[Mapbender-commits] r9812 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org
Mon Nov 13 07:30:17 PST 2017
Author: armin11
Date: 2017-11-13 07:30:17 -0800 (Mon, 13 Nov 2017)
New Revision: 9812
trunk/mapbender/http/classes/class_iso19139.php
trunk/mapbender/http/php/mod_dataISOMetadata.php
trunk/mapbender/http/php/mod_layerISOMetadata.php
trunk/mapbender/http/php/wms.php
New coupling for view services and datasets as demanded from inspire since march 2017 - see - http://inspire.ec.europa.eu/file/1705/download?token=iSTwpRWd&usg=AOvVaw18y1aTdkoMCBxpIz7tOOgu
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php 2017-11-13 13:20:26 UTC (rev 9811)
+++ trunk/mapbender/http/classes/class_iso19139.php 2017-11-13 15:30:17 UTC (rev 9812)
@@ -302,8 +302,19 @@
$this->datasetId = 'undefined';
$code = $iso19139Xml->xpath('//gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:MD_Identifier/gmd:code/gco:CharacterString');
if (isset($code[0]) && $code[0] != '') {
- $this->datasetId = $code[0];
- $this->datasetIdCodeSpace = "";
+ //new implementation:
+ //http://inspire.ec.europa.eu/file/1705/download?token=iSTwpRWd&usg=AOvVaw18y1aTdkoMCBxpIz7tOOgu
+ //from 2017-03-02 - the MD_Identifier - see C.2.5 Unique resource identifier - it is separated with a slash - the codespace should be everything after the last slash
+ //now try to check if a single slash is available and if the md_identifier is a url
+ $parsedUrl = parse_url($code[0]);
+ if (($parsedUrl['scheme'] == 'http' || $parsedUrl['scheme'] == 'https') && strpos($parsedUrl['path'],'/') !== false) {
+ $explodedUrl = explode('/', $code[0]);
+ $this->datasetId = $explodedUrl[count($explodedUrl) - 1];
+ $this->datasetIdCodeSpace = rtrim($code[0], $this->datasetId);
+ } else {
+ $this->datasetId = $code[0];
+ $this->datasetIdCodeSpace = "";
} else { //try to read code from RS_Identifier
$code = $iso19139Xml->xpath('//gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:code/gco:CharacterString');
$codeSpace = $iso19139Xml->xpath('//gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:codeSpace/gco:CharacterString');
Modified: trunk/mapbender/http/php/mod_dataISOMetadata.php
--- trunk/mapbender/http/php/mod_dataISOMetadata.php 2017-11-13 13:20:26 UTC (rev 9811)
+++ trunk/mapbender/http/php/mod_dataISOMetadata.php 2017-11-13 15:30:17 UTC (rev 9812)
@@ -302,21 +302,26 @@
//constraints - after descriptive keywords
if (isset($tou) && $tou !== '' && $tou !== false) {
//count old resourceConstraints elements
- $resourceConstraintsNodeList = $xpath->query('//gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:resourceConstraints');
- //load xml from constraint generator
- $licenseDomObject = new DOMDocument();
- $licenseDomObject->loadXML($tou);
- $xpathLicense = new DOMXpath($licenseDomObject);
- $licenseNodeList = $xpathLicense->query('/mb:constraints/gmd:resourceConstraints');
- //insert new constraints before first old constraints node
- for ($i = ($licenseNodeList->length)-1; $i >= 0; $i--) {
- $resourceConstraintsNodeList->item(0)->parentNode->insertBefore($metadataDomObject->importNode($licenseNodeList->item($i), true), $resourceConstraintsNodeList->item(0));
+ $resourceConstraintsNodeList = $xpath->query('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:resourceConstraints');
+ $arrayResourceConstraintsNodeList = (array)$resourceConstraintsNodeList;
+ //TODO - if this is empty - create a new entry
+ if (!empty($arrayResourceConstraintsNodeList)) {
+ //$e = new mb_exception("list is not empty!");
+ //load xml from constraint generator
+ $licenseDomObject = new DOMDocument();
+ $licenseDomObject->loadXML($tou);
+ $xpathLicense = new DOMXpath($licenseDomObject);
+ $licenseNodeList = $xpathLicense->query('/mb:constraints/gmd:resourceConstraints');
