[Mapbender-commits] r9653 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Thu Jan 12 11:51:15 PST 2017
Author: armin11
Date: 2017-01-12 11:51:15 -0800 (Thu, 12 Jan 2017)
New Revision: 9653
trunk/mapbender/http/classes/class_syncCkan.php
Fix to be downward compatible with php < 5.5 - array_column() is not available in php5.4!
Modified: trunk/mapbender/http/classes/class_syncCkan.php
--- trunk/mapbender/http/classes/class_syncCkan.php 2017-01-12 19:50:30 UTC (rev 9652)
+++ trunk/mapbender/http/classes/class_syncCkan.php 2017-01-12 19:51:15 UTC (rev 9653)
@@ -16,7 +16,7 @@
require_once(dirname(__FILE__) . '/../../core/globalSettings.php');
require_once(dirname(__FILE__).'/../classes/class_connector.php');
-require_once(dirname(__FILE__).'/../classes/class_ckanApi25.php');
+require_once(dirname(__FILE__).'/../classes/class_ckanApi.php');
require_once(dirname(__FILE__).'/../classes/class_group.php');
require_once(dirname(__FILE__) . '/../php/mod_getDownloadOptions.php');
require_once(dirname(__FILE__).'/../../conf/ckan.conf');
@@ -42,18 +42,48 @@
} else {
$this->ckanApiUrl = CKAN_SERVER_IP;
- //$this->ckanApiKey;
if (defined("CKAN_API_VERSION") && CKAN_API_VERSION !== '') {
$this->ckanApiVersion = CKAN_API_VERSION;
} else {
$this->ckanApiVersion = 3;
+ if (defined("CKAN_API_PROTOCOL") && CKAN_API_PROTOCOL !== '') {
+ $this->ckanApiProtocol = CKAN_API_PROTOCOL;
+ } else {
+ $this->ckanApiProtocol = 'https';
$this->mapbenderUserId = 0;
$this->syncOrgaId = 0;
$this->topicCkanCategoryMap = $topicCkanCategoryMap; //from ckan.conf
$this->compareTimestamps = false; //default to update each dataset, because the ckan index for metadata_modified may not be up to date !!!
+ //TODO: Following function is only needed til php 5.5 - after upgrade to debian 8 it is obsolet - see also class_iso19139.php!
+ public function array_column(array $input, $columnKey, $indexKey = null) {
+ $array = array();
+ foreach ($input as $value) {
+ if ( !array_key_exists($columnKey, $value)) {
+ trigger_error("Key \"$columnKey\" does not exist in array");
+ return false;
+ if (is_null($indexKey)) {
+ $array[] = $value[$columnKey];
+ else {
+ if ( !array_key_exists($indexKey, $value)) {
+ trigger_error("Key \"$indexKey\" does not exist in array");
+ return false;
+ if ( ! is_scalar($value[$indexKey])) {
+ trigger_error("Key \"$indexKey\" does not contain scalar value");
+ return false;
+ $array[$value[$indexKey]] = $value[$columnKey];
+ return $array;
public function getMapbenderOrganizations() {
if (isset($this->mapbenderUserId) && (integer)$this->mapbenderUserId > 0) {
if (isset($this->syncOrgaId) && (integer)$this->syncOrgaId > 0) {
@@ -100,24 +130,28 @@
public function getSyncListJson($departmentsArray, $listAllMetadataInJson = false) {
- $syncList = new stdClass();
+ $syncList = new stdClass(); //should handle the returned json object
+ $syncListResult = new stdClass();
+ $syncList->help = "helptext";
+ $syncList->success = false;
+ $syncList->function = "getSyncListJson";
$numberGeoportalOrga = 0;
foreach ($departmentsArray as $organization) {
- $syncList->geoportal_organization[$numberGeoportalOrga]->name = $organization["name"];
- $syncList->geoportal_organization[$numberGeoportalOrga]->id = $organization["id"];
- $syncList->geoportal_organization[$numberGeoportalOrga]->title = $organization["title"];
