[Mapbender-commits] r9801 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Oct 9 08:33:28 PDT 2017
Author: armin11
Date: 2017-10-09 08:33:28 -0700 (Mon, 09 Oct 2017)
New Revision: 9801
   trunk/mapbender/http/classes/class_crs.php
Fix 2
Modified: trunk/mapbender/http/classes/class_crs.php
--- trunk/mapbender/http/classes/class_crs.php	2017-10-09 15:32:55 UTC (rev 9800)
+++ trunk/mapbender/http/classes/class_crs.php	2017-10-09 15:33:28 UTC (rev 9801)
@@ -1,4 +1,3 @@
-<<<<<<< .mine
 <?php
 # http://www.mapbender2.org/index.php/class_crs.php
@@ -242,244 +241,3 @@
-<?php
-# http://www.mapbender2.org/index.php/class_crs.php
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../core/globalSettings.php");
-require_once(dirname(__FILE__)."/../../conf/altered_axis_epsg.php");
-require_once(dirname(__FILE__)."/class_connector.php");
-require_once(dirname(__FILE__)."/class_cache.php");
- * A class to handle information about different CoordinateReferenceSystems. The class tries to call the epsg registry an pulls some
- * information from it. The handling of CRS axis in different ows is not really homogeneous.
- * Further information:
- * https://themes.jrc.ec.europa.eu/discussion/view/109106/fyi-interpreted-coordinate-order-flipped-in-gml-files-with-uri-format-srsname
- * http://postgis.net/2013/08/18/tip_lon_lat/
- * https://github.com/deegree/deegree3/wiki/Axis-order-handling
- * http://docs.geotools.org/latest/userguide/library/referencing/order.html
- * http://mapserver.org/ogc/wms_server.html
-class Crs {
-	var $identifierType; //'epsg', 'urn', 'url', 'other'
-	var $identifierCode;
-	var $identifier;
-	var $name;
-	var $gmlRepresentation;
-	var $epsgType; // false, 'geographic 2D', 'projected', '...'
-	var $axisOrder; //different types:'east,north' - ('lon,lat') or 'north,east' - ('lat,lon')
-	//preasume, that the old order is always lon/lat for geo and east/north for projected systems
-	var $resolveSuccess;
-	var $resolveOrigin;
-	var $resolveErrorMessage;
-	public function __construct ($identifier) {
-		$this->resolveSuccess = false;
-		$this->resolveErrorMessage = false;
-		$this->extractIdentifierType($identifier);
-		if ($this->resolveCrsInfo() == true) {
-			$this->resolveSuccess = true;
- * A public function whith a parameter for {owstype}_{version}. If the ows needs a swap of the crs axis order true is returned,
- * otherwise - if the axis are handled as they are defined in the epsg registry - the function returns false
-	//handles ows identifier: wms_1.0.0, wms_1.1.1, wms_1.3.0, wfs_1.0.0, wfs_1.1.0, wfs_2.0.0, wfs_2.0.2
-	public function alterAxisOrder ($targetOws) {
-		$owsWithSpecialOrder = array("wms_1.0.0","wms_1.1.1","wfs_1.0.0");
-		$order = "east,north";
-		if (in_array($targetOws, $owsWithSpecialOrder) && $this->identifierType == 'epsg' && $this->axisOrder !== $order) {
-			return true;
-		} else {
-			return false;
-	private function extractIdentifierType ($identifier) {
-		//check for type
-		if (substr(strtoupper($identifier), 0, 5) === "EPSG:") {
-			$this->identifier = $identifier;
-			$this->identifierType = 'epsg';
-			$this->identifierCode = explode(':',$identifier)[1];
-			return;
-		} else {
-			//check for urn based version - example: urn:ogc:def:crs:EPSG:
-			if (substr(strtoupper($identifier), 0, 21) === "URN:OGC:DEF:CRS:EPSG:") {
-				//delete this part from original identifier
-				$identifierNew = str_replace('URN:OGC:DEF:CRS:EPSG:','',strtoupper($identifier));
-				$this->identifierType = 'urn';
-				$this->identifierCode = explode(':',$identifierNew)[1];
-				return;
-			} else {
-				if (substr($identifier, 0, 31) === 'http://www.opengis.net/def/crs/') {
-					$identifierNew = str_replace('http://www.opengis.net/def/crs/','',$identifier);
-					//remaining string: ({OGC|EPSG}/{0}/{code})
-					$this->identifierType = 'url';
-					$this->identifierCode = explode('/',$identifierNew)[2];
-					return;
-				} else {
-					$this->identifierType = 'other';
-					$this->identifierCode = $identifier;
-	private function resolveCrsInfo () {
-		$cache = new Cache();
-		//try to read from cache if already exists
-		if ($cache->isActive && $cache->cachedVariableExists(md5($this->identifier))) {
-			$cachedObject = json_decode($cache->cachedVariableFetch(md5($this->identifier)));
-			$this->gmlRepresentation = $cachedObject->gmlRepresentation;
-			$this->epsgType = $cachedObject->epsgType;
-			$this->axisOrder = $cachedObject->axisOrder;
-			$this->name = $cachedObject->name;
-			$e = new mb_notice("http/classes/class_crs.php - read crs info from cache!");
-			return true;