+ //insert new constraints before first old constraints node
+ for ($i = ($licenseNodeList->length)-1; $i >= 0; $i--) {
+ $resourceConstraintsNodeList->item(0)->parentNode->insertBefore($metadataDomObject->importNode($licenseNodeList->item($i), true), $resourceConstraintsNodeList->item(0));
+ //delete all resourceConstraints from original xml document
+ for ($i = 0; $i < $resourceConstraintsNodeList->length; $i++) {
+ $temp = $resourceConstraintsNodeList->item($i); //avoid calling a function twice
+ $temp->parentNode->removeChild($temp);
- //delete all resourceConstraints from original xml document
- for ($i = 0; $i < $resourceConstraintsNodeList->length; $i++) {
- $temp = $resourceConstraintsNodeList->item($i); //avoid calling a function twice
- $temp->parentNode->removeChild($temp);
//test http://localhost/mb_trunk/php/mod_dataISOMetadata.php?outputFormat=iso19139&id=0da11651-aa61-d75a-446c-ea4ea073bc48
@@ -437,14 +442,14 @@
if (!isset($mapbenderMetadata['fkey_mb_group_id']) or is_null($mapbenderMetadata['fkey_mb_group_id']) or $mapbenderMetadata['fkey_mb_group_id'] == 0){
$e = new mb_notice("mod_dataISOMetadata.php: fkey_mb_group_id not found!");
//Get information about owning user of the relation mb_user_mb_group - alternatively the defined fkey_mb_group_id from the service must be used!
- $sqlDep = "SELECT mb_group_name, mb_group_title, mb_group_id, mb_group_logo_path, mb_group_address, mb_group_email, mb_group_postcode, mb_group_city, mb_group_voicetelephone, mb_group_facsimiletelephone FROM mb_group AS a, mb_user AS b, mb_user_mb_group AS c WHERE b.mb_user_id = $1 AND b.mb_user_id = c.fkey_mb_user_id AND c.fkey_mb_group_id = a.mb_group_id AND c.mb_user_mb_group_type=2 LIMIT 1";
+ $sqlDep = "SELECT mb_group_name, mb_group_title, mb_group_id, mb_group_logo_path, mb_group_address, mb_group_email, mb_group_postcode, mb_group_city, mb_group_voicetelephone, mb_group_facsimiletelephone, mb_group_homepage, mb_group_registry_url FROM mb_group AS a, mb_user AS b, mb_user_mb_group AS c WHERE b.mb_user_id = $1 AND b.mb_user_id = c.fkey_mb_user_id AND c.fkey_mb_group_id = a.mb_group_id AND c.mb_user_mb_group_type=2 LIMIT 1";
$vDep = array($mapbenderMetadata['wms_owner']);
$tDep = array('i');
$resDep = db_prep_query($sqlDep, $vDep, $tDep);
$departmentMetadata = db_fetch_array($resDep);
} else {
$e = new mb_notice("mod_dataISOMetadata.php: fkey_mb_group_id found!");
- $sqlDep = "SELECT mb_group_name , mb_group_title, mb_group_id, mb_group_logo_path , mb_group_address, mb_group_email, mb_group_postcode, mb_group_city, mb_group_voicetelephone, mb_group_facsimiletelephone FROM mb_group WHERE mb_group_id = $1 LIMIT 1";
+ $sqlDep = "SELECT mb_group_name , mb_group_title, mb_group_id, mb_group_logo_path , mb_group_address, mb_group_email, mb_group_postcode, mb_group_city, mb_group_voicetelephone, mb_group_facsimiletelephone, mb_group_homepage, mb_group_registry_url FROM mb_group WHERE mb_group_id = $1 LIMIT 1";
$vDep = array($mapbenderMetadata['fkey_mb_group_id']);
$tDep = array('i');
@@ -761,6 +766,10 @@
#do the things for identification
$identificationInfo=$iso19139->createElement("gmd:identificationInfo");
$MD_DataIdentification=$iso19139->createElement("gmd:MD_DataIdentification");
+ $MD_DataIdentification->setAttribute("id", "spatial_dataset_".md5($mb_metadata['uuid']));
$citation=$iso19139->createElement("gmd:citation");
$CI_Citation=$iso19139->createElement("gmd:CI_Citation");
@@ -938,12 +947,37 @@
$code=$iso19139->createElement("gmd:code");
$code_cs=$iso19139->createElement("gco:CharacterString");
- if (defined('METADATA_DEFAULT_CODESPACE')) {
- $codeText=$iso19139->createTextNode(METADATA_DEFAULT_CODESPACE."#".$mb_metadata['uuid']); //in case of the mapbender addon!
