[Mapbender-commits] r9744 - trunk/mapbender/http/geoportal
svn_mapbender at osgeo.org
Wed May 24 03:06:29 PDT 2017
Author: armin11
Date: 2017-05-24 03:06:29 -0700 (Wed, 24 May 2017)
New Revision: 9744
trunk/mapbender/http/geoportal/mod_showCatalogueStatistics.php
trunk/mapbender/http/geoportal/mod_showCatalogueStatistics_server.php
New possibility to show amount of opendata classified datasets
Modified: trunk/mapbender/http/geoportal/mod_showCatalogueStatistics.php
--- trunk/mapbender/http/geoportal/mod_showCatalogueStatistics.php 2017-05-19 09:18:31 UTC (rev 9743)
+++ trunk/mapbender/http/geoportal/mod_showCatalogueStatistics.php 2017-05-24 10:06:29 UTC (rev 9744)
@@ -197,6 +197,9 @@
case "inspire":
searchLinkNew = searchLink+"inspireThemes="+data.data.id;
break;
+ case "opendata":
+ searchLinkNew = searchLink+"restrictToOpenData=true";
+ break;
default:
searchLinkNew = searchLink;
@@ -207,7 +210,7 @@
} else {
//alert("Keine weitere Kategorisierung vorhanden!");
- $("#dialog").append( "<p id=\"error\">Keine Kategorisierung von Datensätzen vorhanden!<br><a onclick='window.top.location.href = searchAll;'>Alle Datensätze anzeigen</a></p>" );
+ $("#dialog").append( "<p id=\"error\">Keine Kategorisierung von Datensätzen vorhanden!<br><a onclick=\"window.top.location.href = searchAll;\">Alle Datensätze anzeigen</a></p>" );
if (pie2 !== undefined) {
pie2.destroy();
Modified: trunk/mapbender/http/geoportal/mod_showCatalogueStatistics_server.php
--- trunk/mapbender/http/geoportal/mod_showCatalogueStatistics_server.php 2017-05-19 09:18:31 UTC (rev 9743)
+++ trunk/mapbender/http/geoportal/mod_showCatalogueStatistics_server.php 2017-05-24 10:06:29 UTC (rev 9744)
@@ -102,12 +102,6 @@
$e = new mb_exception("Error while request to database!");
} else {
- //call searchInterface for categories
- $connector = new connector(MAPBENDER_PATH."/php/mod_callMetadata.php?searchText=e&outputFormat=json&resultTarget=categories&searchResources=wms&searchId=test®istratingDepartments=".$registratingDepartments);
- $jsonString = $connector->file;
- $jsonObject = json_decode($jsonString);
- $i = 0;
- $dataCount = 0;
switch ($categoryType) {
case "inspire":
$catId = 1;
@@ -119,13 +113,51 @@
$catId = 0;
break;
- foreach ($jsonObject->searchMD->category[$catId]->subcat as $cat) {
- $resultObj[$i]["label"] = $cat->title . " (".$cat->count.")";
- $resultObj[$i]["value"] = $cat->count;
- $resultObj[$i]["caption"] = $cat->title;
- $resultObj[$i]["id"] = $cat->id;
- $dataCount = $dataCount + $resultObj[$i]["value"];
- $i++;
+ if ($categoryType !== "opendata") {
+ //call searchInterface for categories
+ $connector = new connector(MAPBENDER_PATH."/php/mod_callMetadata.php?searchText=e&outputFormat=json&resultTarget=categories&searchResources=wms&searchId=test®istratingDepartments=".$registratingDepartments);
+ $jsonString = $connector->file;
+ $jsonObject = json_decode($jsonString);
+ $i = 0;
+ $dataCount = 0;
+ foreach ($jsonObject->searchMD->category[$catId]->subcat as $cat) {
+ $resultObj[$i]["label"] = $cat->title . " (".$cat->count.")";
+ $resultObj[$i]["value"] = $cat->count;
+ $resultObj[$i]["caption"] = $cat->title;
+ $resultObj[$i]["id"] = $cat->id;
+ $dataCount = $dataCount + $resultObj[$i]["value"];
+ $i++;
+ } else {
+ //count twice - first for number of all results, second for number of opendata classified results
+ $connector = new connector(MAPBENDER_PATH."/php/mod_callMetadata.php?searchText=e&outputFormat=json&searchResources=wms&searchId=test®istratingDepartments=".$registratingDepartments."&maxResults=1");
+ $numberOfResults = $jsonObject->wms->md->nresults;
+ $connector = new connector(MAPBENDER_PATH."/php/mod_callMetadata.php?searchText=e&outputFormat=json&searchResources=wms&searchId=test®istratingDepartments=".$registratingDepartments."&maxResults=1&restrictToOpenData=true");
+ $numberOfOpenResults = $jsonObject->wms->md->nresults;
+ //define values to return
+ $dataCount = $numberOfResults;
+ if ($numberOfOpenResults == $numberOfResults) {
+ $resultObj[0]["label"] = "OpenData (100%)";
+ $resultObj[0]["value"] = $numberOfResults;
+ $resultObj[0]["caption"] = "OpenData";
+ $resultObj[0]["id"] = 0;
+ $i = 1;
+ } else {
+ $resultObj[0]["label"] = "OpenData";
+ $resultObj[0]["value"] = $numberOfOpenResults;
+ $resultObj[1]["label"] = "Keine freie Lizenz!";
+ $resultObj[1]["value"] = $numberOfResults;
+ $resultObj[1]["caption"] = "Keine freie Lizenz!";
+ $resultObj[1]["id"] = 1;
+ $i = 2;
if ($i == 0) {
$resultObj = false;
More information about the Mapbender_commits
