[Mapbender-commits] r9738 - trunk/mapbender/owsproxy/http
svn_mapbender at osgeo.org
Wed May 10 05:07:19 PDT 2017
Author: armin11
Date: 2017-05-10 05:07:19 -0700 (Wed, 10 May 2017)
New Revision: 9738
trunk/mapbender/owsproxy/http/index.php
New possibilities for secured ows getfeatureinfo requests
Modified: trunk/mapbender/owsproxy/http/index.php
--- trunk/mapbender/owsproxy/http/index.php 2017-05-10 12:07:06 UTC (rev 9737)
+++ trunk/mapbender/owsproxy/http/index.php 2017-05-10 12:07:19 UTC (rev 9738)
@@ -30,6 +30,8 @@
require_once(dirname(__FILE__) . "/../../conf/excludeproxyurls.conf");
//database connection
$con = db_connect(DBSERVER, OWNER, PW);
db_select_db(DB, $con);
@@ -206,6 +208,8 @@
if ($auth['auth_type'] == '') {
unset($auth);
+ //get info about the url exchange management
+ $exchangeUrlsWmsFi = $n->getWmsExchangeUrlTag($wmsId);
break;
case 'wfs':
@@ -259,6 +263,9 @@
break;
case 'getfeatureinfo':
$arrayOnlineresources = checkWmsPermission($query->getOwsproxyServiceId(), $userId);
+ //define following global to use it in matchUrls function**************
+ $featureInfoUrl = $arrayOnlineresources['wms_getfeatureinfo'];
$query->setOnlineResource($arrayOnlineresources['wms_getfeatureinfo']);
$request = $query->getRequest();
//Ergaenzungen secured UMN Requests
@@ -737,6 +744,9 @@
function matchUrls($content)
global $urlsToExclude;
+ global $featureInfoUrl;
+ global $exchangeUrlsWmsFi;
//check if isset owsproxyUrls else create
$owsproxyUrls = Mapbender::session()->get('owsproxyUrls');
if ($owsproxyUrls == false) {
@@ -755,6 +765,23 @@
if (in_array($req,$urlsToExclude)) {
continue;
+ //Generaly urls should not be exchanged. It must be controlled, if it directly come from the same server as the fi request. Those urls have always to be exchanged!
+ if ($exchangeUrlsWmsFi === "0") {
+ //get servername for featureinfo request
+ $url_array = parse_url($featureInfoUrl);
+ $servername = $url_array['scheme']."://".$url_array['host'];
+ //test if url came from same server - if not use original urls!
+ //switch for localhost/127.0.0.1 - they are the same!
+ if ($url_array['host'] == 'localhost' || $url_array['host'] == '127.0.0.1') {
+ if (strpos($req, $url_array['scheme']."://"."localhost") !== 0 && strpos($req, $url_array['scheme']."://"."127.0.0.1") !== 0) {
+ continue;
+ } else {
+ if (strpos($req, $servername) !== 0) {
+ continue;
$id = registerURL($req);
$extReq = setExternalRequest($id);
$notice = new mb_notice("MD5 URL " . $id . " - external link: " . $extReq);
More information about the Mapbender_commits