+ if (isset($departmentMetadata['mb_group_registry_url']) && $departmentMetadata['mb_group_registry_url'] !== "") {
+ if (substr($departmentMetadata['mb_group_registry_url'], -1) !== '/') {
+ $uniqueResourceIdentifierCodespace = $departmentMetadata['mb_group_registry_url'].'/';
+ } else {
+ $uniqueResourceIdentifierCodespace = $departmentMetadata['mb_group_registry_url'];
} else {
- $codeText=$iso19139->createTextNode("http://www.mapbender.org"."#".$mb_metadata['uuid']); //in case of the mapbender addon!
+ if (isset($departmentMetadata['mb_group_homepage']) && $departmentMetadata['mb_group_homepage'] !== "") {
+ if (substr($departmentMetadata['mb_group_homepage'], -1) !== '/') {
+ $uniqueResourceIdentifierCodespace = $departmentMetadata['mb_group_homepage'].'/'.'registry/spatial/dataset/';
+ } else {
+ $uniqueResourceIdentifierCodespace = $departmentMetadata['mb_group_homepage'].'registry/spatial/dataset/';
+ } else {
+ if (defined('METADATA_DEFAULT_CODESPACE')) {
+ $uniqueResourceIdentifierCodespace = METADATA_DEFAULT_CODESPACE.'/'.'registry/spatial/dataset/';
+ } else {
+ $uniqueResourceIdentifierCodespace = METADATA_DEFAULT_CODESPACE.'registry/spatial/dataset/';
+ } else {
+ $uniqueResourceIdentifierCodespace = "http://www.mapbender.org/registry/spatial/dataset/";
+$e = new mb_exception($uniqueResourceIdentifierCodespace);
+ $codeText=$iso19139->createTextNode($uniqueResourceIdentifierCodespace.$mb_metadata['uuid']);
$code_cs->appendChild($codeText);
$code->appendChild($code_cs);
$md_identifier->appendChild($code);
Modified: trunk/mapbender/http/php/mod_layerISOMetadata.php
--- trunk/mapbender/http/php/mod_layerISOMetadata.php 2017-11-13 13:20:26 UTC (rev 9811)
+++ trunk/mapbender/http/php/mod_layerISOMetadata.php 2017-11-13 15:30:17 UTC (rev 9812)
@@ -130,14 +130,14 @@
$e = new mb_notice("mod_layerISOMetadata.php: fkey_mb_group_id not found!");
$tDep = array('i');
} else {
$e = new mb_notice("mod_layerISOMetadata.php: fkey_mb_group_id found!");
$tDep = array('i');
@@ -666,7 +666,7 @@
$i=0;
$sql = <<<SQL
-SELECT metadata_id, uuid, link, linktype, md_format, origin, datasetid FROM mb_metadata
+SELECT metadata_id, uuid, link, linktype, md_format, origin, datasetid, datasetid_codespace FROM mb_metadata
INNER JOIN (SELECT * from ows_relation_metadata
WHERE fkey_layer_id = $recordId ) as relation ON
mb_metadata.metadata_id = relation.fkey_metadata_id WHERE mb_metadata.origin IN ('capabilities','external','metador')
@@ -746,35 +746,66 @@
/*INSPIRE demands a href for the metadata record!*/
/*TODO: Exchange HTTP_HOST with other baseurl*/
while ($row_metadata = db_fetch_array($res_metadataurl)) {
- switch ($row_metadata['origin']) {
- case 'capabilities':
- $operatesOn=$iso19139->createElement("srv:operatesOn");
- $operatesOn->setAttribute("xlink:href", "http://".$_SERVER['HTTP_HOST']."/mapbender/php/mod_dataISOMetadata.php?outputFormat=iso19139&id=".$row_metadata['uuid']);
- $operatesOn->setAttribute("uuidref", $row_metadata['datasetid']);
- $SV_ServiceIdentification->appendChild($operatesOn);
- break;
- case 'metador':
+ //$row_metadata['datasetid_codespace']
+ //check codespace for trailing slash - if not there - add it ;-)
+ //unique resource identifier
+ if (isset($row_metadata['datasetid_codespace']) && $row_metadata['datasetid_codespace'] != "") {
