[Mapbender-commits] r9721 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Mar 30 01:47:34 PDT 2017
Author: armin11
Date: 2017-03-30 01:47:34 -0700 (Thu, 30 Mar 2017)
New Revision: 9721
   trunk/mapbender/http/plugins/mb_metadata_addon.php
   trunk/mapbender/http/plugins/mb_metadata_featuretype.js
   trunk/mapbender/http/plugins/mb_metadata_layer.js
style adoptions from karlo
Modified: trunk/mapbender/http/plugins/mb_metadata_addon.php
--- trunk/mapbender/http/plugins/mb_metadata_addon.php	2017-03-30 08:47:04 UTC (rev 9720)
+++ trunk/mapbender/http/plugins/mb_metadata_addon.php	2017-03-30 08:47:34 UTC (rev 9721)
@@ -29,10 +29,10 @@
 	<fieldset id="addonChooser" name="addonChooser" style="display: none">
 		<legend><?php echo _mb("Choose kind of coupled metadata");?></legend>
 		<p>
-			<table><tr><td><img src='../img/osgeo_graphics/geosilk/link.png' title='linkage' onclick='$("#addonChooser").css("display","none");$("#link_editor").css("display","block");$("#kindOfMetadataAddOn").attr("value","link");' /></td><td><?php echo _mb("Add URL to existing Metadataset");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Here someone can add a url to an existing metadata record, which is available over www. The record can either be harvested and pushed to the own catalogue service or it is only used as a link. This links are pushed into the service metadata record and the new capabilities document.");?>'}" src="../img/questionmark.png" alt="" /></td></tr>
-			<tr><td><img src='../img/gnome/edit-select-all.png' title='metadata'  onclick='$("#addonChooser").css("display","none");$("#simple_metadata_editor").css("display","block");$("#kindOfMetadataAddOn").attr("value","metadataset");' /></td><td><?php echo _mb("Add a simple metadata record which is mostly generated from given layer information");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("With this option someone can generate a very simple metadata record for the data which is distributed thru the wms layer. The record fulfills only the INSPIRE Metadata Regulation! Most of the needed data is pulled from the service, layer and group information of the owner of the service. The metadate will be created on the fly. It is not stored in the database!");?>'}" src="../img/questionmark.png" alt="" /></td></tr>
-			<tr><td><img onclick='initUploadForm();' src='../img/button_blue_red/up.png' id='uploadImage' title='upload'  /></td><td><?php echo _mb("Add a simple metadata record from a local file");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("With this option someone can upload an existing metadata record and couple it to the layer. The uploaded data is pushed to the catalogue and will be available for searching. The uploaded data is not fully controlled and validated. It cannot be edited but must be replaced with a new record if needed!");?>'}" src="../img/questionmark.png" alt="" /></td></tr>
-			<tr><td><img src='../img/osgeo_graphics/geosilk/link.png' title='linkage' onclick='getOwnedMetadata();$("#addonChooser").css("display","none");$("#internal_link").css("display","block");$("#kindOfMetadataAddOn").attr("value","internallink");' /></td><td><?php echo _mb("Linkage to existing internal Metadataset");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Here someone can add a linkage to an existing internal metadata record, which is also available over www. This link is also pushed into the service metadata record and the new capabilities document.");?>'}" src="../img/questionmark.png" alt="" /></td></tr>
+			<table><tr><td><img class='clickable' src='../img/osgeo_graphics/geosilk/link_mae.png' title='linkage' onclick='$("#addonChooser").css("display","none");$("#link_editor").css("display","block");$("#kindOfMetadataAddOn").attr("value","link");' /></td><td><?php echo _mb("Add URL to existing Metadataset");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Here someone can add a url to an existing metadata record, which is available over www. The record can either be harvested and pushed to the own catalogue service or it is only used as a link. This links are pushed into the service metadata record and the new capabilities document.");?>'}" src="../img/questionmark.png" alt="" /></td></tr>
+			<tr><td><img  class='clickable' src='../img/gnome/edit-select-all.png' title='metadata'  onclick='$("#addonChooser").css("display","none");$("#simple_metadata_editor").css("display","block");$("#kindOfMetadataAddOn").attr("value","metadataset");' /></td><td><?php echo _mb("Add a simple metadata record which is mostly generated from given layer information");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("With this option someone can generate a very simple metadata record for the data which is distributed thru the wms layer. The record fulfills only the INSPIRE Metadata Regulation! Most of the needed data is pulled from the service, layer and group information of the owner of the service. The metadate will be created on the fly. It is not stored in the database!");?>'}" src="../img/questionmark.png" alt="" /></td></tr>
+			<tr><td><img  class='clickable' onclick='initUploadForm();' src='../img/button_blue_red/up_mae.png' id='uploadImage' title='upload'  /></td><td><?php echo _mb("Add a simple metadata record from a local file");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("With this option someone can upload an existing metadata record and couple it to the layer. The uploaded data is pushed to the catalogue and will be available for searching. The uploaded data is not fully controlled and validated. It cannot be edited but must be replaced with a new record if needed!");?>'}" src="../img/questionmark.png" alt="" /></td></tr>
+			<tr><td><img  class='clickable' src='../img/osgeo_graphics/geosilk/link_mae.png' title='linkage' onclick='getOwnedMetadata();$("#addonChooser").css("display","none");$("#internal_link").css("display","block");$("#kindOfMetadataAddOn").attr("value","internallink");' /></td><td><?php echo _mb("Linkage to existing internal Metadataset");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Here someone can add a linkage to an existing internal metadata record, which is also available over www. This link is also pushed into the service metadata record and the new capabilities document.");?>'}" src="../img/questionmark.png" alt="" /></td></tr>
