[Mapbender-commits] r9706 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Wed Mar 15 05:09:16 PDT 2017
Author: armin11
Date: 2017-03-15 05:09:16 -0700 (Wed, 15 Mar 2017)
New Revision: 9706
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
Allow dataset search for metadata_id and uuid
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql 2017-03-09 12:59:56 UTC (rev 9705)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql 2017-03-15 12:09:16 UTC (rev 9706)
@@ -1744,3 +1744,38 @@
ALTER TABLE search_wfs_view
OWNER TO postgres;
+-- Function: f_collect_searchtext_dataset(integer)
+-- DROP FUNCTION f_collect_searchtext_dataset(integer);
+CREATE OR REPLACE FUNCTION f_collect_searchtext_dataset(integer)
+ RETURNS text AS
+$BODY$
+DECLARE
+ p_dataset_id ALIAS FOR $1;
+ r_keywords RECORD;
+ l_result TEXT;
+BEGIN
+ l_result := '';
+ l_result := l_result || (SELECT COALESCE(title, '') || ' ' || COALESCE(abstract, '') || ' ' || COALESCE(metadata_id::text, '') || ' ' || COALESCE(uuid, '') FROM mb_metadata WHERE metadata_id = p_dataset_id);
+ FOR r_keywords IN SELECT DISTINCT keyword FROM
+ (SELECT keyword FROM mb_metadata_keyword L JOIN keyword K ON (K.keyword_id = L.fkey_keyword_id AND L.fkey_metadata_id = p_dataset_id)
+ ) AS __keywords__ LOOP
+ l_result := l_result || ' ' || COALESCE(r_keywords.keyword, '');
+ END LOOP;
+ l_result := UPPER(l_result);
+ l_result := replace(replace(replace(replace(replace(replace(replace(l_result,'Ä','AE'),'ß','SS'),'Ö','OE'),'Ü','UE'),'ä','AE'),'ü','UE'),'ö','OE');
+ RETURN l_result;
+END;
+$BODY$
+ LANGUAGE plpgsql VOLATILE
+ COST 100;
+ALTER FUNCTION f_collect_searchtext_dataset(integer)
+ OWNER TO postgres;
More information about the Mapbender_commits
