[Mapbender-commits] r9607 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Wed Sep 28 05:23:52 PDT 2016
Author: armin11
Date: 2016-09-28 05:23:51 -0700 (Wed, 28 Sep 2016)
New Revision: 9607
trunk/mapbender/http/classes/class_connector.php
Fix for setting timeout public instead of private and do an exception if curl give back a timed-out signal
Modified: trunk/mapbender/http/classes/class_connector.php
--- trunk/mapbender/http/classes/class_connector.php 2016-09-27 13:51:31 UTC (rev 9606)
+++ trunk/mapbender/http/classes/class_connector.php 2016-09-28 12:23:51 UTC (rev 9607)
@@ -28,7 +28,7 @@
var $file;
private $connectionType;
- private $timeOut = 20;
+ public $timeOut = 20;
private $httpType = "get";
private $httpVersion = "1.0";
private $httpPostData;
@@ -336,6 +336,10 @@
$error_log .= "lookup time: ".$info['namelookup_time']."\n";
$error_log .= "redirect_time: ".$info['redirect_time']."\n";
$error_log .= "redirect_count: ".$info['redirect_count']."\n";*/
+ if ($info['total_time'] == (float)0) {
+ $this->timedOut = true;
+ $e = new mb_exception("class_connector.php: Problem when connecting to external resource via curl - connection timed out: Waited more than ".$this->timeOut." seconds!");
if ($info['http_code'] == '401') {
curl_close ($ch);
return $info['http_code'];
@@ -354,7 +358,7 @@
if ($tmpHttpProxy != '') {
putenv("http_proxy=$tmpHttpProxy");
- #$e = new mb_notice("class_connector.php: CURL give back: ".$file);
+ //$e = new mb_notice("class_connector.php: CURL give back: ".$file);
return $file;
@@ -411,7 +415,7 @@
$postStr .= $this->httpPostData;
fputs($fp, $this->httpPostData);
- new mb_notice("connector.http.postData: ".$this->httpPostData);
+ //new mb_notice("connector.http.postData: ".$this->httpPostData);
$xmlstr = false;
//@TODO remove possibly infinite loop
More information about the Mapbender_commits
