[Mapbender-commits] r9663 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Sun Jan 22 08:24:46 PST 2017
Author: armin11
Date: 2017-01-22 08:24:46 -0800 (Sun, 22 Jan 2017)
New Revision: 9663
trunk/mapbender/http/classes/class_syncCkan.php
Bugfix
Modified: trunk/mapbender/http/classes/class_syncCkan.php
--- trunk/mapbender/http/classes/class_syncCkan.php 2017-01-18 16:24:01 UTC (rev 9662)
+++ trunk/mapbender/http/classes/class_syncCkan.php 2017-01-22 16:24:46 UTC (rev 9663)
@@ -58,31 +58,31 @@
$this->compareTimestamps = false; //default to update each dataset, because the ckan index for metadata_modified may not be up to date !!!
- //TODO: Following function is only needed til php 5.5 - after upgrade to debian 8 it is obsolet - see also class_iso19139.php!
- public function array_column(array $input, $columnKey, $indexKey = null) {
- $array = array();
- foreach ($input as $value) {
- if ( !array_key_exists($columnKey, $value)) {
- trigger_error("Key \"$columnKey\" does not exist in array");
- return false;
- if (is_null($indexKey)) {
- $array[] = $value[$columnKey];
- else {
- if ( !array_key_exists($indexKey, $value)) {
- trigger_error("Key \"$indexKey\" does not exist in array");
- return false;
- if ( ! is_scalar($value[$indexKey])) {
- trigger_error("Key \"$indexKey\" does not contain scalar value");
- return false;
- $array[$value[$indexKey]] = $value[$columnKey];
- return $array;
+ //TODO: Following function is only needed til php 5.5 - after upgrade to debian 8 it is obsolet - see also class_iso19139.php!
+ public function array_column(array $input, $columnKey, $indexKey = null) {
+ $array = array();
+ foreach ($input as $value) {
+ if ( !array_key_exists($columnKey, $value)) {
+ trigger_error("Key \"$columnKey\" does not exist in array");
+ return false;
+ if (is_null($indexKey)) {
+ $array[] = $value[$columnKey];
+ else {
+ if ( !array_key_exists($indexKey, $value)) {
+ trigger_error("Key \"$indexKey\" does not exist in array");
+ return false;
+ if ( ! is_scalar($value[$indexKey])) {
+ trigger_error("Key \"$indexKey\" does not contain scalar value");
+ return false;
+ $array[$value[$indexKey]] = $value[$columnKey];
+ return $array;
public function getMapbenderOrganizations() {
if (isset($this->mapbenderUserId) && (integer)$this->mapbenderUserId > 0) {
@@ -246,11 +246,12 @@
//build diffs for ckan and geoportal
//Arrays: ckanPackageNames / geoportalUuids
//Those which are only in ckan: delete them
- $onlyInCkan = array_diff($ckanPackageNames, $geoportalUuids);
+ $onlyInCkan = array_values(array_diff($ckanPackageNames, $geoportalUuids));
//Those which are only in geoportal: create them
- $onlyInGeoportal = array_diff($geoportalUuids, $ckanPackageNames);
+ $onlyInGeoportal = array_values(array_diff($geoportalUuids, $ckanPackageNames));
//Those which are in both - update them if geoportal metadata is newer than the package in ckan
- $inBoth = array_intersect($ckanPackageNames, $geoportalUuids);
+ $inBoth = array_values(array_intersect($ckanPackageNames, $geoportalUuids));
//if the timestamps should be compared before
if ($this->compareTimestamps == true) {
foreach ($inBoth as $uuid) {
@@ -260,13 +261,16 @@
if ($dateTimeCkan > $dateTimeGeoportal) {
//delete from $inBoth!
$e = new mb_notice("classes/class_syncCkan.php: Ckans package newer than geoportals metadata!");
- $inBoth = array_diff($inBoth, [$uuid]);
+ $inBoth = array_values(array_diff($inBoth, [$uuid]));
} else {
$e = new mb_notice("classes/class_syncCkan.php: Ckans package older than geoportals metadata!");
//$e = new mb_exception("Number of packages which are only in ckan: ".count($onlyInCkan)." - number of packages which are only in geoportal: ".count($onlyInGeoportal)." - number of packages which are in both catalogues: ".count($inBoth));
+ //$e = new mb_exception("both: ".gettype($inBoth)." number: ".count($inBoth)." json: ".json_encode($inBoth));
+ //$e = new mb_exception("only ckan: ".gettype($onlyInCkan)." number: ".count($onlyInCkan)." json: ".json_encode($onlyInCkan));
+ //$e = new mb_exception("only geoportal: ".gettype($onlyInGeoportal)." number: ".count($onlyInGeoportal)." json: ".json_encode($onlyInGeoportal));
$syncListResult->geoportal_organization[$numberGeoportalOrga]->update = $inBoth;
$syncListResult->geoportal_organization[$numberGeoportalOrga]->delete = $onlyInCkan;
$syncListResult->geoportal_organization[$numberGeoportalOrga]->create = $onlyInGeoportal;
More information about the Mapbender_commits