- $syncList->geoportal_organization[$numberGeoportalOrga]->email = $organization["email"];
- $syncList->geoportal_organization[$numberGeoportalOrga]->ckan_orga_ident = false;
+ $syncListResult->geoportal_organization[$numberGeoportalOrga]->name = $organization["name"];
+ $syncListResult->geoportal_organization[$numberGeoportalOrga]->id = $organization["id"];
+ $syncListResult->geoportal_organization[$numberGeoportalOrga]->title = $organization["title"];
+ $syncListResult->geoportal_organization[$numberGeoportalOrga]->email = $organization["email"];
+ $syncListResult->geoportal_organization[$numberGeoportalOrga]->ckan_orga_ident = false;
if (isset($organization["ckan_uuid"]) && isset($organization["ckan_api_key"])) {
//Test if organization with the given external uuid exists in the coupled ckan
//show organizations of the authorized user (from geoportal group table) via action api
$ckan = new ckanApi($organization["ckan_api_key"], CKAN_SERVER_IP);
- $ckan->base_url='http://'.$this->ckanApiUrl.'/api/3/';
+ $ckan->base_url = $this->ckanApiProtocol.'://'.$this->ckanApiUrl.'/api/3/';
$ckan->api_version = $this->ckanApiVersion;
$result = $ckan->action_organization_list_for_user();
foreach($result->result as $orga) {
if ($orga->id == $organization["ckan_uuid"]) {
- $syncList->geoportal_organization[$numberGeoportalOrga]->ckan_orga_ident = $organization["ckan_uuid"];
+ $syncListResult->geoportal_organization[$numberGeoportalOrga]->ckan_orga_ident = $organization["ckan_uuid"];
//echo "Corresponding ckan organization ".$orga->display_name." found for geoportal group ".$organization["name"]." with id ".$organization["id"]."!<br>";
//get list of ids for existing spatial datasets - category spatial should be defined!!!!!!
//http://localhost:5000/api/3/action/package_search?fq=transparency_category_de_rp:spatial_data
@@ -131,7 +165,7 @@
//echo "List of datasets in ckan instance:"."<br>";
$ckanPackageNames = array();
if ($listOfSpatialData->success == true) {
- $syncList->geoportal_organization[$numberGeoportalOrga]->count_ckan_packages = $listOfSpatialData->result->count;
+ $syncListResult->geoportal_organization[$numberGeoportalOrga]->count_ckan_packages = $listOfSpatialData->result->count;
//echo json_encode($listOfSpatialData)."<br>";
//$e = new mb_exception("Number of results: ".$listOfSpatialData->result->count);
foreach ($listOfSpatialData->result->results as $dataset) {
@@ -139,8 +173,8 @@
$ckanMetadataArray[$countCkanMetadataArray]['name'] = $dataset->name;
$ckanMetadataArray[$countCkanMetadataArray]['changedate'] = $dataset->metadata_modified;
if ($listAllMetadataInJson == true) {
- $syncList->geoportal_organization[$numberGeoportalOrga]->ckan_packages[$countCkanMetadataArray]->id = $dataset->name;
- $syncList->geoportal_organization[$numberGeoportalOrga]->ckan_packages[$countCkanMetadataArray]->date_time = $dataset->metadata_modified;
+ $syncListResult->geoportal_organization[$numberGeoportalOrga]->ckan_packages[$countCkanMetadataArray]->id = $dataset->name;
+ $syncListResult->geoportal_organization[$numberGeoportalOrga]->ckan_packages[$countCkanMetadataArray]->date_time = $dataset->metadata_modified;
//echo $dataset->title." - ".$dataset->name." - ".$dataset->metadata_modified."<br>";
$ckanPackageNames[] = $dataset->name;
@@ -199,16 +233,16 @@
//use only those that have resources!
