[Mapbender-commits] r9689 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Mon Feb 20 07:43:49 PST 2017
Author: armin11
Date: 2017-02-20 07:43:49 -0800 (Mon, 20 Feb 2017)
New Revision: 9689
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
New view for wfs metadata search - to be tested
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql 2017-02-17 11:25:28 UTC (rev 9688)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql 2017-02-20 15:43:49 UTC (rev 9689)
@@ -1626,5 +1626,89 @@
ALTER TABLE search_wfs_view
OWNER TO postgres;
+--f_get_responsible_organization(integer, integer)
+-- DROP FUNCTION f_get_responsible_organization(integer, integer);
+CREATE OR REPLACE FUNCTION f_get_responsible_organization(i_user_id integer, i_group_id integer)
+ RETURNS integer AS
+$BODY$DECLARE
+ --i_user_id ALIAS FOR $1;
+ --i_group_id ALIAS FOR $2;
+ -- give i_group_id in form: coalesce(i_group_id,0), because otherwise NULL values will not be interpreted!
+ -- select f_get_responsible_organization(1,coalesce(21,0));
+ i_resp_orga_id INTEGER;
+BEGIN
+RAISE NOTICE 'group_id = %', i_group_id;
+IF i_group_id IS NULL OR i_group_id <= 0 THEN
+ i_resp_orga_id := fkey_mb_group_id FROM mb_user_mb_group WHERE mb_user_mb_group_type = 2 AND fkey_mb_user_id = i_user_id LIMIT 1;
+ELSE
+ i_resp_orga_id = i_group_id;
+END IF;
+RETURN i_resp_orga_id;
+END;
+$BODY$
+ LANGUAGE plpgsql VOLATILE STRICT
+ COST 100;
+ALTER FUNCTION f_get_responsible_organization(integer, integer)
+ OWNER TO postgres;
+-- Function: f_get_geometry_type(integer)
+-- DROP FUNCTION f_get_geometry_type(integer);
+CREATE OR REPLACE FUNCTION f_get_geometry_type(integer)
+ RETURNS text AS
+$BODY$DECLARE
+ i_featuretype_id ALIAS FOR $1;
+ geometry_type TEXT;
+BEGIN
+geometry_type := element_type FROM wfs_element WHERE fkey_featuretype_id = i_featuretype_id AND element_type in ('GeometryPropertyType','MultiPolygonPropertyType','GeometryAssociationType','PointPropertyType','gml:MultiSurfacePropertyType','MultiSurfacePropertyType','MultiCurvePropertyType','MultiPointPropertyType','MultiLineStringPropertyType','LineStringPropertyType') LIMIT 1;
+RETURN geometry_type;
+END;
+$BODY$
+ COST 100;
+ALTER FUNCTION f_get_geometry_type(integer)
+-- new view for wfs search
+-- View: search_wfs_view_2
+-- DROP VIEW search_wfs_view_2;
+CREATE OR REPLACE VIEW search_wfs_view_2 AS
+SELECT wfs_new.*, isopen FROM (SELECT wfs_table.*, wfs_termsofuse.fkey_termsofuse_id FROM
+(SELECT wfs_info.*, mb_group.mb_group_id as department, mb_group.mb_group_name, mb_group_logo_path FROM (SELECT featuretype.*, geometryfromtext(((((((((((((((((((('POLYGON(('::text || featuretype.featuretype_latlon_array[1]) || ' '::text) || featuretype.featuretype_latlon_array[2]) || ','::text) || featuretype.featuretype_latlon_array[1]) || ' '::text) || featuretype.featuretype_latlon_array[4]) || ','::text) || featuretype.featuretype_latlon_array[3]) || ' '::text) || featuretype.featuretype_latlon_array[4]) || ','::text) || featuretype.featuretype_latlon_array[3]) || ' '::text) || featuretype.featuretype_latlon_array[2]) || ','::text) || featuretype.featuretype_latlon_array[1]) || ' '::text) || featuretype.featuretype_latlon_array[2]) || '))'::text, 4326) AS the_geom, (((((featuretype.featuretype_latlon_array[1] || ','::text) || featuretype.featuretype_latlon_array[2]) || ','::text) || featuretype.featuretype_latlon_array[3]) || ','::text) || featuretype.featuretype_latlon_array[
4] AS bbox, f_collect_searchtext_wfs(wfs_id, featuretype.featuretype_id) AS searchtext, wfs_conf_id, wfs_conf_abstract, wfs_conf_description, wfs_conf_type as modultype FROM
+(SELECT DISTINCT featuretype_id, featuretype_srs, featuretype_title, featuretype_abstract, featuretype_latlon_bbox, f_get_geometry_type(featuretype_id) AS element_type, CASE
+ WHEN wfs_featuretype.featuretype_latlon_bbox::text = ''::text THEN string_to_array('-180,-90,180,90'::text, ','::text)
+ WHEN wfs_featuretype.featuretype_latlon_bbox IS NULL THEN string_to_array('-180,-90,180,90'::text, ','::text)
+ ELSE string_to_array(wfs_featuretype.featuretype_latlon_bbox::text, ','::text)
+ END AS featuretype_latlon_array, wfs.* FROM
+(SELECT DISTINCT wfs_id, wfs_title, wfs_abstract, wfs_timestamp_create, wfs_network_access, wfs_pricevolume, wfs_proxylog, wfs_owner, country, administrativearea, accessconstraints, fkey_mb_group_id, f_get_responsible_organization(wfs_owner, COALESCE(fkey_mb_group_id, 0)) AS orga_id
+FROM wfs WHERE wfs_owner IN (SELECT fkey_mb_user_id FROM users_for_publishing) ORDER BY wfs_id) AS wfs
+LEFT JOIN wfs_featuretype ON wfs.wfs_id = wfs_featuretype.fkey_wfs_id WHERE wfs_featuretype.featuretype_searchable = 1) AS featuretype
+LEFT JOIN wfs_conf ON featuretype.featuretype_id = wfs_conf.fkey_featuretype_id) AS wfs_info LEFT JOIN mb_group ON wfs_info.orga_id = mb_group.mb_group_id) AS wfs_table LEFT JOIN wfs_termsofuse ON wfs_table.wfs_id = wfs_termsofuse.fkey_wfs_id) AS wfs_new LEFT JOIN termsofuse ON wfs_new.fkey_termsofuse_id = termsofuse.termsofuse_id
+ WHERE element_type IS NOT NULL;
+ALTER TABLE search_wfs_view_2
More information about the Mapbender_commits
