[Mapbender-commits] r9840 - in trunk/mapbender: conf http/classes
svn_mapbender at osgeo.org
Fri Jan 5 04:27:47 PST 2018
Author: armin11
Date: 2018-01-05 04:27:47 -0800 (Fri, 05 Jan 2018)
New Revision: 9840
Added:
trunk/mapbender/conf/geoJsonSimpleStyle.json
trunk/mapbender/http/classes/class_kml_ows.php
trunk/mapbender/http/classes/class_kml_parser_ows.php
trunk/mapbender/http/classes/class_kml_polygon.php
First draft for serverside geojson2kml export possibility with support of mapbox simplestyle spec 1.1.0
Added: trunk/mapbender/conf/geoJsonSimpleStyle.json
--- trunk/mapbender/conf/geoJsonSimpleStyle.json (rev 0)
+++ trunk/mapbender/conf/geoJsonSimpleStyle.json 2018-01-05 12:27:47 UTC (rev 9840)
@@ -0,0 +1,33 @@
+ "point": {
+ "simple_style_spec_attributes":
+ ["title","description","marker-size","marker-symbol","marker-color"],
+ "simple_style_spec_defaults":
+ ["dummy title","dummy description","medium","","7e7e7e"],
+ "mapbender_extensions":
+ ["marker-type"],
+ "mapbender_extensions_default":
+ "linestring": {
+ ["title","description","stroke","stroke-opacity","stroke-width"],
+ ["dummy title","dummy description","#555555",1.0,2],
+ "polygon": {
+ ["title","description","stroke","stroke-opacity","stroke-width","fill","fill-opacity"],
+ ["dummy title","dummy description","#555555",1.0,2,"5555557",0.6],
Modified: trunk/mapbender/http/classes/class_kml_ows.php
--- trunk/mapbender/http/classes/class_kml_ows.php 2018-01-04 14:17:38 UTC (rev 9839)
+++ trunk/mapbender/http/classes/class_kml_ows.php 2018-01-05 12:27:47 UTC (rev 9840)
@@ -18,14 +18,14 @@
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
require_once(dirname(__FILE__)."/../../core/globalSettings.php");
require_once(dirname(__FILE__)."/../classes/class_json.php");
require_once(dirname(__FILE__)."/../classes/class_point.php");
require_once(dirname(__FILE__)."/../classes/class_kml_geometry.php");
require_once(dirname(__FILE__)."/../classes/class_kml_placemark.php");
-require_once(dirname(__FILE__)."/../classes/class_kml_parser_ows.php");;
+require_once(dirname(__FILE__)."/../classes/class_kml_parser_ows.php");
* Allows parsing a KML file, extracting the placemarks.
@@ -38,13 +38,16 @@
// ------------------------------- public -----------------------------------------------
* The constructor function, currently empty.
public function __construct() {
+ public function getGeoJsonSimpleStyleInfo() {
+ return json_decode(file_get_contents("../../conf/geoJsonSimpleStyle.json"));
public function toSingleLineStringKml() {
//KML 2.2 output
$doc = new DOMDocument("1.0", CHARSET);
@@ -157,20 +160,22 @@
* @return string the KML document.
