[Mapbender-commits] r9676 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Tue Jan 31 16:04:39 PST 2017
Author: armin11
Date: 2017-01-31 16:04:38 -0800 (Tue, 31 Jan 2017)
New Revision: 9676
trunk/mapbender/http/classes/class_cswClient.php
Some new handlings for harvesting external csw
Modified: trunk/mapbender/http/classes/class_cswClient.php
--- trunk/mapbender/http/classes/class_cswClient.php 2017-02-01 00:03:37 UTC (rev 9675)
+++ trunk/mapbender/http/classes/class_cswClient.php 2017-02-01 00:04:38 UTC (rev 9676)
@@ -41,11 +41,12 @@
$this->operationSuccessful = false;
- public function doRequest($cswId, $operationName, $recordId=false, $record=false) {
+ public function doRequest($cswId, $operationName, $recordId=false, $record=false, $recordtype=false, $maxrecords=false, $startposition=false) {
$this->cswId = $cswId;
$csw = new csw();
$csw->createCatObjFromDB($this->cswId);
- $e = new mb_exception($csw->cat_op_values[$operationName]['get']);
+ $operationNameCsw = $operationName;
+ //$e = new mb_exception($csw->cat_op_values[$operationName]['post']);
//check for operation support
switch (strtolower($operationName)) {
case "getrecords":
@@ -80,7 +81,23 @@
return false;
break;
+ //wrapped operations for internal usage
+ case "counthits":
+ if (isset($csw->cat_op_values['getrecords']['post'])) {
+ //all ok
+ } else {
+ $e = new mb_exception("classes/class_cswClient.php: Needed operation not supported by catalogue!");
+ return false;
+ break;
+ case "getrecordspaging":
+ //all ok
+ } else {
+ return false;
+ break;
default:
break;
@@ -132,17 +149,69 @@
$postRequest .= '</csw:Delete>';
$postRequest .= '</csw:Transaction>';
break;
+ case "counthits":
+ $postRequest = '<?xml version="1.0" encoding="UTF-8"?>';
+ $postRequest .= '<csw:GetRecords service="CSW" version="2.0.2" xmlns:csw="http://www.opengis.net/cat/csw/2.0.2" xmlns:ogc="http://www.opengis.net/ogc" xmlns:apiso="http://www.opengis.net/cat/csw/apiso/1.0">';
+ $postRequest .= '<csw:Query typeNames="csw:Record">';
+ $postRequest .= '<csw:ElementSetName>summary</csw:ElementSetName>';
+ if ($recordtype !== false) {
+ $postRequest .= '<csw:Constraint version="1.0.0">';
+ $postRequest .= '<ogc:Filter>';
+ $postRequest .= '<ogc:PropertyIsEqualTo>';
+ $postRequest .= '<ogc:PropertyName>Type</ogc:PropertyName>';
+ $postRequest .= '<ogc:Literal>'.$recordtype.'</ogc:Literal>';
+ $postRequest .= '</ogc:PropertyIsEqualTo>';
+ $postRequest .= '</ogc:Filter>';
+ $postRequest .= '</csw:Constraint>';
+ $postRequest .= '</csw:Query>';
+ $postRequest .= '</csw:GetRecords>';
+ //alter operationName
+ $operationNameCsw = 'getrecords';
+ break;
+ if ($recordtype !== false && $maxrecords !== false && $startposition !== false) {
+ $postRequest .= '<csw:GetRecords service="CSW" version="2.0.2" xmlns:csw="http://www.opengis.net/cat/csw/2.0.2" xmlns:ogc="http://www.opengis.net/ogc" xmlns:apiso="http://www.opengis.net/cat/csw/apiso/1.0" ';
+ $postRequest .= 'maxRecords="'.$maxrecords.'" ';
+ $postRequest .= 'startPosition="'.$startposition.'" ';
+ $postRequest .= 'resultType="results"';
+ $postRequest .= '>';
+ //$postRequest .= '<csw:ElementSetName>summary</csw:ElementSetName>';
+ $postRequest .= '<csw:ElementSetName>full</csw:ElementSetName>';
+ $postRequest .= ' <ogc:PropertyName>Type</ogc:PropertyName>';
+ } else {
+ $e = new mb_exception("classes/class_cswClient.php: Operation getrecordspaging needs more parameters!");
+ break;
default:
break;
//do request and return result
- if (strpos($operationName, "transaction") === false) {
- $this->operationResult = $this->getResult($csw->cat_op_values[$operationName]['post'], $postRequest);
+ if (strpos($operationNameCsw, "transaction") === false) {
+ //$e = new mb_exception("test: ".$csw->cat_op_values[$operationNameCsw]['post']);
+ $this->operationResult = $this->getResult($csw->cat_op_values[$operationNameCsw]['post'], $postRequest);
} else {
$this->operationResult = $this->getResult($csw->cat_op_values["transaction"]['post'], $postRequest);
+ //$e = new mb_exception("test: ".$this->operationResult);
//parse response
libxml_use_internal_errors(true);
try {
@@ -194,6 +263,44 @@
return true;
break;
+ case "getrecords":
+ $metadataRecord = $cswResponseObject->xpath('/csw:GetRecordsResponse/csw:SearchResults at numberOfRecordsMatched');
+ $e = new mb_exception(json_encode($metadataRecord));
+ if (is_array($metadataRecord) && count($metadataRecord) <> 1 || !is_array($metadataRecord)) {
+ $this->operationResult = "No result for counting metadata records via csw query!";
+ return false;
+ } else {
+ $this->operationSuccessful = true;
+ $this->operationResult = $metadataRecord[0];
+ return true;
+ break;
+ case "counthits":
+ //$e = new mb_exception('count hits');
+ $metadataRecord = $cswResponseObject->xpath('/csw:GetRecordsResponse/csw:SearchResults/@numberOfRecordsMatched');
+ //$e = new mb_exception(json_encode($metadataRecord));
+ return false;
+ } else {
+ return true;
+ $metadataRecord = $cswResponseObject->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata');
+ if (is_array($metadataRecord) && count($metadataRecord) < 1 || !is_array($metadataRecord)) {
+ $this->operationSuccessful = false;
+ return false;
+ } else {
+ //give back all records in json
+ $this->operationResult = $cswResponseObject;
+ return true;
+ break;
//handle expections if occur
@@ -215,12 +322,13 @@
private function getResult($url, $postData, $auth=false) {
- //$e = new mb_exception("postdata: ".$postData);
+ $e = new mb_exception("postdata: ".$postData);
$cswInterfaceObject = new connector();
$cswInterfaceObject->set('httpType','POST');
$postData = stripslashes($postData);
$dataXMLObject = new SimpleXMLElement($postData);
$postData = $dataXMLObject->asXML();
//$e = new mb_exception($postData);
$cswInterfaceObject->set('curlSendCustomHeaders',true);
$cswInterfaceObject->set('httpPostData', $postData);
@@ -231,7 +339,6 @@
//insert or update - depends if record with same fileidentifier already exists in catalog and if timestamp is not newer than the timestamp of the new record
public function deleteRecord($fileIdentifier, $auth=false) {
//check if exists before!
if ($this->doRequest($this->cswId, 'getrecordbyid', $fileIdentifier, false)) {
More information about the Mapbender_commits