+ if (substr($row_metadata['datasetid_codespace'], -1) !== '/') {
+ $uniqueResourceIdentifierCodespace = $row_metadata['datasetid_codespace'].'/';
+ } else {
+ $uniqueResourceIdentifierCodespace = $row_metadata['datasetid_codespace'];
+ } else {
+ } else {
+ } else {
+ } else {
+ } else {
- $operatesOn->setAttribute("uuidref", METADATA_DEFAULT_CODESPACE."#".$row_metadata['uuid']);
+ } else {
} else {
- $operatesOn->setAttribute("uuidref", "http://www.mapbender.org#".$row_metadata['uuid']);
- break;
- case 'external':
- $operatesOn->setAttribute("uuidref", $row_metadata['uuid']);
- break;
- default:
- break;
+ switch ($row_metadata['origin']) {
+ case 'capabilities':
+ $operatesOn=$iso19139->createElement("srv:operatesOn");
+ $operatesOn->setAttribute("xlink:href", "http://".$_SERVER['HTTP_HOST']."/mapbender/php/mod_dataISOMetadata.php?outputFormat=iso19139&id=".$row_metadata['uuid']);
+ $operatesOn->setAttribute("uuidref", $uniqueResourceIdentifierCodespace.$row_metadata['datasetid']);
+ $SV_ServiceIdentification->appendChild($operatesOn);
+ break;
+ case 'metador':
+ $operatesOn->setAttribute("xlink:href", "http://".$_SERVER['HTTP_HOST']."/mapbender/php/mod_dataISOMetadata.php?outputFormat=iso19139&id=".$row_metadata['uuid'].'#spatial_dataset_'.md5($row_metadata['uuid']));
+ $operatesOn->setAttribute("uuidref", $uniqueResourceIdentifierCodespace.$row_metadata['uuid']);
+ break;
+ case 'external':
+ break;
+ default:
+ break;
$serviceTypeVersion_cs->appendChild($serviceTypeVersionText);
Modified: trunk/mapbender/http/php/wms.php
--- trunk/mapbender/http/php/wms.php 2017-11-13 13:20:26 UTC (rev 9811)
+++ trunk/mapbender/http/php/wms.php 2017-11-13 15:30:17 UTC (rev 9812)
@@ -162,7 +162,7 @@
if (!isset($wms_row['fkey_mb_group_id']) or is_null($wms_row['fkey_mb_group_id']) or $wms_row['fkey_mb_group_id'] == 0){
$e = new mb_notice("wms.php: fkey_mb_group_id not found!");
- $sqlDep = "SELECT mb_group_name as metadatapointofcontactorgname,mb_group_homepage as metadatapointofcontactorgurl, mb_group_title as metadatapointofcontactorgtitle, mb_group_id, mb_group_logo_path as metadatapointofcontactorglogo, mb_group_address as metadatapointofcontactorgaddress, mb_group_email as metadatapointofcontactorgemail, mb_group_postcode as metadatapointofcontactorgpostcode, mb_group_city as metadatapointofcontactorgcity, mb_group_voicetelephone as metadatapointofcontactorgtelephone, mb_group_facsimiletelephone as metadatapointofcontactorgfax FROM mb_group AS a, mb_user AS b, mb_user_mb_group AS c WHERE b.mb_user_id = $1 AND b.mb_user_id = c.fkey_mb_user_id AND c.fkey_mb_group_id = a.mb_group_id AND c.mb_user_mb_group_type=2 LIMIT 1";
+ $sqlDep = "SELECT mb_group_name as metadatapointofcontactorgname, mb_group_homepage as metadatapointofcontactorgurl, mb_group_registry_url as metadatapointofcontactregistryurl, mb_group_title as metadatapointofcontactorgtitle, mb_group_id, mb_group_logo_path as metadatapointofcontactorglogo, mb_group_address as metadatapointofcontactorgaddress, mb_group_email as metadatapointofcontactorgemail, mb_group_postcode as metadatapointofcontactorgpostcode, mb_group_city as metadatapointofcontactorgcity, mb_group_voicetelephone as metadatapointofcontactorgtelephone, mb_group_facsimiletelephone as metadatapointofcontactorgfax FROM mb_group AS a, mb_user AS b, mb_user_mb_group AS c WHERE b.mb_user_id = $1 AND b.mb_user_id = c.fkey_mb_user_id AND c.fkey_mb_group_id = a.mb_group_id AND c.mb_user_mb_group_type=2 LIMIT 1";