if ($geoportalMetadata['hasResource']) {
- $syncList->geoportal_organization[$numberGeoportalOrga]->geoportal_metadata[$numberGeoportalMetadata]->id = $geoportalMetadata['uuid'];
- $syncList->geoportal_organization[$numberGeoportalOrga]->geoportal_metadata[$numberGeoportalMetadata]->date_time = $geoportalMetadata['changedate'];
- $syncList->geoportal_organization[$numberGeoportalOrga]->geoportal_metadata[$numberGeoportalMetadata]->resources = json_decode($geoportalMetadata['resources']);
+ $syncListResult->geoportal_organization[$numberGeoportalOrga]->geoportal_metadata[$numberGeoportalMetadata]->id = $geoportalMetadata['uuid'];
+ $syncListResult->geoportal_organization[$numberGeoportalOrga]->geoportal_metadata[$numberGeoportalMetadata]->date_time = $geoportalMetadata['changedate'];
+ $syncListResult->geoportal_organization[$numberGeoportalOrga]->geoportal_metadata[$numberGeoportalMetadata]->resources = json_decode($geoportalMetadata['resources']);
$geoportalUuids[] = $geoportalMetadata['uuid'];
$numberGeoportalMetadata++;
- $syncList->geoportal_organization[$numberGeoportalOrga]->count_geoportal_packages = $numberGeoportalMetadata;
+ $syncListResult->geoportal_organization[$numberGeoportalOrga]->count_geoportal_packages = $numberGeoportalMetadata;
//build diffs for ckan and geoportal
//Arrays: ckanPackageNames / geoportalUuids
//Those which are only in ckan: delete them
@@ -220,9 +254,9 @@
//if the timestamps should be compared before
if ($this->compareTimestamps == true) {
foreach ($inBoth as $uuid) {
- $e = new mb_notice("classes/class_syncCkan.php: search for uuid: ".$uuid."ckan time : ".$ckanMetadataArray[array_search($uuid, array_column($ckanMetadataArray,'name'))]['changedate']. " - geoportal time: ".$metadataArray[array_search($uuid, array_column($metadataArray,'uuid'))]['changedate']);
- $dateTimeCkan = new DateTime($ckanMetadataArray[array_search($uuid, array_column($ckanMetadataArray,'name'))]['changedate']);
- $dateTimeGeoportal = new DateTime($metadataArray[array_search($uuid, array_column($metadataArray,'uuid'))]['changedate']);
+ $e = new mb_notice("classes/class_syncCkan.php: search for uuid: ".$uuid."ckan time : ".$ckanMetadataArray[array_search($uuid, $this->array_column($ckanMetadataArray,'name'))]['changedate']. " - geoportal time: ".$metadataArray[array_search($uuid, $this->array_column($metadataArray,'uuid'))]['changedate']);
+ $dateTimeCkan = new DateTime($ckanMetadataArray[array_search($uuid, $this->array_column($ckanMetadataArray,'name'))]['changedate']);
+ $dateTimeGeoportal = new DateTime($metadataArray[array_search($uuid, $this->array_column($metadataArray,'uuid'))]['changedate']);
if ($dateTimeCkan > $dateTimeGeoportal) {
//delete from $inBoth!
$e = new mb_notice("classes/class_syncCkan.php: Ckans package newer than geoportals metadata!");
@@ -233,9 +267,9 @@
//$e = new mb_exception("Number of packages which are only in ckan: ".count($onlyInCkan)." - number of packages which are only in geoportal: ".count($onlyInGeoportal)." - number of packages which are in both catalogues: ".count($inBoth));
- $syncList->geoportal_organization[$numberGeoportalOrga]->update = $inBoth;
- $syncList->geoportal_organization[$numberGeoportalOrga]->delete = $onlyInCkan;
- $syncList->geoportal_organization[$numberGeoportalOrga]->create = $onlyInGeoportal;
+ $syncListResult->geoportal_organization[$numberGeoportalOrga]->update = $inBoth;
+ $syncListResult->geoportal_organization[$numberGeoportalOrga]->delete = $onlyInCkan;
+ $syncListResult->geoportal_organization[$numberGeoportalOrga]->create = $onlyInGeoportal;
//then pull the ressources which are owned by the user but have no group defined - only if the primary group of the user is the corresponding group!
