[Mapbender-commits] r9923 - in trunk/mapbender/http/extensions/mobilemap2: . scripts/netgis
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jul 12 04:19:34 PDT 2018
Author: armin11
Date: 2018-07-12 04:19:34 -0700 (Thu, 12 Jul 2018)
New Revision: 9923
   trunk/mapbender/http/extensions/mobilemap2/index.html
   trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js
   trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/map.js
   trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/menu.js
Some bugfixes and enhancements from netgis for height information and ...
Modified: trunk/mapbender/http/extensions/mobilemap2/index.html
--- trunk/mapbender/http/extensions/mobilemap2/index.html	2018-07-12 07:26:36 UTC (rev 9922)
+++ trunk/mapbender/http/extensions/mobilemap2/index.html	2018-07-12 11:19:34 UTC (rev 9923)
@@ -10,7 +10,6 @@
 	<head>
 		<meta http-equiv="content-type" content="text/html; charset=utf-8" />
 		<meta http-equiv="X-UA-Compatible" content="IE=edge" />
 		<meta name="viewport" content="width=device-width, initial-scale=1" />
 		<title>GeoPortal RLP</title>
@@ -144,6 +143,10 @@
 						<span id="measure-close" class="glyphicon glyphicon-remove clickable" style="margin-left: 0.25em"></span>
 					</div>
+					<div id="result-overlay">
+						<span class="glyphicon glyphicon-record"></span>
+					</div>
 					<div id="watermark-container" class="index-top small">
 						<a href="http://www.geoportal.rlp.de/portal/servicebereich/impressum.html" target="_blank">© GDI-RP</a>
 					</div>
@@ -162,6 +165,12 @@
 							<span class="glyphicon glyphicon-search icon-left"></span>
 							<strong>Suchergebnisse:</strong>
 							<span class="glyphicon glyphicon-remove pull-right"></span>
+							<div id="search-message">
+								<div class="alert alert-info">
+									<strong>Ihre Ortsuche ergab keine Treffer. Tipp: Trennen Sie mehrere Suchbegriffe mit einem Komma!</strong><br/>
+									Beispiel: <i>„Von-Kuhl-Straße 49, Koblenz“</i>
+								</div>
+							</div>
 						</a>
 					</div>
 				</div>
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js	2018-07-12 07:26:36 UTC (rev 9922)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js	2018-07-12 11:19:34 UTC (rev 9923)
@@ -55,5 +55,10 @@
 	URL_BACKGROUND_HYBRID:	"http://www.gdi-rp-dienste2.rlp.de/mapcache/tms/1.0.0/test@UTM32",
 	URL_BACKGROUND_AERIAL:	"http://geo4.service24.rlp.de/wms/dop_basis.fcgi",
-	URL_FEATURE_INFO_PROXY:	"./scripts/proxy.php"
+	URL_FEATURE_INFO_PROXY:	"./scripts/proxy.php",
+	URL_HEIGHT_PROXY:		"./scripts/proxy.php",
+	URL_HEIGHT_REQUEST:		"http://www.geoportal.rlp.de/mapbender/extensions/mobilemap/query/rasterqueryWms.php?&lang=de" //"http://www.gdi-rp-dienste2.rlp.de/cgi-bin/mapserv.fcgi?map=/data/umn/geoportal/dhm_query/dhm.map&" + "SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&SERVICE=WMS&LAYERS=mydhm&QUERY_LAYERS=mydhm"
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/map.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/map.js	2018-07-12 07:26:36 UTC (rev 9922)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/map.js	2018-07-12 11:19:34 UTC (rev 9923)
@@ -45,6 +45,8 @@
 		var measureContent;
 		var measureClose;
+		var resultOverlay;
 		var backLayerHybrid;
 		var backLayerAerial;
@@ -227,6 +229,15 @@
 			map.addOverlay( measureOverlay );
+			// Search Result Overlay
+			resultOverlay = new ol.Overlay
+					element: $( "#result-overlay" )[ 0 ],
+					positioning: 'center-center'
 			// Interactions
 			interactions.pan = new ol.interaction.DragPan
