[Mapbender-commits] r9714 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Mon Mar 27 09:24:30 PDT 2017
Author: armin11
Date: 2017-03-27 09:24:30 -0700 (Mon, 27 Mar 2017)
New Revision: 9714
trunk/mapbender/http/classes/class_owsPostQueryParser.php
Bugfix for owsproxy post handling
Modified: trunk/mapbender/http/classes/class_owsPostQueryParser.php
--- trunk/mapbender/http/classes/class_owsPostQueryParser.php 2017-03-24 08:47:24 UTC (rev 9713)
+++ trunk/mapbender/http/classes/class_owsPostQueryParser.php 2017-03-27 16:24:30 UTC (rev 9714)
@@ -26,6 +26,7 @@
var $serviceType; //string
var $serviceVersion; //string
var $serviceRequestType; //string
+ var $serviceResourceName; //string - layer name(s), featuretype name(s)
var $parsingSuccessful; //boolean
* Constructor of the OwsPostQueryHandler
@@ -33,6 +34,7 @@
function __construct($postData){
//parse xml via dom
+ //$e = new mb_exception($postData);
$this->parsingSuccessfull = false;
$queryDomObject = new DOMDocument();
libxml_use_internal_errors(true);
@@ -50,7 +52,23 @@
if ($queryDomObject !== false) {
$xpath = new DOMXPath($queryDomObject);
- $rootNamespace = $queryDomObject->lookupNamespaceUri($queryDomObject->namespaceURI);
+ //test if namespace is used in operation declaration
+ $this->serviceRequestType = $queryDomObject->documentElement->tagName;
+ //explode this
+ $explodedTagName = explode(':', $this->serviceRequestType);
+ if (count($explodedTagName) == 2) {
+ $hasNamespace = true;
+ } else {
+ $hasNamespace = false;
+ if ($hasNamespace) {
+ $this->serviceRequestType = $explodedTagName[1];
+ //get relevant namespace uri for first element (root)
+ $rootNamespace = $queryDomObject->lookupNamespaceUri($explodedTagName[0]);
+ } else {
+ $rootNamespace = $queryDomObject->lookupNamespaceUri($queryDomObject->namespaceURI);
//$e = new mb_exception("class_owsPostQueryHandler.php: ".json_encode($rootNamespace));
switch ($rootNamespace) {
case "http://www.opengis.net/wfs/2.0":
@@ -65,8 +83,23 @@
$this->serviceType = "WMS";
break;
- //$xpath->registerNamespace('defaultns', $rootNamespace);
- $this->serviceRequestType = $queryDomObject->documentElement->tagName;
+ if ($this->serviceType == "WFS") {
+ //read out typename from wfs query as attribute
+ //register namespace
+ $xpath->registerNamespace($explodedTagName[0], $rootNamespace);
+ $queryNodeList = $xpath->query('/'.$explodedTagName[0].':'.$this->serviceRequestType.'/'.$explodedTagName[0].':Query');
+ } else {
+ $xpath->registerNamespace('defaultns', $rootNamespace);
+ $queryNodeList = $xpath->query('/defaultns:'.$this->serviceRequestType.'/defaultns:Query');
+ //array of requests that need typenames
+ $typenameRequired = array('getfeature','describefeaturetype');
+ if (in_array(strtolower($this->serviceRequestType), $typenameRequired)) {
+ $this->serviceResourceName = $queryNodeList->item(0)->getAttribute('typeName');
+ //$e = new mb_exception("class_owsPostQueryHandler.php: ".$this->serviceRequestType);
$this->serviceVersion = $queryDomObject->documentElement->getAttribute("version");
//validate extracted parameters
More information about the Mapbender_commits
