
+				case "featuretype":
+					$sql = "SELECT fkey_mb_group_id, wfs.wfs_id as service_id, fkey_termsofuse_id FROM wfs LEFT JOIN wfs_termsofuse ON wfs.wfs_id = wfs_termsofuse.fkey_wfs_id WHERE wfs_id = (SELECT fkey_wfs_id FROM wfs_featuretype WHERE featuretype_id = $resourceId)";
+					break;
+			$res = db_query($sql);
+			while ($row = db_fetch_array($res)){
+				$fkey_mb_group_id = $row['fkey_mb_group_id'];
+				$service_id = $row['service_id'];
+				$fkey_termsofuse_id = $row['fkey_termsofuse_id'];
+			//regexpr for strings which represents integer
+			$regExprInt = "/^[0-9]+$/";
+		if ($inheritContactInfo == true && preg_match($regExprInt,$fkey_mb_group_id)) {
+			$sqlInheritContact = "UPDATE mb_metadata set fkey_mb_group_id = $fkey_mb_group_id WHERE metadata_id = $metadataId";
+			$res = db_query($sqlInheritContact);
+			//$e = new mb_exception("Metadata with id ".$metadataId." inherits contact information from ".$resourceType." with resourceId ".$resourceId);
+		if ($inheritLicenceInfo == true && preg_match($regExprInt,$fkey_termsofuse_id)) {
+			try {
+				//delete own termsofuse if exists
+				$sqlDeleteTouRelation = "DELETE from md_termsofuse WHERE fkey_metadata_id = $metadataId";
+				$res = db_query($sqlDeleteTouRelation);
+				//insert service termsofuse relation
+				$sqlInsertTouRelation = "INSERT INTO md_termsofuse (fkey_termsofuse_id, fkey_metadata_id) VALUES ($fkey_termsofuse_id,$metadataId)";
+				$res = db_query($sqlInsertTouRelation);
+				//$e = new mb_exception("Metadata with id ".$metadataId." inherits licence information from ".$resourceType." with resourceId ".$resourceId);
+			catch (Exception $e) {
+				$exception = new mb_exception($e->getMessage());
 	public function insertKeywordsAndCategoriesIntoDB($metadataId,$resourceType,$resourceId){
 		//first delete old classifications - after that create new ones
 		//$e = new mb_exception($metadataId." - ".$resourceType." - ".$resourceId);
@@ -1471,7 +1515,7 @@
 			$sqlInsert = rtrim($sqlInsert,",");
-			$e = new mb_exception("class_Iso19139: insert topic categories: ".$sqlInsert);
+			//$e = new mb_exception("class_Iso19139: insert topic categories: ".$sqlInsert);
 			$sql = "INSERT INTO mb_metadata_md_topic_category (fkey_metadata_id, fkey_md_topic_category_id) VALUES ".$sqlInsert;
 			if (!$res) {
@@ -1489,7 +1533,7 @@
 			$sql = "INSERT INTO mb_metadata_inspire_category (fkey_metadata_id, fkey_inspire_category_id) VALUES ".$sqlInsert;
-			$e = new mb_exception("class_Iso19139: insert inspire categories: ".$sqlInsert);
+			//$e = new mb_exception("class_Iso19139: insert inspire categories: ".$sqlInsert);
 			if (!$res) {
 				$e = new mb_exception("class_Iso19139:"._mb("Cannot insert inspire categories for this metadata!"));
@@ -1506,7 +1550,7 @@
 			$sql = "INSERT INTO mb_metadata_custom_category (fkey_metadata_id, fkey_custom_category_id) VALUES ".$sqlInsert;
-			$e = new mb_exception("class_Iso19139: insert custom categories: ".$sqlInsert);
+			//$e = new mb_exception("class_Iso19139: insert custom categories: ".$sqlInsert);
 			if (!$res) {
 				$e = new mb_exception("class_Iso19139:"._mb("Cannot insert custom categories for this metadata!"));
