[Mapbender-commits] r9896 - in trunk/mapbender/http: classes php
    svn_mapbender at osgeo.org
    Fri Apr 13 03:02:23 PDT 2018
Author: armin11
Date: 2018-04-13 03:02:23 -0700 (Fri, 13 Apr 2018)
New Revision: 9896
   trunk/mapbender/http/classes/class_user.php
   trunk/mapbender/http/php/mod_showMetadata.php
New possibility to subscribe wfs monitoring
Modified: trunk/mapbender/http/classes/class_user.php
--- trunk/mapbender/http/classes/class_user.php	2018-04-13 09:46:51 UTC (rev 9895)
+++ trunk/mapbender/http/classes/class_user.php	2018-04-13 10:02:23 UTC (rev 9896)
@@ -901,15 +901,21 @@
 		return false;
-	private function addSingleSubscription ($wmsId) {
-		if (!is_numeric($wmsId)) {
-			$e = new mb_exception("class_user.php: addSingleSubscription: WMS Id not a number.");
+	private function addSingleSubscription ($id, $serviceType = "WMS") {
+		if (!is_numeric($id)) {
+			$e = new mb_exception("class_user.php: addSingleSubscription: ".$serviceType." Id is not a number.");
 			return false;
-		$id = intval($wmsId);
+		$id = intval($id);
 		if ($this->cancelSingleSubscription($id)) {
-			$sql = "INSERT INTO mb_user_abo_ows (fkey_mb_user_id, fkey_wms_id) VALUES ($1, $2)";
+			switch ($serviceType) {
+				case "WMS":
+					$sql = "INSERT INTO mb_user_abo_ows (fkey_mb_user_id, fkey_wms_id) VALUES ($1, $2)";
+					break;
+				case "WFS":
+					$sql = "INSERT INTO mb_user_abo_ows (fkey_mb_user_id, fkey_wfs_id) VALUES ($1, $2)";
+					break;
 			$v = array($this->id, $id);
 			$t = array('i', 'i');
 			$res = db_prep_query($sql, $v, $t);
@@ -918,15 +924,22 @@
 		return false;
-	private function cancelSingleSubscription ($wmsId) {
-			$e = new mb_exception("class_user.php: cancelSingleSubscription: WMS Id not a number.");
+	private function cancelSingleSubscription ($id, $serviceType = "WMS") {
+			$e = new mb_exception("class_user.php: cancelSingleSubscription: ".$serviceType." Id not a number.");
 			return false;
-		$sql = "DELETE FROM mb_user_abo_ows WHERE fkey_wms_id = $1 " .
-			"AND fkey_mb_user_id = $2";
+			case "WMS":
+				$sql = "DELETE FROM mb_user_abo_ows WHERE fkey_wms_id = $1 " .
+					"AND fkey_mb_user_id = $2";
+				break;
+			case "WFS":
+				$sql = "DELETE FROM mb_user_abo_ows WHERE fkey_wfs_id = $1 " .
+				break;
 		$v = array($id, $this->id);
@@ -933,44 +946,59 @@
 		return ($res) ? true : false;
-	public function addSubscription ($wms) {
-		if (is_array($wms)) {
-			foreach ($wms as $wmsId) {
-				$this->addSingleSubscription($wmsId);
+	public function addSubscription ($services, $serviceType = "WMS") {
+		if (is_array($services)) {
+			foreach ($services as $serviceId) {
+				$this->addSingleSubscription($serviceId, $serviceType);
 		else {
-			$this->addSingleSubscription($wms);
+			$this->addSingleSubscription($services, $serviceType);
-	public function cancelSubscription ($wms) {
-				$this->cancelSingleSubscription($wmsId);
+	public function cancelSubscription ($services, $serviceType = "WMS") {
+				$this->cancelSingleSubscription($serviceId, $serviceType);
 		else {
-			$this->cancelSingleSubscription($wms);
+			$this->cancelSingleSubscription($services, $serviceType);
-	public function hasSubscription ($wmsId) {
+	public function hasSubscription ($serviceId, $serviceType = "WMS") {
+		if (!is_numeric($serviceId)) {
 			return false;
-		$sql = "SELECT * FROM mb_user_abo_ows WHERE fkey_wms_id = $1 AND " .
-			"fkey_mb_user_id = $2 LIMIT 1";
+		$id = intval($serviceId);
+			case "WMS":
+  				$sql = "SELECT * FROM mb_user_abo_ows WHERE fkey_wms_id = $1 AND " .