public function __toString() {
+ //read configuration for geojson simple style from conf folder - to handle style information from geojson if available
+ $geoJsonStyleInfo = $this->getGeoJsonSimpleStyleInfo();
if (!$this->kml) {
//KML 2.2 output
$doc->preserveWhiteSpace = false;
- // attach kml and Document tag
+ //attach kml and Document tag
$e_kml = $doc->createElementNS("http://earth.google.com/kml/2.2", "kml");
$e_document = $doc->createElement("Document");
$e_kml->appendChild($e_document);
$doc->appendChild($e_kml);
- // attach placemarks
+ $styleHashArray = array();
+ $styleArray = array();
+ $placemarkArray = array();
+ //attach placemarks
$e = new mb_notice("to string: #placemarks: " . count($this->placemarkArray));
for ($i = 0; $i < count($this->placemarkArray); $i++) {
$currentPlacemark = $this->placemarkArray[$i];
@@ -198,26 +203,26 @@
$e_geometry->appendChild($e_coordinates);
break;
-/* TODO:Polygons
case "KMLPolygon" :
+ //<Polygon><outerBoundaryIs><LinearRing><coordinates>100,0 101,0 101,1 100,1 100,0</coordinates></LinearRing></outerBoundaryIs></Polygon>
$e_geometry = $doc->createElement("Polygon");
- $e_outer = $doc->createElement("OuterBoundaryIs");
+ $e_outer = $doc->createElement("outerBoundaryIs");
$e_outer_lr = $doc->createElement("LinearRing");
- $outer_coordinates = ""; // TODO: get coords from placemark
- $e_outer_coordinates = $doc->createElement("Coordinates", $outer_coordinates);
- $e_outer_lr->appendChild($e_outer_coordinates);
+ $coordinatesArray = $currentPlacemark->getGeometry()->getOuterBoundary()->getPointArray();
+ $coordinates = "";
+ for ($j = 0; $j < count($coordinatesArray); $j++) {
+ if ($j > 0) {
+ $coordinates .= " ";
+ $coordinates .= $coordinatesArray[$j]["x"] . "," . $coordinatesArray[$j]["y"] . "," . $coordinatesArray[$j]["z"];
+ $e_coordinates = $doc->createElement("coordinates", $coordinates);
+ $e_outer_lr->appendChild($e_coordinates);
$e_outer->appendChild($e_outer_lr);
+ $e_geometry->appendChild($e_outer);
+ //TODO - fill out inner rings as holes
+ break;
- for ($j = 0; $j < $currentPlacemark; $j++) {
- $e_geometry->appendChild($e_coordinates);
- outerBoundaryIs"}->{"LinearRing"}->{"coordinates
- break;
case "KMLLine" :
if (count($pl_name_array) > 2) {
$pl_description = $pl_name_array[1];
@@ -230,7 +235,6 @@
@@ -241,10 +245,200 @@
break;
+ //check for properties
+ $currentProperties = $currentPlacemark->getProperties();
+ if (count($currentProperties) > 0) {
+ $e_ExtendedData = $doc->createElement("ExtendedData");
+ //read out attribute information
+ //initial geojson style handling
+ $currentPropertiesSimpleStyle = array();
+ foreach($currentProperties as $key => $value){
+ $e_Data = $doc->createElement("Data");
+ $e_value = $doc->createElement("value");
+ $e_Data->setAttribute("name", $key);
+ if (isset($value)) {
+ $e_DataValue = $doc->createTextNode($value);
+ } else {
+ $e_DataValue = $doc->createTextNode('null');
+ $e_value->appendChild($e_DataValue);
+ $e_Data->appendChild($e_value);
+ $e_ExtendedData->appendChild($e_Data);
+ //parse styling information from simplestyle spec to define it in header of kml
+ //switch for geometry type
+ switch ($currentPlacemark->getGeometryType()) {
+ case "KMLPoint" :
+ foreach($geoJsonStyleInfo->point->simple_style_spec_attributes as $attributeKey => $attributeValue) {
+ //if (array_key_exists($attributeValue, $currentProperties)) {
+ if (isset($currentProperties[$attributeValue])) {
+ $value = $currentProperties[$attributeValue];
+ } else {
+ //set default value!
