[Mapbender-commits] r9823 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Fri Dec 1 02:09:52 PST 2017
Author: armin11
Date: 2017-12-01 02:09:52 -0800 (Fri, 01 Dec 2017)
New Revision: 9823
trunk/mapbender/http/php/mod_exportWmc2Json.php
Enhance wmc export handler to export hierarchical objects
Modified: trunk/mapbender/http/php/mod_exportWmc2Json.php
--- trunk/mapbender/http/php/mod_exportWmc2Json.php 2017-11-23 14:09:45 UTC (rev 9822)
+++ trunk/mapbender/http/php/mod_exportWmc2Json.php 2017-12-01 10:09:52 UTC (rev 9823)
@@ -16,12 +16,12 @@
require_once(dirname(__FILE__)."/../../core/globalSettings.php");
require_once(dirname(__FILE__) . "/../classes/class_wmc.php");
require_once(dirname(__FILE__) . "/../../conf/mobilemap.conf");
$user = new User();
$admin = new administration();
$userId = $user->id;
$mb_myBBOX = null;
$mb_myBBOXEpsg = null;
+$withHierarchy = false;
//check for parameter wmc_id
if(!isset($_GET["wmc_id"])){
echo 'Error: wmc_id not requested<br>';
@@ -52,6 +52,20 @@
die();
+if (isset($_REQUEST["withHierarchy"]) & $_REQUEST["withHierarchy"] != "") {
+ //validate to csv integer list
+ $testMatch = $_REQUEST["withHierarchy"];
+ if ($testMatch !== '1'){
+ echo 'Parameter <b>withHierarchy</b> is not valid - should be 1 or omitted.<br/>';
+ die();
+ if ($testMatch == '1') {
+ $withHierarchy = true;
+ //$e = new mb_exception("set hierarchy to true");
+ $testMatch = NULL;
if (isset($_REQUEST["epsg"]) & $_REQUEST["epsg"] != "") {
$testMatch = $_REQUEST["epsg"];
@@ -167,6 +181,7 @@
global $backgroundLayer;
global $mb_myBBOXEpsg;
global $mb_myBBOX;
+ global $withHierarchy;
//maybe faster to parse the xml itself and read the new layer_names and getmapurls directly
/* example reduced wmc json
{"wmc":{"id":"6","title":"Testwmc","bbox":"","timeStamp":"123123123"},"layerList":[{"internal":true,"currentFormat":"image/png","id":31452,"opacity":50},{"internal":"false","currentFormat":"image/jpeg","getMapUrl":"","layerTitle":"","layerName":"","layerAbstract":"","layerBbox":"","opacity":"50"}]}
@@ -271,35 +286,81 @@
//<Layer queryable="0" hidden="0">
//gui_wms_opacity
//use only layer which are not hidden and no root layer and support the requested SRS
- if ($layerParent != '' && in_array($crs, $layerSRS)) {
- if (!isset($layerId) || $layerId == '') {
- $wmcObject->layerList[$layerCount]->internal = false;
- $wmcObject->layerList[$layerCount]->layerName = (string)$layerArray[$i]->Name;
- $wmcObject->layerList[$layerCount]->opacity = (integer)$mbExtensions->gui_wms_opacity;
- $wmcObject->layerList[$layerCount]->active = $layerActive;
- $wmcObject->layerList[$layerCount]->currentFormat = (string)$layerArray[$i]->FormatList->Format[0];
- $wmcObject->layerList[$layerCount]->getMapUrl = (string)$layerArray[$i]->Server->OnlineResource->attributes('http://www.w3.org/1999/xlink')->href;
- $wmcObject->layerList[$layerCount]->layerTitle = (string)$layerArray[$i]->Title;
- $wmcObject->layerList[$layerCount]->layerAbstract = (string)$layerArray[$i]->Abstract;
- $wmcObject->layerList[$layerCount]->layerQueryable = $layerQueryable;
- $wmcObject->layerList[$layerCount]->queryLayer = (integer)$mbExtensions->querylayer;
- //layerBbox - TODO
- $layerCount++;
- } else {
- if (!in_array($layerId,$backgroundLayer)) {
- $wmcObject->layerList[$layerCount]->internal = true;
- $wmcObject->layerList[$layerCount]->layerId = (integer)$mbExtensions->layer_id;
+ if ($withHierarchy == true) {
+ if (in_array($crs, $layerSRS)) {
+ if (!isset($layerId) || $layerId == '') {
+ $wmcObject->layerList[$layerCount]->internal = false;
+ $wmcObject->layerList[$layerCount]->layerName = (string)$layerArray[$i]->Name;
+ $wmcObject->layerList[$layerCount]->getMapUrl = (string)$layerArray[$i]->Server->OnlineResource->attributes('http://www.w3.org/1999/xlink')->href;
+ $wmcObject->layerList[$layerCount]->layerTitle = (string)$layerArray[$i]->Title;
+ $wmcObject->layerList[$layerCount]->layerAbstract = (string)$layerArray[$i]->Abstract;
- //$wmcObject->layerList[$layerCount]->hidden = $layerHidden;
- //$wmcObject->layerList[$i]->layerHidden = $layerHidden;
- //$wmcObject->layerList[$layerCount]->layerParent = $layerParent;
+ if ($layerParent == '') {
+ $wmcObject->layerList[$layerCount]->layerParent = null;
+ } else {
+ $wmcObject->layerList[$layerCount]->layerParent = (integer)$mbExtensions->layer_parent;
+ $wmcObject->layerList[$layerCount]->layerPos = (integer)$mbExtensions->layer_pos;
+ //layerBbox - TODO
$layerCount++;
+ } else {
+ if (!in_array($layerId,$backgroundLayer)) {
+ $wmcObject->layerList[$layerCount]->internal = true;
+ $wmcObject->layerList[$layerCount]->layerId = (integer)$mbExtensions->layer_id;
+ $wmcObject->layerList[$layerCount]->opacity = (integer)$mbExtensions->gui_wms_opacity;
+ $wmcObject->layerList[$layerCount]->active = $layerActive;
+ $wmcObject->layerList[$layerCount]->currentFormat = (string)$layerArray[$i]->FormatList->Format[0];
+ $wmcObject->layerList[$layerCount]->layerQueryable = $layerQueryable;
+ $wmcObject->layerList[$layerCount]->queryLayer = (integer)$mbExtensions->querylayer;
+ } else {
+ //$wmcObject->layerList[$layerCount]->hidden = $layerHidden;
+ //$wmcObject->layerList[$i]->layerHidden = $layerHidden;
+ //$wmcObject->layerList[$layerCount]->layerParent = $layerParent;
+ $layerCount++;
+ } else {
+ if ($layerParent != '' && in_array($crs, $layerSRS)) {
+ $layerCount++;
+ } else {
+ $layerCount++;
echo json_encode($wmcObject);
More information about the Mapbender_commits
