[Mapbender-commits] r9945 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Aug 10 05:33:01 PDT 2018
Author: armin11
Date: 2018-08-10 05:33:00 -0700 (Fri, 10 Aug 2018)
New Revision: 9945
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql
comment out some sql - TBD later
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql	2018-08-10 12:30:18 UTC (rev 9944)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql	2018-08-10 12:33:00 UTC (rev 9945)
@@ -1,5 +1,5 @@
 UPDATE gui_element SET e_content='<div id="printPDF_working_bg"></div><div id="printPDF_working"><img src="../img/indicator_wheel.gif" style="padding:10px 0 0 10px">Generating PDF</div><div id="printPDF_input"><form id="printPDF_form" action="../print/printFactory.php"><div id="printPDF_selector"></div><div class="print_option"><input type="hidden" id="map_url" name="map_url" value=""/><input type="hidden" id="legend_url" name="legend_url" value=""/><input type="hidden" id="opacity" name="opacity" value=""/> <input type="hidden" id="overview_url" name="overview_url" value=""/><input type="hidden" id="map_scale" name="map_scale" value=""/><input type="hidden" name="measured_x_values" /><input type="hidden" name="measured_y_values" /><input type="hidden" name="map_svg_kml" /><input type="hidden" name="svg_extent" /><input type="hidden" name="map_svg_measures" /><br /></div><div class="print_option" id="printPDF_formsubmit"><input id="submit" type="submit" value="Print"><br /></div></f
 orm><div id="printPDF_result"></div></div>' WHERE e_id='printPDF';
 --create new database content
 --geoportal specific extensions
 ALTER TABLE mb_user ADD COLUMN mb_user_glossar character varying(5);
@@ -96,6 +96,5 @@
 INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('Geoportal-RLP', 22);
 INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('service_container1_free', 22);
More information about the Mapbender_commits mailing list
