[Mapbender-commits] r9798 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Fri Oct 6 06:08:59 PDT 2017
Author: armin11
Date: 2017-10-06 06:08:59 -0700 (Fri, 06 Oct 2017)
New Revision: 9798
trunk/mapbender/http/classes/class_cswClient.php
trunk/mapbender/http/classes/class_syncCkan.php
New option to show html metadata for external CSW based records in ckan export handler
Modified: trunk/mapbender/http/classes/class_cswClient.php
--- trunk/mapbender/http/classes/class_cswClient.php 2017-10-05 13:29:28 UTC (rev 9797)
+++ trunk/mapbender/http/classes/class_cswClient.php 2017-10-06 13:08:59 UTC (rev 9798)
@@ -246,9 +246,16 @@
if (strpos($operationNameCsw, "transaction") === false) {
//$e = new mb_exception("test: ".$csw->cat_op_values[$operationNameCsw]['post']);
$this->operationResult = $this->getResult($csw->cat_op_values[$operationNameCsw]['post'], $postRequest);
+ //Also give back url of operation
+ $this->operationUrl = $csw->cat_op_values[$operationNameCsw]['post'];
} else {
$this->operationResult = $this->getResult($csw->cat_op_values["transaction"]['post'], $postRequest);
+ //$this->operationUrl = $csw->cat_op_values[$operationNameCsw]['post'];
+ //if (strpos($operationNameCsw, "getrecords") !== false) {
+ // $this->operationUrl = $csw->cat_op_values[$operationNameCsw]['get'];
//$e = new mb_exception("testresponse: ".$this->operationResult);
//parse response
libxml_use_internal_errors(true);
Modified: trunk/mapbender/http/classes/class_syncCkan.php
--- trunk/mapbender/http/classes/class_syncCkan.php 2017-10-05 13:29:28 UTC (rev 9797)
+++ trunk/mapbender/http/classes/class_syncCkan.php 2017-10-06 13:08:59 UTC (rev 9798)
@@ -636,7 +636,7 @@
if ($result->success == true) {
//echo "Creation of package successful!"."<br>";
//recreate views
- //$viewsUpdateProtocol = $this->recreateResourceViews($ckan, $result, $resultCkanRepresentation);
+ $viewsUpdateProtocol = $this->recreateResourceViews($ckan, $result, $resultCkanRepresentation);
$numberOfUpdatedPackages++;
//$e = new mb_exception($viewsUpdateProtocol);
} else {
@@ -656,7 +656,7 @@
//recreate views
$numberOfCreatedPackages++;
} else {
@@ -792,6 +792,11 @@
//private function getCkanRepresentationFromCsw($syncList->external_csw[0]->id, uuid) {
private function getCkanRepresentationFromCsw($cswId, $fileIdentifier, $ckan_orga_ident, $orgaTitle, $orgaEmail, $topicDataThemeCategoryMap, $ckanCategoryFilter) {
+ if (defined("MAPBENDER_PATH") && MAPBENDER_PATH != '') {
+ $mapbenderUrl = MAPBENDER_PATH;
+ } else {
+ $mapbenderUrl = "http://www.geoportal.rlp.de/mapbender";
//getRecordById
$csw = new csw();
$csw->createCatObjFromDB($cswId);
@@ -820,7 +825,7 @@
$format = (string)$format[0];
//$e = new mb_exception($metadataTitle);
//$e = new mb_exception($fileIdentifier);
+ $originalMetadataUrl = $mapbenderUrl."/php/mod_exportIso19139.php?url=".urlencode($cswClient->operationUrl."?REQUEST=GetRecordById&VERSION=2.0.2&SERVICE=CSW&id=".$fileIdentifier);
//TODO
//write json object
@@ -849,6 +854,7 @@
$keywordIndex++;
+ //Add resources (name/url/format)
$resourcesArray = array();
if (isset($resourceName) && $resourceName !=="") {
$resourcesArray[0]->name = $resourceName;
@@ -861,13 +867,37 @@
} else {
$resourcesArray[0]->format = "Unbekannt";
- $ckanPackage->resources = array_unique($resourcesArray);
+ //$e = new mb_exception("classes/class_syncCkan.php: Original metadata url: ".$originalMetadataUrl);
+ //Add further resource (name/id/description/url/format)
+ $viewArray = array();
+ $resourcesArray[1]->name = "Originäre Metadaten";// für ".$row['layer_title'];
+ $resourcesArray[1]->id = $fileIdentifier."_iso19139";
+ $resourcesArray[1]->description = $ckanPackage->title." - Anzeige der originären Metadaten";
+ $resourcesArray[1]->url = $originalMetadataUrl;
+ $resourcesArray[1]->format = "HTML";
+ //views to generate
+ $viewArray[0]['view_type'] = "webpage_view";
+ $viewArray[0]['resource_id'] = $fileIdentifier."_iso19139";
+ //build whole json structure
+ $viewJson->resource_id = $fileIdentifier."_iso19139";
+ $viewJson->title = "Metadaten HTML";
+ $viewJson->description = "Metadaten HTML";
+ $viewJson->view_type = "webpage_view";
+ $viewArray[0]['json'] = json_encode($viewJson);
+ //$ckanPackage->resources = array_unique($resourcesArray);
+ $ckanPackage->resources = $resourcesArray;
$returnArray = array();
$returnArray['json'] = json_encode($ckanPackage);
- //$e = new mb_exception("json: ".$returnArray['json']);
- //$returnArray['views'] = $viewArray;
+ //$e = new mb_exception("classes/class_syncCkan.php: package from csw: ".$returnArray['json']);
+ $returnArray['views'] = $viewArray;
return $returnArray;
//tags
@@ -950,7 +980,7 @@
$indexResourceArray = 0;
$indexViewArray = 0;
//add html preview for metadata
- $resourcesArray[$indexResourceArray]->name = "Geo-Metadaten";// für ".$row['layer_title'];
+ $resourcesArray[$indexResourceArray]->name = "Originäre Metadaten";// für ".$row['layer_title'];
$resourcesArray[$indexResourceArray]->id = $metadataUuid."_iso19139";
$resourcesArray[$indexResourceArray]->description = $ckanPackage->title." - Anzeige der originären Metadaten";
$resourcesArray[$indexResourceArray]->url = $mapbenderUrl."/php/mod_exportIso19139.php?url=http%3A%2F%2Fwww.geoportal.rlp.de%2Fmapbender%2Fphp%2Fmod_dataISOMetadata.php%3FoutputFormat%3Diso19139%26id%3D".$metadataUuid;
@@ -962,7 +992,7 @@
$viewJson->resource_id = $metadataUuid."_iso19139";
- $viewJson->description = "Geo-Metadaten HTML";
$viewArray[$indexViewArray]['json'] = json_encode($viewJson);
$indexViewArray++;
More information about the Mapbender_commits
