[Mapbender-commits] r9569 - trunk/documents/presentations/FOSS4G2016
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Sep 2 02:57:52 PDT 2016
Author: astrid_emde
Date: 2016-09-02 02:57:52 -0700 (Fri, 02 Sep 2016)
New Revision: 9569
   trunk/documents/presentations/FOSS4G2016/FOSS4G2016_Mapbender3_Workshop_digitizer.txt
   trunk/documents/presentations/FOSS4G2016/FOSS4G2016_Mapbender3_Workshop_searchrouter.txt
fixed
Modified: trunk/documents/presentations/FOSS4G2016/FOSS4G2016_Mapbender3_Workshop_digitizer.txt
--- trunk/documents/presentations/FOSS4G2016/FOSS4G2016_Mapbender3_Workshop_digitizer.txt	2016-08-31 15:21:04 UTC (rev 9568)
+++ trunk/documents/presentations/FOSS4G2016/FOSS4G2016_Mapbender3_Workshop_digitizer.txt	2016-09-02 09:57:52 UTC (rev 9569)
@@ -1,55 +1,44 @@
--- DROP VIEW public.view_planet_osm_point;
+# add a connection to your osm_local database to mapbender
+# read more about database connections http://doc.mapbender3.org/en/book/database.html
+## in config.yml
+            osm_local:
+                driver:   %database2_driver%
+                host:     %database2_host%
+                port:     %database2_port%
+                dbname:   %database2_name%
+                path:     %database2_path%
+                user:     %database2_user%
+                password: %database2_password%
+                charset:  UTF8
-CREATE OR REPLACE VIEW public.view_planet_osm_point AS
- SELECT planet_osm_point.osm_id,
- planet_osm_point.gid,
-    planet_osm_point."addr:housenumber" AS housenumber,
-    planet_osm_point.amenity,
-    planet_osm_point.barrier,
-    planet_osm_point.bicycle,
-    planet_osm_point.brand,
-    planet_osm_point.building,
-    planet_osm_point.capital,
-    planet_osm_point.disused,
-    planet_osm_point.highway,
-    planet_osm_point.historic,
-    planet_osm_point.man_made,
-    planet_osm_point.name,
-    planet_osm_point.power,
-    planet_osm_point.public_transport,
-    planet_osm_point.railway,
-    planet_osm_point.ref AS location,
-    planet_osm_point.religion,
-    planet_osm_point.shop,
-    planet_osm_point.tourism,
-    planet_osm_point."tower:type" AS towertype,
-    planet_osm_point.z_order,
-    planet_osm_point.way AS geom
-   FROM planet_osm_point
-  WHERE planet_osm_point.amenity = 'post_box'::text
+# in parameters.yml
-ALTER TABLE public.view_planet_osm_point
-  OWNER TO "user";
+    # database connection to PostgreSQL database osm_local
+    database2_driver:   pdo_pgsql
+    database2_host:     localhost
+    database2_port:     5432
+    database2_name:     osm_local
+    database2_path:     ~
+    database2_user:     user
+    database2_password: user
-#-------------UNIQUE ID------------------------------------
-ALTER TABLE public.planet_osm_point ADD COLUMN gid integer;
-ALTER TABLE public.planet_osm_point ALTER COLUMN gid SET NOT NULL;
-ALTER TABLE public.planet_osm_point ALTER COLUMN gid SET DEFAULT nextval('planet_osm_point_gid_seq'::regclass);
-planet_osm_point_gid_seq: start value auf 9570 setzen
+# digitizer configuration
 poi:
     label: point digitizing
     maxResults: 500
     featureType:
         connection: osm_local
-        table: view_planet_osm_point
+        table: planet_osm_point
         uniqueId: gid
         geomType: point
         geomField: geom
         srid: 4326
+        filter: amenity = 'post_box'
     openFormAfterEdit: true
     zoomScaleDenominator: 500
     allowEditData: true
Modified: trunk/documents/presentations/FOSS4G2016/FOSS4G2016_Mapbender3_Workshop_searchrouter.txt
--- trunk/documents/presentations/FOSS4G2016/FOSS4G2016_Mapbender3_Workshop_searchrouter.txt	2016-08-31 15:21:04 UTC (rev 9568)
+++ trunk/documents/presentations/FOSS4G2016/FOSS4G2016_Mapbender3_Workshop_searchrouter.txt	2016-09-02 09:57:52 UTC (rev 9569)
@@ -1,44 +1,41 @@
--- View: public.view_planet_osm_point
+-- Create view on table planet_osm_point and refer only to the post boxes
+CREATE OR REPLACE VIEW view_planet_osm_point AS
+ SELECT osm_id,
+ gid,
+    "addr:housenumber" AS housenumber,
+    amenity,
+    barrier,
+    bicycle,
+    brand,
+    building,
+    capital,
+    disused,
+    highway,
+    historic,
+    man_made,
+    name,
+    power,
+    public_transport,
+    railway,
+    ref AS location,
+    religion,
+    shop,
+    tourism,
+    "tower:type" AS towertype,
+    z_order,
+    way AS geom
+  WHERE amenity = 'post_box'::text
-  OWNER TO "user";
 class: Mapbender\CoreBundle\Component\SQLSearchEngine
 class_options:
-    relation: public.view_planet_osm_point
+    relation: view_planet_osm_point
     attributes:
         - osm_id
         - amenity
More information about the Mapbender_commits mailing list