@@ -1810,7 +1854,7 @@
 		//insert an instance for iso19139 into mapbenders database
 		$e = new mb_notice("class_iso19139.php: insert metadata with title: ".$this->title);
 		$sql = <<<SQL
-INSERT INTO mb_metadata (lastchanged, link, origin, md_format, data, linktype, uuid, title, createdate, changedate, abstract, searchtext, type, tmp_reference_1, tmp_reference_2, export2csw, datasetid, datasetid_codespace, randomid, fkey_mb_user_id, harvestresult, harvestexception, lineage, inspire_top_consistence, spatial_res_type, spatial_res_value, update_frequency, format, inspire_charset, ref_system, the_geom, datalinks, inspire_whole_area, inspire_actual_coverage, inspire_download, bounding_geom, transfer_size, fees, md_license_source_note, constraints, responsible_party_name, responsible_party_email, preview_image)  VALUES(now(), $1, $18, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17, $19, $20, $21, $22, $23, $24, $25, $26, $27, $28, $29, $30, $31, $32, $33, $34, $35, $36, $37, $38, $39, $40, $41, $42)
+INSERT INTO mb_metadata (lastchanged, link, origin, md_format, data, linktype, uuid, title, createdate, changedate, abstract, searchtext, type, tmp_reference_1, tmp_reference_2, export2csw, datasetid, datasetid_codespace, randomid, fkey_mb_user_id, harvestresult, harvestexception, lineage, inspire_top_consistence, spatial_res_type, spatial_res_value, update_frequency, format, inspire_charset, ref_system, the_geom, datalinks, inspire_whole_area, inspire_actual_coverage, inspire_download, bounding_geom, transfer_size, fees, md_license_source_note, constraints, responsible_party_name, responsible_party_email, preview_image, fkey_mb_group_id)  VALUES(now(), $1, $18, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17, $19, $20, $21, $22, $23, $24, $25, $26, $27, $28, $29, $30, $31, $32, $33, $34, $35, $36, $37, $38, $39, $40, $41, $42, $43)
 SQL;
 		$v = array(
 			$this->href,
@@ -1854,13 +1898,14 @@
 			$this->accessConstraints,
 			$this->resourceResponsibleParty,
 			$this->resourceContactEmail,
-			$this->previewImage
+			$this->previewImage,
 			//$e = new mb_exception($this->tmpExtentBegin);
 			//$e = new mb_exception($this->tmpExtentEnd);
 			//$e = new mb_exception($this->createDate);
 			//$e = new mb_exception($this->changeDate);
-			$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','b','s','s','s','s','i','i','s','s','b','s','s','s','s','s','s','POLYGON','s','s','s','i','POLYGON','d','s','s','s','s','s','s');
+			$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','b','s','s','s','s','i','i','s','s','b','s','s','s','s','s','s','POLYGON','s','s','s','i','POLYGON','d','s','s','s','s','s','s','i');
 			$res = db_prep_query($sql,$v,$t);
 			return $res;
@@ -1919,7 +1964,7 @@
 		$sql .= "linktype = $4, uuid = $5, title = $6, createdate = $7, changedate = $8, lastchanged = now(), ";
 		$sql .= "abstract = $9, searchtext = $10, type = $11, tmp_reference_1 = $12, tmp_reference_2 = $13, export2csw = $14, datasetid = $15, ";
 		$sql .= "datasetid_codespace = $16, randomid = $17, harvestresult = $20, harvestexception = $21, lineage = $22, inspire_top_consistence = $23, ";