+ $value = $geoJsonStyleInfo->point->simple_style_spec_defaults[$attributeKey];
+ $currentPropertiesSimpleStyle[$attributeValue] = $value;
+ //build style part
+ $hash = md5('point'.$currentPropertiesSimpleStyle['marker-size'].$currentPropertiesSimpleStyle['marker-symbol'].$currentPropertiesSimpleStyle['marker-color']);
+ if (!in_array($hash, $styleHashArray)) {
+ //generate style part
+ $e_Style = $doc->createElement("Style");
+ $e_Style->setAttribute("id", $hash);
+ $e_IconStyle = $doc->createElement("IconStyle");
+ $e_Icon = $doc->createElement("Icon");
+ $e_href = $doc->createElement("href");
+ $makiUrl = "https://raw.githubusercontent.com/mapbox/maki/master/icons/";
+ switch($currentPropertiesSimpleStyle['marker-size']) {
+ case "medium":
+ $symbol = $makiUrl.$currentPropertiesSimpleStyle['marker-symbol']."-11.svg";
+ break;
+ case "smal":
+ break;
+ default :
+ $symbol = $makiUrl.$currentPropertiesSimpleStyle['marker-symbol']."-15.svg";
+ break;
+ $e_hrefText = $doc->createTextNode($symbol);
+ $e_href->appendChild($e_hrefText);
+ $e_Icon->appendChild($e_href);
+ $e_IconStyle->appendChild($e_Icon);
+ $e_hotSpot = $doc->createElement("hotSpot");
+ $e_hotSpot->setAttribute("xunits", "fraction");
+ $e_hotSpot->setAttribute("yunits", "fraction");
+ $e_hotSpot->setAttribute("x", "0.5");
+ $e_hotSpot->setAttribute("y", "0.5");
+ /*$e_width = $doc->createElement("width");
+ $e_widthText = $doc->createTextNode($currentPropertiesSimpleStyle['stroke-width']);
+ $e_width->appendChild($e_widthText);
+ $e_LineStyle->appendChild($e_width);*/
+ $e_Style->appendChild($e_IconStyle);
+ $e_Style->appendChild($e_hotSpot);
+ //$e_document->appendChild($e_Style);
+ $styleArray[] = $e_Style;
+ $styleHashArray[] = $hash;
+ $e_styleUrl = $doc->createElement("styleUrl");
+ $e_styleUrlText = $doc->createTextNode("#".$hash);
+ $e_styleUrl->appendChild($e_styleUrlText);
+ break;
+ case "KMLLine" :
+ foreach($geoJsonStyleInfo->linestring->simple_style_spec_attributes as $attributeKey => $attributeValue) {
+ } else {
+ $value = $geoJsonStyleInfo->linestring->simple_style_spec_defaults[$attributeKey];
+ $hash = md5('linestring'.$currentPropertiesSimpleStyle['stroke'].$currentPropertiesSimpleStyle['stroke-opacity'].$currentPropertiesSimpleStyle['stroke-width']);
+ $e_LineStyle = $doc->createElement("LineStyle");
+ $e_color = $doc->createElement("color");
+ $e_colorText = $doc->createTextNode($currentPropertiesSimpleStyle['stroke']);
+ $e_color->appendChild($e_colorText);
+ $e_LineStyle->appendChild($e_color);
+ $e_width = $doc->createElement("width");
+ $e_Style->appendChild($e_LineStyle);
+ break;
+ case "KMLPolygon":
+ foreach($geoJsonStyleInfo->polygon->simple_style_spec_attributes as $attributeKey => $attributeValue) {
+ } else {
+ $value = $geoJsonStyleInfo->polygon->simple_style_spec_defaults[$attributeKey];
+ $hash = md5('polygon'.$currentPropertiesSimpleStyle['stroke'].$currentPropertiesSimpleStyle['stroke-opacity'].$currentPropertiesSimpleStyle['stroke-width']);
+ //polystyle
+ //<PolyStyle><color>7fff44ff</color></PolyStyle>
+ $e_PolyStyle = $doc->createElement("PolyStyle");
+ $e_colorText = $doc->createTextNode($currentPropertiesSimpleStyle['fill']);
+ $e_PolyStyle->appendChild($e_color);
+ $e_Style->appendChild($e_PolyStyle);
+ break;
+ //overwrite name and description with info from geojson simplestyle spec
+ //if (!isset($pl_name)) {
+ $pl_name = $currentPropertiesSimpleStyle['title'];
+ //if (!isset($pl_description)) {
+ $pl_description = $currentPropertiesSimpleStyle['description'];