-		//built urls to get information from registries
-		switch ($this->identifierType) {
-			case "epsg":
-				$registryBaseUrl = "http://www.epsg-registry.org/export.htm?gml=";
-				$registryUrl = $registryBaseUrl.urlencode("urn:ogc:def:crs:EPSG::".$this->identifierCode);
-				break;
-			case "urn":
-				$registryUrl = $registryBaseUrl.urlencode($this->identifier);
-				/*$xpathCrsType = "";
-				$xpathAxis = "";*/
-				break;
-			case "url":
-				break;
-			default:
-				break;
-		$crsConnector = new connector($registryUrl);
-		$crsConnector->set("timeOut", "2");
-		if ($crsConnector->timedOut == true) {
-			return false;
-		$this->gmlRepresentation = $crsConnector->file;
-		//generate separate jsonObject
-		$jsonCrsInfo->gmlRepresentation = $this->gmlRepresentation;
-		//parse relevant information
-		libxml_use_internal_errors(true);
-		try {
-			$crsXml = simplexml_load_string($this->gmlRepresentation);
-			if ($crsXml === false) {
-				foreach(libxml_get_errors() as $error) {
-        				$err = new mb_exception("class_crs:".$error->message);
-				throw new Exception("class_crs:".'Cannot parse crs gml!');
-				return false;
-		catch (Exception $e) {
-    			$err = new mb_exception("class_crs:".$e->getMessage());
-			return false;
-		//if parsing was successful
-		if ($crsXml !== false) {
-			$crsXml->registerXPathNamespace("epsg", "urn:x-ogp:spec:schema-xsd:EPSG:1.0:dataset");
-			$crsXml->registerXPathNamespace("gml", "http://www.opengis.net/gml/3.2");
-			$crsXml->registerXPathNamespace("xlink", "http://www.w3.org/1999/xlink");
-			//switch for type of cs - distinguish between ellipsoidalCS and CartesianCS (begin with lowercase character in crs document)
-			$this->epsgType = $crsXml->xpath('//gml:metaDataProperty/epsg:CommonMetaData/epsg:type');
-			$this->epsgType = $this->epsgType[0];
-			$this->name = $crsXml->xpath('//gml:name');
-			$this->name = $this->name[0];
-			$e = new mb_notice("http/classes/class_crs.php - name of crs: ".$this->name);
-			$jsonCrsInfo->name = (string)$this->name;
-			$jsonCrsInfo->epsgType = (string)$this->epsgType;
-			//echo $this->name;
-			//echo $this->epsgType;
-			//get attribute for specific system
-			switch ($this->epsgType) {
-				case "projected":
-					$xpathIdentifierCs = "//gml:cartesianCS/@xlink:href";
-					break;
-				case "geographic 2D":
-					$xpathIdentifierCs = "//gml:ellipsoidalCS/@xlink:href";
-					break;
-			$csIdentifier = $crsXml->xpath($xpathIdentifierCs);
-			$csIdentifier = $csIdentifier[0];
-			//get axis order from further xml document
-			$urlToCsDefinition = $registryBaseUrl.urlencode($csIdentifier);
-			$csConnector = new connector($urlToCsDefinition);
-			$csConnector->set("timeOut", "2");
-			if ($csConnector->timedOut == true) {
-				return false;
-			$csGmlRepresentation = $csConnector->file;
-			try {
-				$csXml = simplexml_load_string($csGmlRepresentation);
-				if ($csXml === false) {
-					throw new Exception("class_crs: Cannot parse cs gml!");
-					return false;
-    				$err = new mb_exception("class_cs:".$e->getMessage());
-				return false;
-			if ($csXml !== false) {
-				$csXml->registerXPathNamespace("epsg", "urn:x-ogp:spec:schema-xsd:EPSG:1.0:dataset");
-				$csXml->registerXPathNamespace("gml", "http://www.opengis.net/gml/3.2");
-				$csXml->registerXPathNamespace("xlink", "http://www.w3.org/1999/xlink");
-				$axis = $csXml->xpath('//gml:axis/gml:CoordinateSystemAxis/gml:axisDirection');
-				//TODO - think about it? switch for crs lookup table of crs which axis order was swapped from earlier ogc standards to newer - identify them by the usage og EPSG:XXXX notation - no good idea
-				/*if (DEFINED("OLD_EPSG_AXIS_ORDER_ALTERED") && OLD_EPSG_AXIS_ORDER_ALTERED !== "") {
-					$old_epsg_axis_order_altered = explode(",", OLD_EPSG_AXIS_ORDER_ALTERED);
-				} else {
-					$old_epsg_axis_order_altered = array();
-				if ($this->identifierType == 'epsg' && in_array($this->identifierCode, $old_epsg_axis_order_altered)) {
-					$this->axisOrder = $axis[1].",".$axis[0];
-				} else {
-					$this->axisOrder = $axis[0].",".$axis[1];
-				$jsonCrsInfo->axisOrder = $this->axisOrder;
-		//store information - maybe to cache, if it does not already exists!
-		if ($cache->isActive && $cache->cachedVariableExists(md5($this->identifier)) == false) {
-			$cache->cachedVariableAdd(md5($this->identifier), json_encode($jsonCrsInfo));
-			$e = new mb_notice("http/classes/class_crs.php - store crs info to cache!");
-			return true;
-		return true;
->>>>>>> .r9799
More information about the Mapbender_commits mailing list