 			</table>
 		</p>
 	</fieldset>
Modified: trunk/mapbender/http/plugins/mb_metadata_featuretype.js
--- trunk/mapbender/http/plugins/mb_metadata_featuretype.js	2017-03-30 08:47:04 UTC (rev 9720)
+++ trunk/mapbender/http/plugins/mb_metadata_featuretype.js	2017-03-30 08:47:34 UTC (rev 9721)
@@ -108,34 +108,34 @@
 		for (i=0;i<obj.md_metadata.metadata_id.length;i++) {
 				if (obj.md_metadata.origin[i] == "capabilities") {
 					if (obj.md_metadata.internal[i] == 1) {
-						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/server_map-ilink.png' title='link to metadata from capabilities'/></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\");return false;'/></td></tr>").appendTo($("#metadataTable"));
+						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/server_map-ilink.png' title='link to metadata from capabilities'/></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td></td><td><img class='clickable' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\");return false;'/></td></tr>").appendTo($("#metadataTable"));
 					} else {
 						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/osgeo_graphics/geosilk/server_map.png' title='capabilities'/></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td></td></tr>").appendTo($("#metadataTable"));
 				if (obj.md_metadata.origin[i] == "external") {
-						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/link-ilink.png' title='link to external linkage'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\");return false;'/></td></tr>").appendTo($("#metadataTable"));
+						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/link-ilink.png' title='link to external linkage'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img class='clickable' title='edit' src='../img/pencil.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\",false);return false;'/></td><td><img class='clickable' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\");return false;'/></td></tr>").appendTo($("#metadataTable"));
 					} else {
-						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/osgeo_graphics/geosilk/link.png' title='linkage'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\");return false;'/></td></tr>").appendTo($("#metadataTable"));
+						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/osgeo_graphics/geosilk/link.png' title='linkage'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img class='clickable' title='edit' src='../img/pencil.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\",false);return false;'/></td><td><img class='clickable' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\");return false;'/></td></tr>").appendTo($("#metadataTable"));
 				if (obj.md_metadata.origin[i] == "upload") {
-						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/up-ilink.png' title='link to external uploaded data'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\");return false;'/></td></tr>").appendTo($("#metadataTable"));
+						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/up-ilink.png' title='link to external uploaded data'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img class='clickable' title='edit' src='../img/pencil.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\",false);return false;'/></td><td><img class='clickable' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\");return false;'/></td></tr>").appendTo($("#metadataTable"));
 					} else {
-						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/button_blue_red/up.png' title='uploaded data'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\");return false;'/></td></tr>").appendTo($("#metadataTable"));
+						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/button_blue_red/up.png' title='uploaded data'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img class='clickable' title='edit' src='../img/pencil.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\",false);return false;'/></td><td><img class='clickable' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\");return false;'/></td></tr>").appendTo($("#metadataTable"));
 				if (obj.md_metadata.origin[i] == "metador") {
-						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/edit-select-all-ilink.png' title='link to external edited metadata'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\");return false;'/></td></tr>").appendTo($("#metadataTable"));
+						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/edit-select-all-ilink.png' title='link to external edited metadata'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img class='clickable' title='edit' src='../img/pencil.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\",false);return false;'/></td><td><img class='clickable' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\");return false;'/></td></tr>").appendTo($("#metadataTable"));
 					} else {
-						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/gnome/edit-select-all.png' title='metadata'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\");return false;'/></td></tr>").appendTo($("#metadataTable"));
+						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/gnome/edit-select-all.png' title='metadata'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img class='clickable' title='edit' src='../img/pencil.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\",false);return false;'/></td><td><img class='clickable' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\");return false;'/></td></tr>").appendTo($("#metadataTable"));
-		$("<img class='metadataEntry' title='new' src='../img/add.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\",true);return false;'/>").appendTo($("#metadataTable"));
+		$("<img class='metadataEntry clickable' title='new' src='../img/add.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+featuretypeId+",\"featuretype\",true);return false;'/>").appendTo($("#metadataTable"));
Modified: trunk/mapbender/http/plugins/mb_metadata_layer.js