// create a placemark tag with a geometry and add it to the document
if ($e_geometry) {
$e_placemark = $doc->createElement("Placemark");
+ if ($e_ExtendedData) {
+ $e_placemark->appendChild($e_ExtendedData);
$e_placemark->appendChild($e_geometry);
+ if ($e_styleUrl) {
+ $e_placemark->appendChild($e_styleUrl);
if ($pl_name) {
$e_pl_name = $doc->createElement("name", $pl_name);
$e_placemark->appendChild($e_pl_name);
@@ -253,9 +447,15 @@
$e_pl_description = $doc->createElement("description", $pl_description);
$e_placemark->appendChild($e_pl_description);
- $e_document->appendChild($e_placemark);
+ $placemarkArray[] = $e_placemark;
+ foreach($styleArray as $style) {
+ $e_document->appendChild($style);
+ foreach($placemarkArray as $placemark) {
+ $e_document->appendChild($placemark);
$this->kml = $doc->saveXML();
return $this->kml;
Modified: trunk/mapbender/http/classes/class_kml_parser_ows.php
--- trunk/mapbender/http/classes/class_kml_parser_ows.php 2018-01-04 14:17:38 UTC (rev 9839)
+++ trunk/mapbender/http/classes/class_kml_parser_ows.php 2018-01-05 12:27:47 UTC (rev 9840)
@@ -38,12 +38,9 @@
public function parseGeoJSON ($geoJSON, $kmlId) {
-// $e = new mb_notice("GEOJSON: " . $geoJSON);
$json = new Mapbender_JSON();
$geometryFromGeoJSON = $json->decode($geoJSON);
$id = 0;
if (gettype($geometryFromGeoJSON) == "object" && $geometryFromGeoJSON->type == "FeatureCollection") {
if ($geometryFromGeoJSON->crs->type == "EPSG" && $geometryFromGeoJSON->crs->properties->code) {
$epsg = $geometryFromGeoJSON->crs->properties->code;
@@ -57,12 +54,12 @@
$epsg = $feature->geometry->crs->properties->code;
if (!$epsg) {
- $e = new mb_notice("EPSG is not set! Aborting...(" . $epsg . ")");
- $currentGeometry = false;
+ $e = new mb_exception("EPSG is not set defaults to 4326!");
+ //$currentGeometry = false;
+ $epsg = "4326";
$geometry = $feature->geometry;
- //TODO: missing Polygon and MultiGeometry
+ //TODO: missing MultiGeometry
switch ($geometry->type) {
case "LineString" :
$coordinateList = "";
@@ -70,24 +67,79 @@
if ($j > 0) {
$coordinateList .= " ";
+ //add zero altitude if only two dimensions are given
+ if (count($geometry->coordinates[$j]) == 2) {
+ $geometry->coordinates[$j][] = 0;
$coordinateList .= implode(",", $geometry->coordinates[$j]);
$currentGeometry = new KMLLine($coordinateList, $epsg);
break;
case "Point" :
+ if (count($geometry->coordinates) == 2) {
+ $geometry->coordinates[] = 0;
$coordinateList = implode(",", $geometry->coordinates);
$currentGeometry = new KMLPoint($coordinateList, $epsg);
break;
+ case "Polygon" :
+ $coordinateList = "";
+ $countLinearRings = count($geometry->coordinates);
+ if ($countLinearRings == 0) {
+ } elseif ($countLinearRings == 1) {
+ for ($j = 0; $j < count($geometry->coordinates[0]); $j++) {
+ if ($j > 0) {
+ $coordinateList .= " ";
+ if (count($geometry->coordinates[0][$j]) == 2) {
+ $geometry->coordinates[0][$j][] = 0;
+ $coordinateList .= implode(",", $geometry->coordinates[0][$j]);
+ $outerRing = new KMLLinearRing($coordinateList, $epsg);
+ $currentGeometry = new KMLPolygon($outerRing);
+ } elseif ($countLinearRings > 1) {
+ if ($j > 0) {
+ for ($k = 1; $k < $countLinearRings; $k++) {
+ for ($j = 0; $j < count($geometry->coordinates[$k]); $j++) {
+ if ($j > 0) {
+ if (count($geometry->coordinates[$k][$j]) == 2) {
+ $geometry->coordinates[$k][$j][] = 0;
+ $coordinateList .= implode(",", $geometry->coordinates[$k][$j]);
+ $innerRing = new KMLLinearRing($coordinateList, $epsg);
+ $currentGeometry->appendInnerBoundary($innerRing);
