[Mapbender-commits] r9825 - in trunk/mapbender: conf http/classes http/geoportal/xslt http/php
svn_mapbender at osgeo.org
Wed Dec 6 08:19:28 PST 2017
Author: armin11
Date: 2017-12-06 08:19:28 -0800 (Wed, 06 Dec 2017)
New Revision: 9825
Added:
trunk/mapbender/http/geoportal/xslt/dcat-ap-rdf2rdfa.xsl
trunk/mapbender/conf/isoMetadata.conf
trunk/mapbender/http/classes/class_iso19139.php
trunk/mapbender/http/php/mod_layerISOMetadata.php
New option to export html+rdf-a - some further configuration needed
Modified: trunk/mapbender/conf/isoMetadata.conf
--- trunk/mapbender/conf/isoMetadata.conf 2017-12-01 11:46:27 UTC (rev 9824)
+++ trunk/mapbender/conf/isoMetadata.conf 2017-12-06 16:19:28 UTC (rev 9825)
@@ -11,7 +11,11 @@
html => _mb("Metadata identifier"),
value => "",
category => "identification",
- description => _mb("A value uniquely identifying the resource. The value domain of this metadata element is a mandatory character string code, generally assigned by the data owner, and a character string namespace uniquely identifying the context of the identifier code (for example, the data owner).")
+ description => _mb("A value uniquely identifying the resource. The value domain of this metadata element is a mandatory character string code, generally assigned by the data owner, and a character string namespace uniquely identifying the context of the identifier code (for example, the data owner)."),
+ #rdf-a
+ property => null,
+ #content => null,
+ datatype => null
//B 1.1 (1)
array( ibus => "rtitle",
@@ -23,7 +27,9 @@
html => _mb("Resource title"),
value => "",
- description => _mb("This a characteristic, and often unique, name by which the resource is known. The value domain of this metadata element is free text.")
+ description => _mb("This a characteristic, and often unique, name by which the resource is known. The value domain of this metadata element is free text."),
+ #rdf-a
+ property => 'http://purl.org/dc/terms/title',
//B 1.2 (2)
array( ibus => "abstract",
@@ -35,7 +41,9 @@
html => _mb("Resource abstract"),
value => "",
- description => _mb("This is a brief narrative summary of the content of the resource.")
+ description => _mb("This is a brief narrative summary of the content of the resource."),
+ #rdf-a
+ property => 'http://purl.org/dc/terms/description'
//B 1.3 (3)
array( ibus => "rtype",
@@ -404,7 +412,10 @@
html => _mb("Metadata date"),
value => "",
category => "metadata",
- description => _mb("The date which specifies when the metadata record was created or updated. This date shall be expressed in conformity with ISO 8601.")
+ description => _mb("The date which specifies when the metadata record was created or updated. This date shall be expressed in conformity with ISO 8601."),
+ #rdf-a
+ property => 'http://purl.org/dc/terms/modified',
+ datatype => 'http://www.w3.org/2001/XMLSchema#date'
//B 10.3. Metadata language (32)
array( ibus => "t01_object.obj_id",
@@ -510,7 +521,11 @@
html => _mb("Encoding"),
value => "",
category => "dataspec",
- description => _mb("Description of the computer language construct(s) specifying the representation of data objects in a record, file, message, storage device or transmission channel.")
+ description => _mb("Description of the computer language construct(s) specifying the representation of data objects in a record, file, message, storage device or transmission channel."),
+ //rdf-a
+ //property => "http://www.w3.org/2011/content#characterEncoding",
+ //content => null,
+ //datatype => "http://www.w3.org/2001/XMLSchema#string"
//4. Topological Consistency ()
@@ -542,7 +557,11 @@
html => _mb("Character encoding"),
value => "",
- description => _mb("The character encoding used in the data set. This element is mandatory only if an encoding is used that is not based on UTF-8.")
+ description => _mb("The character encoding used in the data set. This element is mandatory only if an encoding is used that is not based on UTF-8."),
+ //rdf-a
+ property => "http://www.w3.org/2011/content#characterEncoding",
+ content => null,
+ datatype => "http://www.w3.org/2001/XMLSchema#string"
//Preview (36)
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php 2017-12-01 11:46:27 UTC (rev 9824)
+++ trunk/mapbender/http/classes/class_iso19139.php 2017-12-06 16:19:28 UTC (rev 9825)
@@ -313,7 +313,7 @@
$this->datasetIdCodeSpace = rtrim($code[0], $this->datasetId);
} else {
if (($parsedUrl['scheme'] == 'http' || $parsedUrl['scheme'] == 'https') && strpos($code[0],'#') !== false) {
- //$e = new mb_exception($code[0]);
+ $e = new mb_exception($code[0]);
$explodedUrl = explode('#', $code[0]);
$this->datasetId = $explodedUrl[1];
$this->datasetIdCodeSpace = $explodedUrl[0];
@@ -696,6 +696,23 @@
return $proc->transformToXML($xmlDoc);
+ public function transformToHtml2() {
+ $dcat = $this->transformToRdf();
+ $xslDoc = new DOMDocument();
+ $xslDoc->load(dirname(__FILE__) . "/../geoportal/xslt/dcat-ap-rdf2rdfa.xsl");
+ $xmlDoc = new DOMDocument();
+ $xmlDoc->loadXML($dcat);
+ $proc = new XSLTProcessor();
+ libxml_use_internal_errors(true);
+ $result = $proc->importStylesheet($xslDoc);
+ if (!$result) {
+ foreach (libxml_get_errors() as $error) {
+ $e = new mb_exception("Libxml error: {$error->message}\n");
+ return $proc->transformToXML($xmlDoc);
public function transformToHtml($layout,$languageCode){
//TODO don't parse it again, but change the internal parser function!
