[Mapbender-commits] r9796 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Thu Oct 5 06:28:26 PDT 2017
Author: armin11
Date: 2017-10-05 06:28:26 -0700 (Thu, 05 Oct 2017)
New Revision: 9796
trunk/mapbender/http/classes/class_crs.php
Fix for axis order decision, also use apc to cache axis order
Modified: trunk/mapbender/http/classes/class_crs.php
--- trunk/mapbender/http/classes/class_crs.php 2017-10-04 16:13:56 UTC (rev 9795)
+++ trunk/mapbender/http/classes/class_crs.php 2017-10-05 13:28:26 UTC (rev 9796)
@@ -1,7 +1,6 @@
<?php
# http://www.mapbender2.org/index.php/class_crs.php
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2, or (at your option)
@@ -19,19 +18,17 @@
require_once(dirname(__FILE__)."/../../core/globalSettings.php");
require_once(dirname(__FILE__)."/../../conf/altered_axis_epsg.php");
require_once(dirname(__FILE__)."/class_connector.php");
+require_once(dirname(__FILE__)."/class_cache.php");
-//class_crs.php
-//TODO
-//get information from registry
-//axisOrder - lat/lon, lon/lat, easting/northing, northing/easting
-//conf file - instead of registry as fallback
-//TODO - use also service type and version as parameter??? wms 1.3+, wfs 1.0+?
- * A class to handle information about different CoordinateReferenceSystems
+ * A class to handle information about different CoordinateReferenceSystems. The class tries to call the epsg registry an pulls some
+ * information from it. The handling of CRS axis in different ows is not really homogeneous.
+ * Further information:
+ * https://themes.jrc.ec.europa.eu/discussion/view/109106/fyi-interpreted-coordinate-order-flipped-in-gml-files-with-uri-format-srsname
+ * http://postgis.net/2013/08/18/tip_lon_lat/
+ * https://github.com/deegree/deegree3/wiki/Axis-order-handling
+ * http://docs.geotools.org/latest/userguide/library/referencing/order.html
+ * http://mapserver.org/ogc/wms_server.html
class Crs {
@@ -40,19 +37,36 @@
var $identifier;
var $name;
var $gmlRepresentation;
- //var $uuid;
- var $epsgType; // false, 'geographic 2D', 'projected', ''
- var $axisOrder; //different types, first: 'east,north' - ('lon,lat'), second: 'north,east' - ('lat,lon')
- //preasume, that the old order is always lat/lon for geo and east/north for projected systems
+ var $epsgType; // false, 'geographic 2D', 'projected', '...'
+ var $axisOrder; //different types:'east,north' - ('lon,lat') or 'north,east' - ('lat,lon')
+ //preasume, that the old order is always lon/lat for geo and east/north for projected systems
var $resolveSuccess;
+ var $resolveOrigin;
var $resolveErrorMessage;
public function __construct ($identifier) {
+ $this->resolveSuccess = false;
+ $this->resolveErrorMessage = false;
$this->extractIdentifierType($identifier);
- $this->resolveCrsInfo();
+ if ($this->resolveCrsInfo() == true) {
+ $this->resolveSuccess = true;
+ * A public function whith a parameter for {owstype}_{version}. If the ows needs a swap of the crs axis order true is returned,
+ * otherwise - if the axis are handled as they are defined in the epsg registry - the function returns false
+ //handles ows identifier: wms_1.0.0, wms_1.1.1, wms_1.3.0, wfs_1.0.0, wfs_1.1.0, wfs_2.0.0, wfs_2.0.2
+ public function alterAxisOrder ($targetOws) {
+ $owsWithSpecialOrder = array("wms_1.0.0","wms_1.1.1","wfs_1.0.0");
+ $order = "east,north";
+ if (in_array($targetOws, $owsWithSpecialOrder) && $this->identifierType == 'epsg' && $this->axisOrder !== $order) {
+ return true;
+ } else {
+ return false;
private function extractIdentifierType ($identifier) {
//check for type
if (substr(strtoupper($identifier), 0, 5) === "EPSG:") {
@@ -87,6 +101,17 @@
private function resolveCrsInfo () {
+ $cache = new Cache();
+ //try to read from cache if already exists
+ if ($cache->isActive && $cache->cachedVariableExists(md5($this->identifier))) {
+ $cachedObject = json_decode($cache->cachedVariableFetch(md5($this->identifier)));
+ $this->gmlRepresentation = $cachedObject->gmlRepresentation;
