[Mapbender-commits] r9794 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Oct 4 09:11:55 PDT 2017
Author: armin11
Date: 2017-10-04 09:11:55 -0700 (Wed, 04 Oct 2017)
New Revision: 9794
Added:
   trunk/mapbender/http/classes/class_crs.php
First draft of a simple class to request information from the epsg registry
Added: trunk/mapbender/http/classes/class_crs.php
--- trunk/mapbender/http/classes/class_crs.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_crs.php	2017-10-04 16:11:55 UTC (rev 9794)
@@ -0,0 +1,210 @@
+<?php
+# http://www.mapbender2.org/index.php/class_crs.php
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/../../conf/altered_axis_epsg.php");
+require_once(dirname(__FILE__)."/class_connector.php");
+//class_crs.php
+//TODO
+//get information from registry
+//axisOrder - lat/lon, lon/lat, easting/northing, northing/easting
+//conf file - instead of registry as fallback
+//TODO - use also service type and version as parameter??? wms 1.3+, wfs 1.0+?
+ * A class to handle information about different CoordinateReferenceSystems
+class Crs {
+	var $identifierType; //'epsg', 'urn', 'url', 'other'
+	var $identifierCode;
+	var $identifier;
+	var $name;
+	var $gmlRepresentation;
+	//var $uuid;
+	var $epsgType; // false, 'geographic 2D', 'projected', ''
+	var $axisOrder; //different types, first: 'east,north' - ('lon,lat'), second: 'north,east' - ('lat,lon')
+	//preasume, that the old order is always lat/lon for geo and east/north for projected systems
+	var $resolveSuccess;
+	var $resolveErrorMessage;
+	public function __construct ($identifier) {
+		$this->extractIdentifierType($identifier);
+		$this->resolveCrsInfo();
+	private function extractIdentifierType ($identifier) {
+		//check for type
+		if (substr(strtoupper($identifier), 0, 5) === "EPSG:") {
+			$this->identifier = $identifier;
+			$this->identifierType = 'epsg';
+			$this->identifierCode = explode(':',$identifier)[1];
+			return;
+		} else {
+			//check for urn based version - example: urn:ogc:def:crs:EPSG:
+			if (substr(strtoupper($identifier), 0, 21) === "URN:OGC:DEF:CRS:EPSG:") {
+				//delete this part from original identifier
+				$identifierNew = str_replace('URN:OGC:DEF:CRS:EPSG:','',strtoupper($identifier));
+				$this->identifierType = 'urn';
+				$this->identifierCode = explode(':',$identifierNew)[1];
+				return;
+			} else {
+				if (substr($identifier, 0, 31) === 'http://www.opengis.net/def/crs/') {
+					$identifierNew = str_replace('http://www.opengis.net/def/crs/','',$identifier);
+					//remaining string: ({OGC|EPSG}/{0}/{code})
+					$this->identifierType = 'url';
+					$this->identifierCode = explode('/',$identifierNew)[2];
+					return;
+				} else {
+					$this->identifierType = 'other';
+					$this->identifierCode = $identifier;
+	private function resolveCrsInfo () {
+		//built urls to get information from registries
+		switch ($this->identifierType) {
+			case "epsg":
+				$registryBaseUrl = "http://www.epsg-registry.org/export.htm?gml=";
+				$registryUrl = $registryBaseUrl.urlencode("urn:ogc:def:crs:EPSG::".$this->identifierCode);
+				break;
+			case "urn":
+				$registryUrl = $registryBaseUrl.urlencode($this->identifier);
+				$xpathCrsType = "";
+				$xpathAxis = "";
+				break;
+			case "url":
+				$xpathAxis = "";
+				break;
+			default:
+				break;
+		//get gml description from registry
+		//echo $registryUrl . "<br>";
+		//die();
+		$crsConnector = new connector($registryUrl);