@@ -734,7 +751,7 @@
$iso19139Hash[$a]['value'] = ltrim($iso19139Hash[$a]['value'],',');
//generate html
- $html = '<!DOCTYPE html><html xmlns="http://www.w3.org/1999/xhtml" xml:lang="'.$languageCode.'">';
+ $html = '<!DOCTYPE html><html xmlns="http://www.w3.org/1999/xhtml" xmlns:dcat="http://www.w3.org/ns/dcat#" xmlns:dcterms="http://purl.org/dc/terms/" xmlns:dctype="http://purl.org/dc/dcmitype/" xmlns:foaf="http://xmlns.com/foaf/0.1/" xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#" xmlns:rdfs="http://www.w3.org/2000/01/rdf-schema#" xmlns:vcard="http://www.w3.org/2006/vcard/ns#" xml:lang="'.$languageCode.'">';
$metadataStr .= '<head>' .
'<title>'._mb("Metadata").'</title>' .
@@ -808,44 +825,56 @@
$tableEnd = "</table>\n";
//**************************overview part begin******************************
//generate div tags for the content - the divs are defined in the array
- if ($layout == 'accordion') {
- $html .= '<div style="height:300px">';
+ switch ($layout) {
+ case "accordion":
+ $html .= '<div style="height:300px">';
+ break;
+ case "tabs":
+ $html .= '<div id="tabs-1">';
+ break;
+ case "plain":
+ $html .= '<div>';
+ break;
+ default:
+ $html .= '<div>';
+ break;
- if ($layout == 'tabs') {
- $html .= '<div id="tabs-1">';
- if ($layout == 'plain') {
- $html .= '<div>';
- $html .= '<p>';
+ //$html .= '<p>';
$html .= '<fieldset><legend>'._mb("Metadata").'</legend>';
$html .= $tableBegin;
- $html .= $t_a."<b>".$iso19139Hash[0]['html']."</b>: ".$t_b.$iso19139Hash[0]['value'].$t_c;
- $html .= $t_a."<b>".$iso19139Hash[31]['html']."</b>: ".$t_b.$iso19139Hash[31]['value'].$t_c;
- $html .= $t_a."<b>".$iso19139Hash[32]['html']."</b>: ".$t_b.$iso19139Hash[32]['value'].$t_c;
+ #$html .= $t_a."<b>".$iso19139Hash[0]['html']."</b>: ".$t_b.'<p property="'.$iso19139Hash[0]['property'].'" datatype="'.$iso19139Hash[0]['datatype'].'" content="'.$iso19139Hash[0]['value'].'">'.$iso19139Hash[0]['value']."</p>".$t_c;
+ $hashIndices = array(0, 31 ,32);
+ foreach ($hashIndices as $index) {
+ $html .= $this->getHtmlRow($t_a, $t_b, $t_c, $iso19139Hash, $index);
$html .= $tableEnd;
$html .= '</fieldset>';
$html .= '<fieldset><legend>'._mb("Identification").'</legend>';
- $html .= $t_a."<b>".$iso19139Hash[1]['html']."</b>: ".$t_b.$iso19139Hash[1]['value'].$t_c;//title
- $html .= $t_a."<b>".$iso19139Hash[2]['html']."</b>: ".$t_b.$iso19139Hash[2]['value'].$t_c;//abstract
- $html .= $t_a."<b>".$iso19139Hash[3]['html']."</b>: ".$t_b.$iso19139Hash[3]['value'].$t_c;//type
+ $hashIndices = array(1, 2, 3); //title, abstract, type
if ($iso19139Hash[36]['value'] != "") {
$html .= $t_a."<b>".$iso19139Hash[36]['html']."</b>: ".$t_b."<img width=120 height=120 src = '".$iso19139Hash[36]['value']."'>".$t_c;//preview
//resource identifier
if ($iso19139Hash[37]['value'] != "") {
- //split with #
+ //split with # - TODO alter this!
