[Mapbender-commits] r9755 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Thu Jul 27 09:13:52 PDT 2017
Author: armin11
Date: 2017-07-27 09:13:51 -0700 (Thu, 27 Jul 2017)
New Revision: 9755
Added:
trunk/mapbender/http/php/mod_schemaRegister.php
New possibility to get info about json schematas which are stored in mapbender database
Added: trunk/mapbender/http/php/mod_schemaRegister.php
--- trunk/mapbender/http/php/mod_schemaRegister.php (rev 0)
+++ trunk/mapbender/http/php/mod_schemaRegister.php 2017-07-27 16:13:51 UTC (rev 9755)
@@ -0,0 +1,134 @@
+<?php
+# http://www.mapbender2.org/
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once dirname(__FILE__) . "/../../core/globalSettings.php";
+require_once dirname(__FILE__) . "/../classes/class_Uuid.php";
+/* Initial import of json */
+//read string from file
+/*$polygonSchema = file_get_contents('../../conf/polygonType-Schema.json');
+$polylineSchema = file_get_contents('../../conf/polylineType-Schema.json');
+$pointSchema = file_get_contents('../../conf/pointType-Schema.json');
+$sql = "DELETE from json_schema";
+$res = db_query($sql);
+$uuid = new Uuid();
+$sql = "INSERT INTO json_schema (version, uuid, title, geomtype, schema, public, created) VALUES ('draft-04', '".$uuid."', 'Standard Polygon', 3, '".$polygonSchema."', TRUE, EXTRACT(EPOCH FROM NOW())::INTEGER)";
+$sql = "INSERT INTO json_schema (version, uuid, title, geomtype, schema, public, created) VALUES ('draft-04', '".$uuid."', 'Standard Polyline', 2, '".$polylineSchema."', TRUE, EXTRACT(EPOCH FROM NOW())::INTEGER)";
+$sql = "INSERT INTO json_schema (version, uuid, title, geomtype, schema, public, created) VALUES ('draft-04', '".$uuid."', 'Standard Point', 1, '".$pointSchema."', TRUE, EXTRACT(EPOCH FROM NOW())::INTEGER)";
+$res = db_query($sql);*/
+//parameters:
+//geometryType : point, linestring, polygon
+//id:
+//uuid:
+//operation: list, show
+$geometryType = "false";
+//Parse REQUEST Parameters
+if (isset($_REQUEST["geometryType"]) & $_REQUEST["geometryType"] != "") {
+ //validate to csv integer list
+ $testMatch = $_REQUEST["geometryType"];
+ if (!($testMatch == '1' or $testMatch == '2' or $testMatch == '3')){
+ //echo 'resource: <b>'.$testMatch.'</b> is not valid.<br/>';
+ echo 'Parameter <b>geometryType</b> is not valid (point(1),polyline(2),polygon(3))<br/>';
+ die();
+ $geometryType = $testMatch;
+ $testMatch = NULL;
+if (isset($_REQUEST["id"]) & $_REQUEST["id"] != "") {
+ $testMatch = $_REQUEST["id"];
+ $pattern = '/^[\d,]*$/';
+ if (!preg_match($pattern,$testMatch)){
+ //echo 'id: <b>'.$testMatch.'</b> is not valid.<br/>';
+ echo 'Parameter <b>id</b> is not valid (integer or cs integer list).<br/>';
+ die();
+ $id = $testMatch;
+if (isset($_REQUEST["operation"]) & $_REQUEST["operation"] != "") {
+ $testMatch = $_REQUEST["operation"];
+ if (!($testMatch == 'list' or $testMatch == 'show')){
+ echo 'Parameter <b>operation</b> is not valid (list,show)<br/>';
+ die();
+ $operation = $testMatch;
+header('Content-Type: application/json');
+switch($operation) {
+ case "list":
+ $sql = "SELECT uuid, id, title, updated FROM json_schema WHERE public IS TRUE ";
+ switch($geometryType) {
+ case "false":
+ $v = array();
+ $t = array();
+ break;
+ default:
+ $sql .= "AND geomtype = $1";
+ $v = array((integer)$geometryType);
+ $t = array("i");
+ break;
+ break;
+ case "show":
+ $sql = "SELECT schema FROM json_schema WHERE id = $1 AND public IS TRUE ";
+ $v = array($id);
+ $t = array("i");
+ break;
+$res = db_prep_query($sql, $v, $t);
+ case "list":
+ $schemaArray = array();
+ $j = 0;
+ while ($row = db_fetch_array($res)) {
+ $schemaArray[$j] = array();
+ $schemaArray[$j]['id'] = $row['id'];
+ $schemaArray[$j]['uuid'] = $row['uuid'];
+ $schemaArray[$j]['updated'] = date(DATE_ATOM, $row['updated']);
+ $schemaArray[$j]['title'] = $row['title'];
+ $j++;
+ echo json_encode($schemaArray);
+ break;
+ case "show":
+ $row = db_fetch_array($res);
+ $schema = $row["schema"];
+ echo json_encode(json_decode($schema));
+ break;
More information about the Mapbender_commits
