[Mapbender-commits] r9647 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Thu Jan 12 01:33:13 PST 2017
Author: armin11
Date: 2017-01-12 01:33:13 -0800 (Thu, 12 Jan 2017)
New Revision: 9647
trunk/mapbender/http/classes/class_iso19139.php
New possibility to test the conformancy declarations in metadata again a inspire legislation conf file (json based)
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php 2017-01-12 09:31:37 UTC (rev 9646)
+++ trunk/mapbender/http/classes/class_iso19139.php 2017-01-12 09:33:13 UTC (rev 9647)
@@ -58,6 +58,7 @@
var $lineage;
var $inspireTopConsistence; //db bool, 't' or 'f'
var $inspireInteroperability; //db bool, 't' or 'f' - declaration if the provided data should be compliant with the interoperablity implementing rule
+ var $inspireResulations; //array of actual inspire regulations which are relevant for this metadata representation (dataset/service)
var $spatialResType;
var $spatialResValue;
var $export2Csw; //db bool, 't' or 'f'
@@ -142,11 +143,54 @@
$this->resourceContactEmail = null;
$this->previewImage = null;
$this->codeListUpdateFrequencyArray = $codeListUpdateFrequencyArray;
- //read inspire legislation info from json file
- //$e = new mb_exception(__FILE__ ."/../../conf/inspire_legislation.json");
- //$this->inspireLegislation = json_decode(file_get_contents(__FILE__ ."/../../../conf/inspire_legislation.json"), true);
- //$e = new mb_exception(json_encode($this->inspireLegislation));
+ //read inspire legislation info from json file - enhancement for INSPIRE - maybe to be defined as an extension of the class in further developments!
+ //source: http://inspire.ec.europa.eu/inspire-legislation/
+ $inspireLegislationConf = realpath(dirname(__FILE__) ."/../../conf/inspire_legislation.json");
+ $this->inspireLegislation = json_decode(file_get_contents($inspireLegislationConf));
+ $this->inspireRegulations = $this->getRelevantInspireRegulations();
+ public function getRelevantInspireRegulations($withAmendmentAndCorrigendum = true) {
+ //use $this->hierachyLevel and give back all relevant regulations (only the newest of each type) with their dates in the requested language
+ $language = $this->inspireLegislation->default_language;
+ $countInspireRegulations = 0;
+ $regulations = array();
+ if ($withAmendmentAndCorrigendum == true) {
+ //$legislationTypeArray = array("legislation","legislation_amendment","legislation_corrigendum");
+ $legislationTypeArray = array("legislation","legislation_amendment");
+ } else {
+ $legislationTypeArray = array("legislation");
+ //iterate over object and array !
+ foreach ($this->inspireLegislation as $inspire_rules) {
+ foreach ($inspire_rules as $regulation) {
+ if (in_array($regulation->type, $legislationTypeArray) && in_array($regulation->group, array("data_specifications","metadata","network_services"))) {
+ if (in_array($this->hierachyLevel, $regulation->subject)) {
+ //check if already a regulation with this name exists in the array - if it is already there, check if the date is newer or older!
+ $keyInArray = array_search($regulation->label->{$language}, array_column($regulations, 'name'));//TODO []
+ if ($keyInArray !== false) {
+ $newDateTime = new dateTime($regulation->date);
+ if ($newDateTime < $regulations[$keyInArray]['date']) {
+ $regulations[$keyInArray]['date'] = $newDateTime;
+ } else {
+ $regulations[$countInspireRegulations]['date'] = new dateTime($regulation->date);
+ $regulations[$countInspireRegulations]['name'] = $regulation->label->{$language};
+ $regulations[$countInspireRegulations]['type'] = $regulation->group;
+ $countInspireRegulations++;
+ //debug output
+ /*foreach ($regulations as $reg) {
+ $e = new mb_exception("regulation date: ".$reg['date']->format('Y-m-d'));
+ $e = new mb_exception("regulation: ".$reg['name']);
+ $e = new mb_exception("regulation type: ".$reg['type']);
+ return $regulations;
public function removeGetRecordTag ($xml) {
$regex = "#<csw:GetRecordByIdResponse .*?>#";
@@ -470,6 +514,39 @@
if (in_array($updateFrequency, $codeListUpdateFrequencyArray)) {
$this->updateFrequency = $updateFrequency;
+ //check declaration of inspire conformity - only true if true for all relevant regulations is declared!
+ $this->inspireInteroperability = 't';
+ $interoperabilityArray = array();
+ $countInteroperabilityArray = 0;
+ foreach ($this->inspireRegulations as $regulation) {
+ $interoperabilityArray[$countInteroperabilityArray]['name'] = $regulation['name'];
+ $interoperabilityArray[$countInteroperabilityArray]['date'] = $regulation['date']->format('Y-m-d');
+ $interoperabilityArray[$countInteroperabilityArray]['pass'] = null;
+ //get boolean from metadata
+ //string(//gmd:MD_Metadata/gmd:dataQualityInfo/gmd:DQ_DataQuality/gmd:report/gmd:DQ_DomainConsistency/gmd:result/gmd:DQ_ConformanceResult[gmd:specification/gmd:CI_Citation/gmd:title/gco:CharacterString="Verordnung (EG) Nr. 1205/2008 der Kommission vom 3. Dezember 2008 zur Durchführung der Richtlinie 2007/2/EG des Europäischen Parlaments und des Rates hinsichtlich Metadaten" and gmd:specification/gmd:CI_Citation/gmd:date/gmd:CI_Date/gmd:date/gco:Date="2008-12-03"]/gmd:pass/gco:Boolean)
+ $conformanceStatement = $iso19139Xml->xpath('//gmd:MD_Metadata/gmd:dataQualityInfo/gmd:DQ_DataQuality/gmd:report/gmd:DQ_DomainConsistency/gmd:result/gmd:DQ_ConformanceResult[gmd:specification/gmd:CI_Citation/gmd:title/gco:CharacterString="'.$regulation['name'].'" and gmd:specification/gmd:CI_Citation/gmd:date/gmd:CI_Date/gmd:date/gco:Date="'.$regulation['date']->format('Y-m-d').'"]/gmd:pass/gco:Boolean');
+ //problem: xpath extract this element strange - the first entry is a string object
+ $conformanceStatement = (string)$conformanceStatement[0];
+ switch ($conformanceStatement) {
+ case "true":
+ $interoperabilityArray[$countInteroperabilityArray]['pass'] = "true";
+ break;
+ case "false":
+ $interoperabilityArray[$countInteroperabilityArray]['pass'] = "false";
+ $this->inspireInteroperability = 'f';
+ default:
+ $interoperabilityArray[$countInteroperabilityArray]['pass'] = "not declared";
+ break;
+ $countInteroperabilityArray++;
+ //for debugging purposes
+ foreach ($interoperabilityArray as $declaredSpec) {
+ $e = new mb_exception("classes/class_iso19139.php: check conformance declaration: name: ".$declaredSpec['name']. " - date: ".$declaredSpec['date']." - pass: ".$declaredSpec['pass']);
+ $e = new mb_notice("classes/class_iso19139.php: sufficient declared inspire conformity: ".$this->inspireInteroperability);
$this->qualifyMetadata();
return $this;
} else {
More information about the Mapbender_commits