$mdIdentifier = explode('#',$iso19139Hash[37]['value']);
- $html .= $t_a."<b>".$iso19139Hash[37]['html']."</b>: ".$t_b.$iso19139Hash[37]['value'].$t_c;//MD Identifier
+ $html .= $this->getHtmlRow($t_a, $t_b, $t_c, $iso19139Hash, 37); //MD Identifier
} else {
- $html .= $t_a."<b>".$iso19139Hash[5]['html']."</b>: ".$t_b.$iso19139Hash[5]['value'].$t_c;//namespace
- $html .= $t_a."<b>".$iso19139Hash[6]['html']."</b>: ".$t_b.$iso19139Hash[6]['value'].$t_c;//id
+ $hashIndices = array(5, 6); //namespace, id
- $html .= $t_a."<b>".$iso19139Hash[26]['html']."</b>: ".$t_b.$iso19139Hash[26]['value'].$t_c;//orga name
- $html .= $t_a."<b>".$iso19139Hash[27]['html']."</b>: ".$t_b.$iso19139Hash[27]['value'].$t_c;//email
+ $hashIndices = array(26, 27); //orga name, email
$html .= $tableEnd;
@@ -864,176 +893,218 @@
$html .= '<fieldset><legend>'._mb("Contact").'</legend>';
$html .= $tableEnd;
- $html .= '</p>';
+ //$html .= '</p>';
$html .= '</div>';//element
//**************************properties part begin******************************
- $html .= '<h3><a href="#">'._mb("Properties").'</a></h3>';
+ case "accordion":
+ $html .= '<h3><a href="#">'._mb("Properties").'</a></h3>';
+ break;
+ case "tabs":
+ $html .= '<div id="tabs-2">';
+ break;
+ case "plain":
+ $html .= '<h3>'._mb("Properties").'</h3>';
+ $html .= '<div>';
+ break;
+ default:
+ $html .= '<div>';
+ break;
- $html .= '<div id="tabs-2">';
- $html .= '<h3>'._mb("Properties").'</h3>';
- $html .= '<div>';
- $html .= '<p>';
+ //$html .= '<p>';
$html .= '<fieldset><legend>'._mb("Common").'</legend>';
- $html .= $t_a."<b>".$iso19139Hash[8]['html']."</b>: ".$t_b.$iso19139Hash[8]['value'].$t_c;
- $html .= $t_a."<b>".$iso19139Hash[9]['html']."</b>: ".$t_b.$iso19139Hash[9]['value'].$t_c;
- $html .= $t_a."<b>".$iso19139Hash[11]['html']."</b>: ".$t_b.$iso19139Hash[11]['value'].$t_c;
+ $hashIndices = array(8, 9, 11);
$html .= $tableEnd;
$html .= '<fieldset><legend>'._mb("Geographic extent").'</legend>';
- $html .= $t_a."<b>".$iso19139Hash[33]['html']."</b>: ".$t_b.$iso19139Hash[33]['value'].$t_c;
- $html .= $t_a."<b>".$iso19139Hash[12]['html']."</b>: ".$t_b.$iso19139Hash[12]['value'].$t_c;
+ $hashIndices = array(33, 12);
$html .= $tableEnd;
$html .= '<fieldset><legend>'._mb("Temporal extent").'</legend>';
- $html .= $t_a."<b>".$iso19139Hash[38]['html']."</b>: ".$t_b.$iso19139Hash[38]['value'].$t_c;
- $html .= $t_a."<b>".$iso19139Hash[39]['html']."</b>: ".$t_b.$iso19139Hash[39]['value'].$t_c;
- $html .= $t_a."<b>".$iso19139Hash[14]['html']."</b>: ".$t_b.$iso19139Hash[14]['value'].$t_c;
- $html .= $t_a."<b>".$iso19139Hash[15]['html']."</b>: ".$t_b.$iso19139Hash[15]['value'].$t_c;
- $html .= $t_a."<b>".$iso19139Hash[16]['html']."</b>: ".$t_b.$iso19139Hash[16]['value'].$t_c;
+ $hashIndices = array(38, 39, 14, 15, 16);
$html .= $tableEnd;
if ($iso19139Hash[3]['value'] == 'dataset' || $iso19139Hash[3]['value'] == 'series') {
$html .= '<fieldset><legend>'._mb("Format").'</legend>';
- $html .= $t_a."<b>".$iso19139Hash[34]['html']."</b>: ".$t_b.$iso19139Hash[34]['value'].$t_c;
- $html .= $t_a."<b>".$iso19139Hash[35]['html']."</b>: ".$t_b.$iso19139Hash[35]['value'].$t_c;
+ $hashIndices = array(34, 35);
$html .= $tableEnd;
if ($iso19139Hash[3]['value'] == 'service') {
$html .= '<fieldset><legend>'._mb("Service information").'</legend>';
- $html .= $t_a."<b>".$iso19139Hash[10]['html']."</b>: ".$t_b.$iso19139Hash[10]['value'].$t_c;
- $html .= $t_a."<b>".$iso19139Hash[7]['html']."</b>: ".$t_b.$iso19139Hash[7]['value'].$t_c;
+ $hashIndices = array(10, 7);
$html .= $tableEnd;
- $html .= '</p>';
//**************************contact part begin******************************
+ case "accordion":
+ $html .= '<h3><a href="#">'._mb("Contact").'</a></h3>';
+ break;
+ case "tabs":
+ $html .= '<div id="tabs-3">';
+ break;
+ case "plain":
+ $html .= '<h3>'._mb("Contact").'</h3>';
+ $html .= '<div>';
+ break;
+ default:
+ $html .= '<div>';
+ break;
- $html .= '<div id="tabs-3">';
- $html .= '<div>';
- $html .= '<p>';
+ //$html .= '<p>';
$html .= '<fieldset><legend>'._mb("Data/Service provider").'</legend>';
- $html .= $t_a."<b>".$iso19139Hash[28]['html']."</b>: ".$t_b.$iso19139Hash[28]['value'].$t_c;
+ $hashIndices = array(26, 28, 27);
$html .= $tableEnd;
$html .= '<fieldset><legend>'._mb("Metadata provider").'</legend>';
- $html .= $t_a."<b>".$iso19139Hash[29]['html']."</b>: ".$t_b.$iso19139Hash[29]['value'].$t_c;