-		$sql .= "spatial_res_type = $24, spatial_res_value = $25, update_frequency = $26, format = $27, inspire_charset = $28, ref_system = $29, the_geom = $30, datalinks = $31, inspire_whole_area = $32, inspire_actual_coverage = $33, inspire_download = $34, bounding_geom = $35, transfer_size = $36, fees = $37, md_license_source_note = $38, constraints = $39, responsible_party_name = $40, responsible_party_email = $41 , preview_image = $42 WHERE metadata_id = $19";
+		$sql .= "spatial_res_type = $24, spatial_res_value = $25, update_frequency = $26, format = $27, inspire_charset = $28, ref_system = $29, the_geom = $30, datalinks = $31, inspire_whole_area = $32, inspire_actual_coverage = $33, inspire_download = $34, bounding_geom = $35, transfer_size = $36, fees = $37, md_license_source_note = $38, constraints = $39, responsible_party_name = $40, responsible_party_email = $41, preview_image = $42, fkey_mb_group_id = $43 WHERE metadata_id = $19";
 		//$e= new mb_exception("class_iso19139.php: downloadLinks json".$this->jsonEncodeDownloadLinks($this->downloadLinks));
 		//$e= new mb_exception("class_iso19139.php: downloadLinks[0]".$this->downloadLinks[0]);
 		$v = array(
@@ -1965,10 +2010,11 @@
 		//$e = new mb_exception("class_iso19139: ".$this->createWktBboxFromArray($this->wgs84Bbox));
 		return $res;
@@ -2098,7 +2144,7 @@
 		return $getMapUrl;
-	public function insertToDB($resourceType, $resourceId){
+	public function insertToDB($resourceType, $resourceId, $inheritContactInfo = false, $inheritLicenceInfo = false){
 		$result = array(); //value/message
 		switch ($this->origin) {
@@ -2205,6 +2251,7 @@
 			$res = $this->updateMetadataById($metadataId);
 			$this->insertKeywordsAndCategoriesIntoDB($metadataId,$resourceType,$resourceId);
+			$this->inheritContactAndLicenceInformation($metadataId,$resourceType,$resourceId,$inheritContactInfo,$inheritLicenceInfo);
 		} else {
 			//check if href already exists
 			$metadataId = $this->isLinkAlreadyInDB();
@@ -2216,6 +2263,7 @@
 				//check if the timestamp of an existing metadata element is not newer than the timestamp of the current metadata object!!!!
 			} else {
 				//insert new record
 				$e = new mb_notice("class_Iso19139:"."No existing metadata fileIdentifier found in mapbender metadata table. New record will be inserted with uuid: ".$this->fileIdentifier);
@@ -2254,7 +2302,7 @@
 				//Propagate information for each new layer to csw if configured*******************
 				$propagation = new propagateMetadata();
 				$uuidArray[0] = $this->fileIdentifier;
-				$result = $propagation->doPropagation("metadata", false, "push",  $uuidArray);
+				$resultPropagation = $propagation->doPropagation("metadata", false, "push",  $uuidArray);
 				//insert relations
 				$row = db_fetch_assoc($res);
@@ -2298,7 +2346,10 @@
 						return $result;
 					} else {
-						//if this was ok, let the resource (layer/featuretype) inherit the classification from the coupled metadata to support better catalogue search
+						//inherit licence info and contact info from coupled service if this is wished so - that will override and/or extent the original metadata!!!