+					"fkey_mb_user_id = $2 LIMIT 1";
+				break;
+			case "WFS":
+   				$sql = "SELECT * FROM mb_user_abo_ows WHERE fkey_wfs_id = $1 AND " .
+				break;
 		$row = db_fetch_array($res);
-		if (!isset($row['fkey_wms_id'])) {
-	        return false;
+			case "WMS":
+				if (!isset($row['fkey_wms_id'])) {
+	        			return false;
+				break;
+			case "WFS":
+   				if (!isset($row['fkey_wfs_id'])) {
+	        			return false;
+				break;
         return true;
Modified: trunk/mapbender/http/php/mod_showMetadata.php
--- trunk/mapbender/http/php/mod_showMetadata.php	2018-04-13 09:46:51 UTC (rev 9895)
+++ trunk/mapbender/http/php/mod_showMetadata.php	2018-04-13 10:02:23 UTC (rev 9896)
@@ -658,6 +658,14 @@
 	$serviceQuality = db_fetch_array($res);
+//db select for service quality
+if ($resource == 'wfs' or $resource == 'featuretype' or $resource == 'wfs-conf') {
+	$sql = "SELECT availability, last_status FROM mb_wfs_availability WHERE fkey_wfs_id = $1";
+	$v = array($serviceId);
+	$t = array('i');
+	$res = db_prep_query($sql, $v, $t);
+	$serviceQuality = db_fetch_array($res);
 //db select for content properties
 if ($resource == 'wms' or $resource == 'layer') {
 	//get bbox and crs codes for single layer - maybe some entries ;-)
@@ -908,12 +916,12 @@
 		//show abo function to registred and authorized users
 		if (!$is_public) {
 			if ($subscribe == 1) {
-				$user->addSubscription($resourceMetadata['serviceid']);
+				$user->addSubscription($resourceMetadata['serviceid'], "WMS");
 			else if ($subscribe == 0) {
-				$user->cancelSubscription($resourceMetadata['serviceid']);
+				$user->cancelSubscription($resourceMetadata['serviceid'], "WMS");
-			$is_subscribed = $user->hasSubscription($resourceMetadata['serviceid']);
+			$is_subscribed = $user->hasSubscription($resourceMetadata['serviceid'], "WMS");
 			if ($is_subscribed) {
 				$aboStr = "<tr><th>Abo</th><td><a href = '../php/mod_showMetadata.php?id=" .
 					$layerId . "&resource=layer&user_id=" . $user->id . "&subscribe=0'><img  style='border: none;' src = '../img/mail_delete.png' title='"._mb("Monitoring Abo löschen")."'></a></td></tr>"; //TODO check wherefor user_id should be given as parameter?
@@ -925,6 +933,30 @@
 	$html .= $aboStr;
+		$is_public = $user->isPublic();
+		//show abo function to registred and authorized users
+		if (!$is_public) {
+			if ($subscribe == 1) {
+				$user->addSubscription($resourceMetadata['serviceid'], "WFS");
+			else if ($subscribe == 0) {
+				$user->cancelSubscription($resourceMetadata['serviceid'], "WFS");
+			$e = new mb_exception("test subscription");
+			$is_subscribed = $user->hasSubscription($resourceMetadata['serviceid'], "WFS");
+			if ($is_subscribed) {
+				$aboStr = "<tr><th>Abo</th><td><a href = '../php/mod_showMetadata.php?id=" .
+					$featuretypeId . "&resource=featuretype&user_id=" . $user->id . "&subscribe=0'><img  style='border: none;' src = '../img/mail_delete.png' title='"._mb("Monitoring Abo löschen")."'></a></td></tr>"; //TODO check wherefor user_id should be given as parameter?
+			else if (!$is_subscribed) {
+				$aboStr = "<tr><th>Abo</th><td><a href = '../php/mod_showMetadata.php?id=" . $featuretypeId .
+					"&resource=featuretype&user_id=" . $user->id . "&subscribe=1'><img style='border: none;' src = '../img/mail_send.png' title='"._mb("Monitoring abonnieren")."'></a></td></tr>";
+$html .= $aboStr;
 if ($layerAccessibility && WRAPPER_PATH != '' && ($resource == 'layer' or $resource == 'wms' )) {
More information about the Mapbender_commits