- $html .= $t_a."<b>".$iso19139Hash[30]['html']."</b>: ".$t_b.$iso19139Hash[30]['value'].$t_c;
+ $hashIndices = array(29, 30);
$html .= $tableEnd;
- $html .= '</p>';
//**************************terms of use part begin******************************
- $html .= '<h3><a href="#">'._mb("Terms of use").'</a></h3>';
+ case "accordion":
+ $html .= '<h3><a href="#">'._mb("Terms of use").'</a></h3>';
+ break;
+ case "tabs":
+ $html .= '<div id="tabs-4">';
+ break;
+ case "plain":
+ $html .= '<h3>'._mb("Terms of use").'</h3>';
+ $html .= '<div>';
+ break;
+ default:
+ $html .= '<div>';
+ break;
- $html .= '<div id="tabs-4">';
- $html .= '<h3>'._mb("Terms of use").'</h3>';
- $html .= '<div>';
- $html .= '<p>';
+ //$html .= '<p>';
$html .= '<fieldset><legend>'._mb("Conditions").'</legend>';
- $html .= $t_a."<b>".$iso19139Hash[23]['html']."</b>: ".$t_b.$iso19139Hash[23]['value'].$t_c;
+ $html .= $this->getHtmlRow($t_a, $t_b, $t_c, $iso19139Hash, 23);
$html .= $tableEnd;
$html .= '<fieldset><legend>'._mb("Access constraints").'</legend>';
- $html .= $t_a."<b>".$iso19139Hash[24]['html']."</b>: ".$t_b.$iso19139Hash[24]['value'].$t_c;
- $html .= $t_a."<b>".$iso19139Hash[25]['html']."</b>: ".$t_b.$iso19139Hash[25]['value'].$t_c;
+ $hashIndices = array(24, 25);
$html .= $tableEnd;
- $html .= '</p>';
//**************************quality part begin******************************
- $html .= '<h3><a href="#">'._mb("Quality").'</a></h3>';
+ case "accordion":
+ $html .= '<h3><a href="#">'._mb("Quality").'</a></h3>';
+ break;
+ case "tabs":
+ $html .= '<div id="tabs-5">';
+ break;
+ case "plain":
+ $html .= '<h3>'._mb("Quality").'</h3>';
+ $html .= '<div>';
+ break;
+ default:
+ $html .= '<div>';
+ break;
- $html .= '<div id="tabs-5">';
- $html .= '<h3>'._mb("Quality").'</h3>';
- $html .= '<div>';
- $html .= '<p>';
+ //$html .= '<p>';
$html .= '<fieldset><legend>'._mb("Lineage").'</legend>';
- $html .= $t_a."<b>".$iso19139Hash[17]['html']."</b>: ".$t_b.$iso19139Hash[17]['value'].$t_c;
+ $html .= $this->getHtmlRow($t_a, $t_b, $t_c, $iso19139Hash, 17);
$html .= $tableEnd;
$html .= '<fieldset><legend>'._mb("Resolution").'</legend>';
- $html .= $t_a."<b>".$iso19139Hash[18]['html']."</b>: ".$t_b.$iso19139Hash[18]['value'].$t_c;
- $html .= $t_a."<b>".$iso19139Hash[19]['html']."</b>: ".$t_b.$iso19139Hash[19]['value'].$t_c;
+ $hashIndices = array(18, 19);
$html .= $tableEnd;
$html .= '<fieldset><legend>'._mb("Validity").'</legend>';
- $html .= $t_a."<b>".$iso19139Hash[20]['html']."</b>: ".$t_b.$iso19139Hash[20]['value'].$t_c;
- $html .= $t_a."<b>".$iso19139Hash[21]['html']."</b>: ".$t_b.$iso19139Hash[21]['value'].$t_c;
- $html .= $t_a."<b>".$iso19139Hash[22]['html']."</b>: ".$t_b.$iso19139Hash[22]['value'].$t_c;
+ $hashIndices = array(20, 21, 22);
$html .= $tableEnd;
- $html .= '</p>';
//**************************Interfaces part begin******************************
- $html .= '<h3><a href="#">'._mb("Interfaces").'</a></h3>';
+ case "accordion":
+ $html .= '<h3><a href="#">'._mb("Interfaces").'</a></h3>';
+ break;
+ case "tabs":
+ $html .= '<div id="tabs-6">';
+ break;
+ case "plain":
+ $html .= '<h3>'._mb("Interfaces").'</h3>';
+ $html .= '<div>';
+ break;
+ default:
+ $html .= '<div>';
+ break;
- $html .= '<div id="tabs-6">';
- $html .= '<h3>'._mb("Interfaces").'</h3>';
- $html .= '<div>';
+ //$html .= '<p>';
$html .= '<fieldset><legend>'._mb("Online access").'</legend>';
$html .= $t_a."<b>".$iso19139Hash[4]['html']."</b>: ".$t_b."<a href='".$iso19139Hash[4]['value']."' target='_blank'>".$iso19139Hash[4]['value']."</a>".$t_c;
@@ -1047,19 +1118,17 @@
$html .= $tableEnd;
- $html .= '</p>';
//exchange mdtype html with iso19139
//$queryNew = str_replace("mdtype=html","mdtype=iso19139",$_SERVER['QUERY_STRING']);
- $html .= $t_a."<b>"._mb("ISO19139")."</b>: <a href='".$this->href."' target='_blank'>"._mb("Metadata")."</a>".$t_c;
- $html .= $t_a."<b>"._mb("RDF")."</b>: <a href='".$_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING']."&outputFormat=rdf"."' target='_blank'>"._mb("Geo-DCAT Metadata")."</a>".$t_c;
+ $html .= $t_a."<b>"._mb("ISO19139")."</b>: ".$t_b."<a href='".$this->href."' target='_blank'>"._mb("Metadata")."</a>".$t_c;
+ $html .= $t_a."<b>"._mb("RDF")."</b>: ".$t_b."<a href='".$_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING']."&outputFormat=rdf"."' target='_blank'>"._mb("Geo-DCAT Metadata")."</a>".$t_c;
