[Mapbender-commits] r9717 - trunk/mapbender/owsproxy/http
svn_mapbender at osgeo.org
Mon Mar 27 09:25:07 PDT 2017
Author: armin11
Date: 2017-03-27 09:25:07 -0700 (Mon, 27 Mar 2017)
New Revision: 9717
trunk/mapbender/owsproxy/http/index.php
Bugfix for owsproxy post handling
Modified: trunk/mapbender/owsproxy/http/index.php
--- trunk/mapbender/owsproxy/http/index.php 2017-03-27 16:24:57 UTC (rev 9716)
+++ trunk/mapbender/owsproxy/http/index.php 2017-03-27 16:25:07 UTC (rev 9717)
@@ -232,6 +232,10 @@
$query->setOnlineResource($arrayOnlineresources['wfs_getcapabilities']);
$request = $query->getRequest();
$request = str_replace('?&','?',$request);
+ //don't allow get parameters in conjunction with post!
+ if ($postData !== false) {
+ $request = $arrayOnlineresources['wfs_getcapabilities'];
if (isset($auth)) {
getWfsCapabilities($request, $auth);
} else {
@@ -350,6 +354,10 @@
} else {
$log_id = false;
+ $request = $arrayOnlineresources['wfs_getfeature'];
if (isset($auth)) {
getFeature($log_id, $request, $auth);
} else {
@@ -362,6 +370,10 @@
$query->setOnlineResource($arrayOnlineresources['wfs_describefeaturetype']);
$request = stripslashes($request);
+ $request = $arrayOnlineresources['wfs_describefeaturetype'];
if (isset($auth)) {
describeFeaturetype($request, $auth);
} else {
@@ -762,19 +774,36 @@
function getWfsCapabilities($request, $auth = false)
- global $arrayOnlineresources;
+ global $arrayOnlineresources, $postData;
global $sid, $serviceId;
$t = array(htmlentities($arrayOnlineresources["wfs_getcapabilities"]), htmlentities($arrayOnlineresources["wfs_getmap"]),
htmlentities($arrayOnlineresources["wfs_getfeatureinfo"]));
$new = OWSPROXY . "/" . $sid . "/" . $serviceId . "?";
- //get actual capabilities from external server
- if (!$auth) {
- $wfsCaps = new connector($request);
+ if ($postData == false) {
+ if (func_num_args() == 4) { //new for HTTP Authentication
+ $auth = func_get_arg(3);
+ $d = new connector($request, $auth);
+ } else {
+ $d = new connector($request);
+ $wfsCaps = $d->file;
} else {
- $wfsCaps = new connector($request, $auth);
+ //$e = new mb_exception("owsproxy/index.php: postData will be send: ".$postData);
+ $postInterfaceObject = new connector();
+ $postInterfaceObject->set('httpType','POST');
+ $postInterfaceObject->set('curlSendCustomHeaders',true);
+ $postInterfaceObject->set('httpPostData', $postData);
+ $postInterfaceObject->set('httpContentType','text/xml');
+ $postInterfaceObject->load($request, $auth);
+ } else {
+ $postInterfaceObject->load($request);
+ $wfsCaps = $postInterfaceObject->file;
- $r = str_replace($t, $new, $wfsCaps->file);
+ $r = str_replace($t, $new, $wfsCaps);
//delete trailing amp; 's
$r = str_replace('amp;', '', $r);
header("Content-Type: application/xml");
More information about the Mapbender_commits
