[Mapbender-commits] r9934 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Wed Aug 8 07:09:35 PDT 2018
Author: armin11
Date: 2018-08-08 07:09:34 -0700 (Wed, 08 Aug 2018)
New Revision: 9934
trunk/mapbender/http/php/mod_inspireDownloadFeed.php
Fix inspire atom feed generator for describedby references in dataset feeds - TBD: reference inspire registry if conformant data is provided!
Modified: trunk/mapbender/http/php/mod_inspireDownloadFeed.php
--- trunk/mapbender/http/php/mod_inspireDownloadFeed.php 2018-08-08 09:53:04 UTC (rev 9933)
+++ trunk/mapbender/http/php/mod_inspireDownloadFeed.php 2018-08-08 14:09:34 UTC (rev 9934)
@@ -818,6 +818,17 @@
break;
case "wfs":
$atomFeedKey .= $wfsId;
+ switch ($mapbenderMetadata[$m]->wfs_version) {
+ case "2.0.2":
+ $typeParameterName = "typeNames";
+ break;
+ case "2.0.0":
+ break;
+ default:
+ $typeParameterName = "typeName";
+ break;
break;
//$e = new mb_exception("mod_inspireDownloadFeed.php: cachedVariableTimestamp: ".date("Y-m-d H:i:s",$cache->cachedVariableCreationTime($atomFeedKey)));
@@ -915,17 +926,42 @@
} else {
$feedLink->setAttribute("href", $mapbenderPath."php/mod_inspireAtomFeedISOMetadata.php?id=".$recordId."&outputFormat=iso19139&generateFrom=".$generateFrom."&layerid=".$layerId);
+ $feedLink->setAttribute("rel", "describedby");
+ $feedLink->setAttribute("type", "application/xml");
+ $feed->appendChild($feedLink);
} else { //DATASET
- $feedLink->setAttribute("href", $mapbenderPath."php/mod_dataISOMetadata.php?id=".$mapbenderMetadata[$m]->metadata_uuid."&outputFormat=iso19139");
+ switch ($generateFrom) {
+ //TODO: set inspire data model reference if conformity is declared and theme is given!
+ case "wfs":
+ if ($admin->getWFSOWSstring($mapbenderMetadata[$m]->wfs_id) == false) {
+ $feedLink->setAttribute("href", $mapbenderMetadata[$m]->wfs_describefeaturetype."SERVICE=WFS&VERSION=".$mapbenderMetadata[$m]->wfs_version."&REQUEST=DescribeFeaturetype&".$typeParameterName."=".$mapbenderMetadata[$m]->featuretype_name);
+ } else {
+ $feedLink->setAttribute("href", $mapbenderServerUrl."/registry/wfs/".$mapbenderMetadata[$m]->wfs_id."?INSPIRE=1&"."SERVICE=WFS&VERSION=".$mapbenderMetadata[$m]->wfs_version."&REQUEST=DescribeFeaturetype&".$typeParameterName."=".$mapbenderMetadata[$m]->featuretype_name);
+ break;
+ case "wms":
+ $feedLink->setAttribute("href", "https://en.wikipedia.org/wiki/GeoTIFF");
+ $feedLink->setAttribute("type", "text/html");
+ break;
+ case "dataurl":
+ $feedLink->setAttribute("href", "https://www.google.com/search?q=".$mapbenderMetadata[$m]->format."+spatial");
+ break;
+ case "metadata":
+ break;
- $feedLink->setAttribute("rel", "describedby");
- $feedLink->setAttribute("type", "application/xml");
- //$feedLink->setAttribute("title", "Metadaten");
- //$feedLink->setAttribute("hreflang", "de");
- $feed->appendChild($feedLink);
//self reference - 5.1.4 / 5.2
if ($type == 'SERVICE') {
$selfReference = $mapbenderServerUrl.$_SERVER['SCRIPT_NAME']."?id=".$recordId."&type=SERVICE&generateFrom=".$generateFrom;
@@ -970,13 +1006,13 @@
} else { //5.2.2
//description of datatypes - if given??? What todo when there is no description available - some html page have to be referenced?
- $feedLink = $feedDoc->createElement("link");
+ /*$feedLink = $feedDoc->createElement("link");
$feedLink->setAttribute("href", $mapbenderPath."php/mod_showMetadata.php?languageCode=de&resource=layer&layout=tabs&id=".$recordId); //TODO show metadata in form of html content - switch for each type
$feedLink->setAttribute("title", "Nähere Beschreibung des Datensatzes");
+ $feed->appendChild($feedLink);*/
//5.1.6 - 5.1.7
//other -- not needed cause only one language is defined
@@ -1193,17 +1229,7 @@
//define request to get number of hits per featuretype
//add ? if not given in string
$gHLink = $mapbenderMetadata[$i]->wfs_getfeature."SERVICE=WFS&REQUEST=GetFeature&VERSION=";
- switch ($mapbenderMetadata[$i]->wfs_version) {
- case "2.0.0":
- $gHLink .= $mapbenderMetadata[$i]->wfs_version."&typeNames=";
- break;
- case "2.0.2":
- break;
- default:
- $gHLink .= $mapbenderMetadata[$i]->wfs_version."&typeName=";
- break;
+ $gHLink .= $mapbenderMetadata[$i]->wfs_version."&".$typeParameterName."=";
$gHLink .= $mapbenderMetadata[$i]->featuretype_name."&resultType=hits";
$startRequestTime = time();
//get auth information from database:
@@ -1426,17 +1452,7 @@
$wfsGetFeatureUrl = $mapbenderServerUrl."/registry/wfs/".$mapbenderMetadata[$i]->wfs_id."?";
$gFLink = $wfsGetFeatureUrl."SERVICE=WFS&REQUEST=GetFeature&VERSION=";
- case "2.0.0":
- $gFLink .= $mapbenderMetadata[$i]->wfs_version."&typeNames=".$mapbenderMetadata[$i]->featuretype_name;
- break;
- case "2.0.2":
- break;
- default:
- $gFLink .= $mapbenderMetadata[$i]->wfs_version."&typeName=".$mapbenderMetadata[$i]->featuretype_name;
- break;
+ $gFLink .= $mapbenderMetadata[$i]->wfs_version."&".$typeParameterName."=".$mapbenderMetadata[$i]->featuretype_name;
$gFLink .= "&srsName=".$mapbenderMetadata[$i]->featuretype_srs;
//TODO check if other epsg string should be used!
//$crsObject->identifier;
@@ -2010,6 +2026,7 @@
$mapbenderMetadata[$indexMapbenderMetadata]->wfs_abstract = $row['wfs_abstract'];
$mapbenderMetadata[$indexMapbenderMetadata]->wfs_getfeature = $admin->checkUrl($row['wfs_getfeature']);
$mapbenderMetadata[$indexMapbenderMetadata]->wfs_getcapabilities = $row['wfs_getcapabilities'];
+ $mapbenderMetadata[$indexMapbenderMetadata]->wfs_describefeaturetype = $row['wfs_describefeaturetype'];
$mapbenderMetadata[$indexMapbenderMetadata]->wfs_version = $row['wfs_version'];
$mapbenderMetadata[$indexMapbenderMetadata]->wfs_max_features = $row['wfs_max_features'];
More information about the Mapbender_commits