//<a href='".$_SERVER['PHP_SELF']."?".$queryNew."&validate=true' target='_blank'><img style='border: none;' src = '../img/misc/icn_inspire_validate.png' title='"._mb("INSPIRE Validator")."'></a>
//push xml instead of html? But there is no real url
$html .= $tableEnd;
- $html .= '</p>';
$html .= '</div>'; //accordion
@@ -1069,7 +1138,25 @@
return $html;
+ private function getHtmlRow($t_a, $t_b, $t_c, $iso19139Hash, $isoHashIndex){
+ $stringToReturn = $t_a."<b>".$iso19139Hash[$isoHashIndex]['html']."</b>: ".$t_b."<p ";
+ if (!isset($iso19139Hash[$isoHashIndex]['content']) && isset($iso19139Hash[$isoHashIndex]['property'])) {
+ $iso19139Hash[$isoHashIndex]['content'] = $iso19139Hash[$isoHashIndex]['value'];
+ if (isset($iso19139Hash[$isoHashIndex]['property'])) {
+ $stringToReturn .= ' property="'.$iso19139Hash[$isoHashIndex]['property'].'"';
+ if (isset($iso19139Hash[$isoHashIndex]['content'])) {
+ $stringToReturn .= ' content="'.$iso19139Hash[$isoHashIndex]['content'].'"';
+ if (isset($iso19139Hash[$isoHashIndex]['datatype'])) {
+ $stringToReturn .= ' datatype="'.$iso19139Hash[$isoHashIndex]['datatype'].'"';
+ $stringToReturn .= ">".$iso19139Hash[$isoHashIndex]['value']."</p>".$t_c;
+ return $stringToReturn;
private function parseExteriorPolygon($gml3Polygon) {
//cause postgis gives back polygons without namspace, we have to add a namespace before parsing the xml again :-(
$gml3Polygon = "<?xml version=\"1.0\" encoding=\"utf-8\" ?>".$gml3Polygon;
Added: trunk/mapbender/http/geoportal/xslt/dcat-ap-rdf2rdfa.xsl
--- trunk/mapbender/http/geoportal/xslt/dcat-ap-rdf2rdfa.xsl (rev 0)
+++ trunk/mapbender/http/geoportal/xslt/dcat-ap-rdf2rdfa.xsl 2017-12-06 16:19:28 UTC (rev 9825)
@@ -0,0 +1,426 @@
+<?xml version="1.0" encoding="utf-8" ?>
+ Copyright 2015-2017 EUROPEAN UNION
+ Licensed under the EUPL, Version 1.1 or - as soon they will be approved by
+ the European Commission - subsequent versions of the EUPL (the "Licence");
+ You may not use this work except in compliance with the Licence.
+ You may obtain a copy of the Licence at:
+ http://ec.europa.eu/idabc/eupl
+ Unless required by applicable law or agreed to in writing, software
+ distributed under the Licence is distributed on an "AS IS" basis,
+ WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ See the Licence for the specific language governing permissions and
+ limitations under the Licence.
+ Authors: European Commission, Joint Research Centre (JRC)
+ Andrea Perego <andrea.perego at ec.europa.eu>
+ This work was supported by the EU Interoperability Solutions for
+ European Public Administrations Programme (http://ec.europa.eu/isa)
+ through Action 1.17: Re-usable INSPIRE Reference Platform
+ (http://ec.europa.eu/isa/actions/01-trusted-information-exchange/1-17action_en.htm).
+ PURPOSE AND USAGE
+ This XSLT is a proof of concept for the HTML+RDFa representation of metadata
+ based on DCAT-AP, and related extensions (as GeoDCAT-AP). The DCAT-AP
+ specification is available on Joinup, the collaboration platform of the
+ EU ISA Programme:
+ https://joinup.ec.europa.eu/node/63567/
+ As such, this XSLT must be considered as unstable, and can be updated any
+ time based on the revisions to the DCAT-AP specification and related
+ extensions.
+ The official distributions of this XSLT are published in the European
+ Commission's Stash repository:
+ https://webgate.ec.europa.eu/CITnet/stash/projects/ODCKAN/repos/dcat-ap-rdf2html
+ Comments and inquiries should be sent to the GeoDCAT-AP WG mailing list:
+ dcat_application_profile-geo at joinup.ec.europa.eu
+<xsl:transform
+ xmlns:dcat = "http://www.w3.org/ns/dcat#"
+ xmlns:dcterms = "http://purl.org/dc/terms/"
+ xmlns:dctype = "http://purl.org/dc/dcmitype/"
+ xmlns:foaf = "http://xmlns.com/foaf/0.1/"
+ xmlns:rdf = "http://www.w3.org/1999/02/22-rdf-syntax-ns#"
+ xmlns:rdfs = "http://www.w3.org/2000/01/rdf-schema#"
+ xmlns:vcard = "http://www.w3.org/2006/vcard/ns#"
+ xmlns:xsl = "http://www.w3.org/1999/XSL/Transform"
+ version="1.0">
+ <xsl:output method="html"
+ doctype-system="about:legacy-compact"
+ media-type="text/html"
+ omit-xml-declaration="yes"
+ encoding="UTF-8"
+ exclude-result-prefixes="#all"
+ indent="yes" />
+<!-- Global parameters -->
+<!-- The URL of the repository hosting the XSLT source code -->
+ <xsl:param name="home">https://webgate.ec.europa.eu/CITnet/stash/projects/ODCKAN/repos/dcat-ap-html</xsl:param>
+<!-- The title of the resulting HTML page.