+ $this->epsgType = $cachedObject->epsgType;
+ $this->axisOrder = $cachedObject->axisOrder;
+ $this->name = $cachedObject->name;
+ $e = new mb_notice("http/classes/class_crs.php - read crs info from cache!");
+ return true;
//built urls to get information from registries
switch ($this->identifierType) {
case "epsg":
@@ -96,28 +121,26 @@
case "urn":
$registryBaseUrl = "http://www.epsg-registry.org/export.htm?gml=";
$registryUrl = $registryBaseUrl.urlencode($this->identifier);
- $xpathCrsType = "";
- $xpathAxis = "";
+ /*$xpathCrsType = "";
+ $xpathAxis = "";*/
break;
case "url":
$registryUrl = $registryBaseUrl.urlencode("urn:ogc:def:crs:EPSG::".$this->identifierCode);
- $xpathAxis = "";
break;
default:
break;
- //get gml description from registry
- //echo $registryUrl . "<br>";
- //die();
$crsConnector = new connector($registryUrl);
$crsConnector->set("timeOut", "2");
if ($crsConnector->timedOut == true) {
return false;
$this->gmlRepresentation = $crsConnector->file;
+ //generate separate jsonObject
+ $jsonCrsInfo->gmlRepresentation = $this->gmlRepresentation;
//parse relevant information
libxml_use_internal_errors(true);
try {
@@ -144,6 +167,9 @@
$this->epsgType = $this->epsgType[0];
$this->name = $crsXml->xpath('//gml:name');
$this->name = $this->name[0];
+ $e = new mb_notice("http/classes/class_crs.php - name of crs: ".$this->name);
+ $jsonCrsInfo->name = (string)$this->name;
+ $jsonCrsInfo->epsgType = (string)$this->epsgType;
//echo $this->name;
//echo $this->epsgType;
//get attribute for specific system
@@ -157,7 +183,6 @@
$csIdentifier = $crsXml->xpath($xpathIdentifierCs);
$csIdentifier = $csIdentifier[0];
- //echo $csIdentifier."<br>";
//get axis order from further xml document
$urlToCsDefinition = $registryBaseUrl.urlencode($csIdentifier);
$csConnector = new connector($urlToCsDefinition);
@@ -166,9 +191,6 @@
return false;
$csGmlRepresentation = $csConnector->file;
- //echo $csGmlRepresentation;
- //parse relevant information
- //libxml_use_internal_errors(true);
try {
$csXml = simplexml_load_string($csGmlRepresentation);
if ($csXml === false) {
@@ -182,16 +204,15 @@
catch (Exception $e) {
$err = new mb_exception("class_cs:".$e->getMessage());
return false;
if ($csXml !== false) {
$csXml->registerXPathNamespace("epsg", "urn:x-ogp:spec:schema-xsd:EPSG:1.0:dataset");
$csXml->registerXPathNamespace("gml", "http://www.opengis.net/gml/3.2");
$csXml->registerXPathNamespace("xlink", "http://www.w3.org/1999/xlink");
//switch for type of cs - distinguish between ellipsoidalCS and CartesianCS (begin with lowercase character in crs document)
$axis = $csXml->xpath('//gml:axis/gml:CoordinateSystemAxis/gml:axisDirection');
- //switch for crs lookup table of crs which axis order was swapped from earlier ogc standards to newer - identify them by the usage og EPSG:XXXX notation
- if (DEFINED("OLD_EPSG_AXIS_ORDER_ALTERED") && OLD_EPSG_AXIS_ORDER_ALTERED !== "") {
+ //TODO - think about it? switch for crs lookup table of crs which axis order was swapped from earlier ogc standards to newer - identify them by the usage og EPSG:XXXX notation - no good idea
+ /*if (DEFINED("OLD_EPSG_AXIS_ORDER_ALTERED") && OLD_EPSG_AXIS_ORDER_ALTERED !== "") {
$old_epsg_axis_order_altered = explode(",", OLD_EPSG_AXIS_ORDER_ALTERED);
} else {
$old_epsg_axis_order_altered = array();
@@ -200,10 +221,18 @@
$this->axisOrder = $axis[1].",".$axis[0];
} else {
$this->axisOrder = $axis[0].",".$axis[1];
+ $this->axisOrder = $axis[0].",".$axis[1];
+ $jsonCrsInfo->axisOrder = $this->axisOrder;
- //store information
+ //store information - maybe to cache, if it does not already exists!
+ if ($cache->isActive && $cache->cachedVariableExists(md5($this->identifier)) == false) {
+ $cache->cachedVariableAdd(md5($this->identifier), json_encode($jsonCrsInfo));
+ $e = new mb_notice("http/classes/class_crs.php - store crs info to cache!");
+ return true;
+ return true;
More information about the Mapbender_commits
