[Mapbender-commits] r9595 - in trunk/mapbender/http: php plugins
svn_mapbender at osgeo.org
Tue Sep 13 04:48:32 PDT 2016
Author: pschmidt
Date: 2016-09-13 04:48:32 -0700 (Tue, 13 Sep 2016)
New Revision: 9595
trunk/mapbender/http/php/mb_validateSession.php
trunk/mapbender/http/plugins/mb_digitize_widget.php
fixing export digitize
Modified: trunk/mapbender/http/php/mb_validateSession.php
--- trunk/mapbender/http/php/mb_validateSession.php 2016-09-13 06:35:27 UTC (rev 9594)
+++ trunk/mapbender/http/php/mb_validateSession.php 2016-09-13 11:48:32 UTC (rev 9595)
@@ -67,7 +67,7 @@
//use lang parameter to set the session var mb_lang
-if (isset($_REQUEST["lang"]) & $_REQUEST["lang"] != "") {
+if (isset($_REQUEST["lang"]) && $_REQUEST["lang"] != "") {
//validate to de, en, fr, ... give a whitelist
$testMatch = $_REQUEST["lang"];
if (!($testMatch == 'de' or $testMatch == 'en' or $testMatch == 'fr')){
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php 2016-09-13 06:35:27 UTC (rev 9594)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php 2016-09-13 11:48:32 UTC (rev 9595)
@@ -383,58 +383,40 @@
var exportItem = function(data) {
var dlg = $(exportHtml).dialog({ width: 330, height: 220 });
- // $(dlg).find('input').bind('change', function() {
- // if(!$(this).is(':checked')) {
- // return;
- // var fmt = $(this).val();
- // var url;
- // if(fmt === 'kml') {
- // url = tokml(data, {simplestyle: true});
- // if(fmt === 'gpx') {
- // url = togpx(data, {simplestyle: true});
- // if(fmt === 'geojson') {
- // url = JSON.stringify(data);
- // url = 'data:application/octet-stream,' + encodeURIComponent(url);
- // var lnk = $(dlg).find('.digitize-export')
- // .attr('download', 'myfeatures.' + fmt)
- // .attr('href', url);
- // }).change();
$(dlg).find('.exportDataLink').bind('click', function() {
var outputformat = $(this).attr('outputformat');
- var url;
- // var fmt = $(dlg).find('input:checked').val();
- if(outputformat === 'kml') {
- url = tokml(data, {simplestyle: true});
+ var content;
+ if(outputformat === 'kml') {
+ content = tokml(data, {simplestyle: true});
+ } else if(outputformat === 'gpx') {
+ content = togpx(data, {simplestyle: true});
+ } else if(outputformat === 'geojson') {
+ if (data.type != "Feature") {
+ content = JSON.stringify(data);
+ } else {
+ var newFeatureJson = $.extend(true, {}, data);
+ var jsonFeatureHeader = {"type": "FeatureCollection", "features": [newFeatureJson]};
+ content = JSON.stringify(jsonFeatureHeader);
- if(outputformat === 'gpx') {
- url = togpx(data, {simplestyle: true});
- if(outputformat === 'geojson') {
- if (data.type != "Feature") {
- url = JSON.stringify(data);
- } else {
- var newFeatureJson = $.extend(true, {}, data);
- var jsonFeatureHeader = {"type": "FeatureCollection", "features": [newFeatureJson]};
- url = JSON.stringify(jsonFeatureHeader);
+ } else {
+ alert('The output format "' + outputformat + '" is not supported.');
+ return false;
+ var ua = window.navigator.userAgent;
+ var msie = ua.indexOf("MSIE ");
+ if ((msie > 0 && parseInt(ua.substring(msie + 5, ua.indexOf(".", msie))) === 10) || !!ua.match(/Trident.*rv\:11\./)){
+ var blob = new Blob([content],{type:'application/' + outputformat});
+ window.navigator.msSaveBlob(blob, 'data.' + outputformat);
+ } else {
var link = document.createElement("a");
- link.setAttribute('href', 'data:text/text;charset=utf-8,' + encodeURIComponent(url));
+ link.setAttribute('href', 'data:application/octet-stream;charset=utf-8,' + encodeURIComponent(content));
link.setAttribute('download', 'myfeatures.' + outputformat);
$(dlg).append(link);
link.click();
$(dlg).remove(link);
- return false;
+ return false;
More information about the Mapbender_commits