$vDep = array($wms_row['wms_owner']);
$tDep = array('i');
@@ -172,7 +172,7 @@
$e = new mb_notice("wms.php: mb_group_logo_path: ".$metadataContactGroup['metadatapointofcontactorglogo']);
} else {
$e = new mb_notice("wms.php: fkey_mb_group_id found!");
- $sqlDep = "SELECT mb_group_name as metadatapointofcontactorgname, mb_group_homepage as metadatapointofcontactorgurl, mb_group_title as metadatapointofcontactorgtitle, mb_group_id, mb_group_logo_path as metadatapointofcontactorglogo, mb_group_address as metadatapointofcontactorgaddress, mb_group_email as metadatapointofcontactorgemail, mb_group_postcode as metadatapointofcontactorgpostcode, mb_group_city as metadatapointofcontactorgcity, mb_group_voicetelephone as metadatapointofcontactorgtelephone, mb_group_facsimiletelephone as metadatapointofcontactorgfax FROM mb_group WHERE mb_group_id = $1 LIMIT 1";
+ $sqlDep = "SELECT mb_group_name as metadatapointofcontactorgname, mb_group_homepage as metadatapointofcontactorgurl, mb_group_registry_url as metadatapointofcontactregistryurl, mb_group_title as metadatapointofcontactorgtitle, mb_group_id, mb_group_logo_path as metadatapointofcontactorglogo, mb_group_address as metadatapointofcontactorgaddress, mb_group_email as metadatapointofcontactorgemail, mb_group_postcode as metadatapointofcontactorgpostcode, mb_group_city as metadatapointofcontactorgcity, mb_group_voicetelephone as metadatapointofcontactorgtelephone, mb_group_facsimiletelephone as metadatapointofcontactorgfax FROM mb_group WHERE mb_group_id = $1 LIMIT 1";
$vDep = array($wms_row['fkey_mb_group_id']);
$tDep = array('i');
@@ -180,16 +180,22 @@
$AuthorityName = $metadataContactGroup["metadatapointofcontactorgname"];
-$AuthorityUrl = $metadataContactGroup["metadatapointofcontactorgurl"];
+//check for given urls
+if (isset($metadataContactGroup["metadatapointofcontactregistryurl"]) && $metadataContactGroup["metadatapointofcontactregistryurl"] !== "") {
+ $AuthorityUrl = $metadataContactGroup["metadatapointofcontactregistryurl"];
+} else {
+ $AuthorityUrl = $metadataContactGroup["metadatapointofcontactorgurl"];
if ($AuthorityName == '') {
$AuthorityName = "defaultauthority";
if ($AuthorityUrl == '') {
if (defined("METADATA_DEFAULT_CODESPACE") && METADATA_DEFAULT_CODESPACE != '') {
- $AuthorityUrl = METADATA_DEFAULT_CODESPACE;
+ $AuthorityUrl = METADATA_DEFAULT_CODESPACE."/registry/spatial/dataset/";
} else {
- $AuthorityUrl = "http://www.mapbender.org";
+ $AuthorityUrl = "http://www.mapbender.org"."/registry/spatial/dataset/";
@@ -1182,12 +1188,15 @@
if ($row_metadata["datasetid"] == '' || !isset($row_metadata["datasetid"])) {
//this column is empty, if metador was used and the identifier for dataset id is equal to the identifier of the metadata fileidentifier. In this case we expand a standard codespace http://www.geoportal.rlp.de
- $datasetId = METADATA_DEFAULT_CODESPACE."#".$row_metadata["uuid"];
+ //$datasetId = METADATA_DEFAULT_CODESPACE."#".$row_metadata["uuid"];
+ $datasetId = $row_metadata["uuid"];
} else {
} else {
- $datasetId = "http://www.mapbender.org"."#".$row_metadata["uuid"];
+ //$datasetId = "http://www.mapbender.org"."#".$row_metadata["uuid"];
} else {
More information about the Mapbender_commits