+						//TODO: if this was ok, let the resource (layer/featuretype) inherit the classification from the coupled metadata to support better catalogue search
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php	2016-10-20 11:41:18 UTC (rev 9619)
+++ trunk/mapbender/http/classes/class_wms.php	2016-10-21 10:37:57 UTC (rev 9620)
@@ -35,7 +35,7 @@
 	//extended information
 	var $wms_termsofuse;
 	var $wms_license_source_note;
 	var $fees;
 	var $accessconstraints;
 	var $contactperson;
@@ -69,7 +69,6 @@
 	var $gui_wms_exceptionformat;
 	var $gui_wms_epsg;
 	var $gui_wms_sldurl;
 	var $gui_wms_dimension_time;
 	var $gui_wms_dimension_elevation;
@@ -78,6 +77,13 @@
 	var $overwriteCategories = false;
 	var $twitterNews = false;
 	var $setGeoRss = false;
+        //dataset metadata handling - defaults to true
+	var $harvestCoupledDatasetMetadata = true;
+	//inheritance of service elements to coupled dataset metadata
+	var $bequeathLicenceInformation = true; //relation wms_termsofuse
+	var $bequeathContactInformation = true; //database attribute fkey_mb_group_id
 	var $geoRss;
 	var $geoRssFactory; // = new GeoRssFactory();
 	const GEORSS = true;
@@ -2479,7 +2485,7 @@
 		//do the things for the parent layers
 		//get parent layer
-		$e = new mb_exception("wms_id: ".$this->wms_id);
+		//$e = new mb_exception("wms_id: ".$this->wms_id);
 		if (is_int($this->wms_id)) {
 			$admin = new administration();
 			$layerIdArray = $admin->getParentLayers($this->wms_id, $this->objLayer[$i]->db_id);
@@ -2772,17 +2778,19 @@
 			$mbMetadata->type = $this->objLayer[$i]->layer_metadataurl[$j]->type;
 			$mbMetadata->origin = "capabilities";
 			$mbMetadata->owner = $mdOwner;
-			$result = $mbMetadata->insertToDB("layer",$this->objLayer[$i]->db_id);
-			if ($result['value'] == false){
-				$e = new mb_exception("Problem while storing metadata url from wms to db");
-				$e = new mb_exception($result['message']);
-			} else {
-				$e = new mb_notice("Storing of metadata url from wms to db was successful");
-				$e = new mb_notice($result['message']);
+                        if ($this->harvestCoupledDatasetMetadata == true) {
+				try {
+					$result = $mbMetadata->insertToDB("layer",$this->objLayer[$i]->db_id, $this->bequeathContactInformation, $this->bequeathLicenceInformation );
+					if ($result['value'] == false){
+						throw new Exception("Problem while storing metadata url from wms to db");
+					} else {
+						$ex = new mb_notice("Storing of metadata url from wms to db was successful");
+						$ex = new mb_notice($result['message']);
+				catch(Exception $e) {
Modified: trunk/mapbender/http/javascripts/initWmcObj.php
--- trunk/mapbender/http/javascripts/initWmcObj.php	2016-10-20 11:41:18 UTC (rev 9619)
+++ trunk/mapbender/http/javascripts/initWmcObj.php	2016-10-21 10:37:57 UTC (rev 9620)
@@ -460,6 +460,12 @@
 				$latitudes = array();
 				$longitudes = array();
 				foreach($kmls->{$geojsonTitle}->data->features as $feature) {
+					//TODO: ugly fix to read multipolygons - delete if multiobjects are supported somewhen!
+					if ($feature->geometry->type == 'MultiPolygon') {
+						$feature->geometry->type = "Polygon";
+						//read only the first polygon!!
+						$feature->geometry->coordinates = $feature->geometry->coordinates[0];
 					switch ($feature->geometry->type) {
 						case "Polygon":
 							//$e = new mb_exception("Polygon found!");
Modified: trunk/mapbender/http/php/mb_getWmsData.php
--- trunk/mapbender/http/php/mb_getWmsData.php	2016-10-20 11:41:18 UTC (rev 9619)
+++ trunk/mapbender/http/php/mb_getWmsData.php	2016-10-21 10:37:57 UTC (rev 9620)
@@ -104,6 +104,9 @@