//maybe the catalogue itself is the best way to pull all relevant data, cause the coupling is resolved already!
@@ -250,12 +284,21 @@
$numberGeoportalOrga++;
+ if (count($syncListResult->geoportal_organization) >= 1) {
+ $syncList->result = $syncListResult;
+ $syncList->success = true;
return json_encode($syncList);
public function syncSingleOrga($syncListJson) {
+ $resultObject = new stdClass();
+ $resultObject->help = "Syncing mapbender with ckan for organization with id: ".$this->syncOrgaId;
$syncList = json_decode($syncListJson);
if ($syncList->id == $this->syncOrgaId) {
+ $numberOfDeletedPackages = 0;
+ $numberOfCreatedPackages = 0;
+ $numberOfUpdatedPackages = 0;
//read ckan api-key from database again, because we wont transfer it via json thru the web ;-)
$sql = "SELECT mb_group_ckan_api_key FROM mb_group WHERE mb_group_id = $1";
$v = array($this->syncOrgaId);
@@ -265,17 +308,17 @@
$row = db_fetch_assoc($res);
$ckanApiKey = $row['mb_group_ckan_api_key'];
$ckan = new ckanApi($ckanApiKey, CKAN_SERVER_IP);
} else {
$e = new mb_exception("classes/class_syncCkan.php: No api-key found for mapbender group: ".$this->syncOrgaId);
return false;
- //echo "Synchronize metadata catalogues:"."<br>";
foreach($syncList->delete as $ckanNameToDelete) {
$result = $ckan->action_package_delete("{\"id\":\"".$ckanNameToDelete."\"}");
if ($result->success == true) {
$e = new mb_notice("classes/class_syncCkan.php: Ckan package with name ".$ckanNameToDelete." successfully deleted!");
+ $numberOfDeletedPackages++;
} else {
$e = new mb_exception("classes/class_syncCkan.php: A problem occured while trying to delete ckan package with name ".$ckanNameToDelete);
@@ -309,6 +352,7 @@
//echo "Creation of package successful!"."<br>";
//recreate views
$viewsUpdateProtocol = $this->recreateResourceViews($ckan, $result, $resultCkanRepresentation);
+ $numberOfUpdatedPackages++;
//$e = new mb_exception($viewsUpdateProtocol);
} else {
//echo "A problem occured while trying to create the ckan package"."<br>";
@@ -326,6 +370,7 @@
//recreate views
+ $numberOfCreatedPackages++;
} else {
$e = new mb_exception("classes/class_syncCkan.php: A problem occured while trying to create the ckan package");
@@ -339,9 +384,17 @@
} else {
$e = new mb_exception("classes/class_syncCkan.php (syncSingleOrga): Id from json is not identical to id from class! Sync will not be started!");
- return false;
- return true;
+ $resultObject->success = false;
+ $resultObject->error->message = "Organization id for the invoked sync process could not be obtained - please check the id!";
+ //$resultObject->help = "Sync of metadata for orga ";
+ return json_encode($resultObject);
+ $resultObject->success = true;
+ $resultObject->result->orga_id = $this->syncOrgaId;
+ $resultObject->result->numberOfDeletedPackages = $numberOfDeletedPackages;
+ $resultObject->result->numberOfUpdatedPackages = $numberOfUpdatedPackages;
+ $resultObject->result->numberOfCreatedPackages = $numberOfCreatedPackages;
private function getCkanRepresentation($uuid, $layerArray, $featuretypeArray, $orgaId, $orgaTitle, $orgaEmail, $topicCkanCategoryMap) {
More information about the Mapbender_commits