@@ -535,6 +546,11 @@
 			addHistory( view.getCenter(), view.getZoom() );
+		var getScale = function()
+			return getScaleFromResolution( view.getResolution() );
 		var addHistory = function( center, zoom )
 			// No duplicates at the end
@@ -571,7 +587,7 @@
 		var getResolutionFromScale = function( scale )
 			var mpu = view ? ol.proj.METERS_PER_UNIT[ view.getProjection().getUnits() ] : 1.0;
-			var ipu = mpu * 39.3701;
+			var ipu = mpu * 39.3701; // inches per unit = 39.3701
 			var dpi = 72;
 			var res = 1 / ( normalizeScale( scale ) * ipu * dpi );
@@ -584,6 +600,16 @@
 			return 1 < scale ? 1 / scale : scale;
+		var getScaleFromResolution = function( res )
+			var scale = 39.3701 * 72 * res;
+			// Round
+			scale = Math.round( scale );
+			return scale;
 		var createLayerWms = function( url, layerName, index )
 			//var type = ol.source.TileWMS;
@@ -813,6 +839,23 @@
 			netgis.events.call( netgis.events.LAYER_TOGGLE, { id: backLayer.id } );
+		var showPopup = function( x, y, content )
+			// Clear
+			popupContent.empty();
+			popupContent.append( content );
+			// Show Popup
+			popupContainer.fadeIn( 200 );
+			popupOverlay.setPosition( [ x, y ] );
+		var hidePopup = function()
+			popupContainer.fadeOut( 200 );
 		// Event Handlers
 		$( document ).ready( init );
@@ -897,6 +940,7 @@
 				popupContent.append( element );
+			// WMS Feature Info
 			var layers = netgis.entities.get( [ netgis.component.Layer, netgis.component.Active, netgis.component.Queryable ] );
 			//console.info( "QUERY:", layers );
@@ -969,10 +1013,53 @@
+			// Height Info
+			var heightUrl = netgis.config.URL_HEIGHT_REQUEST + "&coord=" + event.coordinate.join( "," );
+			if ( netgis.config.URL_HEIGHT_PROXY && netgis.config.URL_HEIGHT_PROXY.length > 0 )
+				heightUrl = netgis.config.URL_HEIGHT_PROXY + "?q=" + encodeURIComponent( heightUrl );
+			$.get
+				heightUrl,
+				function( data )
+					var panelId = "popup-panel-height";
+					var content = "<p></p>";
+					content += "<div class='panel panel-primary'>";
+					content += "<div class='panel-heading clickable' data-toggle='collapse' data-target='#" + panelId + "'>";
+					content += "<h4 class='panel-title'>" + "Digitales Höhenmodell" + "</h4>";
+					content += "</div>";
+					content += "<div id='" + panelId + "' class='panel-collapse collapse'>";
+					content += "<div class='panel-body'>";
+					content += data;
+					var element = $( content );
+					element.find( ".panel-heading" ).click( function() { element.find( "#" + panelId ).collapse( "toggle" ); } );
+					popupContent.append( element );
+			// Show Popup
 			popupOverlay.setPosition( event.coordinate );
+			//TODO: use showPopup method
 			// Go back to pan mode
 			//if ( ! netgis.sidebar.isVisible() ) pan();
@@ -1355,13 +1442,16 @@
 			isPositionCenter:	isPositionCenter,
 			setBackgroundLayer:	setBackgroundLayer,
 			setScale:			setScale,
+			getScale:			getScale,
+			showPopup:			showPopup,
+			hidePopup:			hidePopup,
-			setInteraction: setInteraction,
-			interactions: interactions,
+			setInteraction:		setInteraction,
+			interactions:		interactions,
-			update: update
+			update:				update
 		return iface;
\ No newline at end of file
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/menu.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/menu.js	2018-07-12 07:26:36 UTC (rev 9922)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/menu.js	2018-07-12 11:19:34 UTC (rev 9923)
@@ -6,7 +6,7 @@
  * The NetGIS Menu module.