 	#$changedLayerObj = json_encode($changedLayerArray);
     	$mywms = new wms();
+	if(empty($_POST['harvest_dataset_metadata'])) {
+		$mywms->harvestCoupledDatasetMetadata = false;
 	if ($useAuthentication) {
 		$result = $mywms->createObjFromXML($url, $auth);
 	} else {
Modified: trunk/mapbender/http/php/mod_loadCapabilities.php
--- trunk/mapbender/http/php/mod_loadCapabilities.php	2016-10-20 11:41:18 UTC (rev 9619)
+++ trunk/mapbender/http/php/mod_loadCapabilities.php	2016-10-21 10:37:57 UTC (rev 9620)
@@ -177,7 +177,7 @@
 		echo"Password:<br>";
 		echo"<input type='text' name='password' size='50' value=''><br>";
+	echo "<input type='checkbox' name='harvest_dataset_metadata' checked='checked'>"._mb('Harvest coupled dataset metadata from given MetadataURL tags')."<br>";
 	if (defined("TWITTER_NEWS") && TWITTER_NEWS == true) {
 		echo"<input type='checkbox' name='twitter_news' checked='checked'>Publish via Twitter<br>";
Modified: trunk/mapbender/http/php/mod_loadwms.php
--- trunk/mapbender/http/php/mod_loadwms.php	2016-10-20 11:41:18 UTC (rev 9619)
+++ trunk/mapbender/http/php/mod_loadwms.php	2016-10-21 10:37:57 UTC (rev 9620)
@@ -31,6 +31,9 @@
     		$auth['auth_type'] = $_REQUEST["auth_type"];
     	$mywms = new wms();
     	if(empty($_POST['twitter_news'])) {
 		$mywms->twitterNews = false;
Modified: trunk/mapbender/http/php/mod_updateWMS.php
--- trunk/mapbender/http/php/mod_updateWMS.php	2016-10-20 11:41:18 UTC (rev 9619)
+++ trunk/mapbender/http/php/mod_updateWMS.php	2016-10-21 10:37:57 UTC (rev 9620)
@@ -35,10 +35,6 @@
 $myURL = $_POST["myURL"];
 $secParams = SID."&guiID=".$_REQUEST["guiID"]."&elementID=".$_REQUEST["elementID"];
 $self = $_SERVER["SCRIPT_NAME"]."?".$secParams;
@@ -53,7 +49,6 @@
 	return $row ? $row["layer_id"] : null;
 <html>
 <head>
@@ -156,8 +151,8 @@
 		authPassword = $("#imrAuthPassword").val();
 		authName = $("#imrAuthName").val();
-	console.log(dbOldNameArray);
-	console.log(dbCurrentNameArray);
+	//console.log(dbOldNameArray);
+	//console.log(dbCurrentNameArray);
 	var updateParams = {
 		//TODO add auth info!
 		"command": "updateWMS",
@@ -166,6 +161,7 @@
 		"authType" : authType,
 		"authName" : authName,
 		"authPassword" : authPassword,
+		"harvestDatasetMetadata" : $("#harvest_dataset_metadata").attr("checked"),
 		"publishRss" : $("#rss_news").attr("checked"),
 		"publishTwitter" : $("#twitter_news").attr("checked"),
 		"overwriteCategories" : $("#overwrite_categories").attr("checked"),
@@ -439,6 +435,7 @@
  	echo "Password : <input type='text' name='imrAuthPassword' id='imrAuthPassword'/><br><br>";
  	echo "</div>";
  	echo "Link to new WMS Capabilities URL:<br><input size='100' type='text' name='myURL' id='myURL'><br>";
+	echo"<input type='checkbox' name='harvest_dataset_metadata' id='harvest_dataset_metadata' checked='checked'>"._mb('Harvest/update dataset metadata by following existing MetadataURL tags in the capabilities')."<br>";
 		echo"<input type='checkbox' name='twitter_news' id='twitter_news' checked='checked'>Publish via Twitter<br>";
@@ -492,6 +489,9 @@
 	} else {
 		$mywms->overwrite=true;
 	//possibility to see update information in georss and/or twitter channel
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql	2016-10-20 11:41:18 UTC (rev 9619)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql	2016-10-21 10:37:57 UTC (rev 9620)
@@ -1251,4 +1251,4 @@
 ALTER TABLE gui_layer ALTER COLUMN gui_layer_style TYPE VARCHAR(100);
 ALTER TABLE mb_group ADD COLUMN uuid UUID;
+ALTER TABLE mb_metadata ADD COLUMN fkey_mb_group_id integer;
More information about the Mapbender_commits mailing list
