[Mapbender-commits] r9571 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Fri Sep 2 05:35:38 PDT 2016
Author: armin11
Date: 2016-09-02 05:35:38 -0700 (Fri, 02 Sep 2016)
New Revision: 9571
trunk/mapbender/http/classes/class_map.php
trunk/mapbender/http/classes/class_wmc.php
trunk/mapbender/http/classes/class_wms.php
New functions for support of wms dimension parameters
Modified: trunk/mapbender/http/classes/class_map.php
--- trunk/mapbender/http/classes/class_map.php 2016-09-02 12:35:17 UTC (rev 9570)
+++ trunk/mapbender/http/classes/class_map.php 2016-09-02 12:35:38 UTC (rev 9571)
@@ -523,7 +523,6 @@
$currentWms = $jsMapObject->wms[$i];
//$e = new mb_exception("class_map.php: json map object: ".json_encode($jsMapObject));
$wms = new wms();
// set WMS data
@@ -542,6 +541,8 @@
$wms->gui_maxx = $currentWms->gui_maxx;
$wms->gui_maxy = $currentWms->gui_maxy;
$wms->gui_wms_mapformat = $currentWms->gui_wms_mapformat;
+ $wms->gui_wms_dimension_time = false;
+ $wms->gui_wms_dimension_elevation = false;
$wms->gui_wms_featureinfoformat = $currentWms->gui_wms_featureinfoformat;
$wms->gui_wms_exceptionformat = $currentWms->gui_wms_exceptionformat;
$e = new mb_notice('class_map: gui_wms_mapopacity: '.$currentWms->gui_wms_mapopacity);
@@ -611,7 +612,6 @@
$newLayer->layer_epsg[$z]["maxx"] = $currentLayer->layer_epsg[$z]->maxx;
$newLayer->layer_epsg[$z]["maxy"] = $currentLayer->layer_epsg[$z]->maxy;
// BEWARE THIS IS SUPER UGLY CODE
$newLayer->layer_style = array();
for ($z = 0; $z < count($currentLayer->layer_style); $z++) {
@@ -626,15 +626,10 @@
$indexDimension = count($newLayer->layer_dimension);
foreach($currentLayer->layer_dimension as $dimension) {
- //$dimensionAttributes = array();
foreach(get_object_vars($dimension) as $key=>$value) {
- //$dimensionAttributes[$key] = $value;
- //$newLayer->layer_dimension[] = array($key => $value);
- //$e = new mb_exception("class_map.php: (from map object to layer object) dimension attribute: ".$key." - with value: ".$value);
$newLayer->layer_dimension[$indexDimension]->$key = $value;
$indexDimension++;
array_push($this->wmsArray, $wms);
@@ -642,7 +637,6 @@
return true;
// database functions
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php 2016-09-02 12:35:17 UTC (rev 9570)
+++ trunk/mapbender/http/classes/class_wmc.php 2016-09-02 12:35:38 UTC (rev 9571)
@@ -2102,6 +2102,12 @@
$wms->gui_wms_visible = $currentLayer["extension"]["WMS_VISIBLE"];
$wms->gui_wms_opacity = $currentLayer["extension"]["GUI_WMS_OPACITY"];
$wms->gui_wms_sldurl = $currentLayer["style"][$styleIndex]["sld_url"];
+ //things for dimension
$wms->wms_srs = $currentLayer["epsg"];
$wms->gui_epsg = $currentLayer["epsg"];
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php 2016-09-02 12:35:17 UTC (rev 9570)
+++ trunk/mapbender/http/classes/class_wms.php 2016-09-02 12:35:38 UTC (rev 9571)
@@ -69,6 +69,9 @@
var $gui_wms_exceptionformat;
var $gui_wms_epsg;
var $gui_wms_sldurl;
+ var $gui_wms_dimension_time;
+ var $gui_wms_dimension_elevation;
var $default_epsg = 0;
var $overwrite = true;
@@ -1587,7 +1590,9 @@
"'" . $this->gui_wms_epsg ."'," .
"'" . $this->gui_wms_visible ."'," .
"'" . $this->gui_wms_opacity ."'," .
- "'" . $this->gui_wms_sldurl ."" .
+ "'" . $this->gui_wms_sldurl ."'," .
+ "'" . $this->gui_wms_dimension_time ."'," .
+ "'" . $this->gui_wms_dimension_elevation ."" .
$str .= $add_wms_string;
//add possible data formats
@@ -1722,7 +1727,9 @@
$this->gui_wms_epsg ."','".
$this->gui_wms_visible ."','".
$this->gui_wms_opacity ."','".
- $this->gui_wms_sldurl ."');");
+ $this->gui_wms_sldurl ."','".
+ $this->gui_wms_dimension_time ."','".
+ $this->gui_wms_dimension_elevation ."');");
for($i=0;$i<count($this->data_format);$i++){
if($parent){
@@ -3407,7 +3414,8 @@
$this->gui_wms_visible = $row["gui_wms_visible"];
$this->gui_wms_opacity = $row["gui_wms_opacity"];
$this->gui_wms_sldurl = $row["gui_wms_sldurl"];
+ $this->gui_wms_dimension_time = false;
+ $this->gui_wms_dimension_elevation = false;
$sql = "Select * from wms where wms_id = $1 ";
$v = array($wms_id);
$t = array('i');
@@ -3686,13 +3694,18 @@
$this->wms_max_imagesize = $row2["wms_max_imagesize"];
$this->inspire_annual_requests = $row2["inspire_annual_requests"];
- #some default
+ //some default values
$this->gui_wms_visible = 1;
$this->gui_wms_opacity = 100;
//the following things are not given without a special gui!!!!!
$this->gui_wms_epsg=$row["gui_wms_epsg"];
+ //default
if($this->wms_version == "1.0.0"){
$this->gui_wms_mapformat = "PNG";
$this->gui_wms_featureinfoformat = "MIME";
More information about the Mapbender_commits