+ This information can be passed as a parameter by the XSLT
+ processor used. -->
+ <xsl:param name="title">
+ <xsl:choose>
+ <xsl:when test="/rdf:RDF/rdf:Description[@rdf:about='']">
+ <xsl:choose>
+ <xsl:when test="/rdf:RDF/rdf:Description/dcterms:title">
+ <xsl:value-of select="/rdf:RDF/rdf:Description/dcterms:title"/>
+ </xsl:when>
+ <xsl:when test="/rdf:RDF/rdf:Description/rdfs:label">
+ <xsl:value-of select="/rdf:RDF/rdf:Description/rdfs:label"/>
+ </xsl:when>
+ <xsl:otherwise>
+ <xsl:text>DCAT-AP in HTML+RDFa</xsl:text>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:when>
+ <xsl:otherwise>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:param>
+<!-- The footer of the resulting HTML page.
+ <xsl:param name="footer">
+ <p><xsl:value-of select="$title"/><xsl:text> @ Stash: </xsl:text><a href="{$home}"><xsl:value-of select="$home"/></a></p>
+ </xsl:param>
+<!-- Use this parameter to specify the set of LINK, STYLE, SCRIPT
+ elements to be added to the HEAD of the resulting HTML document.
+ <xsl:param name="head"/>
+<!-- Namespace URIs -->
+ <xsl:param name="rdf">http://www.w3.org/1999/02/22-rdf-syntax-ns#</xsl:param>
+<!-- Class to be used to type untyped blank nodes -->
+ <xsl:param name="bnodeClass">
+ <rdfs:Resource/>
+ </xsl:param>
+ <xsl:param name="bnodeClassName" select="name(document('')/*/xsl:param[@name='bnodeClass']/*)"/>
+ <xsl:param name="bnodeClassURI" select="concat(namespace-uri(document('')/*/xsl:param[@name='bnodeClass']/*),local-name(document('')/*/xsl:param[@name='bnodeClass']/*))"/>
+<!-- Main template -->
+ <xsl:template match="/">
+ <xsl:param name="DatasetNr" select="count(rdf:RDF/dcat:Dataset|rdf:RDF/rdf:Description[rdf:type/@rdf:resource='http://www.w3.org/ns/dcat#Dataset'])"/>
+ <xsl:param name="ServiceNr" select="count(rdf:RDF/dcat:Catalog|rdf:RDF/dctype:Service|rdf:RDF/rdf:Description[rdf:type/@rdf:resource='http://www.w3.org/ns/dcat#Catalog' or rdf:type/@rdf:resource='http://purl.org/dc/dcmitype/Service'])"/>
+<html>
+ <head>
+ <title><xsl:value-of select="$title"/></title>
+ <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
+ <xsl:value-of select="$head" disable-output-escaping="yes"/>
+ </head>
+ <body>
+ <header><h1><xsl:value-of select="$title"/></h1></header>
+ <nav>
+ </nav>
+ <section>
+ <h1>Summary</h1>
+ <dl>
+ <dt>Datasets</dt>
+ <dd><xsl:value-of select="$DatasetNr"/></dd>
+ <dt>Services</dt>
+ <dd><xsl:value-of select="$ServiceNr"/></dd>
+ </dl>
+ </section>
+ <xsl:apply-templates select="rdf:RDF/dcat:Dataset|rdf:RDF/rdf:Description[rdf:type/@rdf:resource='http://www.w3.org/ns/dcat#Dataset']"/>
+ <xsl:apply-templates select="rdf:RDF/dcat:Catalog|rdf:RDF/dctype:Service|rdf:RDF/rdf:Description[rdf:type/@rdf:resource='http://www.w3.org/ns/dcat#Catalog' or rdf:type/@rdf:resource='http://purl.org/dc/dcmitype/Service']"/>
+ <section>
+ <h1>Datasets (<xsl:value-of select="count(rdf:RDF/dcat:Dataset|rdf:RDF/rdf:Description[rdf:type/@rdf:resource='http://www.w3.org/ns/dcat#Dataset'])"/>)</h1>
+ </section>
+ <section>
+ <h1>Services (<xsl:value-of select="count(rdf:RDF/dcat:Catalog|rdf:RDF/dctype:Service|rdf:RDF/rdf:Description[rdf:type/@rdf:resource='http://www.w3.org/ns/dcat#Catalog' or rdf:type/@rdf:resource='http://purl.org/dc/dcmitype/Service'])"/>)</h1>
+ </section>
+ <aside>
+ </aside>
+ <footer>
+ <xsl:copy-of select="$footer"/>
+ </footer>
+ </body>
+</html>
+ </xsl:template>
+ <xsl:template name="Dataset" match="rdf:RDF/dcat:Dataset|rdf:RDF/rdf:Description[rdf:type/@rdf:resource='http://www.w3.org/ns/dcat#Dataset']">
+ <section class="record">
+ <h1>Dataset: <span xml:lang="{dcterms:title/@xml:lang}" lang="{dcterms:title/@xml:lang}"><xsl:value-of select="dcterms:title"/></span></h1>
+ <xsl:call-template name="Agent"/>
+ <p xml:lang="{dcterms:description/@xml:lang}" lang="{dcterms:description/@xml:lang}"><xsl:value-of select="dcterms:description"/></p>