+		$crsConnector->set("timeOut", "2");
+		if ($crsConnector->timedOut == true) {
+			return false;
+		$this->gmlRepresentation = $crsConnector->file;
+		//parse relevant information
+		libxml_use_internal_errors(true);
+		try {
+			$crsXml = simplexml_load_string($this->gmlRepresentation);
+			if ($crsXml === false) {
+				foreach(libxml_get_errors() as $error) {
+        				$err = new mb_exception("class_crs:".$error->message);
+				throw new Exception("class_crs:".'Cannot parse crs gml!');
+				return false;
+		catch (Exception $e) {
+    			$err = new mb_exception("class_crs:".$e->getMessage());
+			return false;
+		//if parsing was successful
+		if ($crsXml !== false) {
+			$crsXml->registerXPathNamespace("epsg", "urn:x-ogp:spec:schema-xsd:EPSG:1.0:dataset");
+			$crsXml->registerXPathNamespace("gml", "http://www.opengis.net/gml/3.2");
+			$crsXml->registerXPathNamespace("xlink", "http://www.w3.org/1999/xlink");
+			//switch for type of cs - distinguish between ellipsoidalCS and CartesianCS (begin with lowercase character in crs document)
+			$this->epsgType = $crsXml->xpath('//gml:metaDataProperty/epsg:CommonMetaData/epsg:type');
+			$this->epsgType = $this->epsgType[0];
+			$this->name = $crsXml->xpath('//gml:name');
+			$this->name = $this->name[0];
+			//echo $this->name;
+			//echo $this->epsgType;
+			//get attribute for specific system
+			switch ($this->epsgType) {
+				case "projected":
+					$xpathIdentifierCs = "//gml:cartesianCS/@xlink:href";
+					break;
+				case "geographic 2D":
+					$xpathIdentifierCs = "//gml:ellipsoidalCS/@xlink:href";
+					break;
+			$csIdentifier = $crsXml->xpath($xpathIdentifierCs);
+			$csIdentifier = $csIdentifier[0];
+			//echo $csIdentifier."<br>";
+			//get axis order from further xml document
+			$urlToCsDefinition = $registryBaseUrl.urlencode($csIdentifier);
+			$csConnector = new connector($urlToCsDefinition);
+			$csConnector->set("timeOut", "2");
+			if ($csConnector->timedOut == true) {
+				return false;
+			$csGmlRepresentation = $csConnector->file;
+			//echo $csGmlRepresentation;
+			//libxml_use_internal_errors(true);
+			try {
+				$csXml = simplexml_load_string($csGmlRepresentation);
+				if ($csXml === false) {
+					throw new Exception("class_crs: Cannot parse cs gml!");
+					return false;
+    				$err = new mb_exception("class_cs:".$e->getMessage());
+				return false;
+			if ($csXml !== false) {
+				$csXml->registerXPathNamespace("epsg", "urn:x-ogp:spec:schema-xsd:EPSG:1.0:dataset");
+				$csXml->registerXPathNamespace("gml", "http://www.opengis.net/gml/3.2");
+				$csXml->registerXPathNamespace("xlink", "http://www.w3.org/1999/xlink");
+				$axis = $csXml->xpath('//gml:axis/gml:CoordinateSystemAxis/gml:axisDirection');
+				//switch for crs lookup table of crs which axis order was swapped from earlier ogc standards to newer - identify them by the usage og EPSG:XXXX notation
+				if (DEFINED("OLD_EPSG_AXIS_ORDER_ALTERED") && OLD_EPSG_AXIS_ORDER_ALTERED !== "") {
+					$old_epsg_axis_order_altered = explode(",", OLD_EPSG_AXIS_ORDER_ALTERED);
+				} else {
+					$old_epsg_axis_order_altered = array();
+				if ($this->identifierType == 'epsg' && in_array($this->identifierCode, $old_epsg_axis_order_altered)) {
+					$this->axisOrder = $axis[1].",".$axis[0];
+				} else {
+					$this->axisOrder = $axis[0].",".$axis[1];
+		//store information
More information about the Mapbender_commits mailing list