- * @namespace
+ * @namespace
 netgis.menu =
@@ -23,6 +23,8 @@
 		var searchQuery;
 		//var searchSpinner;
 		var searchButton;
+		var searchMessage;
+		var scaleItems;
 		var legendPanel;
 		var geolocationDialog;
@@ -36,6 +38,7 @@
 			searchList = $( "#search-list" );
 			//searchSpinner = $( "#search-spinner" );
 			searchButton = $( "#search-button" );
+			searchMessage = $( "#search-message" );
 			legendPanel = $( "#legend-panel" );
 			geolocationDialog = $( "#geolocation-dialog" );
@@ -50,19 +53,17 @@
 			for ( var s = 0; s < scales.length; s++ )
 				var item = "<li data-scale='" + scales[ s ] + "'>";
 				item += "<a href='#' class='btn-scale'>";
+				item += "<span class='icon-left glyphicon glyphicon-unchecked'></span>";
 				item += "1 : " + scales[ s ];
 				item += "</a>";
 				item += "</li>";
 				scaleMenu.append( item );
-			scaleMenu.find( ".btn-scale" ).click( onScaleClick );
+			scaleItems = scaleMenu.find( ".btn-scale" );
+			scaleItems.click( onScaleClick );
 			searchInput.val( "" );
@@ -100,6 +101,8 @@
 			netgis.events.on( netgis.events.POSITION_TOGGLE, onPositionToggle );
 			netgis.events.on( netgis.events.POSITION_CENTER, onPositionCenter );
 			netgis.events.on( netgis.events.POSITION_ERROR, onPositionError );
+			netgis.events.on( netgis.events.MAP_MOVE, onMapMove );
 		//TODO: testing
@@ -575,8 +578,6 @@
 		var onSearchResponse = function( data, status, xhr )
-			//console.info( "SEARCH RESPONSE:", status, data );
 			// Clear
 			searchList.children().first().nextAll().remove();
@@ -586,7 +587,13 @@
 			if ( searchResults.length > 0 )
 				searchPanel.collapse( "show" );
+				searchMessage.hide();
+			else
+				searchPanel.collapse( "show" );
+				searchMessage.show();
 			for ( var r = 0; r < searchResults.length; r++ )
@@ -634,7 +641,16 @@
 			if ( result )
+				if ( result.category === "str" || result.category === "haus" )
+					netgis.map.showPopup( ( parseFloat( result.minx ) + parseFloat( result.maxx ) ) / 2, ( parseFloat( result.miny ) + parseFloat( result.maxy ) ) / 2, result.title );
+				else
+					netgis.map.hidePopup();
 				netgis.map.viewExtent( result.minx, result.miny, result.maxx, result.maxy );
+				if ( netgis.config.MIN_SEARCH_SCALE && netgis.map.getScale() < netgis.config.MIN_SEARCH_SCALE )
+					netgis.map.setScale( netgis.config.MIN_SEARCH_SCALE );
 				searchPanel.collapse( "hide" );
 				$( ".navbar-collapse" ).collapse( "hide" ); //TODO: menu.hide()
@@ -672,6 +688,24 @@
+		var onMapMove = function( evt )
+			var scale = netgis.map.getScale();
+			scaleItems.each
+				function( key, value )
+					var item  = $( value ).parent();
+					var icon = item.find( ".glyphicon" );
+					var checked = ( scale === item.data( "scale" ) );
+					icon.toggleClass( "glyphicon-check", checked );
+					icon.toggleClass( "glyphicon-unchecked", ! checked );
 		// Public Interface
 		var iface =
@@ -680,4 +714,4 @@
 		return iface;
More information about the Mapbender_commits mailing list