--- trunk/mapbender/http/plugins/mb_metadata_layer.js	2017-03-30 08:47:04 UTC (rev 9720)
+++ trunk/mapbender/http/plugins/mb_metadata_layer.js	2017-03-30 08:47:34 UTC (rev 9721)
@@ -114,35 +114,35 @@
         for (i = 0; i < obj.md_metadata.metadata_id.length; i++) {
-                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/server_map-ilink.png' title='link to metadata from capabilities'/></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\");return false;'/></td></tr>").appendTo($("#metadataTable"));
+                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/server_map-ilink.png' title='link to metadata from capabilities'/></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td></td><td><img class='clickable' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\");return false;'/></td></tr>").appendTo($("#metadataTable"));
                 } else {
                     $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/osgeo_graphics/geosilk/server_map.png' title='capabilities'/></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td></td></tr>").appendTo($("#metadataTable"));
-                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/link-ilink.png' title='link to external linkage'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\");return false;'/></td></tr>").appendTo($("#metadataTable"));
+                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/link-ilink.png' title='link to external linkage'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td><img class='clickable' title='edit' src='../img/pencil.png' onclick='initMetadataAddon(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\",false);return false;'/></td><td><img class='clickable' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\");return false;'/></td></tr>").appendTo($("#metadataTable"));
                 } else {
-                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/osgeo_graphics/geosilk/link.png' title='linkage'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\");return false;'/></td></tr>").appendTo($("#metadataTable"));
+                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/osgeo_graphics/geosilk/link.png' title='linkage'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td><img class='clickable' title='edit' src='../img/pencil.png' onclick='initMetadataAddon(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\",false);return false;'/></td><td><img class='clickable' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\");return false;'/></td></tr>").appendTo($("#metadataTable"));
-                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/up-ilink.png' title='link to external uploaded data'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\");return false;'/></td></tr>").appendTo($("#metadataTable"));
+                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/up-ilink.png' title='link to external uploaded data'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td><img class='clickable' title='edit' src='../img/pencil.png' onclick='initMetadataAddon(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\",false);return false;'/></td><td><img class='clickable' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\");return false;'/></td></tr>").appendTo($("#metadataTable"));
                 } else {
-                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/button_blue_red/up.png' title='uploaded data'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\");return false;'/></td></tr>").appendTo($("#metadataTable"));
+                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/button_blue_red/up.png' title='uploaded data'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td><img class='clickable' title='edit' src='../img/pencil.png' onclick='initMetadataAddon(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\",false);return false;'/></td><td><img class='clickable' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\");return false;'/></td></tr>").appendTo($("#metadataTable"));
-                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/edit-select-all-ilink.png' title='link to external edited metadata'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\");return false;'/></td></tr>").appendTo($("#metadataTable"));
+                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/edit-select-all-ilink.png' title='link to external edited metadata'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td><img class='clickable' title='edit' src='../img/pencil.png' onclick='initMetadataAddon(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\",false);return false;'/></td><td><img class='clickable' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\");return false;'/></td></tr>").appendTo($("#metadataTable"));
                 } else {
-                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/gnome/edit-select-all.png' title='metadata'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\");return false;'/></td></tr>").appendTo($("#metadataTable"));
+                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/gnome/edit-select-all.png' title='metadata'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td><img class='clickable' title='edit' src='../img/pencil.png' onclick='initMetadataAddon(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\",false);return false;'/></td><td><img class='clickable' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\");return false;'/></td></tr>").appendTo($("#metadataTable"));
-        $("<img class='metadataEntry' title='new' src='../img/add.png' onclick='initMetadataAddon(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\",true);return false;'/>").appendTo($("#metadataTable"));
+        $("<img class='metadataEntry clickable' title='new' src='../img/add.png' onclick='initMetadataAddon(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",\"layer\",true);return false;'/>").appendTo($("#metadataTable"));
     this.enableResetButton = function() {
More information about the Mapbender_commits mailing list
