[Mapbender-commits] r9668 - trunk/mapbender/lib
svn_mapbender at osgeo.org
Mon Jan 23 10:55:11 PST 2017
Author: armin11
Date: 2017-01-23 10:55:11 -0800 (Mon, 23 Jan 2017)
New Revision: 9668
trunk/mapbender/lib/ajax.php
New possibility to do a serverside filtering of metadata editor list (actual for datatables 1.9)
Modified: trunk/mapbender/lib/ajax.php
--- trunk/mapbender/lib/ajax.php 2017-01-23 18:55:00 UTC (rev 9667)
+++ trunk/mapbender/lib/ajax.php 2017-01-23 18:55:11 UTC (rev 9668)
@@ -116,6 +116,7 @@
class AjaxResponse extends AjaxRequest {
private $data = array();
+ private $highLevelAttributes = array();
private $success = true;
private $error = null;
private $message = "";
@@ -155,8 +156,23 @@
public function setMessage ($aMessage) {
$this->message = $aMessage;
+ * Compose data to be sent back to the client on highest level.
+ * Either by key and value, or by passing the complete associative array.
+ public function setHighLevelAttributes () {
+ if (func_num_args() == 1) {
+ $this->highLevelAttributes = func_get_arg(0);
+ else if (func_num_args() == 2) {
+ $key = func_get_arg(0);
+ $value = func_get_arg(1);
+ $this->highLevelAttributes[$key] = $value;
* Set status of the RPC.
* @param $trueOrFalse Boolean
@@ -221,6 +237,10 @@
"error" => $this->error,
"id" => $this->id
+ //add highlevel attributes
+ foreach ($this->highLevelAttributes as $key => $value) {
+ $obj[$key] = $value;
return $this->json->encode($obj);
More information about the Mapbender_commits