+ <xsl:call-template name="metadata"/>
+ </section>
+ </xsl:template>
+ <xsl:template name="Service" match="rdf:RDF/dcat:Catalog|rdf:RDF/dctype:Service|rdf:RDF/rdf:Description[rdf:type/@rdf:resource='http://www.w3.org/ns/dcat#Catalog' or rdf:type/@rdf:resource='http://purl.org/dc/dcmitype/Service']">
+ <h1>Service: <span xml:lang="{dcterms:title/@xml:lang}" lang="{dcterms:title/@xml:lang}"><xsl:value-of select="dcterms:title"/></span></h1>
+ </section>
+ </xsl:template>
+ <xsl:template name="Agent">
+ <address>
+ <dl>
+ <xsl:for-each select="dcterms:publisher">
+ <xsl:variable name="org" select="*/foaf:name"/>
+ <xsl:variable name="email" select="*/foaf:mbox/@rdf:resource"/>
+ <xsl:variable name="url" select="*/foaf:workplaceHomepage/@rdf:resource"/>
+ <xsl:variable name="name" select="$org"/>
+ <dt>Publisher</dt>
+ <dd>
+ <xsl:choose>
+ <xsl:when test="$url != ''">
+ <a href="{$url}"><xsl:value-of select="$name"/></a>
+ </xsl:when>
+ <xsl:otherwise>
+ <xsl:value-of select="$name"/>
+ </xsl:otherwise>
+ </xsl:choose>
+ <xsl:if test="$email != ''">
+ <xsl:text> (</xsl:text><a href="{$email}"><xsl:value-of select="substring-after($email, 'mailto:')"/></a><xsl:text>)</xsl:text>
+ </xsl:if>
+ </dd>
+ </xsl:for-each>
+ <xsl:for-each select="dcat:contactPoint">
+ <xsl:variable name="individual" select="*/vcard:fn"/>
+ <xsl:variable name="org" select="*/vcard:organization-name"/>
+ <xsl:variable name="email" select="*/vcard:hasEmail/@rdf:resource"/>
+ <xsl:variable name="url" select="*/vcard:hasURL/@rdf:resource"/>
+ <xsl:variable name="name">
+ <xsl:choose>
+ <xsl:when test="$individual != '' and $org != ''">
+ <xsl:value-of select="$individual"/>
+ <xsl:text>, </xsl:text>
+ <xsl:value-of select="$org"/>
+ </xsl:when>
+ <xsl:otherwise>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:variable>
+ <dt>Contact point</dt>
+ <dd>
+ <xsl:choose>
+ </xsl:when>
+ <xsl:otherwise>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:if>
+ </dd>
+ </xsl:for-each>
+ </dl>
+ </address>
+ </xsl:template>
+ <xsl:template name="metadata">
+ <section class="metadata">
+ <h2>Metadata</h2>
+ <details>
+ <summary>Details</summary>
+ <xsl:call-template name="subject"/>
+ </details>
+ </section>
+ </xsl:template>
+ <xsl:template name="subject">
+ <xsl:param name="ename">
+ <xsl:call-template name="setEname"/>
+ </xsl:param>
+ <xsl:param name="predicate">
+ <xsl:call-template name="label"/>
+ <dd>
+ <xsl:for-each select="*">
+ <xsl:call-template name="predicate"/>
+ </xsl:for-each>
+ </dd>
+ </xsl:param>
+ <xsl:choose>
+ <xsl:when test="@rdf:about">
+ <dl about="{@rdf:about}" typeof="{$ename}">
+ <xsl:copy-of select="$predicate"/>
+ </dl>
+ </xsl:when>
+ <xsl:when test="@rdf:ID">
+ <dl about="#{@rdf:ID}" typeof="{$ename}">
+ </dl>
+ </xsl:when>
+ <xsl:when test="@rdf:nodeID">
+ <dl typeof="{$ename}">
+ </dl>
+ </xsl:when>
+ <xsl:otherwise>
+ </dl>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:template>
+ <xsl:template name="predicate">
+ </xsl:param>
+ <xsl:choose>
+<!-- Object properties -->
+ <xsl:when test="(child::* and not(@rdf:parseType='Literal')) or @rdf:resource">
+ <dl rel="{$ename}">
+ <xsl:choose>
+ <xsl:when test="@rdf:resource">
+ <dd><a resource="{@rdf:resource}" href="{@rdf:resource}"><xsl:value-of select="@rdf:resource"/></a></dd>
+ </xsl:when>
+ <xsl:when test="@rdf:parseType = 'Resource'">
+ <dd>
+ <dl typeof="{$bnodeClassURI}">
+ <dt><xsl:value-of select="$bnodeClassName"/></dt>
+ <dd>
+ </xsl:for-each>
+ </dd>
+ </dl>
+ </dd>
+ </xsl:when>
+ <xsl:otherwise>
+ <dd>
+ </xsl:for-each>
+ </dd>
+ </xsl:otherwise>
+ </xsl:choose>
+ </dl>
+ </xsl:when>
+<!-- Datatype properties -->
+ <xsl:otherwise>
+ <dl>
+ <xsl:choose>
+ <xsl:when test="@xml:lang">
+ <dd property="{$ename}" content="{.}" xml:lang="{@xml:lang}" lang="{@xml:lang}"><xsl:value-of select="."/></dd>
+ </xsl:when>
+ <xsl:when test="@rdf:datatype">