+ break;
if ($currentGeometry) {
$currentPlacemark = new KMLPlacemark($currentGeometry);
if (gettype($feature->properties) == "object") {
foreach ($feature->properties as $key => $value) {
$currentPlacemark->setProperty($key, $value);
+ //some specific values
$currentPlacemark->setProperty("Mapbender:kml", true);
$currentPlacemark->setProperty("Mapbender:name", "unknown");
$currentPlacemark->setProperty("Mapbender:id", $kmlId);
Modified: trunk/mapbender/http/classes/class_kml_polygon.php
--- trunk/mapbender/http/classes/class_kml_polygon.php 2018-01-04 14:17:38 UTC (rev 9839)
+++ trunk/mapbender/http/classes/class_kml_polygon.php 2018-01-05 12:27:47 UTC (rev 9840)
@@ -4,19 +4,19 @@
* @link http://www.mapbender.org/index.php/class_wmc.php
* @copyright 2002 CCGIS
* @license http://opensource.org/licenses/gpl-license.php
- * This program is free software; you can redistribute it and/or modify
- * it under the terms of the GNU General Public License as published by
- * the Free Software Foundation; either version 2, or (at your option)
- * any later version.
+ * This program is free software; you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation; either version 2, or (at your option)
+ * any later version.
- * This program is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- * GNU General Public License for more details.
+ * This program is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+ * GNU General Public License for more details.
- * You should have received a copy of the GNU General Public License
- * along with this program; if not, write to the Free Software
- * Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+ * You should have received a copy of the GNU General Public License
+ * along with this program; if not, write to the Free Software
+ * Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
@@ -32,7 +32,7 @@
class KMLPolygon extends KMLGeometry {
- * @param KMLLinearRing $aLinearRing the outer ring of the polygon
+ * @param KMLLinearRing $aLinearRing the outer ring of the polygon
public function __construct ($aLinearRing) {
if ($aLinearRing instanceof KMLLinearRing) {
@@ -44,7 +44,7 @@
- * @return string a string representation of the object, currently
+ * @return string a string representation of the object, currently
* {@link http://www.geojson.org GeoJSON}
@@ -52,7 +52,7 @@
- * @return string the geoJSON representation of the object
+ * @return string the geoJSON representation of the object
public function toGeoJSON () {
if ($this->outerBoundary !== null) {
@@ -78,8 +78,8 @@
* Cuts a hole in the polygon.
- * @param KMLLinearRing $aLinearRing the linear ring describing the hole that is being cut.
- * @return bool true, if the parameter is a linear ring; else false
+ * @param KMLLinearRing $aLinearRing the linear ring describing the hole that is being cut.
+ * @return bool true, if the parameter is a linear ring; else false
public function appendInnerBoundary ($aLinearRing) {
@@ -105,7 +105,7 @@
- * @var KMLLinearRing The outer boundary of the polygon
+ * @var KMLLinearRing The outer boundary of the polygon
private $outerBoundary;
@@ -113,5 +113,20 @@
* @var KMLLinearRing[] The inner boundaries (holes) of the polygon
private $innerBoundaryArray = array();
+ * @return outerBoundary
+ public function getOuterBoundary () {
+ return $this->outerBoundary;
+ * @return innerBoundaryArray
+ public function getInnerBoundaryArray () {
+ return $this->innerBoundaryArray;
More information about the Mapbender_commits