+ <dd property="{$ename}" content="{.}" datatype="{@rdf:datatype}"><code><xsl:value-of select="."/></code></dd>
+ </xsl:when>
+ <xsl:when test="@rdf:parseType = 'Literal'">
+ <dd property="{$ename}" content="{.}" datatype="{$rdf}XMLLiteral"><code><xsl:value-of select="."/></code></dd>
+ </xsl:when>
+ <xsl:otherwise>
+ <dd property="{$ename}" content="{.}"><xsl:value-of select="."/></dd>
+ </xsl:otherwise>
+ </xsl:choose>
+ </dl>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:template>
+ <xsl:template name="label">
+ <xsl:param name="qname">
+ <xsl:call-template name="setQname"/>
+ </xsl:param>
+ <xsl:choose>
+<!-- Object properties & individuals -->
+ <xsl:when test="child::* or @rdf:about or @rdf:resource">
+ <xsl:choose>
+ <xsl:when test="@rdf:parseType">
+ <dt><xsl:value-of select="$qname"/></dt>
+ </xsl:when>
+ </xsl:when>
+ <dt><a href="{@rdf:about}"><xsl:value-of select="@rdf:about"/></a><xsl:text> (</xsl:text><xsl:value-of select="$qname"/><xsl:text>)</xsl:text></dt>
+ </xsl:when>
+ <dt><a href="#{@rdf:ID}"><xsl:value-of select="concat('#', at rdf:about)"/></a><xsl:text> (</xsl:text><xsl:value-of select="$qname"/><xsl:text>)</xsl:text></dt>
+ </xsl:when>
+ <xsl:otherwise>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:when>
+<!-- Datatype properties, plain and typed literals -->
+ <xsl:otherwise>
+ <xsl:choose>
+ <dt><xsl:value-of select="$qname"/><xsl:text> (</xsl:text><a href="{@rdf:datatype}"><xsl:value-of select="@rdf:datatype"/></a><xsl:text>)</xsl:text></dt>
+ </xsl:when>
+ <dt><xsl:value-of select="$qname"/><xsl:text> (</xsl:text><xsl:value-of select="@xml:lang"/><xsl:text>)</xsl:text></dt>
+ </xsl:when>
+ <xsl:otherwise>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:template>
+ <xsl:template name="setQname">
+ <xsl:choose>
+ <xsl:when test="name(.) = 'rdf:Description'">
+ <xsl:value-of select="$bnodeClassName"/>
+ </xsl:when>
+ <xsl:otherwise>
+ <xsl:value-of select="name(.)"/>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:template>
+ <xsl:template name="setEname">
+ <xsl:choose>
+ <xsl:value-of select="$bnodeClassURI"/>
+ </xsl:when>
+ <xsl:otherwise>
+ <xsl:value-of select="concat(namespace-uri(.),local-name(.))"/>
+ </xsl:otherwise>
+ </xsl:choose>
+ </xsl:template>
+</xsl:transform>
Modified: trunk/mapbender/http/php/mod_layerISOMetadata.php
--- trunk/mapbender/http/php/mod_layerISOMetadata.php 2017-12-01 11:46:27 UTC (rev 9824)
+++ trunk/mapbender/http/php/mod_layerISOMetadata.php 2017-12-06 16:19:28 UTC (rev 9825)
@@ -55,7 +55,7 @@
$testMatch = NULL;
-if ($_REQUEST['OUTPUTFORMAT'] == "iso19139" || $_REQUEST['OUTPUTFORMAT'] == "rdf" || $_REQUEST['OUTPUTFORMAT'] == 'html') {
+if ($_REQUEST['OUTPUTFORMAT'] == "iso19139" || $_REQUEST['OUTPUTFORMAT'] == "rdf" || $_REQUEST['OUTPUTFORMAT'] == 'html' || $_REQUEST['OUTPUTFORMAT'] == 'html-rdf-a') {
//Initialize XML document
$iso19139Doc = new DOMDocument('1.0');
$iso19139Doc->encoding = 'UTF-8';
@@ -64,7 +64,7 @@
$outputFormat = $_REQUEST['OUTPUTFORMAT'];
} else {
//echo 'outputFormat: <b>'.$_REQUEST['OUTPUTFORMAT'].'</b> is not set or valid.<br/>';
- echo 'Parameter outputFormat is not set or valid (iso19139 | rdf | html).<br/>';
+ echo 'Parameter outputFormat is not set or valid (iso19139 | rdf | html | html-rdf-a).<br/>';
die();
@@ -882,6 +882,12 @@
return $iso19139->transformToHtml();
+function xml2html2($iso19139xml) {
+ $iso19139 = new Iso19139();
+ $iso19139->createMapbenderMetadataFromXML($iso19139xml);
+ return $iso19139->transformToHtml2();
function proxyFile($iso19139str,$outputFormat) {
switch ($outputFormat) {
case "rdf":
@@ -892,6 +898,10 @@
header("Content-type: text/html; charset=UTF-8");
echo xml2html($iso19139str);
break;
+ case "html-rdf-a":
+ header("Content-type: text/html; charset=UTF-8");
+ echo xml2html2($iso19139str);
+ break;
default:
header("Content-type: text/xml; charset=UTF-8");
echo $iso19139str;
More information about the Mapbender_commits
